[QGIS Commit] r8158 - branches/ogr-plugin-branch/src/app
svn_qgis at osgeo.org
Thu Feb 14 11:48:13 EST 2008
Author: gcontreras
Date: 2008-02-14 11:48:13 -0500 (Thu, 14 Feb 2008)
New Revision: 8158
Added:
branches/ogr-plugin-branch/src/app/qgsnewogrgenericconnection.cpp
branches/ogr-plugin-branch/src/app/qgsnewogrgenericconnection.h
branches/ogr-plugin-branch/src/app/CMakeLists.txt
Implementation of NewOgrGenericConnection dialog
Modified: branches/ogr-plugin-branch/src/app/CMakeLists.txt
--- branches/ogr-plugin-branch/src/app/CMakeLists.txt 2008-02-14 15:37:19 UTC (rev 8157)
+++ branches/ogr-plugin-branch/src/app/CMakeLists.txt 2008-02-14 16:48:13 UTC (rev 8158)
@@ -37,6 +37,7 @@
qgsmeasuredialog.cpp
qgsmeasuretool.cpp
qgsnewhttpconnection.cpp
+qgsnewogrgenericconnection.cpp
qgsnumericsortlistviewitem.cpp
qgsoptions.cpp
qgspastetransformations.cpp
@@ -64,6 +65,12 @@
composer/qgscomposerview.cpp
composer/qgscomposition.cpp
+dbutilities/qgsconnectionregistry.cpp
+dbutilities/qgsdatabaseconnection.cpp
+dbutilities/qgsgeomcolumntypethread.cpp
+dbutilities/qgsogrdatabaseconnection.cpp
+dbutilities/qgspostgresdatabaseconnection.cpp
legend/qgslegendgroup.cpp
legend/qgslegend.cpp
legend/qgslegenditem.cpp
@@ -106,6 +113,7 @@
qgsmarkerdialog.h
qgsmeasuredialog.h
qgsnewhttpconnection.h
+qgsnewogrgenericconnection.h
qgsoptions.h
qgspastetransformations.h
qgspatterndialog.h
@@ -193,7 +201,7 @@
INCLUDE_DIRECTORIES(
- ${CMAKE_CURRENT_SOURCE_DIR} composer legend
+ ${CMAKE_CURRENT_SOURCE_DIR} composer legend dbutilities
${CMAKE_CURRENT_BINARY_DIR}
${CMAKE_CURRENT_BINARY_DIR}/../ui
../core
Added: branches/ogr-plugin-branch/src/app/qgsnewogrgenericconnection.cpp
--- branches/ogr-plugin-branch/src/app/qgsnewogrgenericconnection.cpp (rev 0)
+++ branches/ogr-plugin-branch/src/app/qgsnewogrgenericconnection.cpp 2008-02-14 16:48:13 UTC (rev 8158)
@@ -0,0 +1,109 @@
+ qgsnewogrgenericconnection.cpp - description
+ begin : Wen Jan 08 2008
+ copyright : (C) 2008 by Godofredo Contreras
+ email : frdcn at hotmail.com
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+ /* $Id: qgsnewogrconnection.cpp 7413 2007-11-15 19:34:15Z godofredo $ */
+#include <iostream>
+#include <QSettings>
+#include <QMessageBox>
+#include "qgsnewogrgenericconnection.h"
+#include "qgscontexthelp.h"
+extern "C"
+#include <libpq-fe.h>
+QgsNewOgrGenericConnection::QgsNewOgrGenericConnection(QWidget *parent, const QgsConnectionParameters* conn, Qt::WFlags fl)
+: QDialog(parent, fl)
+ setupUi(this);
+ //create member objects
+ mConnReg=new QgsConnectionRegistry;
+ if (conn!=NULL)
+ txtName->setText(conn->name);
+ txtUri->setText(conn->uri);
+/** Autoconnected SLOTS **/
+void QgsNewOgrGenericConnection::on_btnOk_clicked()
+ saveConnection();
+void QgsNewOgrGenericConnection::on_btnHelp_clicked()
+ helpInfo();
+void QgsNewOgrGenericConnection::on_btnConnect_clicked()
+ testConnection();
+void QgsNewOgrGenericConnection::on_btnCancel_clicked(){
+ // cancel the dialog
+ reject();
+/** end Autoconnected SLOTS **/
+QgsNewOgrGenericConnection::~QgsNewOgrGenericConnection()
+ delete mConnReg;
+void QgsNewOgrGenericConnection::testConnection()
+ QgsConnectionParameters connPar;
+ connPar.type="OgrGeneric";
+ connPar.name=txtName->text();
+ connPar.uri=txtUri->text();
+ QgsDatabaseConnection* connection=new QgsOgrDatabaseConnection(&connPar);
+ connection->setUri(txtUri->text());
+ if (connection->connect())
+ // Database successfully opened; we can now issue SQL commands.
+ QMessageBox::information(this, tr("Test connection"), tr("Connection to %1 was successful").arg(txtUri->text()));
+ } else
+ QMessageBox::information(this, tr("Test connection"), tr("Connection failed - Check settings and try again.\n\nExtended error information:\n") +connection->error());
+ qDebug("Step three");
+ delete connection;
+void QgsNewOgrGenericConnection::saveConnection()
+ QgsConnectionParameters conn;
+ conn.type="OgrGeneric";
+ conn.name=txtName->text();
+ conn.uri=txtUri->text();
+ mConnReg->saveConnection(conn);
+ mConnReg->setSelectedType(conn.type);
+ mConnReg->setSelected(conn.type,conn.name);
+ accept();
+void QgsNewOgrGenericConnection::helpInfo()
+ QgsContextHelp::run(context_id);
Added: branches/ogr-plugin-branch/src/app/qgsnewogrgenericconnection.h
--- branches/ogr-plugin-branch/src/app/qgsnewogrgenericconnection.h (rev 0)
+++ branches/ogr-plugin-branch/src/app/qgsnewogrgenericconnection.h 2008-02-14 16:48:13 UTC (rev 8158)
@@ -0,0 +1,55 @@
+#ifndef QGSNEWOGRGENERICCONNECTION_H
+#define QGSNEWOGRGENERICCONNECTION_H
+#include "ui_qgsnewogrgenericconnectionbase.h"
+#include "qgisgui.h"
+#include "qgsconnectionparameters.h"
+#include "qgsconnectionregistry.h"
+#include "qgsdatabaseconnection.h"
+#include "qgsogrdatabaseconnection.h"
+/*! \class QgsNewConnection
+ * \brief Dialog to allow the user to configure and save connection
+ * information for a PostgresQl database
+class QgsNewOgrGenericConnection : public QDialog, private Ui::QgsNewOgrGenericConnectionBase
+ Q_OBJECT
+ public:
+ //! Constructor
+ QgsNewOgrGenericConnection(QWidget *parent = 0, const QgsConnectionParameters* conn=0, Qt::WFlags fl = QgisGui::ModalDialogFlags);
+ //! Destructor
+ ~QgsNewOgrGenericConnection();
+ //! Tests the connection using the parameters supplied
+ void testConnection();
+ //! Saves the connection to ~/.qt/qgisrc
+ void saveConnection();
+ //! Display the context help
+ void helpInfo();
+ public slots:
+ void on_btnOk_clicked();
+ void on_btnCancel_clicked();
+ void on_btnHelp_clicked();
+ void on_btnConnect_clicked();
+ //void on_cb_geometryColumnsOnly_clicked();
+ private:
+ QgsConnectionRegistry* mConnReg;
+ static const int context_id = 929865718;
+#endif // QGSNEWCONNECTIONBASE_H
