[QGIS Commit] r8160 - in branches/ogr-plugin-branch/src: app
app/dbutilities core ui
svn_qgis at osgeo.org
Fri Feb 15 16:20:18 EST 2008
Author: gcontreras
Date: 2008-02-15 16:20:17 -0500 (Fri, 15 Feb 2008)
New Revision: 8160
branches/ogr-plugin-branch/src/app/CMakeLists.txt
branches/ogr-plugin-branch/src/app/dbutilities/qgsogrdatabaseconnection.cpp
branches/ogr-plugin-branch/src/app/dbutilities/qgspostgresdatabaseconnection.cpp
branches/ogr-plugin-branch/src/app/qgsdbsourceselect.cpp
branches/ogr-plugin-branch/src/app/qgsdbsourceselect.h
branches/ogr-plugin-branch/src/app/qgsnewconnection.cpp
branches/ogr-plugin-branch/src/app/qgsnewconnection.h
branches/ogr-plugin-branch/src/core/qgsdatasourceuri.cpp
branches/ogr-plugin-branch/src/ui/qgsdbsourceselectbase.ui
Changes to adapt newconnection dialog to work with
the new dbutility classes
Modified: branches/ogr-plugin-branch/src/app/CMakeLists.txt
--- branches/ogr-plugin-branch/src/app/CMakeLists.txt 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/app/CMakeLists.txt 2008-02-15 21:20:17 UTC (rev 8160)
@@ -16,6 +16,8 @@
qgsclipboard.cpp
qgscontinuouscolordialog.cpp
qgscustomprojectiondialog.cpp
+qgsdbfilterproxymodel.cpp
+qgsdbtablemodel.cpp
qgsdelattrdialog.cpp
qgsfillstylewidget.cpp
qgsgeomtypedialog.cpp
Modified: branches/ogr-plugin-branch/src/app/dbutilities/qgsogrdatabaseconnection.cpp
--- branches/ogr-plugin-branch/src/app/dbutilities/qgsogrdatabaseconnection.cpp 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/app/dbutilities/qgsogrdatabaseconnection.cpp 2008-02-15 21:20:17 UTC (rev 8160)
@@ -70,7 +70,8 @@
else
uri=this->uri();
+ qDebug("inche uri:"+uri);
//clean all previous errors
CPLErrorReset();
// Register all OGR-drivers
Modified: branches/ogr-plugin-branch/src/app/dbutilities/qgspostgresdatabaseconnection.cpp
--- branches/ogr-plugin-branch/src/app/dbutilities/qgspostgresdatabaseconnection.cpp 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/app/dbutilities/qgspostgresdatabaseconnection.cpp 2008-02-15 21:20:17 UTC (rev 8160)
@@ -54,7 +54,7 @@
" port=" + mConnectionParameters->port +
" user=" + mConnectionParameters->user +
" password='" + pass + "'";
- PGconn *pd = PQconnectdb(connInfo.toLocal8Bit().data());
+ pd = PQconnectdb(connInfo.toLocal8Bit().data());
// std::cout << pd->ErrorMessage();
if (PQstatus(pd) == CONNECTION_OK)
@@ -70,7 +70,6 @@
result=false;
return result;
Modified: branches/ogr-plugin-branch/src/app/qgsdbsourceselect.cpp
--- branches/ogr-plugin-branch/src/app/qgsdbsourceselect.cpp 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/app/qgsdbsourceselect.cpp 2008-02-15 21:20:17 UTC (rev 8160)
@@ -20,10 +20,13 @@
#include "qgsdbsourceselect.h"
#include "qgisapp.h"
+#include "qgslogger.h"
#include "qgsapplication.h"
#include "qgscontexthelp.h"
#include "qgsnewconnection.h"
+#include "qgsnewogrgenericconnection.h"
#include "qgspgquerybuilder.h"
+#include "qgsdatasourceuri.h"
#include <QInputDialog>
#include <QMessageBox>
@@ -39,92 +42,77 @@
QgsDbSourceSelect::QgsDbSourceSelect(QgisApp *app, Qt::WFlags fl)
: QDialog(app, fl), mColumnTypeThread(NULL), qgisApp(app), pd(0)
+ //create member objects
+ mConnectionRegistry=new QgsConnectionRegistry;
setupUi(this);
+ btnAdd->setEnabled(false);
+ //get last connection type used
+ QString connType=mConnectionRegistry->selectedType();
+ populateConnectionList(connType);
+ setConnectionListPosition();
//connect
connect(cmbType,SIGNAL(currentIndexChanged(QString)),this,SLOT(populateConnectionList(QString)));
- btnAdd->setEnabled(false);
- //create connection manager
- mConnMan=new QgsConnectionManager;
- QString conType=mConnMan->getSelectedType();
+ QString conType=mConnectionRegistry->selectedType();
populateConnectionList(conType);
- //loadConnections("PostgreSQL");
- // connect the double-click signal to the addSingleLayer slot in the parent
+ mSearchModeComboBox->addItem(tr("Wildcard"));
+ mSearchModeComboBox->addItem(tr("RegExp"));
- //disable the 'where clause' box for 0.4 release
- // groupBox3->hide();
- //insert the encoding types available in qt
- mEncodingComboBox->insertItem("BIG5");
- mEncodingComboBox->insertItem("BIG5-HKSCS");
- mEncodingComboBox->insertItem("EUCJP");
- mEncodingComboBox->insertItem("EUCKR");
- mEncodingComboBox->insertItem("GB2312");
- mEncodingComboBox->insertItem("GBK");
- mEncodingComboBox->insertItem("GB18030");
- mEncodingComboBox->insertItem("JIS7");
