[QGIS Commit] r9758 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Tue Dec 9 12:40:48 EST 2008
Author: macho
Date: 2008-12-09 12:40:48 -0500 (Tue, 09 Dec 2008)
New Revision: 9758
docs/trunk/english_us/user_guide/plugins_writing_in_cpp.tex
update by otto dassau
Modified: docs/trunk/english_us/user_guide/plugins_writing_in_cpp.tex
--- docs/trunk/english_us/user_guide/plugins_writing_in_cpp.tex 2008-12-09 17:36:12 UTC (rev 9757)
+++ docs/trunk/english_us/user_guide/plugins_writing_in_cpp.tex 2008-12-09 17:40:48 UTC (rev 9758)
@@ -2,24 +2,11 @@
% when the revision of a section has been finalized,
% comment out the following line:
-\updatedisclaimer
+%\updatedisclaimer
In this section we provide a beginner's tutorial for writing a simple QGIS
C++ plugin. It is based on a workshop held by Dr. Marco Hugentobler.
-\subsection{Why C++ and what about licensing}
-QGIS is written in C++ (noch ein bisschem mehr...).
-QGIS C++ plugins use functionalities of libqgis*.so libraries. As they are
-licensed under GNU GPL, QGIS C++ plugins must be licenced under the GPL, too.
-This means you may use your plugins for any purpose and you are not forced to
-publish them. If you do publish them however, they must be published under
-the conditions of the GPL license.
-\subsection{What are C++ plugins and how do they technically work}
QGIS C++ plugins are dynamically linked libraries (.so or .dll). They are
linked to QGIS at runtime when requested in the plugin manager and extend the
functionality of QGIS. They have access to the QGIS GUI and can be devided
@@ -36,6 +23,19 @@
have a few external 'C' functions for description and of course the
\method{classFactory} method.
+\subsection{Why C++ and what about licensing}
+QGIS itself is written in C++, so it also makes sense to write plugins in C++
+as well. It is an object-oriented programming (OOP) language that is viewed
+by many developers as a prefered language for creating large-scale
+applications.
+QGIS C++ plugins use functionalities of libqgis*.so libraries. As they are
+licensed under GNU GPL, QGIS C++ plugins must be licenced under the GPL, too.
+This means you may use your plugins for any purpose and you are not forced to
+publish them. If you do publish them however, they must be published under
+the conditions of the GPL license.
\subsection{Programming a QGIS C++ Plugin in four steps}
The example plugin is a point converter plugin and intentionally kept simple.
@@ -50,12 +50,13 @@
As a first step we create the \filename{QgsPointConverter.h} and
\filename{QgsPointConverter.cpp} files. Then we add virtual methods inherited
from QgisPlugin (but leave them empty for now), create necessary external 'C'
-methods and .pro file, which is a Qt mechanism to easily create Makefiles.
+methods and a .pro file, which is a Qt mechanism to easily create Makefiles.
Then we compile the sources, move the compiled library into the plugin folder
-and load the new plugin in the QGIS plugin manager.
+and load it in the QGIS plugin manager.
+\textbf{a) Create new pointconverter.pro file and add}:
\begin{verbatim}
-pointconverter.pro:
#base directory of the qgis installation
QGIS_DIR = /home/marco/src/qgis
@@ -63,14 +64,17 @@
CONFIG = qt
QT += xml qt3support
unix:LIBS += -L/$$QGIS_DIR/lib -lqgis_core -lqgis_gui
-INCLUDEPATH += $$QGIS_DIR/src/ui $$QGIS_DIR/src/plugins $$QGIS_DIR/src/gui $$QGIS_DIR/src/raster $$QGIS_DIR/src/core $$QGIS_DIR
+INCLUDEPATH += $$QGIS_DIR/src/ui $$QGIS_DIR/src/plugins $$QGIS_DIR/src/gui \
+ $$QGIS_DIR/src/raster $$QGIS_DIR/src/core $$QGIS_DIR
SOURCES = qgspointconverterplugin.cpp
HEADERS = qgspointconverterplugin.h
DEST = pointconverterplugin.so
DEFINES += GUI_EXPORT= CORE_EXPORT=
+\end{verbatim}
-qgspointconverterplugin.h:
+\textbf{b) Create new qgspointconverterplugin.h file and add}:
+\begin{verbatim}
#ifndef QGSPOINTCONVERTERPLUGIN_H
#define QGSPOINTCONVERTERPLUGIN_H
@@ -90,9 +94,11 @@
QgisInterface* mIface;
#endif
+\end{verbatim}
-qgspointconverterplugin.cpp:
+\textbf{c) Create new qgspointconverterplugin.cpp file and add}:
+\begin{verbatim}
#include "qgspointconverterplugin.h"
#ifdef WIN32
@@ -148,7 +154,6 @@
delete theQgsPointConverterPluginPointer;
\end{verbatim}
\minisec{Step 2: Create an icon, a button and a menu for the plugin}
@@ -156,11 +161,11 @@
This step includes adding a pointer to the QgisInterface object in the plugin
class. Then we create a QAction and a callback function (slot), add it to the
QGIS GUI using QgisIface::addToolBarIcon() and QgisIface::addPluginToMenu()
-and finally remove the QAction in the unload() method.
