[QGIS Commit] r9226 - in trunk/qgis/src/core: . raster
svn_qgis at osgeo.org
Sun Aug 31 08:39:27 EDT 2008
Author: timlinux
Date: 2008-08-31 08:39:26 -0400 (Sun, 31 Aug 2008)
New Revision: 9226
trunk/qgis/src/core/qgsdistancearea.h
trunk/qgis/src/core/raster/qgscliptominmaxenhancement.h
trunk/qgis/src/core/raster/qgscolorrampshader.h
trunk/qgis/src/core/raster/qgscolortable.h
trunk/qgis/src/core/raster/qgscontrastenhancement.cpp
trunk/qgis/src/core/raster/qgscontrastenhancement.h
trunk/qgis/src/core/raster/qgscontrastenhancementfunction.h
trunk/qgis/src/core/raster/qgsfreakoutshader.h
trunk/qgis/src/core/raster/qgslinearminmaxenhancement.h
trunk/qgis/src/core/raster/qgslinearminmaxenhancementwithclip.h
trunk/qgis/src/core/raster/qgspseudocolorshader.h
trunk/qgis/src/core/raster/qgsrasterbandstats.h
trunk/qgis/src/core/raster/qgsrasterlayer.h
trunk/qgis/src/core/raster/qgsrasterpyramid.h
trunk/qgis/src/core/raster/qgsrastershader.h
trunk/qgis/src/core/raster/qgsrastershaderfunction.h
trunk/qgis/src/core/raster/qgsrastertransparency.h
trunk/qgis/src/core/raster/qgsrasterviewport.h
Api documentation updates - added class descriptions for all raster classes
Modified: trunk/qgis/src/core/qgsdistancearea.h
--- trunk/qgis/src/core/qgsdistancearea.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/qgsdistancearea.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -23,7 +23,7 @@
class QgsGeometry;
/** \ingroup core
-General purpose distance and area calculator
+General purpose distance and area calculator.
- calculations are done on ellipsoid
- it's possible to pass points/features in any CRS, coordinates are transformed
- two options how to use it
Modified: trunk/qgis/src/core/raster/qgscliptominmaxenhancement.h
--- trunk/qgis/src/core/raster/qgscliptominmaxenhancement.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgscliptominmaxenhancement.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -21,6 +21,12 @@
#include "qgscontrastenhancementfunction.h"
+/** \ingroup core
+ * A raster contrast enhancement that will clip a value to the specified min/max range.
+ * For example if a min max range of [10,240] is specified in the constructor, and
+ * a value of 250 is called using enhanceValue(), the value will be truncated ('clipped')
+ * to 240.
class CORE_EXPORT QgsClipToMinMaxEnhancement : public QgsContrastEnhancementFunction
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.h
--- trunk/qgis/src/core/raster/qgscolorrampshader.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -25,6 +25,9 @@
#include "qgsrastershaderfunction.h"
+/** \ingroup core
+ * A ramp shader will color a raster pixel based on a list of values ranges in a ramp.
class CORE_EXPORT QgsColorRampShader : public QgsRasterShaderFunction
Modified: trunk/qgis/src/core/raster/qgscolortable.h
--- trunk/qgis/src/core/raster/qgscolortable.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgscolortable.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -19,15 +19,6 @@
#include <QVector>
- * Because of performance, this class can store color rules in 2 forms:
- * 1) discrete - vector of descrete values and their colors; can be accessed by index (from 0)
- * 2) ramp - vector of ramps defined by min and max value and a color for min amd max value,
- * colors between min and max are interpolated linearly.
- * Only one type should be used for one instance.
typedef struct
@@ -41,6 +32,18 @@
unsigned char min_c1, min_c2, min_c3, min_c4;
unsigned char max_c1, max_c2, max_c3, max_c4;
} RAMP;
+/** \ingroup core
+ * A raster color table contains a list of indexed values and the color associated with each index.