- mEncodingComboBox->insertItem("SHIFT-JIS");
- mEncodingComboBox->insertItem("TSCII");
- mEncodingComboBox->insertItem("UTF-8");
- mEncodingComboBox->insertItem("UTF-16");
- mEncodingComboBox->insertItem("KOI8-R");
- mEncodingComboBox->insertItem("KOI8-U");
- mEncodingComboBox->insertItem("ISO8859-1");
- mEncodingComboBox->insertItem("ISO8859-2");
- mEncodingComboBox->insertItem("ISO8859-3");
- mEncodingComboBox->insertItem("ISO8859-4");
- mEncodingComboBox->insertItem("ISO8859-5");
- mEncodingComboBox->insertItem("ISO8859-6");
- mEncodingComboBox->insertItem("ISO8859-7");
- mEncodingComboBox->insertItem("ISO8859-8");
- mEncodingComboBox->insertItem("ISO8859-8-I");
- mEncodingComboBox->insertItem("ISO8859-9");
- mEncodingComboBox->insertItem("ISO8859-10");
- mEncodingComboBox->insertItem("ISO8859-13");
- mEncodingComboBox->insertItem("ISO8859-14");
- mEncodingComboBox->insertItem("ISO8859-15");
- mEncodingComboBox->insertItem("IBM 850");
- mEncodingComboBox->insertItem("IBM 866");
- mEncodingComboBox->insertItem("CP874");
- mEncodingComboBox->insertItem("CP1250");
- mEncodingComboBox->insertItem("CP1251");
- mEncodingComboBox->insertItem("CP1252");
- mEncodingComboBox->insertItem("CP1253");
- mEncodingComboBox->insertItem("CP1254");
- mEncodingComboBox->insertItem("CP1255");
- mEncodingComboBox->insertItem("CP1256");
- mEncodingComboBox->insertItem("CP1257");
- mEncodingComboBox->insertItem("CP1258");
- mEncodingComboBox->insertItem("Apple Roman");
- mEncodingComboBox->insertItem("TIS-620");
+ mSearchColumnComboBox->addItem(tr("All"));
+ mSearchColumnComboBox->addItem(tr("Schema"));
+ mSearchColumnComboBox->addItem(tr("Table"));
+ mSearchColumnComboBox->addItem(tr("Type"));
+ mSearchColumnComboBox->addItem(tr("Geometry column"));
+ mSearchColumnComboBox->addItem(tr("Sql"));
- //read the last encoding from the settings
- //or use local as default
- QSettings settings;
- QString lastUsedEncoding = settings.readEntry("/UI/encoding");
- if(lastUsedEncoding.isNull()||lastUsedEncoding.isEmpty()||lastUsedEncoding=="\0")
- mEncodingComboBox->setCurrentText(QString(QTextCodec::codecForLocale()->name()));
- else
- mEncodingComboBox->setCurrentText(lastUsedEncoding);
+ mProxyModel.setParent(this);
+ mProxyModel.setFilterKeyColumn(-1);
+ mProxyModel.setFilterCaseSensitivity(Qt::CaseInsensitive);
+ mProxyModel.setDynamicSortFilter(true);
+ mProxyModel.setSourceModel(&mTableModel);
+ mTablesTreeView->setModel(&mProxyModel);
+ mTablesTreeView->setSortingEnabled(true);
- // Do some things that couldn't be done in designer
- lstTables->horizontalHeader()->setStretchLastSection(true);
- // Set the column count to 3 for the type, name, and sql
- lstTables->setColumnCount(3);
- mColumnLabels += tr("Type");
- mColumnLabels += tr("Name");
- mColumnLabels += tr("Sql");
- lstTables->setHorizontalHeaderLabels(mColumnLabels);
- lstTables->verticalHeader()->hide();
+ mSearchGroupBox->hide();
+ connect(mTablesTreeView, SIGNAL(doubleClicked(const QModelIndex&)), this, SLOT(setSql(const QModelIndex&)));
+ //for Qt < 4.3.2, passing -1 to include all model columns
+ //in search does not seem to work
+ mSearchColumnComboBox->setCurrentIndex(2);
+ /*setupUi(this);
+ populateConnectionList();
+ mSearchColumnComboBox->setCurrentIndex(2);*/
/** Autoconnected SLOTS **/
// Slot for adding a new connection
@@ -143,12 +131,6 @@
addTables();
-// Slot for opening the query builder when a layer is double clicked
-void QgsDbSourceSelect::on_lstTables_itemDoubleClicked(QTableWidgetItem *item)
- setSql(item);
// Slot for editing a connection
void QgsDbSourceSelect::on_btnEdit_clicked()
@@ -162,144 +144,300 @@
/** End Autoconnected SLOTS **/
-//remember what type is selected
-void QgsDbSourceSelect::on_cmbType_activated(int)
- dbChanged();
// Remember which database is selected
void QgsDbSourceSelect::on_cmbConnections_activated(int)
dbChanged();
-void QgsDbSourceSelect::setLayerType(QString schema,
- QString table, QString column,
- QString type)
+void QgsDbSourceSelect::on_mSearchOptionsButton_clicked()
-#ifdef QGISDEBUG
- std::cerr << "Received layer type of " << type.toLocal8Bit().data()
- << " for "
- << (schema+'.'+table+'.'+column).toLocal8Bit().data()
- << '\n';
-#endif
+ if(mSearchGroupBox->isVisible())
+ else
+ mSearchGroupBox->show();
- // Find the right row in the table by searching for the text that
- // was put into the Name column.
