[QGIS Commit] r9201 - in trunk/qgis/src: app/composer ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Aug 28 10:43:41 EDT 2008
Author: mhugent
Date: 2008-08-28 10:43:41 -0400 (Thu, 28 Aug 2008)
New Revision: 9201
   trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp
   trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui
rearranged composer scalebar widget to have less height
Modified: trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp
--- trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp	2008-08-28 13:58:22 UTC (rev 9200)
+++ trunk/qgis/src/app/composer/qgscomposerscalebarwidget.cpp	2008-08-28 14:43:41 UTC (rev 9201)
@@ -28,7 +28,7 @@
   //add widget for general composer item properties
   QgsComposerItemWidget* itemPropertiesWidget = new QgsComposerItemWidget( this, scaleBar );
-  gridLayout->addWidget( itemPropertiesWidget, 14, 0, 1, 3 );
+  gridLayout->addWidget( itemPropertiesWidget, 14, 0, 1, 5 );
   blockMemberSignals( true );
   mStyleComboBox->insertItem( 0, tr( "Single Box" ) );
Modified: trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui	2008-08-28 13:58:22 UTC (rev 9200)
+++ trunk/qgis/src/ui/qgscomposerscalebarwidgetbase.ui	2008-08-28 14:43:41 UTC (rev 9201)
@@ -5,8 +5,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>367</width>
-    <height>476</height>
+    <width>561</width>
+    <height>228</height>
    </rect>
   </property>
   <property name="sizePolicy" >
@@ -29,7 +29,7 @@
      </property>
     </widget>
    </item>
-   <item row="0" column="2" >
+   <item row="0" column="1" >
     <widget class="QDoubleSpinBox" name="mSegmentSizeSpinBox" >
      <property name="decimals" >
       <number>4</number>
@@ -39,7 +39,24 @@
      </property>
     </widget>
    </item>
-   <item row="1" column="0" colspan="2" >
+   <item row="0" column="2" colspan="2" >
+    <widget class="QLabel" name="mMapUnitsPerBarUnitLabel" >
+     <property name="text" >
+      <string>Map units per bar unit:</string>
+     </property>
+     <property name="wordWrap" >
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+   <item row="0" column="4" >
+    <widget class="QDoubleSpinBox" name="mMapUnitsPerBarUnitSpinBox" >
+     <property name="maximum" >
+      <double>9999999999999.000000000000000</double>
+     </property>
+    </widget>
+   </item>
+   <item row="1" column="0" >
     <widget class="QLabel" name="mNumbereOfSegmentsLabel" >
       <string>Number of segments:</string>
@@ -49,63 +66,30 @@
      </property>
     </widget>
    </item>
-   <item row="1" column="2" >
+   <item row="1" column="1" >
     <widget class="QSpinBox" name="mNumberOfSegmentsSpinBox" />
    </item>
-   <item row="2" column="0" colspan="2" >
+   <item row="1" column="2" colspan="2" >
     <widget class="QLabel" name="mSegmentsLeftLabel" >
       <string>Segments left:</string>
      </property>
     </widget>
    </item>
-   <item row="2" column="2" >
+   <item row="1" column="4" >
     <widget class="QSpinBox" name="mSegmentsLeftSpinBox" />
    </item>
-   <item row="3" column="0" >
+   <item row="2" column="0" >
     <widget class="QLabel" name="mStyleLabel" >
       <string>Style:</string>
      </property>
     </widget>
    </item>
-   <item row="3" column="2" >
+   <item row="2" column="1" >
     <widget class="QComboBox" name="mStyleComboBox" />
    </item>
-   <item row="4" column="0" >
-    <widget class="QLabel" name="mUnitLabelLabel" >
-     <property name="text" >
-      <string>Unit label:</string>
-     </property>
-     <property name="wordWrap" >
-      <bool>true</bool>
-     </property>
-     <property name="buddy" >
-      <cstring>mUnitLabelLineEdit</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="2" >