+ * Because of performance, this class can store color rules in 2 forms:
+ * 1) discrete - vector of descrete values and their colors; can be accessed by index (from 0)
+ * 2) ramp - vector of ramps defined by min and max value and a color for min amd max value,
+ * colors between min and max are interpolated linearly.
+ * Only one type should be used for one instance.
class CORE_EXPORT QgsColorTable
public:
Modified: trunk/qgis/src/core/raster/qgscontrastenhancement.cpp
--- trunk/qgis/src/core/raster/qgscontrastenhancement.cpp 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgscontrastenhancement.cpp 2008-08-31 12:39:26 UTC (rev 9226)
@@ -28,8 +28,6 @@
QgsContrastEnhancement::QgsContrastEnhancement( QgsRasterDataType theDataType )
- QgsDebugMsg( "called" );
mLookupTable = 0;
mContrastEnhancementFunction = 0;
mEnhancementDirty = false;
Modified: trunk/qgis/src/core/raster/qgscontrastenhancement.h
--- trunk/qgis/src/core/raster/qgscontrastenhancement.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgscontrastenhancement.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -25,6 +25,11 @@
class QgsContrastEnhancementFunction;
+/** \ingroup core
+ * Manipulates raster pixel values so that they stretch or clip into a
+ * specified numerical range according to the specified
+ * CONTRAST_ENHANCEMENT_ALGORITHM.
class CORE_EXPORT QgsContrastEnhancement
Modified: trunk/qgis/src/core/raster/qgscontrastenhancementfunction.h
--- trunk/qgis/src/core/raster/qgscontrastenhancementfunction.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgscontrastenhancementfunction.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -21,6 +21,12 @@
#include "qgscontrastenhancement.h"
+/** \ingroup core
+ * A contrast enhancement funcion is the base class for all raster contrast enhancements.
+ * The purpose of a contrast enhancement is to stretch or clip a pixel value into
+ * a specified bounding range.
class CORE_EXPORT QgsContrastEnhancementFunction
Modified: trunk/qgis/src/core/raster/qgsfreakoutshader.h
--- trunk/qgis/src/core/raster/qgsfreakoutshader.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgsfreakoutshader.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -23,6 +23,9 @@
+/** \ingroup core
+ * A colorful false color shader that will frighten your granny and make your dogs howl.
class CORE_EXPORT QgsFreakOutShader : public QgsRasterShaderFunction
Modified: trunk/qgis/src/core/raster/qgslinearminmaxenhancement.h
--- trunk/qgis/src/core/raster/qgslinearminmaxenhancement.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgslinearminmaxenhancement.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -21,6 +21,9 @@
+/** \ingroup core
+ * A colour enhancement function that performs a linear stretch between min and max.
class CORE_EXPORT QgsLinearMinMaxEnhancement : public QgsContrastEnhancementFunction
Modified: trunk/qgis/src/core/raster/qgslinearminmaxenhancementwithclip.h
--- trunk/qgis/src/core/raster/qgslinearminmaxenhancementwithclip.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgslinearminmaxenhancementwithclip.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -21,6 +21,10 @@
+/** \ingroup core
+ * A linear stretch enhancement that first clips to min max and then stretches
+ * linearly between min and max.
class CORE_EXPORT QgsLinearMinMaxEnhancementWithClip : public QgsContrastEnhancementFunction
Modified: trunk/qgis/src/core/raster/qgspseudocolorshader.h
--- trunk/qgis/src/core/raster/qgspseudocolorshader.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgspseudocolorshader.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -23,6 +23,9 @@
+/** \ingroup core
+ * A raster color shader that highlighs low values in blue and high values in red.
class CORE_EXPORT QgsPseudoColorShader : public QgsRasterShaderFunction
Modified: trunk/qgis/src/core/raster/qgsrasterbandstats.h
--- trunk/qgis/src/core/raster/qgsrasterbandstats.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgsrasterbandstats.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -16,11 +16,6 @@
/* $Id: qgsrasterlayer.h 4380 2005-12-26 23:37:50Z timlinux $ */
-/** \file qgsrasterbandstats
- * \brief This class provides statistics for a given raster band.