- QString full_desc = fullDescription(schema, table, column);
+void QgsDbSourceSelect::on_mSearchTableEdit_textChanged(const QString & text)
+ if(mSearchModeComboBox->currentText() == tr("Wildcard"))
+ mProxyModel._setFilterWildcard(text);
+ else if(mSearchModeComboBox->currentText() == tr("RegExp"))
+ mProxyModel._setFilterRegExp(text);
- QList<QTableWidgetItem*> ii = lstTables->findItems(full_desc,
- Qt::MatchExactly);
- if (ii.count() > 0)
- int row = lstTables->row(ii.at(0)); // just use the first one
- QTableWidgetItem* iconItem = lstTables->item(row, 0);
- // Get the icon and tooltip text
- const QIcon* p;
- QString toolTipText;
- if (mLayerIcons.contains(type))
+void QgsDbSourceSelect::on_mSearchColumnComboBox_currentIndexChanged(const QString & text)
+ if(text == tr("All"))
- p = &(mLayerIcons.value(type).second);
- toolTipText = mLayerIcons.value(type).first;
- else
+ else if(text == tr("Schema"))
- qDebug(("Unknown geometry type of '" + type + "'.").toLocal8Bit().data());
- p = &(mLayerIcons.value("UNKNOWN").second);
- toolTipText = mLayerIcons.value("UNKNOWN").first;
+ mProxyModel.setFilterKeyColumn(0);
+ else if(text == tr("Table"))
+ mProxyModel.setFilterKeyColumn(1);
+ else if(text == tr("Type"))
+ mProxyModel.setFilterKeyColumn(2);
+ else if(text == tr("Geometry column"))
+ mProxyModel.setFilterKeyColumn(3);
+ else if(text == tr("Sql"))
+ mProxyModel.setFilterKeyColumn(4);
- iconItem->setIcon(*p);
- iconItem->setToolTip(toolTipText);
+void QgsDbSourceSelect::on_mSearchModeComboBox_currentIndexChanged(const QString & text)
+ on_mSearchTableEdit_textChanged(mSearchTableEdit->text());
+void QgsDbSourceSelect::setLayerType(QString schema,
+ QString table, QString column,
+ QString type)
+ mTableModel.setGeometryTypesForTable(schema, table, column, type);
+ mTablesTreeView->sortByColumn(1, Qt::AscendingOrder);
+ mTablesTreeView->sortByColumn(0, Qt::AscendingOrder);
+QString QgsDbSourceSelect::makeGeomQuery(QString schema,
+ QString table, QString column)
+ return QString("select distinct "
+ "case"
+ " when geometrytype(%1) IN ('POINT','MULTIPOINT') THEN 'POINT'"
+ " when geometrytype(%1) IN ('LINESTRING','MULTILINESTRING') THEN 'LINESTRING'"
+ " when geometrytype(%1) IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON'"
+ " end "
+ "from \"%2\".\"%3\"").arg(column).arg(schema).arg(table);
QgsDbSourceSelect::~QgsDbSourceSelect()
- delete mConnMan;
PQfinish(pd);
void QgsDbSourceSelect::populateConnectionList(QString type)
- qDebug("QgsDbSourceSelect::populateConnectionList : type "+type);
+ /*QSettings settings;
+ QStringList keys = settings.subkeyList("/PostgreSQL/connections");
+ QStringList::Iterator it = keys.begin();
+ cmbConnections->clear();
+ while (it != keys.end())
+ cmbConnections->insertItem(*it);
+ ++it;
- QStringList connlist=mConnMan->getConnections(type);
+ setConnectionListPosition();*/
+ qDebug("solo para checar");
+ QStringList connlist=mConnectionRegistry->connectionParametersList(type);
//add the results to combo
for (int i = 0; i < connlist.size(); ++i)
cmbConnections->addItem(connlist.at(i));
- cmbType->setCurrentIndex(cmbType->findText(type));
+ cmbType->setCurrentIndex(cmbType->findText(type));
void QgsDbSourceSelect::addNewConnection()
- QgsNewConnection *nc = new QgsNewConnection(this);
+ /*QgsNewConnection *nc = new QgsNewConnection(this);
if (nc->exec())
- populateConnectionList(cmbType->currentText());
+ QString type=cmbType->currentText();
+ if (type.contains("OgrGeneric"))
+ QgsNewOgrGenericConnection *noc = new QgsNewOgrGenericConnection(this);
+ if (noc->exec())
+ populateConnectionList(cmbType->currentText());
+ else
+ QgsNewConnection *nc = new QgsNewConnection(this);
+ if (nc->exec())
void QgsDbSourceSelect::editConnection()
- QgsConnection conn=mConnMan->getConnectionDetails(cmbType->currentText(),cmbConnections->currentText());
- QgsNewConnection *nc = new QgsNewConnection(this, &conn);
+ /*QgsNewConnection *nc = new QgsNewConnection(this, cmbConnections->currentText());
if (nc->exec())
nc->saveConnection();
+ QgsConnectionParameters conn=mConnectionRegistry->connectionParameters(type,cmbConnections->currentText());
+ QgsNewOgrGenericConnection *noc = new QgsNewOgrGenericConnection(this,&conn);
+ if (noc->exec())
+ noc->saveConnection();
+ else
+ QgsNewConnection *nc = new QgsNewConnection(this,&conn);
+ if (nc->exec())
+ nc->saveConnection();
void QgsDbSourceSelect::deleteConnection()
- mConnMan->removeConnection(cmbType->currentText(),cmbConnections->currentText());
+ QSettings settings;
+ QString key = "/Postgresql/connections/" + cmbConnections->currentText();
+ QString msg =
+ tr("Are you sure you want to remove the ") + cmbConnections->currentText() + tr(" connection and all associated settings?");
+ QMessageBox::StandardButton result = QMessageBox::information(this, tr("Confirm Delete"), msg, QMessageBox::Ok | QMessageBox::Cancel);
+ if (result == QMessageBox::Ok)
+ settings.removeEntry(key + "/host");
+ settings.removeEntry(key + "/database");
