[QGIS Commit] r9034 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Fri Aug 8 09:01:36 EDT 2008
Author: timlinux
Date: 2008-08-08 09:01:35 -0400 (Fri, 08 Aug 2008)
New Revision: 9034
trunk/qgis/src/app/main.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/ui/qgisappbase.ui
As per email thread '[Qgis-developer] Qgis application name' on the QGIS developer list, I have renamed the application name from qgis to QGIS. THe application name is used by some OSes (e.g. OS X) in menus and other places and the lower case name looks incongruous. A side effect of this however is that all application settings will need to be re-set since the qgis key used by QSettings is now called QGIS and it is case sensitive.
Also remove deprecated widget components from main window and renamed Qgis to QGIS in help-about menu.
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp 2008-08-08 09:30:05 UTC (rev 9033)
+++ trunk/qgis/src/app/main.cpp 2008-08-08 13:01:35 UTC (rev 9034)
@@ -386,7 +386,7 @@
// Set up the QSettings environment must be done after qapp is created
QCoreApplication::setOrganizationName("QuantumGIS");
QCoreApplication::setOrganizationDomain("qgis.org");
- QCoreApplication::setApplicationName("qgis");
+ QCoreApplication::setApplicationName("QGIS");
#ifdef Q_OS_MACX
// Install OpenDocuments AppleEvent handler after application object is initialized
// but before any other event handling (including dialogs or splash screens) occurs.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-08-08 09:30:05 UTC (rev 9033)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-08-08 13:01:35 UTC (rev 9034)
@@ -633,7 +633,7 @@
mActionHelpContents->setStatusTip(tr("Help Documentation"));
connect(mActionHelpContents, SIGNAL(triggered()), this, SLOT(helpContents()));
- mActionQgisHomePage= new QAction(getThemeIcon("mActionQgisHomePage.png"), tr("Qgis Home Page"), this);
+ mActionQgisHomePage= new QAction(getThemeIcon("mActionQgisHomePage.png"), tr("QGIS Home Page"), this);
#ifndef Q_WS_MAC
mActionQgisHomePage->setShortcut(tr("Ctrl+H","QGIS Home Page"));
#endif
@@ -1326,10 +1326,6 @@
mMapCanvas->setWhatsThis(tr("Map canvas. This is where raster and vector "
"layers are displayed when added to the map"));
-// mMapCanvas->setMinimumWidth(10);
-// QVBoxLayout *myCanvasLayout = new QVBoxLayout;
-// myCanvasLayout->addWidget(mMapCanvas);
-// tabWidget->widget(0)->setLayout(myCanvasLayout);
setCentralWidget(mMapCanvas);
// set the focus to the map canvas
mMapCanvas->setFocus();
@@ -1427,13 +1423,9 @@
mMapLegend->setToggleEditingAction(mActionToggleEditing);
mMapLegend->setWhatsThis(tr("Map legend that displays all the layers currently on the map canvas. Click on the check box to turn a layer on or off. Double click on a layer in the legend to customize its appearance and set other properties."));
-// QVBoxLayout *myLegendLayout = new QVBoxLayout;
-// myLegendLayout->addWidget(mMapLegend);
-// toolBox->widget(0)->setLayout(myLegendLayout);
mLegendDock = new QDockWidget(tr("Legend"), this);
mLegendDock->setObjectName("Legend");
mLegendDock->setAllowedAreas(Qt::LeftDockWidgetArea | Qt::RightDockWidgetArea);
-// mLegendDock->setFeatures(mLegendDock->features() & ~QDockWidget::DockWidgetClosable);
mLegendDock->setWidget(mMapLegend);
addDockWidget(Qt::LeftDockWidgetArea, mLegendDock);
return;
Modified: trunk/qgis/src/ui/qgisappbase.ui
--- trunk/qgis/src/ui/qgisappbase.ui 2008-08-08 09:30:05 UTC (rev 9033)
+++ trunk/qgis/src/ui/qgisappbase.ui 2008-08-08 13:01:35 UTC (rev 9034)
@@ -10,134 +10,40 @@
</rect>
</property>
<property name="windowTitle" >
- <string>MainWindow</string>
+ <string>QGIS</string>
</property>
+ <property name="windowIcon" >
+ <iconset>../../images/icons/qgis-icon-16x16.png</iconset>
+ </property>
+ <property name="dockNestingEnabled" >
+ <bool>true</bool>
+ </property>
<widget class="QWidget" name="centralWidget" >
<property name="sizePolicy" >
- <sizepolicy>
- <hsizetype>7</hsizetype>
- <vsizetype>7</vsizetype>
+ <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
<layout class="QGridLayout" >
- <property name="margin" >
+ <property name="leftMargin" >
<number>9</number>
</property>
- <property name="spacing" >
+ <property name="topMargin" >
+ <number>9</number>
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <property name="horizontalSpacing" >
<number>6</number>
</property>
- <item row="0" column="0" >
- <widget class="QSplitter" name="canvasLegendSplit" >
- <property name="sizePolicy" >
- <sizepolicy>
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="frameShape" >
- <enum>QFrame::NoFrame</enum>
- </property>
- <property name="frameShadow" >
- <enum>QFrame::Plain</enum>
- </property>
- <property name="lineWidth" >
- <number>1</number>
- </property>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <widget class="QSplitter" name="legendOverviewSplit" >
- <sizepolicy>
- <hsizetype>0</hsizetype>
- <vsizetype>0</vsizetype>
- </sizepolicy>
- </property>
- <property name="minimumSize" >
- <size>
- <width>0</width>
- <height>0</height>
- </size>
- </property>
- <enum>Qt::Vertical</enum>
- </property>
- <widget class="QToolBox" name="toolBox" >
- <property name="font" >
- <font>
- <family>Lucida Grande</family>
- <pointsize>10</pointsize>
- <weight>50</weight>
- <italic>false</italic>
- <bold>false</bold>
- <underline>false</underline>
- <strikeout>false</strikeout>
- </font>
- </property>
- </property>
- <enum>QFrame::Raised</enum>
- </property>
- <property name="currentIndex" >
- <number>0</number>
- </property>
- <widget class="QWidget" name="legendPage" >
- <property name="geometry" >
- <rect>
- <x>0</x>
- <y>0</y>
- <width>386</width>
- <height>244</height>
- </rect>
- </property>
- <attribute name="label" >
- <string>Legend</string>
- </attribute>
- </widget>
- </widget>
- <widget class="QFrame" name="overviewFrame" >
- <enum>QFrame::StyledPanel</enum>
- </property>
- </property>
- </widget>
- </widget>
- <widget class="QTabWidget" name="tabWidget" >
- <font>
- <family>Arial</family>
- </font>
- </property>
- <property name="tabPosition" >
- <enum>QTabWidget::East</enum>
- </property>
- <property name="tabShape" >
- <enum>QTabWidget::Rounded</enum>
- </property>
- <widget class="QWidget" name="Map View" >
- <attribute name="title" >
- <string>Map View</string>
- </attribute>
- </widget>
- </widget>
- </widget>
- </item>
+ <property name="verticalSpacing" >
+ <number>6</number>
+ </property>
</layout>
</widget>
</widget>
