[QGIS Commit] r9756 - trunk/qgis/doc
svn_qgis at osgeo.org
Tue Dec 9 06:16:27 EST 2008
Author: jef
Date: 2008-12-09 06:16:27 -0500 (Tue, 09 Dec 2008)
New Revision: 9756
trunk/qgis/doc/INSTALL.t2t
fix typos
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t 2008-12-09 07:11:54 UTC (rev 9755)
+++ trunk/qgis/doc/INSTALL.t2t 2008-12-09 11:16:27 UTC (rev 9756)
@@ -60,7 +60,7 @@
and getting involved in the project further.
/!\ ***Note to document writers:*** Please use this document as the central
-place for describing build procefures. Please do not remove this notice.
+place for describing build procedures. Please do not remove this notice.
/!\ ***Note:*** This is a 'cut and paste' tutorial - in most cases you can
simply copy the commands listed in codeblocks that look like this:
@@ -667,7 +667,7 @@
== Configure the build ==
CMake supports out of source build so we will create a 'build' dir for the
-build process . By convention I build my software into a dir called 'apps' in
+build process. By convention I build my software into a dir called 'apps' in
my home directory. If you have the correct permissions you may want to build
straight into your /Applications folder. The instructions below assume you are
building into a pre-existing ${HOME}/apps directory ...
@@ -974,7 +974,7 @@
you can install them using ``apt-get`` and re-run the command.
/!\ ***Note:*** If you have ``libqgis1-dev`` installed, you need to remove it first
-using ``dpkg -r libqgis1-dev``. Otherwise ``dpkg-buildpackage`` will complain about at
+using ``dpkg -r libqgis1-dev``. Otherwise ``dpkg-buildpackage`` will complain about a
build conflict.
The the packages are created in the parent directory (ie. one level up).