+ settings.removeEntry(key + "/username");
+ settings.removeEntry(key + "/password");
+ settings.removeEntry(key + "/port");
+ settings.removeEntry(key + "/save");
+ settings.removeEntry(key);
+ //if(!success){
+ // QMessageBox::information(this,"Unable to Remove","Unable to remove the connection " + cmbConnections->currentText());
+ cmbConnections->removeItem(cmbConnections->currentItem()); // populateConnectionList();
void QgsDbSourceSelect::addTables()
- QString type=cmbType->currentText();
+ m_selectedTables.clear();
+ typedef QMap<int, QVector<QString> > schemaInfo;
+ QMap<QString, schemaInfo> dbInfo;
+ QItemSelection selection = mTablesTreeView->selectionModel()->selection();
+ QModelIndexList selectedIndices = selection.indexes();
+ QStandardItem* currentItem = 0;
+ QModelIndexList::const_iterator selected_it = selectedIndices.constBegin();
+ for(; selected_it != selectedIndices.constEnd(); ++selected_it)
+ if(!selected_it->parent().isValid())
+ //top level items only contain the schema names
+ continue;
+ currentItem = mTableModel.itemFromIndex(mProxyModel.mapToSource(*selected_it));
+ if(!currentItem)
+ continue;
+ QString currentSchemaName = currentItem->parent()->text();
+ int currentRow = currentItem->row();
+ int currentColumn = currentItem->column();
+ if(dbInfo[currentSchemaName][currentRow].size() == 0)
+ dbInfo[currentSchemaName][currentRow].resize(5);
+ dbInfo[currentSchemaName][currentRow][currentColumn] = currentItem->text();
- //store the table info
+ //now traverse all the schemas and table infos
+ QString schemaName, tableName, geomColumnName, sql;
+ QString query;
- for (int i = 0; i < lstTables->rowCount(); ++i)
- if (lstTables->isItemSelected(lstTables->item(i, 0)))
+ QMap<QString, schemaInfo>::const_iterator schema_it = dbInfo.constBegin();
+ for(; schema_it != dbInfo.constEnd(); ++schema_it)
- QString table;
- //if(type.contains("Ogr",FALSE)>0)
- // table = lstTables->item(i,1)->text();
- //else
- table = lstTables->item(i,1)->text() + " sql=";
- QTableWidgetItem* sqlItem = lstTables->item(i,2);
- if (sqlItem)
- table += sqlItem->text();
- m_selectedTables += table;
+ schemaInfo scheme = schema_it.value();
+ schemaInfo::const_iterator entry_it = scheme.constBegin();
+ for(; entry_it != scheme.constEnd(); ++entry_it)
+ schemaName = entry_it->at(0);
+ tableName = entry_it->at(1);
+ geomColumnName = entry_it->at(3);
+ sql = entry_it->at(4);
+ if(geomColumnName.contains(" AS "))
+ int a = geomColumnName.find(" AS ");
+ QString typeName = geomColumnName.mid(a+4); //only the type name
+ geomColumnName = geomColumnName.mid(0, a); //only the geom column name
+ if(!sql.isEmpty())
+ sql += " AND ";
+ if( typeName=="POINT" )
+ sql += QString("GeometryType(\"%1\") IN ('POINT','MULTIPOINT')").arg(geomColumnName);
+ else if(typeName=="LINESTRING")
+ sql += QString("GeometryType(\"%1\") IN ('LINESTRING','MULTILINESTRING')").arg(geomColumnName);
+ else if(typeName=="POLYGON")
+ sql += QString("GeometryType(\"%1\") IN ('POLYGON','MULTIPOLYGON')").arg(geomColumnName);
+ else
+ continue;
+ query = "\"" + schemaName + "\".\"" + tableName + "\" " + "(" + geomColumnName + ") sql=" + sql;
+ m_selectedTables.push_back(query);
- // BEGIN CHANGES ECOS
- if (m_selectedTables.empty() == true)
- QMessageBox::information(this, tr("Select Table"), tr("You must select a table in order to add a Layer."));
+ if(m_selectedTables.empty())
+ QMessageBox::information(this, tr("Select Table"), tr("You must select a table in order to add a Layer."));
else
- accept();
- // END CHANGES ECOS
+ accept();
void QgsDbSourceSelect::on_btnConnect_clicked()
- qDebug("QgsDbSourceSelect::on_btnConnect_clicked");
+ disconnect();
+ QModelIndex rootItemIndex = mTableModel.indexFromItem(mTableModel.invisibleRootItem());
+ mTableModel.removeRows(0, mTableModel.rowCount(rootItemIndex), rootItemIndex);
+ QgsConnectionParameters conn=mConnectionRegistry->connectionParameters(cmbType->currentText(),cmbConnections->currentText());
bool makeConnection=true;
if (conn.password == QString::null)
@@ -314,106 +452,173 @@
conn.password=password;
- if (mConnMan->connect(cmbType->currentText(),conn))
+ bool searchPublicOnly = conn.publicOnly;
+ bool searchGeometryColumnsOnly = conn.geometryColumnsOnly;
+ QgsDataSourceURI uri;
+ uri.setConnection(conn.type,
+ conn.host,
+ conn.port,
+ conn.database,
+ conn.user,
+ conn.password );
+ if (makeConnection)
+ m_connInfo = uri.connInfo();
+ if (type.startsWith("Ogr"))
+ mDatabaseConnection= new QgsOgrDatabaseConnection(&conn);
+ else
+ mDatabaseConnection= new QgsPostgresDatabaseConnection(&conn);
+ if (mDatabaseConnection->connect())
+ //load geometry tables to view
+ //qDebug("Unable to get list of spatially enabled tables from the database");
+ //qDebug(PQerrorMessage(pd));
+ else
+ QMessageBox::warning(this, tr("Connection failed"),
+ tr
+ ("Connection to %1 on %2 failed. Either the database is down or your settings are incorrect.%3Check your username and password and try again.%4The database said:%5%6").
