[QGIS Commit] r9035 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Fri Aug 8 09:03:09 EDT 2008
Author: sholl
Date: 2008-08-08 09:03:09 -0400 (Fri, 08 Aug 2008)
New Revision: 9035
docs/trunk/english_us/user_guide/ChangeLog
docs/trunk/english_us/user_guide/working_with_vector.tex
* working_with_vector.tex: added a section about the topological
editing, some typos fixed.
Modified: docs/trunk/english_us/user_guide/ChangeLog
--- docs/trunk/english_us/user_guide/ChangeLog 2008-08-08 13:01:35 UTC (rev 9034)
+++ docs/trunk/english_us/user_guide/ChangeLog 2008-08-08 13:03:09 UTC (rev 9035)
@@ -1,3 +1,8 @@
+2008-08-08 Stephan Holl <stephan at keto>
+ * working_with_vector.tex: added a section about the topological
+ editing, some typos fixed.
2008-08-05 Stephan Holl <stephan at keto>
* working_with_raster.tex: Added some text for the new
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2008-08-08 13:01:35 UTC (rev 9034)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2008-08-08 13:03:09 UTC (rev 9035)
@@ -760,7 +760,6 @@
actions to launch web-based reports for an attribute field or combination of
fields, specifying them in the same way we did in our Google search example.
-% FIXME: Note for SH: please continue editing this file here (SH:20080801)
\subsection{Editing}\index{editing}
QGIS supports basic capabilities for editing spatial data. Before reading any
@@ -783,12 +782,30 @@
proximity. Set it too small and it won't find anything and it will pop up an
annoying warning to that effect.
-To set the snap tolerance, choose \dropmenuopttwo{mActionOptions}{Project Properties} from the
-\mainmenuopt{Settings} menu and click on the \tab{General} tab. Remember the
+To set the snap tolerance, choose \dropmenuopttwo{mActionOptions}{Options} from the
+\mainmenuopt{Settings} menu and click on the \tab{Digitizing} tab. Remember the
tolerance is in map units. For our little digitizing project, the units
are in decimal degrees. Your results may vary, but something on the order
of 0.05 to 0.1 should be fine.
+Additionally QGIS supports {\em special} snapping options for every project.
+Therefor you can select \dropmenuopttwo{mActionOptions}{Project
+Properties\dots} from the \mainmenuopt{Settings} menu. The \tab{General} tab
+provides a section \classname{Digitize} where you can \checkbox{Enable
+topological editing} or activate the option \checkbox{Avoid intersections of
+new polygons}. \\
+The button \button{Snapping options\dots} provides the dialog \dialog{Snapping
+options\dots} (see fig. \ref{fig:snappingoptions}) where you can enable and
+adjust the snapping-mode and the tolerance on a layer basis.
+% FIXME: needs to be replaced
+%\begin{figure}[H]
+% \begin{center}
+% \caption{Edit snapping options on a layer basis}\label{fig:snappingoptions}\smallskip
+% \includegraphics[clip=true, width=8cm]{}
+%\end{center}
+%\end{figure}
\subsubsection{Editing an Existing Layer}
\index{vector layers!editing}
\index{editing!an existing layer}
@@ -810,7 +827,7 @@
\end{Tip}
\index{Allow Editing}
-All editing sessions start by choosing the \dropmenuopttwo{mActionToggleEditing}{Allow editing} option.
+All editing sessions start by choosing the \dropmenuopttwo{mActionToggleEditing}{Toggle editing} option.
This can be found in the context menu after right clicking on the legend
entry for that layer.
Alternately, you can use the \index{Toggle Editing}
@@ -824,7 +841,7 @@
\end{Tip}
\begin{Tip}[ht]\caption{\textsc{Save Regularly}}
-\qgistip{Remember to toggle \toolbtntwo{mActionToggleEditing}{Allow editing} off regularly. This allows you to save your changes thus far,
+\qgistip{Remember to toggle \toolbtntwo{mActionToggleEditing}{Toggle editing} off regularly. This allows you to save your changes thus far,
and also confirms that your data source can accept all
your changes.
