[QGIS Commit] r9228 - in trunk/qgis/src: app/composer core/composer
svn_qgis at osgeo.org
Sun Aug 31 09:10:14 EDT 2008
Author: mhugent
Date: 2008-08-31 09:10:14 -0400 (Sun, 31 Aug 2008)
New Revision: 9228
trunk/qgis/src/app/composer/qgscomposerlegendwidget.cpp
trunk/qgis/src/core/composer/qgslegendmodel.cpp
trunk/qgis/src/core/composer/qgslegendmodel.h
Legend update function for composer on item level
Modified: trunk/qgis/src/app/composer/qgscomposerlegendwidget.cpp
--- trunk/qgis/src/app/composer/qgscomposerlegendwidget.cpp 2008-08-31 12:49:15 UTC (rev 9227)
+++ trunk/qgis/src/app/composer/qgscomposerlegendwidget.cpp 2008-08-31 13:10:14 UTC (rev 9228)
@@ -363,13 +363,11 @@
return;
- QModelIndex parentIndex = currentIndex.parent();
- if ( !parentIndex.isValid() ) // a layer item
- QString mapLayerId = currentItem->data().toString();
- mLegend->model()->updateLayer( mapLayerId );
- mLegend->update();
+ if(mLegend->model())
+ mLegend->model()->updateItem(currentItem);
+ mLegend->update();
void QgsComposerLegendWidget::on_mUpdateAllPushButton_clicked()
Modified: trunk/qgis/src/core/composer/qgslegendmodel.cpp
--- trunk/qgis/src/core/composer/qgslegendmodel.cpp 2008-08-31 12:49:15 UTC (rev 9227)
+++ trunk/qgis/src/core/composer/qgslegendmodel.cpp 2008-08-31 13:10:14 UTC (rev 9228)
@@ -134,6 +134,7 @@
continue;
+#if 0
//label
QString label;
QString lowerValue = ( *symbolIt )->lowerValue();
@@ -170,13 +171,15 @@
currentSymbolItem->setData( QVariant::fromValue(( void* )symbolCopy ) );
insertSymbol( symbolCopy );
- if ( !currentSymbolItem )
- continue;
currentSymbolItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
+#endif //0
+ QStandardItem* currentSymbolItem = itemFromSymbol(*symbolIt);
+ if(!currentSymbolItem)
+ continue;
layerItem->setChild( layerItem->rowCount(), 0, currentSymbolItem );
@@ -230,103 +233,180 @@
mSymbols.clear();
-#if 0
-void QgsLegendModel::updateLayerEntries( const QStringList& newLayerIds )
+void QgsLegendModel::updateItem(QStandardItem* item)
- if ( !invisibleRootItem() )
- return;
+ if(!item)
+ return;
- //check for layers to remove
- QStandardItem* currentLayerItem = 0;
- QSet<int> rowsToRemove;
+ //is it a toplevel layer item?
+ QModelIndex itemIndex = indexFromItem(item);
+ QModelIndex parentIndex = itemIndex.parent();
+ if ( !parentIndex.isValid() ) // a layer item?
+ updateLayer(item);
- int numRootItems = rowCount();
- for ( int i = 0; i < numRootItems ; ++i )
- currentLayerItem = item( i );
- if ( !currentLayerItem )
+ //take QgsSymbol* from user data
+ QVariant symbolVariant = item->data();
+ QgsSymbol* symbol = 0;
+ if ( symbolVariant.canConvert<void*>() )
- continue;
+ void* symbolData = symbolVariant.value<void*>();
+ symbol = ( QgsSymbol* )( symbolData );
- QString layerId = currentLayerItem->data().toString();
+ if ( symbol ) //vector classification item
+ updateVectorClassificationItem(item, symbol, item->text());
+ else if(!item->icon().isNull()) //raster classification item
+ updateRasterClassificationItem(item);
- if ( !newLayerIds.contains( layerId ) ) //layer has been removed
+void QgsLegendModel::updateLayer(QStandardItem* layerItem)
+ if(!layerItem)
- rowsToRemove.insert( i );
+ return;
- //remove layers in reverse order
- if ( rowsToRemove.size() > 0 )
+ QString layerId = layerItem->data().toString();
+ QgsMapLayer* mapLayer = QgsMapLayerRegistry::instance()->mapLayer(layerId);
+ if(mapLayer)
+ //delete all the entries under layer item
+ for(int i = rowCount() - 1; i >= 0; --i)
+ layerItem->removeRow(i);
+ //and add the new ones...
