[PyWPS-dev] Why is PyWPS using different XML tags/namespaces for BoundingBoxData as Input and Output?
Gunnar Ströer gunnar.stroeer at yahoo.de
Mon Jan 21 09:02:57 PST 2019
 Thanks Carsten for validation. I found a workaround and use ComplexData as BoundingBoxData, I just have to parse again. It seems the mechanism has changed a bit in the current master.
Cheers, Gunnar
    Am Montag, 21. Januar 2019, 17:40:46 MEZ hat Carsten Ehbrecht <ehbrecht at dkrz.de> Folgendes geschrieben:
 Hi Gunnar,
I find the bbox also quite confusing. But I think your bbox description looks right.
See also owslib:https://github.com/geopython/OWSLib/pull/384
But it looks like we still have an issue in PyWPS:https://github.com/geopython/pywps/issues/405
Cheers,Carsten
On 18 Jan 2019, at 1:40 pm, Gunnar Ströer <gunnar.stroeer at yahoo.de> wrote:
Hi Community,
during my processes coding I've found out a discrepance in the supported Input and Output XML code in the case of using bounding box data. Am I right assuming that the built-in support for Input XML is based on the tag <wps:BoundingBoxData><ows:LowerCorner>(...) and for Output/Response XML is based on the tag <ows:BoundingBox><ows:LowerCorner>(...) only? Or can I modify this XML tag within PyWPS and without XML parse/replace?
As INPUT:
<wps:BoundingBoxData crs="EPSG:25832">
    <ows:LowerCorner>413236.919203 5316621.52211</ows:LowerCorner>
    <ows:UpperCorner>413719.644442 5317104.24735</ows:UpperCorner>
</wps:BoundingBoxData>
As OUTPUT:
<ows:BoundingBox crs="EPSG:25832" dimensions="2">
</ows:BoundingBox>
Cheers, Gunnar
pywps-dev mailing list
pywps-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20190121/65bcd18a/attachment-0001.html>
More information about the pywps-dev mailing list
