[QGIS Commit] r9200 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Thu Aug 28 09:58:22 EDT 2008
Author: ersts
Date: 2008-08-28 09:58:22 -0400 (Thu, 28 Aug 2008)
New Revision: 9200
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
-Added ability to add new single entry to color map
-Added ability to sort color map
-Reorder controls on the Colormap tab
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-08-28 07:57:32 UTC (rev 9199)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2008-08-28 13:58:22 UTC (rev 9200)
@@ -2622,6 +2622,14 @@
+void QgsRasterLayerProperties::on_pbtnAddColorMapEntry_clicked()
+ QTreeWidgetItem* newItem = new QTreeWidgetItem( mColormapTreeWidget );
+ newItem->setText( 0, "0.0");
+ newItem->setBackground( 1, QBrush( QColor(Qt::magenta) ) );
+ newItem->setText( 2, tr("Custom color map entry"));
void QgsRasterLayerProperties::on_pbtnExportColorMapToFile_clicked()
QString myFileName = QFileDialog::getSaveFileName( this, tr( "Save file" ), "/", tr( "Textfile (*.txt)" ) );
@@ -2883,6 +2891,54 @@
+void QgsRasterLayerProperties::on_pbtnSortColorMap_clicked()
+ bool inserted = false;
+ int myCurrentIndex = 0;
+ int myTopLevelItemCount = mColormapTreeWidget->topLevelItemCount();
+ QTreeWidgetItem* myCurrentItem;
+ QList<QgsColorRampShader::ColorRampItem> myColorRampItems;
+ for ( int i = 0; i < myTopLevelItemCount; ++i )
+ myCurrentItem = mColormapTreeWidget->topLevelItem( i );
+ //If the item is null or does not have a pixel values set, skip
+ if(!myCurrentItem || myCurrentItem->text(0) == "")
+ continue;
+ //Create a copy of the new Color ramp Item
+ QgsColorRampShader::ColorRampItem myNewColorRampItem;
+ myNewColorRampItem.value = myCurrentItem->text( 0 ).toDouble();
+ myNewColorRampItem.color = myCurrentItem->background( 1 ).color();
+ myNewColorRampItem.label = myCurrentItem->text( 2 );
+ //Simple insertion sort - speed is not a huge factor here
+ inserted = false;
+ myCurrentIndex = 0;
+ while(!inserted)
+ if(0 == myColorRampItems.size() || myCurrentIndex == myColorRampItems.size())
+ myColorRampItems.push_back( myNewColorRampItem );
+ inserted = true;
+ else if(myColorRampItems[myCurrentIndex].value <= myNewColorRampItem.value && myCurrentIndex == myColorRampItems.size() - 1)
+ inserted = true;
+ else if(myColorRampItems[myCurrentIndex].value <= myNewColorRampItem.value && myColorRampItems[myCurrentIndex+1].value > myNewColorRampItem.value)
+ myColorRampItems.insert(myCurrentIndex+1,myNewColorRampItem );
+ inserted = true;
+ myCurrentIndex++;
+ populateColorMapTable(myColorRampItems);
QLinearGradient QgsRasterLayerProperties::redGradient()
//define a gradient
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2008-08-28 07:57:32 UTC (rev 9199)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2008-08-28 13:58:22 UTC (rev 9200)
@@ -108,6 +108,8 @@
void on_mDeleteEntryButton_clicked();
/**Callback for double clicks on the colormap entry widget*/
void handleColormapTreeWidgetDoubleClick( QTreeWidgetItem* item, int column );
+ /**This slot adds a new row to the color map table */
+ void on_pbtnAddColorMapEntry_clicked();
/**This slots saves the current color map to a file */
void on_pbtnExportColorMapToFile_clicked();
/**This slots loads the current color map from a band */
@@ -120,7 +122,8 @@
void on_pbtnMakeBandCombinationDefault_clicked();
/**This slot sets the default contrast enhancement varaible to current contrast enhancement algorithm */
void on_pbtnMakeContrastEnhancementAlgorithmDefault_clicked();
+ /**This slot will sort the color map in ascending order*/
+ void on_pbtnSortColorMap_clicked();
/** Load the default style when appriate button is pressed. */
void on_pbnLoadDefaultStyle_clicked();
/** Save the default style when appriate button is pressed. */
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-08-28 07:57:32 UTC (rev 9199)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2008-08-28 13:58:22 UTC (rev 9200)
@@ -6,7 +6,7 @@
<x>0</x>
<y>0</y>
<width>596</width>
- <height>610</height>
+ <height>658</height>
</rect>
</property>
<property name="windowTitle" >
@@ -1199,7 +1199,7 @@
<string>Colormap</string>
</attribute>
<layout class="QGridLayout" >
- <item row="0" column="0" colspan="2" >
+ <item row="0" column="0" colspan="3" >
<layout class="QHBoxLayout" >
<property name="leftMargin" >
<number>11</number>
@@ -1214,55 +1214,6 @@
<number>11</number>
</property>
<item>