- * The qgsrasterbandstats holds various stats relating to a given raster band.
#ifndef QGSRASTERBANDSTATS
#define QGSRASTERBANDSTATS
@@ -30,7 +25,8 @@
#include <limits>
#include "qgscolortable.h"
-/** \brief The RasterBandStats struct is a container for statistics about a single
+/** \ingroup core
+ * The RasterBandStats struct is a container for statistics about a single
* raster band.
class CORE_EXPORT QgsRasterBandStats
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -16,9 +16,61 @@
/* $Id$ */
-/** \file qgsrasterlayer.h
- * \brief This class provides qgis with the ability to render raster datasets
- * onto the mapcanvas
+#ifndef QGSRASTERLAYER_H
+#define QGSRASTERLAYER_H
+// Includes
+#include <QColor>
+#include <QDateTime>
+#include <QVector>
+#include <QList>
+#include <QMap>
+#include "qgis.h"
+#include "qgspoint.h"
+#include "qgsmaplayer.h"
+#include "qgscontrastenhancement.h"
+#include "qgsrastertransparency.h"
+#include "qgsrastershader.h"
+#include "qgscolorrampshader.h"
+#include "qgsrastershaderfunction.h"
+#include "qgsrasterdataprovider.h"
+#define CPL_SUPRESS_CPLUSPLUS
+#include <gdal.h>
+/** \ingroup core
+ * A call back function for showing progress of gdal operations.
+int CPL_STDCALL progressCallback( double dfComplete,
+ const char *pszMessage,
+ void * pProgressArg );
+// Forward declarations
+class QgsColorTable;
+class QgsMapToPixel;
+class QgsRect;
+class QgsRasterBandStats;
+class QgsRasterPyramid;
+class QgsRasterLayerProperties;
+struct QgsRasterViewPort;
+class QImage;
+class QPixmap;
+class QSlider;
+class QLibrary;
+/** \ingroup core
+ * This class provides qgis with the ability to render raster datasets
+ * onto the mapcanvas.
* The qgsrasterlayer class makes use of gdal for data io, and thus supports
* any gdal supported format. The constructor attempts to infer what type of
@@ -57,21 +109,29 @@
* Sample usage of the QgsRasterLayer class:
+ * \code
* QString myFileNameQString = "/path/to/file";
* QFileInfo myFileInfo(myFileNameQString);
* QString myBaseNameQString = myFileInfo.baseName();
* QgsRasterLayer *myRasterLayer = new QgsRasterLayer(myFileNameQString, myBaseNameQString);
+ * \endcode
* In order to automate redrawing of a raster layer, you should like it to a map canvas like this :
+ * \code
* QObject::connect( myRasterLayer, SIGNAL(repaintRequested()), mapCanvas, SLOT(refresh()) );
+ * \endcode
* A raster layer can also export its legend as a pixmap:
+ * \code
* QPixmap myQPixmap = myRasterLayer->legendPixmap();
+ * \endcode
* Once a layer has been created you can find out what type of layer it is (GRAY_OR_UNDEFINED, PALETTE or MULTIBAND):
+ * \code
* if (rasterLayer->getRasterLayerType()==QgsRasterLayer::MULTIBAND)
* //do something
@@ -84,10 +144,12 @@
* //do something.
+ * \endcode
* You can combine layer type detection with the setDrawingStyle method to override the default drawing style assigned
* when a layer is loaded:
+ * \code
* myRasterLayer->setDrawingStyle(QgsRasterLayer::MULTI_BAND_SINGLE_BAND_PSEUDO_COLOR);
@@ -100,6 +162,7 @@
* myRasterLayer->setDrawingStyle(QgsRasterLayer::SINGLE_BAND_PSEUDO_COLOR);
+ * \endcode
* Raster layers can also have an arbitrary level of transparency defined, and have their
* color palettes inverted using the setTransparency and setInvertHistogramFlag methods.