+ arg(conn.database).arg(conn.host).arg("\n\n").arg("\n\n").arg("\n").arg(mDatabaseConnection->error()));
+ if (cmbConnections->count() > 0)
+ btnAdd->setEnabled(true);
+ //if we have only one schema item, expand it by default
+ int numTopLevelItems = mTableModel.invisibleRootItem()->rowCount();
+ if(numTopLevelItems < 2 || mTableModel.tableCount() < 20)
- // Database successfully opened; we can now issue SQL commands.
- // create the pixmaps for the layer types if we haven't already
- // done so.
- m_connInfo="type="+conn.type
- +" host="+conn.host
- +" dbname="+conn.database
- +" port="+conn.port
- +" user="+conn.user
- +" password='"+conn.password+"'";
- if (mLayerIcons.count() == 0)
- QString myThemePath = QgsApplication::themePath();
- mLayerIcons.insert("POINT",
- qMakePair(tr("Point layer"),
- QIcon(myThemePath+"/mIconPointLayer.png")));
- mLayerIcons.insert("MULTIPOINT",
- qMakePair(tr("Multi-point layer"),
- mLayerIcons.value("POINT").second));
+ //expand all the toplevel items
+ for(int i = 0; i < numTopLevelItems; ++i)
+ mTablesTreeView->expand(mProxyModel.mapFromSource(mTableModel.indexFromItem(mTableModel.invisibleRootItem()->child(i))));
+ /*if(mColumnTypeThread)
+ mColumnTypeThread->stop();
+ mColumnTypeThread=0;
- mLayerIcons.insert("LINESTRING",
- qMakePair(tr("Linestring layer"),
- QIcon(myThemePath+"/mIconLineLayer.png")));
- mLayerIcons.insert("MULTILINESTRING",
- qMakePair(tr("Multi-linestring layer"),
- mLayerIcons.value("LINESTRING").second));
- mLayerIcons.insert("POLYGON",
- qMakePair(tr("Polygon layer"),
- QIcon(myThemePath+"/mIconPolygonLayer.png")));
- mLayerIcons.insert("MULTIPOLYGON",
- qMakePair(tr("Multi-polygon layer"),
- mLayerIcons.value("POLYGON").second));
+ // populate the table list
- mLayerIcons.insert("GEOMETRY",
- qMakePair(tr("Mixed geometry layer"),
- QIcon(myThemePath+"/mIconGeometryLayer.png")));
- mLayerIcons.insert("GEOMETRYCOLLECTION",
- qMakePair(tr("Geometry collection layer"),
- mLayerIcons.value("GEOMETRY").second));
+ bool makeConnection = true;
+ QString key = "/PostgreSQL/connections/" + cmbConnections->currentText();
- mLayerIcons.insert("WAITING",
- qMakePair(tr("Waiting for layer type"),
- QIcon(myThemePath+"/mIconWaitingForLayerType.png")));
- mLayerIcons.insert("UNKNOWN",
- qMakePair(tr("Unknown layer type"),
- QIcon(myThemePath+"/mIconUnknownLayerType.png")));
- lstTables->clear();
- lstTables->setRowCount(0);
+ QString database = settings.readEntry(key + "/database");
+ QString username = settings.readEntry(key + "/username");
+ QString password = settings.readEntry(key + "/password");
- QStringList tables=mConnMan->getConnection()->getGeometryTables();
- for (int i = 0; i < tables.size(); ++i)
- const QIcon* p;
- QString geometryType=mConnMan->getConnection()->getTableGeometry(tables.at(i));
- if (mLayerIcons.contains(geometryType))
- p = &(mLayerIcons.value(geometryType).second);
- toolTipText = mLayerIcons.value(geometryType).first;
- qDebug(geometryType);
- else
- qDebug(("Unknown geometry type of '" + geometryType + "'.").toLocal8Bit().data());
- if (p != 0)
- QTableWidgetItem *iconItem = new QTableWidgetItem();
- QTableWidgetItem *textItem = new QTableWidgetItem(tables.at(i));
- int row = lstTables->rowCount();
- lstTables->setRowCount(row+1);
- lstTables->setItem(row, 0, iconItem);
- lstTables->setItem(row, 1, textItem);
+ if (password == QString::null)
+ // get password from user
+ makeConnection = false;
+ QString password = QInputDialog::getText(tr("Password for ") + username,
+ tr("Please enter your password:"),
+ QLineEdit::Password, QString::null, &makeConnection, this);
+ // allow null password entry in case its valid for the database
+ uri.setConnection( settings.readEntry(key + "/host"),
+ settings.readEntry(key + "/port"),
+ database,
+ settings.readEntry(key + "/username"),
+ password );
+ bool searchPublicOnly = settings.readBoolEntry(key + "/publicOnly");
+ bool searchGeometryColumnsOnly = settings.readBoolEntry(key + "/geometryColumnsOnly");
+ // Need to escape the password to allow for single quotes and backslashes
+ QgsDebugMsg("Connection info: " + uri.connInfo());
+ //qDebug(m_connInfo);
+ // Tidy up an existing connection if one exists.