+ switch(mapLayer->type())
+ case QgsMapLayer::VECTOR:
+ addVectorLayerItems(layerItem, mapLayer);
+ break;
+ case QgsMapLayer::RASTER:
+ addRasterLayerItem(layerItem, mapLayer);
+ break;
+ default:
+ break;
+void QgsLegendModel::updateVectorClassificationItem(QStandardItem* classificationItem, QgsSymbol* symbol, QString itemText)
+ //this function uses the following logic to find a classification match:
+ //first test if there is a symbol where lowerbound - upperbound equels itemText
+ //if no match found, test if there is a symbol where label equals itemText
+ //still no match found. Test, if there is a symbol with same pen/brush/point symbol
+ //get parent item
+ QStandardItem* parentItem = classificationItem->parent();
+ if(!parentItem)
- QSet<int>::const_iterator delete_it = --rowsToRemove.constEnd();
- for ( ;; --delete_it )
+ return;
+ //get maplayer object from parent item
+ QgsMapLayer* ml = QgsMapLayerRegistry::instance()->mapLayer(parentItem->data().toString());
+ if(!ml)
- removeRow( *delete_it );
- if ( delete_it == rowsToRemove.constBegin() )
- break;
+ return;
+ QgsVectorLayer* vl = dynamic_cast<QgsVectorLayer*>(ml);
+ if(!vl)
+ return;
+ const QgsRenderer* layerRenderer = vl->renderer();
+ if(!layerRenderer)
+ return;
+ QList<QgsSymbol*> symbolList = layerRenderer->symbols();
+ QList<QgsSymbol*>::iterator symbolIt;
+ QgsSymbol* currentSymbol = 0;
+ //try to find a symbol where lowerbound - upperbound matches item text
+ symbolIt = symbolList.begin();
+ for(; symbolIt != symbolList.end(); ++symbolIt)
+ currentSymbol = *symbolIt;
+ if(currentSymbol->lowerValue() + " - " + currentSymbol->upperValue() == itemText)
+ removeSymbol(symbol);
+ parentItem->insertRow(classificationItem->row(), itemFromSymbol(currentSymbol));
+ parentItem->removeRow(classificationItem->row());
+ return;
- mLayerIds = newLayerIds;
-#endif //0
+ //try to find a symbol where lower value matches item text (non-numeric classifications)
+ if(currentSymbol->lowerValue() == itemText)
+ return;
-void QgsLegendModel::updateLayer( const QString& layerId )
+ //try to find a symbol where label matches item text
+ if(currentSymbol->label() == itemText)
+ return;
+void QgsLegendModel::updateRasterClassificationItem(QStandardItem* classificationItem)
- //find layer item
- QStandardItem* layerItem = 0;
+ if(!classificationItem)
+ return;
+ if(!parentItem)
- continue;
+ return;
- QString currentId = currentLayerItem->data().toString();
- if ( currentId == layerId )
+ if(!ml)
- layerItem = currentLayerItem;
- break;
+ return;
- if ( layerItem )
- QgsMapLayer* mapLayer = QgsMapLayerRegistry::instance()->mapLayer( layerId );
- if ( mapLayer )
+ QgsRasterLayer* rl = dynamic_cast<QgsRasterLayer*>(ml);
+ if(!rl)
- //delete all the entries under layer item
- for ( int i = rowCount() - 1; i >= 0; --i )
- layerItem->removeRow( i );
+ return;
- //and add the new ones...