+and finally remove the QAction in the \method{unload()} method.
+\textbf{d) Open qgspointconverterplugin.h again and extend existing content to}:
\begin{verbatim}
-pointconverterplugin.h:
@@ -190,9 +195,11 @@
#endif
+\end{verbatim}
-pointconverterplugin.cpp:
+\textbf{e) Open qgspointconverterplugin.cpp again and extend existing content to}:
+\begin{verbatim}
#include "qgisinterface.h"
#include <QAction>
@@ -203,7 +210,8 @@
#define QGISEXTERN extern "C"
#endif
-QgsPointConverterPlugin::QgsPointConverterPlugin(QgisInterface* iface): mIface(iface), mAction(0)
+QgsPointConverterPlugin::QgsPointConverterPlugin(QgisInterface* iface): \
+ mIface(iface), mAction(0)
@@ -264,40 +272,42 @@
\end{verbatim}
\minisec{Step 3: Read point features from the active layer and write to text file}
To read the point features from the active layer we need to query the current
-layer and the location for the new text file. Then we iterate through all the
-features of the current layer, convert their geometries (vertices) to points,
-open a new text file and use QTextStream to write the x- and y-coordinates
+layer and the location for the new text file. Then we iterate through all
+features of the current layer, convert the geometries (vertices) to points,
+open a new file and use QTextStream to write the x- and y-coordinates
into it.
+\textbf{f) Open qgspointconverterplugin.h again and extend existing content to}
\begin{verbatim}
-additionally to the previous steps:
class QgsGeometry;
class QTextStream;
private:
-void convertPoint(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const;
-void convertMultiPoint(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const;
-void convertLineString(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const;
-void convertMultiLineString(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const;
-void convertPolygon(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const;
-void convertMultiPolygon(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const;
+void convertPoint(QgsGeometry* geom, const QString& attributeString, \
+ QTextStream& stream) const;
+void convertMultiPoint(QgsGeometry* geom, const QString& attributeString, \
+void convertLineString(QgsGeometry* geom, const QString& attributeString, \
+void convertMultiLineString(QgsGeometry* geom, const QString& attributeString, \
+void convertPolygon(QgsGeometry* geom, const QString& attributeString, \
+void convertMultiPolygon(QgsGeometry* geom, const QString& attributeString, \
+\end{verbatim}
+\textbf{g) Open qgspointconverterplugin.cpp again and extend existing content to}:
+\begin{verbatim}
#include "qgsgeometry.h"
#include "qgsvectordataprovider.h"
#include "qgsvectorlayer.h"
@@ -311,13 +321,17 @@
QgsMapLayer* theMapLayer = mIface->activeLayer();
if(!theMapLayer)
- QMessageBox::information(0, tr("no active layer"), tr("this plugin needs an active point vector layer to make conversions to points"), QMessageBox::Ok);
+ QMessageBox::information(0, tr("no active layer"), \
+ tr("this plugin needs an active point vector layer to make conversions \
+ to points"), QMessageBox::Ok);
return;
QgsVectorLayer* theVectorLayer = dynamic_cast<QgsVectorLayer*>(theMapLayer);
if(!theVectorLayer)
- QMessageBox::information(0, tr("no vector layer"), tr("this plugin needs an active point vector layer to make conversions to points"), QMessageBox::Ok);
+ QMessageBox::information(0, tr("no vector layer"), \
return;
@@ -343,7 +357,8 @@
return;
- theVectorLayer->select(provider->attributeIndexes(), theVectorLayer->extent(), true, false);
+ theVectorLayer->select(provider->attributeIndexes(), \
+ theVectorLayer->extent(), true, false);
//write header
theTextStream << "x,y";
@@ -363,32 +378,38 @@
case QGis::WKBPoint:
case QGis::WKBPoint25D:
- convertPoint(currentGeometry, featureAttributesString, theTextStream);
+ convertPoint(currentGeometry, featureAttributesString, \
+ theTextStream);
break;
case QGis::WKBMultiPoint:
case QGis::WKBMultiPoint25D:
- convertMultiPoint(currentGeometry, featureAttributesString, theTextStream);
+ convertMultiPoint(currentGeometry, featureAttributesString, \