+ if (pd != 0)
+ PQfinish(pd);
+ pd = PQconnectdb(m_connInfo.toLocal8Bit().data());
+ // std::cout << pd->ErrorMessage();
+ if (PQstatus(pd) == CONNECTION_OK)
+ //qDebug("Connection succeeded");
+ // tell the DB that we want text encoded in UTF8
+ PQsetClientEncoding(pd, "UNICODE");
+ // get the list of suitable tables and columns and populate the UI
+ geomCol details;
+ if(getTableInfo(pd, searchGeometryColumnsOnly, searchPublicOnly))
+ // Start the thread that gets the geometry type for relations that
+ // may take a long time to return
+ if (mColumnTypeThread != NULL)
+ connect(mColumnTypeThread, SIGNAL(setLayerType(QString,QString,QString,QString)),
+ this, SLOT(setLayerType(QString,QString,QString,QString)));
+ connect(this, SIGNAL(finished()),
+ mColumnTypeThread, SLOT(stop()) );
+ // Do it in a thread.
+ mColumnTypeThread->start();
+ else
+ qDebug("Unable to get list of spatially enabled tables from the database");
+ qDebug(PQerrorMessage(pd));
+ // BEGIN CHANGES ECOS
+ // END CHANGES ECOS
+ else
+ tr
+ arg(settings.readEntry(key + "/database")).arg(settings.readEntry(key + "/host")).arg("\n\n").arg("\n\n").arg("\n").arg(PQerrorMessage(pd)));
- // And tidy up the columns & rows
- lstTables->resizeColumnsToContents();
- lstTables->resizeRowsToContents();
- } else
- QMessageBox::information(this, tr("Connection"), tr("Connection failed - Check settings and try again.\n\nExtended error information:\n") +mConnMan->getError());
- if (cmbConnections->count() > 0)
- btnAdd->setEnabled(true);
QStringList QgsDbSourceSelect::selectedTables()
@@ -421,68 +626,296 @@
return m_selectedTables;
+QString QgsDbSourceSelect::connInfo()
+ return m_connInfo;
-void QgsDbSourceSelect::setSql(QTableWidgetItem *item)
+void QgsDbSourceSelect::setSql(const QModelIndex& index)
-/* int row = lstTables->row(item);
- QString tableText = lstTables->item(row, 1)->text();
+ if(!index.parent().isValid())
+ qWarning("schema item found");
+ return;
- QTableWidgetItem* sqlItem = lstTables->item(row, 2);
- QString sqlText;
- if (sqlItem)
- sqlText = sqlItem->text();
- // Parse out the table name
- QString table = tableText.left(tableText.find("(")); */
- /*assert(pd != 0);
+ if(pd == 0)
+ return;
+ //create "Schema"."Table" and find out existing sql string
+ QModelIndex schemaSibling = index.sibling(index.row(), 0);
+ QModelIndex tableSibling = index.sibling(index.row(), 1);
+ if(!schemaSibling.isValid() || !tableSibling.isValid())
+ return;
+ QString schemaName = mTableModel.itemFromIndex(mProxyModel.mapToSource(schemaSibling))->text();
+ QString tableName = mTableModel.itemFromIndex(mProxyModel.mapToSource(tableSibling))->text();
+ QString tableString = "\"" + schemaName + "\".\"" + tableName + "\"";
+ qWarning(tableString);
+ QString currentSql;
+ QModelIndex sqlSibling = index.sibling(index.row(), 4);
+ if(sqlSibling.isValid())
+ currentSql = mTableModel.itemFromIndex(mProxyModel.mapToSource(sqlSibling))->text();
// create a query builder object
- QgsPgQueryBuilder * pgb = new QgsPgQueryBuilder(table, pd, this);
+ QgsPgQueryBuilder * pgb = new QgsPgQueryBuilder(tableString, pd, this);
// set the current sql in the query builder sql box
- pgb->setSql(sqlText);
+ pgb->setSql(currentSql);
// set the PG connection object so it can be used to fetch the
// fields for the table, get sample values, and test the query
pgb->setConnection(pd);
// show the dialog
if(pgb->exec())
- // if user accepts, store the sql for the layer so it can be used
- // if and when the layer is added to the map
- if (!sqlItem)
+ mTableModel.setSql(mProxyModel.mapToSource(index), pgb->sql());
+void QgsDbSourceSelect::addSearchGeometryColumn(const QString &schema, const QString &table, const QString &column)
+ // store the column details and do the query in a thread
+ /* if (mColumnTypeThread == NULL)
+ mColumnTypeThread = new QgsGeomColumnTypeThread();
+ mColumnTypeThread->setConnInfo(m_connInfo);
+ mColumnTypeThread->addGeometryColumn(schema, table, column);*/
+bool QgsDbSourceSelect::getTableInfo(PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly)
+ /* bool ok = false;
+ QApplication::setOverrideCursor(Qt::waitCursor);
+ QString sql = "select * from geometry_columns";
+ sql += " order by f_table_schema,f_table_name";
+ PGresult *result = PQexec(pg, sql.toLocal8Bit().data());
+ if (result)
+ for (int idx = 0; idx < PQntuples(result); idx++)
- sqlItem = new QTableWidgetItem();
- lstTables->setItem(row, 2, sqlItem);
+ // Be a bit paranoid and check that the table actually
+ // exists. This is not done as a subquery in the query above
+ // because I can't get it to work correctly when there are tables
+ // with capital letters in the name.
+ // Take care to deal with tables with the same name but in different schema.