- switch ( mapLayer->type() )
- case QgsMapLayer::VECTOR:
- addVectorLayerItems( layerItem, mapLayer );
- break;
- case QgsMapLayer::RASTER:
- addRasterLayerItem( layerItem, mapLayer );
- break;
- default:
- break;
+ QStandardItem* currentSymbolItem = new QStandardItem( QIcon( rl->getLegendQPixmap( true ) ), "" );
+ parentItem->insertRow(0, currentSymbolItem);
+ parentItem->removeRow(1);
void QgsLegendModel::removeLayer( const QString& layerId )
@@ -380,7 +460,56 @@
emit layersChanged();
+QStandardItem* QgsLegendModel::itemFromSymbol(QgsSymbol* s)
+ QStandardItem* currentSymbolItem = 0;
+ //label
+ QString label;
+ QString lowerValue = s->lowerValue();
+ QString upperValue = s->upperValue();
+ if ( lowerValue == upperValue || upperValue.isEmpty() )
+ label = lowerValue;
+ else
+ label = lowerValue + " - " + upperValue;
+ //icon item
+ switch (s->type())
+ case QGis::Point:
+ currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage(s->getPointSymbolAsImage() ) ), label );
+ break;
+ case QGis::Line:
+ currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage(s->getLineSymbolAsImage() ) ), label );
+ break;
+ case QGis::Polygon:
+ currentSymbolItem = new QStandardItem( QIcon( QPixmap::fromImage(s->getPolygonSymbolAsImage() ) ), label );
+ break;
+ default:
+ currentSymbolItem = 0;
+ break;
+ return 0;
+ //Pass deep copy of QgsSymbol as user data. Cast to void* necessary such that QMetaType handles it
+ QgsSymbol* symbolCopy = new QgsSymbol(*s);
+ currentSymbolItem->setData( QVariant::fromValue(( void* )symbolCopy ) );
+ insertSymbol( symbolCopy );
+ currentSymbolItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
+ return currentSymbolItem;
bool QgsLegendModel::writeXML( QDomElement& composerLegendElem, QDomDocument& doc )
if ( composerLegendElem.isNull() )
Modified: trunk/qgis/src/core/composer/qgslegendmodel.h
--- trunk/qgis/src/core/composer/qgslegendmodel.h 2008-08-31 12:49:15 UTC (rev 9227)
+++ trunk/qgis/src/core/composer/qgslegendmodel.h 2008-08-31 13:10:14 UTC (rev 9228)
@@ -40,11 +40,14 @@
~QgsLegendModel();
void setLayerSet( const QStringList& layerIds );
- /**Apply added or removed layers to the model*/
- //void updateLayerEntries( const QStringList& newLayerIds );
- /**Updates the symbology of a single layer*/
- void updateLayer( const QString& layerId );
+ /**Tries to automatically update a model entry (e.g. a whole layer or only a single item)*/
+ void updateItem(QStandardItem* item);
+ /**Updates the whole symbology of a layer*/
+ void updateLayer(QStandardItem* layerItem);
+ /**Tries to update a single classification item*/
+ void updateVectorClassificationItem(QStandardItem* classificationItem, QgsSymbol* symbol, QString itemText);
+ void updateRasterClassificationItem(QStandardItem* classificationItem);
bool writeXML( QDomElement& composerLegendElem, QDomDocument& doc );
bool readXML( const QDomElement& legendModelElem, const QDomDocument& doc );
@@ -72,6 +75,9 @@
/**Removes and deletes all stored symbols*/
void removeAllSymbols();
+ /**Creates a model item for a vector symbol. The calling function takes ownership*/
+ QStandardItem* itemFromSymbol(QgsSymbol* s);
/**Keep track of copied symbols to delete them if not used anymore*/
QSet<QgsSymbol*> mSymbols;