+ theTextStream);
break;
case QGis::WKBLineString:
case QGis::WKBLineString25D:
- convertLineString(currentGeometry, featureAttributesString, theTextStream);
+ convertLineString(currentGeometry, featureAttributesString, \
+ theTextStream);
break;
case QGis::WKBMultiLineString:
case QGis::WKBMultiLineString25D:
- convertMultiLineString(currentGeometry, featureAttributesString, theTextStream);
+ convertMultiLineString(currentGeometry, featureAttributesString \
+ theTextStream);
break;
case QGis::WKBPolygon:
case QGis::WKBPolygon25D:
- convertPolygon(currentGeometry, featureAttributesString, theTextStream);
+ convertPolygon(currentGeometry, featureAttributesString, \
+ theTextStream);
break;
case QGis::WKBMultiPolygon:
case QGis::WKBMultiPolygon25D:
- convertMultiPolygon(currentGeometry, featureAttributesString, theTextStream);
+ convertMultiPolygon(currentGeometry, featureAttributesString, \
+ theTextStream);
break;
@@ -396,14 +417,16 @@
//geometry converter functions
-void QgsPointConverterPlugin::convertPoint(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const
+void QgsPointConverterPlugin::convertPoint(QgsGeometry* geom, const QString& \
+attributeString, QTextStream& stream) const
QgsPoint p = geom->asPoint();
stream << p.x() << "," << p.y();
stream << endl;
-void QgsPointConverterPlugin::convertMultiPoint(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const
+void QgsPointConverterPlugin::convertMultiPoint(QgsGeometry* geom, const QString& \
QgsMultiPoint mp = geom->asMultiPoint();
QgsMultiPoint::const_iterator it = mp.constBegin();
@@ -414,7 +437,8 @@
-void QgsPointConverterPlugin::convertLineString(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const
+void QgsPointConverterPlugin::convertLineString(QgsGeometry* geom, const QString& \
QgsPolyline line = geom->asPolyline();
QgsPolyline::const_iterator it = line.constBegin();
@@ -425,7 +449,8 @@
-void QgsPointConverterPlugin::convertMultiLineString(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const
+void QgsPointConverterPlugin::convertMultiLineString(QgsGeometry* geom, const QString& \
QgsMultiPolyline ml = geom->asMultiPolyline();
QgsMultiPolyline::const_iterator lineIt = ml.constBegin();
@@ -441,7 +466,8 @@
-void QgsPointConverterPlugin::convertPolygon(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const
+void QgsPointConverterPlugin::convertPolygon(QgsGeometry* geom, const QString& \
QgsPolygon polygon = geom->asPolygon();
QgsPolygon::const_iterator it = polygon.constBegin();
@@ -457,7 +483,8 @@
-void QgsPointConverterPlugin::convertMultiPolygon(QgsGeometry* geom, const QString& attributeString, QTextStream& stream) const
+void QgsPointConverterPlugin::convertMultiPolygon(QgsGeometry* geom, const QString& \
QgsMultiPolygon mp = geom->asMultiPolygon();
QgsMultiPolygon::const_iterator polyIt = mp.constBegin();
@@ -477,24 +504,20 @@
\end{verbatim}
\minisec{Step 4: Copy the feature attributes to the text file}
At the end we extract the attributes from the active layer using
QgsVectorDataProvider::fieldNameMap(). For each feature we extract the field
values using QgsFeature::attributeMap() and add the contents comma separated
-behind the x- and y-coordinates for each new point feature.
+behind the x- and y-coordinates for each new point feature. For this step
+there is no need for any furter change in \filename{qgspointconverterplugin.h}
-\begin{verbatim}
-no change for qgspointconverterplugin.h:
+\textbf{h) Open qgspointconverterplugin.cpp again and extend existing content
+to}:
-source for qgspointconverterplugin.cpp:
+\begin{verbatim}
@@ -511,7 +534,8 @@
#endif
+mIface(iface), mAction(0)
@@ -542,13 +566,17 @@
if(!theMapLayer)
return;
if(!theVectorLayer)
return;
@@ -574,7 +602,8 @@
return;
//write header
@@ -618,32 +647,38 @@
+ theTextStream);
break;
+ theTextStream);
break;
+ theTextStream);
break;
+ theTextStream);
break;
+ theTextStream);
break;
+ theTextStream);
break;
@@ -651,7 +686,8 @@
@@ -659,7 +695,8 @@
stream << endl;
@@ -671,7 +708,8 @@
@@ -683,7 +721,8 @@
@@ -700,7 +739,8 @@
@@ -717,7 +757,8 @@