-    <widget class="QLineEdit" name="mUnitLabelLineEdit" />
-   </item>
-   <item row="5" column="0" >
-    <widget class="QLabel" name="mMapUnitsPerBarUnitLabel" >
-      <string>Map units per bar unit:</string>
-     </property>
-      <bool>true</bool>
-     </property>
-    </widget>
-   </item>
-   <item row="5" column="2" >
-    <widget class="QDoubleSpinBox" name="mMapUnitsPerBarUnitSpinBox" >
-     <property name="maximum" >
-      <double>9999999999999.000000000000000</double>
-     </property>
-    </widget>
-   </item>
-   <item row="6" column="0" >
+   <item row="2" column="2" >
     <widget class="QLabel" name="mMapLabel" >
       <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
@@ -124,7 +108,7 @@
      </property>
     </widget>
    </item>
-   <item row="6" column="2" >
+   <item row="2" column="4" >
     <widget class="QComboBox" name="mMapComboBox" >
      <property name="enabled" >
       <bool>true</bool>
@@ -137,17 +121,17 @@
      </property>
     </widget>
    </item>
-   <item row="7" column="0" >
+   <item row="3" column="0" >
     <widget class="QLabel" name="mHeightLabel" >
       <string>Height (mm):</string>
      </property>
     </widget>
    </item>
-   <item row="7" column="2" >
+   <item row="3" column="1" >
     <widget class="QSpinBox" name="mHeightSpinBox" />
    </item>
-   <item row="8" column="0" >
+   <item row="3" column="2" colspan="2" >
     <widget class="QLabel" name="mLineWidthLabel" >
       <string>Line width:</string>
@@ -160,7 +144,7 @@
      </property>
     </widget>
    </item>
-   <item row="8" column="2" >
+   <item row="3" column="4" >
     <widget class="QDoubleSpinBox" name="mLineWidthSpinBox" >
@@ -179,27 +163,43 @@
      </property>
     </widget>
    </item>
-   <item row="9" column="0" >
+   <item row="4" column="0" >
     <widget class="QLabel" name="mLabelBarSpaceLabel" >
       <string>Label space:</string>
      </property>
     </widget>
    </item>
-   <item row="9" column="2" >
+   <item row="4" column="1" >
     <widget class="QDoubleSpinBox" name="mLabelBarSpaceSpinBox" />
    </item>
-   <item row="10" column="0" >
+   <item row="4" column="2" colspan="2" >
     <widget class="QLabel" name="mBoxSpaceLabel" >
       <string>Box space:</string>
      </property>
     </widget>
    </item>
-   <item row="10" column="2" >
+   <item row="4" column="4" >
     <widget class="QDoubleSpinBox" name="mBoxSizeSpinBox" />
    </item>
-   <item row="11" column="0" >
+   <item row="5" column="0" >
+    <widget class="QLabel" name="mUnitLabelLabel" >
+      <string>Unit label:</string>
+     </property>
+      <bool>true</bool>
+     </property>
+     <property name="buddy" >
+      <cstring>mUnitLabelLineEdit</cstring>
+     </property>
+    </widget>
+   </item>
+   <item row="5" column="1" >
+    <widget class="QLineEdit" name="mUnitLabelLineEdit" />
+   </item>
+   <item row="5" column="2" >
     <widget class="QPushButton" name="mFontButton" >
       <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
@@ -212,26 +212,13 @@
      </property>
     </widget>
    </item>
-   <item row="11" column="2" >
+   <item row="5" column="3" colspan="2" >
     <widget class="QPushButton" name="mColorPushButton" >
       <string>Color...</string>
      </property>
     </widget>
    </item>
-   <item row="12" column="1" >
-    <spacer>
-     <property name="orientation" >
-      <enum>Qt::Vertical</enum>
-     </property>
-     <property name="sizeHint" >
-      <size>
-       <width>20</width>
-       <height>16</height>
-      </size>
-     </property>
-    </spacer>
-   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11" />
More information about the QGIS-commit mailing list