@@ -847,7 +864,13 @@
\end{Tip}
\begin{Tip}[ht]\caption{\textsc{Vertex Markers}}
-\qgistip{This version of QGIS does not allow you to change the vertex markers used.
+\qgistip{
+The current version of QGIS supports several vertex-markers. Currently
+a semi-transparent circle or a
+cross is supported. To change the markers, choose
+\dropmenuopttwo{mActionOptions}{Options} from the
+\mainmenuopt{Settings} menu and click on the \tab{Digitizing} tab and select
+the appropriate entry.
\end{Tip}
@@ -895,6 +918,7 @@
Figure \ref{fig:vector_digitising} shows setting attributes for a fictitious
new river in Alaska.
+% FIXME: new screenie here
%\begin{figure}[ht]
% \begin{center}
% \caption{Vector Digitizing Attributes Capture
@@ -904,25 +928,28 @@
%\end{figure}
\begin{Tip}[ht]\caption{\textsc{Attribute Value Types}}
-\qgistip{In the current version of QGIS, the attributes
-dialog box does not check that the data entered matches the type expected (e.g. numeric
-vs. text). Make sure of this before pressing \button{OK}, otherwise you may find the error
-will be caught later when you try to save your changes.
+\qgistip{
+At least for shapefile editing the attribue types are validated during the
+entry. Therefor it is not possible to enter a number into the text-column in
+the dialog \dialog{Enter Attribute Values} or vis versa. If you need to do so,
+you should edit the attributes in a second step within the \dialog{Attribute
+table} dialog.
\end{Tip}
-% These features will be added later
-%\minisec{Move Selected Feature}
-%\index{vector layers!move!feature}
-%%% INPUT IS MISSING
-%\minisec{Split Selected Feature}
-%\index{vector layers!split!feature}
+% FIXME: Write me
+\minisec{Move Selected Feature}
+\index{vector layers!move!feature}
+%% INPUT IS MISSING
+write me
+% FIXME: Write me
+\minisec{Split Selected Feature}
+\index{vector layers!split!feature}
%%%% INPUT IS MISSING
+write me
\minisec{Editing Vertices of a Feature}
\index{vector layers!editing!vertex}
@@ -952,8 +979,7 @@
\end{itemize}
You will need to set the property
-\mainmenuopt{Settings}>\dropmenuopttwo{mActionOptions}{Project
-Properties}>\dropmenuopt{General}>\dropmenuopt{Snapping Tolerance}
+\mainmenuopt{Settings}>\dropmenuopttwo{mActionOptions}{Options}>\tab{Digitizing}
to a number greater than zero. Otherwise QGIS will not be able to tell which feature is being edited.
@@ -1105,8 +1131,7 @@
\index{editing!snap}
QGIS allows digitized vertices to be snapped to other vertices of the same layer. To
set the snapping tolerance, go to
-Properties}->\dropmenuopt{General}->\dropmenuopt{Snapping Tolerance}.
+\mainmenuopt{Settings}>\dropmenuopttwo{mActionOptions}{Options}->\tab{Digitizing}.
Note that the snapping tolerance is in map units.
\minisec{Saving Edited Layers}
@@ -1130,6 +1155,7 @@
shown in Figure \ref{fig:newvectorlayer}. Choose the type of layer (point,
line or polygon).
%\begin{figure}[ht]
% \begin{center}
% \caption{Creating a New Vector Dialog}\label{fig:newvectorlayer}\smallskip
@@ -1165,6 +1191,7 @@
\ref{fig:query_builder} shows an example of the query builder populated with
data from a PostGIS layer with attributes stored in PostgreSQL.
%\begin{figure}[ht]
% \begin{center}
% \caption{Query Builder}\label{fig:query_builder}\smallskip
@@ -1191,7 +1218,7 @@
Builder!changing layer definitions}
\qgistip{You can change the layer definition after it is loaded by altering
the SQL query used to define the layer. To do this, open the
-vecotr \dialog{Layer Properties} dialog by double-clicking on the layer in the legend and click on the
+vector \dialog{Layer Properties} dialog by double-clicking on the layer in the legend and click on the
\button{Query Builder} button on the \tab{General} tab. See Section
\ref{sec:vectorprops} for more information.}
\end{Tip}