- <widget class="QLabel" name="mNumberOfEntriesLabel" >
- <property name="text" >
- <string>Number of entries</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QSpinBox" name="sboxNumberOfEntries" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="maximum" >
- <number>256</number>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item row="0" column="2" >
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>71</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="0" column="3" colspan="4" >
- <layout class="QHBoxLayout" >
- <property name="leftMargin" >
- <number>11</number>
- </property>
- <property name="topMargin" >
- </property>
- <property name="rightMargin" >
- </property>
- <property name="bottomMargin" >
- </property>
- <item>
<widget class="QLabel" name="mColorInterpolationLabel" >
<string>Color interpolation</string>
@@ -1274,73 +1225,54 @@
</item>
</layout>
</item>
- <item row="1" column="0" colspan="3" >
+ <item row="0" column="3" colspan="6" >
<spacer>
</property>
<size>
- <width>61</width>
+ <width>321</width>
+ <height>45</height>
</size>
</property>
</spacer>
</item>
- <item row="1" column="3" colspan="4" >
- </property>
- </property>
- </property>
- </property>
- <item>
- <widget class="QLabel" name="mClassificationModeLabel" >
- <string>Classification mode</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QComboBox" name="cboxClassificationMode" />
- </item>
- </layout>
- </item>
- <item row="2" column="0" >
- <widget class="QPushButton" name="mClassifyButton" >
+ <item row="1" column="0" >
+ <widget class="QPushButton" name="pbtnAddColorMapEntry" >
- <string>Classify</string>
+ <string>Add entry</string>
</property>
</widget>
</item>
- <item row="2" column="1" >
+ <item row="1" column="1" >
<widget class="QPushButton" name="mDeleteEntryButton" >
<string>Delete entry</string>
</property>
</widget>
</item>
- <item row="2" column="2" >
+ <item row="1" column="2" colspan="2" >
+ <widget class="QPushButton" name="pbtnSortColorMap" >
+ <property name="text" >
+ <string>Sort</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="4" >
<spacer>
</property>
<size>
- <width>211</width>
+ <width>41</width>
<height>27</height>
</size>
</property>
</spacer>
</item>
- <item row="2" column="3" >
+ <item row="1" column="5" >
<number>11</number>
@@ -1363,11 +1295,14 @@
</item>
</layout>
</item>
- <item row="2" column="4" >
+ <item row="1" column="6" >
<spacer>
</property>
+ <property name="sizeType" >
+ <enum>QSizePolicy::Minimum</enum>
+ </property>
<size>
<width>20</width>
@@ -1376,7 +1311,7 @@
</property>
</spacer>
</item>
- <item row="2" column="5" >
+ <item row="1" column="7" >
<widget class="QToolButton" name="pbtnLoadColorMapFromFile" >
<property name="toolTip" >
<string>Load color map from file</string>
@@ -1389,7 +1324,7 @@
</property>
</widget>
</item>
- <item row="2" column="6" >
+ <item row="1" column="8" >
<widget class="QToolButton" name="pbtnExportColorMapToFile" >
<string>Export color map to file</string>
@@ -1402,7 +1337,7 @@
</property>
</widget>
</item>
- <item row="3" column="0" colspan="7" >
+ <item row="2" column="0" colspan="9" >
<widget class="QTreeWidget" name="mColormapTreeWidget" >
<property name="columnCount" >
<number>3</number>
@@ -1424,6 +1359,84 @@
</column>
</widget>
</item>
+ <item row="3" column="0" colspan="9" >
+ <widget class="QGroupBox" name="groupBox_9" >
+ <property name="title" >
+ <string>Generate new color map</string>
+ </property>
+ <layout class="QHBoxLayout" >
+ <item>
+ <property name="leftMargin" >
+ <number>11</number>
+ </property>
+ <property name="topMargin" >
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <item>
+ <widget class="QLabel" name="mNumberOfEntriesLabel" >
+ <string>Number of entries</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QSpinBox" name="sboxNumberOfEntries" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="maximum" >
+ <number>256</number>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
+ </property>
+ </property>
+ </property>
+ </property>
+ <item>
+ <widget class="QLabel" name="mClassificationModeLabel" >
+ <string>Classification mode</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QComboBox" name="cboxClassificationMode" />
+ </item>
+ </layout>
+ </item>
+ <item>
+ <widget class="QPushButton" name="mClassifyButton" >
+ <string>Classify</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="tabPageGeneral" >
