[QGIS Commit] r9754 - in trunk/qgis: python/core src/app src/core
svn_qgis at osgeo.org
Mon Dec 8 12:02:01 EST 2008
Author: mhugent
Date: 2008-12-08 12:02:01 -0500 (Mon, 08 Dec 2008)
New Revision: 9754
trunk/qgis/python/core/qgsvectorlayer.sip
trunk/qgis/src/app/qgsmaptoolselect.cpp
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/core/qgsvectorlayer.h
Applied patch from Borys to invert selection when ctrl-key pressed
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip 2008-12-08 13:59:07 UTC (rev 9753)
+++ trunk/qgis/python/core/qgsvectorlayer.sip 2008-12-08 17:02:01 UTC (rev 9754)
@@ -70,6 +70,9 @@
/** Select not selected features and deselect selected ones */
void invertSelection();
+ /** Invert selection of features found within the search rectangle (in layer's coordinates) */
+ void invertSelectionInRectangle( QgsRectangle & rect);
/** Get a copy of the user-selected features */
QList<QgsFeature> selectedFeatures();
Modified: trunk/qgis/src/app/qgsmaptoolselect.cpp
--- trunk/qgis/src/app/qgsmaptoolselect.cpp 2008-12-08 13:59:07 UTC (rev 9753)
+++ trunk/qgis/src/app/qgsmaptoolselect.cpp 2008-12-08 17:02:01 UTC (rev 9754)
@@ -114,9 +114,9 @@
QgsRectangle search( ll.x(), ll.y(), ur.x(), ur.y() );
- // if Ctrl key is pressed, selected features will be added to selection
+ // if Ctrl key is pressed, selected features will be flipped in selection
// instead of removing old selection
- bool lock = ( e->modifiers() & Qt::ControlModifier );
+ bool flip = ( e->modifiers() & Qt::ControlModifier );
// toLayerCoordinates will throw an exception for an 'invalid' rectangle.
// For example, if you project a world map onto a globe using EPSG 2163
@@ -136,6 +136,13 @@
QApplication::setOverrideCursor( Qt::WaitCursor );
- vlayer->select( search, lock );
+ if ( flip )
+ vlayer->invertSelectionInRectangle( search );
+ else
+ vlayer->select( search, false );
QApplication::restoreOverrideCursor();
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2008-12-08 13:59:07 UTC (rev 9753)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2008-12-08 17:02:01 UTC (rev 9754)
@@ -875,6 +875,29 @@
emit selectionChanged();
+void QgsVectorLayer::invertSelectionInRectangle( QgsRectangle & rect )
+ // normalize the rectangle
+ rect.normalize();
+ select( QgsAttributeList(), rect, false, true );
+ QgsFeature fet;
+ while ( nextFeature( fet ) )
+ if ( mSelectedFeatureIds.contains( fet.id() ) )
+ deselect( fet.id(), false ); // don't emit signal
+ else
+ select( fet.id(), false ); // don't emit signal
+ emit selectionChanged();
void QgsVectorLayer::removeSelection( bool emitSignal )
mSelectedFeatureIds.clear();
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2008-12-08 13:59:07 UTC (rev 9753)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2008-12-08 17:02:01 UTC (rev 9754)
@@ -132,6 +132,9 @@
QgsFeatureList selectedFeatures();