@@ -116,62 +179,6 @@
* methods.
-#ifndef QGSRASTERLAYER_H
-#define QGSRASTERLAYER_H
-// Includes
-#include <QColor>
-#include <QDateTime>
-#include <QVector>
-#include <QList>
-#include <QMap>
-#include "qgis.h"
-#include "qgspoint.h"
-#include "qgsmaplayer.h"
-#include "qgscontrastenhancement.h"
-#include "qgsrastertransparency.h"
-#include "qgsrastershader.h"
-#include "qgscolorrampshader.h"
-#include "qgsrastershaderfunction.h"
-#include "qgsrasterdataprovider.h"
-#define CPL_SUPRESS_CPLUSPLUS
-#include <gdal.h>
-int CPL_STDCALL progressCallback( double dfComplete,
- const char *pszMessage,
- void * pProgressArg );
-// Forward declarations
-class QgsColorTable;
-class QgsMapToPixel;
-class QgsRect;
-class QgsRasterBandStats;
-class QgsRasterPyramid;
-class QgsRasterLayerProperties;
-struct QgsRasterViewPort;
-class QImage;
-class QPixmap;
-class QSlider;
-class QLibrary;
-/*! \class QgsRasterLayer
- * onto the mapcanvas..
class CORE_EXPORT QgsRasterLayer : public QgsMapLayer
Q_OBJECT
Modified: trunk/qgis/src/core/raster/qgsrasterpyramid.h
--- trunk/qgis/src/core/raster/qgsrasterpyramid.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgsrasterpyramid.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -17,7 +17,9 @@
#ifndef QGSRASTERPYRAMID
#define QGSRASTERPYRAMID
-/** \brief This struct is used to store pyramid info for the raster layer. */
+/** \ingroup core
+ * This struct is used to store pyramid info for the raster layer.
class CORE_EXPORT QgsRasterPyramid
public:
Modified: trunk/qgis/src/core/raster/qgsrastershader.h
--- trunk/qgis/src/core/raster/qgsrastershader.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgsrastershader.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -22,6 +22,9 @@
+/** \ingroup core
+ * Interface for all raster shaders.
class CORE_EXPORT QgsRasterShader
Modified: trunk/qgis/src/core/raster/qgsrastershaderfunction.h
--- trunk/qgis/src/core/raster/qgsrastershaderfunction.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgsrastershaderfunction.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -19,6 +19,10 @@
#ifndef QGSRASTERSHADERFUNCTION_H
#define QGSRASTERSHADERFUNCTION_H
+/** \ingroup core
+ * The raster shade function applies a shader to a pixel at render time -
+ * typically used to render grayscale images as false color.
class CORE_EXPORT QgsRasterShaderFunction
Modified: trunk/qgis/src/core/raster/qgsrastertransparency.h
--- trunk/qgis/src/core/raster/qgsrastertransparency.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgsrastertransparency.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -18,6 +18,10 @@
#ifndef QGSRASTERTRANSPARENCY_H
#define QGSRASTERTRANSPARENCY_H
+/** \ingroup core
+ * Defines the list of pixel values to be considered as transparent or semi
+ * transparent when rendering rasters.
class CORE_EXPORT QgsRasterTransparency
Modified: trunk/qgis/src/core/raster/qgsrasterviewport.h
--- trunk/qgis/src/core/raster/qgsrasterviewport.h 2008-08-31 10:49:44 UTC (rev 9225)
+++ trunk/qgis/src/core/raster/qgsrasterviewport.h 2008-08-31 12:39:26 UTC (rev 9226)
@@ -20,8 +20,8 @@
#include <qgspoint.h>
-/** \file qgsrasterviewport.h
- * \brief This class provides details of the viewable area that a raster will
+/** \ingroup core
+ * This class provides details of the viewable area that a raster will
* be rendered into.
* The qgsrasterviewport class sets up a viewport / area of interest to be used
