[QGIS Commit] r9037 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Fri Aug 8 14:49:46 EDT 2008
Author: timlinux
Date: 2008-08-08 14:49:45 -0400 (Fri, 08 Aug 2008)
New Revision: 9037
trunk/qgis/src/ui/qgsoptionsbase.ui
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
More substitutions of the words Projection/SRS for Coordinate Reference System / CRS
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2008-08-08 15:54:59 UTC (rev 9036)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2008-08-08 18:49:45 UTC (rev 9037)
@@ -783,9 +783,9 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabProjection" >
+ <widget class="QWidget" name="tabCRS" >
<attribute name="title" >
- <string>Pro&jection</string>
+ <string>CRS</string>
</attribute>
<layout class="QGridLayout" >
<property name="leftMargin" >
@@ -826,7 +826,7 @@
<item row="0" column="0" >
<widget class="QGroupBox" name="grpProjectionBehaviour" >
<property name="title" >
- <string>When layer is loaded that has no projection information</string>
+ <string>When layer is loaded that has no coordinate reference system (CRS)</string>
</property>
<layout class="QVBoxLayout" >
@@ -844,21 +844,21 @@
<item>
<widget class="QRadioButton" name="radPromptForProjection" >
<property name="text" >
- <string>Prompt for projection</string>
+ <string>Prompt for CRS</string>
</property>
</widget>
</item>
<item>
<widget class="QRadioButton" name="radUseProjectProjection" >
- <string>Project wide default projection will be used</string>
+ <string>Project wide default CRS will be used</string>
</property>
</widget>
</item>
<item>
<widget class="QRadioButton" name="radUseGlobalProjection" >
- <string>Global default projection displa&yed below will be used</string>
+ <string>Global default CRS displa&yed below will be used</string>
</property>
</widget>
</item>
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-08-08 15:54:59 UTC (rev 9036)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-08-08 18:49:45 UTC (rev 9037)
@@ -1393,7 +1393,7 @@
<item row="4" column="0" colspan="3" >
<widget class="QGroupBox" name="grpSRS" >
- <string>Spatial reference system</string>
+ <string>Coordinate reference system</string>
</property>
@@ -1798,7 +1798,7 @@
<property name="html" >
<string><html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
-</style></head><body style=" font-family:'Verdana'; font-size:10pt; font-weight:400; font-style:normal;">
+</style></head><body style=" font-family:'DejaVu Sans'; font-size:10pt; font-weight:400; font-style:normal;">
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></body></html></string>
</property>
</widget>
Modified: trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2008-08-08 15:54:59 UTC (rev 9036)
+++ trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2008-08-08 18:49:45 UTC (rev 9037)
@@ -204,7 +204,7 @@
<item row="3" column="2" >
<widget class="QPushButton" name="pbnChangeSpatialRefSys" >
- <string>Change SRS</string>
+ <string>Change CRS</string>
</property>
</widget>
</item>