+ QString tableName = PQgetvalue(result, idx, PQfnumber(result, "f_table_name"));
+ QString schemaName = PQgetvalue(result, idx, PQfnumber(result, "f_table_schema"));
+ sql = "select oid from pg_class where relname = '" + tableName + "'";
+ if (schemaName.length() > 0)
+ sql +=" and relnamespace = (select oid from pg_namespace where nspname = '" +
+ schemaName + "')";
+ PGresult* exists = PQexec(pg, sql.toLocal8Bit().data());
+ if (PQntuples(exists) == 1)
+ QString column = PQgetvalue(result, idx, PQfnumber(result, "f_geometry_column"));
+ QString type = PQgetvalue(result, idx, PQfnumber(result, "type"));
+ QString as = "";
+ if(type=="GEOMETRY" && !searchGeometryColumnsOnly)
+ addSearchGeometryColumn(schemaName, tableName, column);
+ as=type="WAITING";
+ mTableModel.addTableEntry(type, schemaName, tableName, column, "");
+ PQclear(exists);
- sqlItem->setText(pgb->sql());
- // Ensure that the current row remains selected
- lstTables->setItemSelected(lstTables->item(row,0), true);
- lstTables->setItemSelected(lstTables->item(row,1), true);
- lstTables->setItemSelected(lstTables->item(row,2), true);
+ ok = true;
- // delete the query builder object
- delete pgb;*/
+ PQclear(result);
+ //search for geometry columns in tables that are not in the geometry_columns metatable
+ QApplication::restoreOverrideCursor();
+ if (searchGeometryColumnsOnly)
+ return ok;
+ // Now have a look for geometry columns that aren't in the
+ // geometry_columns table. This code is specific to postgresql,
+ // but an equivalent query should be possible in other
+ // databases.
+ sql = "select pg_class.relname, pg_namespace.nspname, pg_attribute.attname, "
+ "pg_class.relkind from "
+ "pg_attribute, pg_class, pg_type, pg_namespace where pg_type.typname = 'geometry' and "
+ "pg_attribute.atttypid = pg_type.oid and pg_attribute.attrelid = pg_class.oid ";
+ if (searchPublicOnly)
+ sql += "and pg_namespace.nspname = 'public' ";
+ sql += "and cast(pg_class.relname as character varying) not in "
+ "(select f_table_name from geometry_columns) "
+ "and pg_namespace.oid = pg_class.relnamespace "
+ "and pg_class.relkind in ('v', 'r')"; // only from views and relations (tables)
+ result = PQexec(pg, sql.toLocal8Bit().data());
+ for (int i = 0; i < PQntuples(result); i++)
+ // Have the column name, schema name and the table name. The concept of a
+ // catalog doesn't exist in postgresql so we ignore that, but we
+ // do need to get the geometry type.
+ // Make the assumption that the geometry type for the first
+ // row is the same as for all other rows.
+ QString table = PQgetvalue(result, i, 0); // relname
+ QString schema = PQgetvalue(result, i, 1); // nspname
+ QString column = PQgetvalue(result, i, 2); // attname
+ QString relkind = PQgetvalue(result, i, 3); // relation kind
+ addSearchGeometryColumn(schema, table, column);
+ //details.push_back(geomPair(fullDescription(schema, table, column, "WAITING"), "WAITING"));
+ mTableModel.addTableEntry("Waiting", schema, table, column, "");
+ ok = true;
+ PQclear(result);
+ return ok;*/
+ return true;
+bool QgsDbSourceSelect::getGeometryColumnInfo(PGconn *pg,
+ geomCol& details, bool searchGeometryColumnsOnly,
+ bool searchPublicOnly)
-QString QgsDbSourceSelect::encoding()
- return mEncodingComboBox->currentText();
+ // where f_table_schema ='" + settings.readEntry(key + "/database") + "'";
+ //qDebug("Fetching tables using: " + sql);
+ if (result)
+ QString msg;
+ QTextOStream(&msg) << "Fetched " << PQntuples(result) << " tables from database";
+ //qDebug(msg);
+ QString as = "";
+ if(type=="GEOMETRY" && !searchGeometryColumnsOnly) {
+ details.push_back(geomPair(fullDescription(schemaName, tableName, column, as), type));
+ PQclear(exists);
+ ok = true;
+ PQclear(result);
+ return ok;
+ // databases.
+ details.push_back(geomPair(fullDescription(schema, table, column, "WAITING"), "WAITING"));
+ ok = true;
+ PQclear(result);
+ return ok;*/
+ return true;
void QgsDbSourceSelect::showHelp()
QgsContextHelp::run(context_id);
+QString QgsDbSourceSelect::fullDescription(QString schema, QString table,
+ QString column, QString type)
+ QString full_desc = "";
+ if (schema.length() > 0)
+ full_desc = '"' + schema + "\".\"";
+ full_desc += table + "\" (" + column + ") " + type;
+ return full_desc;
void QgsDbSourceSelect::dbChanged()
// Remember which database was selected.
- mConnMan->setSelectedType(cmbType->currentText());
- mConnMan->setSelected(cmbType->currentText(),cmbConnections->currentText());
- qDebug("Saving last connection position");
+ settings.writeEntry("/PostgreSQL/connections/selected",
void QgsDbSourceSelect::setConnectionListPosition()
- qDebug("Setting connection list position");
- QString toSelect = mConnMan->getSelected(cmbType->currentText());
+ QString toSelect = mConnectionRegistry->selected(cmbType->currentText());
// Does toSelect exist in cmbConnections?
bool set = false;
for (int i = 0; i < cmbConnections->count(); ++i)
@@ -507,10 +940,95 @@
else
cmbConnections->setCurrentItem(cmbConnections->count()-1);
+ // If possible, set the item currently displayed database
+ QString toSelect = settings.readEntry("/PostgreSQL/connections/selected");
+ // Does toSelect exist in cmbConnections?
+ bool set = false;
+ for (int i = 0; i < cmbConnections->count(); ++i)
+ if (cmbConnections->text(i) == toSelect)
+ cmbConnections->setCurrentItem(i);
+ set = true;
+ break;
+ // If we couldn't find the stored item, but there are some,
+ // default to the last item (this makes some sense when deleting
+ // items as it allows the user to repeatidly click on delete to
+ // remove a whole lot of items).
+ if (!set && cmbConnections->count() > 0)
+ // If toSelect is null, then the selected connection wasn't found
+ // by QSettings, which probably means that this is the first time
+ // the user has used qgis with database connections, so default to
+ // the first in the list of connetions. Otherwise default to the last.
+ if (toSelect.isNull())
+ cmbConnections->setCurrentItem(0);
+ else
+ cmbConnections->setCurrentItem(cmbConnections->count()-1);
+void QgsDbSourceSelect::setSearchExpression(const QString& regexp)
-QString QgsDbSourceSelect::connInfo()
+void QgsGeomColumnTypeThread::setConnInfo(QString s)
- return m_connInfo;
+ mConnInfo = s;
+void QgsGeomColumnTypeThread::addGeometryColumn(QString schema, QString table, QString column)
+ schemas.push_back(schema);
+ tables.push_back(table);
+ columns.push_back(column);
+void QgsGeomColumnTypeThread::stop()
+ mStopped=true;
+void QgsGeomColumnTypeThread::getLayerTypes()
+ mStopped=false;
+ PGconn *pd = PQconnectdb(mConnInfo.toLocal8Bit().data());
+ for (uint i = 0; i<schemas.size(); i++)
+ QString query = QgsDbSourceSelect::makeGeomQuery(schemas[i],
+ tables[i],
+ columns[i]);
+ PGresult* gresult = PQexec(pd, query.toLocal8Bit().data());
+ QString type;
+ if (PQresultStatus(gresult) == PGRES_TUPLES_OK) {
+ QStringList types;
+ for(int j=0; j<PQntuples(gresult); j++) {
+ QString type = PQgetvalue(gresult, j, 0);
+ if(type!="")
+ types += type;
+ type = types.join(",");
+ PQclear(gresult);
+ if(mStopped)
+ break;
+ // Now tell the layer list dialog box...
+ emit setLayerType(schemas[i], tables[i], columns[i], type);
+ PQfinish(pd);
Modified: branches/ogr-plugin-branch/src/app/qgsdbsourceselect.h
--- branches/ogr-plugin-branch/src/app/qgsdbsourceselect.h 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/app/qgsdbsourceselect.h 2008-02-15 21:20:17 UTC (rev 8160)
@@ -18,8 +18,12 @@
#ifndef QGSDBSOURCESELECT_H
#define QGSDBSOURCESELECT_H
#include "ui_qgsdbsourceselectbase.h"
+#include "qgsconnectionregistry.h"
+#include "qgsdatabaseconnection.h"
#include "qgisgui.h"
-#include "qgsconnectionmanager.h"
+#include "qgsdbfilterproxymodel.h"
+#include "qgsdbtablemodel.h"
extern "C"
#include <libpq-fe.h>
@@ -43,12 +47,12 @@
* \brief Dialog to create connections and add tables from PostgresQL.
* This dialog allows the user to define and save connection information
- * for PostGIS enabled PostgresQL databases. The user can then connect and add
+ * for PostGIS enabled PostgreSQL databases. The user can then connect and add
* tables from the database to the map canvas.
class QgsDbSourceSelect : public QDialog, private Ui::QgsDbSourceSelectBase
- Q_OBJECT
+ Q_OBJECT
public:
//! Constructor
@@ -61,20 +65,20 @@
void editConnection();
//! Deletes the selected connection
void deleteConnection();
//! Determines the tables the user selected and closes the dialog
void addTables();
//! String list containing the selected tables
QStringList selectedTables();
//! Connection info (database, host, user, password)
QString connInfo();
- QStringList m_selectedTables;
- //! Return the name of the selected encoding (e.g. UTf-8, ISO-8559-1, etc/)
- QString encoding();
// Store the selected database
void dbChanged();
- public slots:
+ // Utility function to construct the query for finding out the
+ // geometry type of a column
+ static QString makeGeomQuery(QString schema, QString table, QString column);
+ public slots:
/*! Connects to the database using the stored connection parameters.
* Once connected, available layers are displayed.
@@ -83,17 +87,26 @@
void on_btnNew_clicked();
void on_btnEdit_clicked();
void on_btnDelete_clicked();
- void on_lstTables_itemDoubleClicked(QTableWidgetItem *);
- void setSql(QTableWidgetItem *);
+ void on_mSearchOptionsButton_clicked();
+ void on_mSearchTableEdit_textChanged(const QString & text);
+ void on_mSearchColumnComboBox_currentIndexChanged(const QString & text);
+ void on_mSearchModeComboBox_currentIndexChanged(const QString & text);
+ void setSql(const QModelIndex& index);
void on_btnHelp_clicked();
- void on_cmbType_activated(int);
void on_cmbConnections_activated(int);
void setLayerType(QString schema, QString table, QString column,
QString type);
+ //!Sets a new regular expression to the model
+ void setSearchExpression(const QString& regexp);
//! Populate the connection list combo box
- void populateConnectionList(QString type);
+ void populateConnectionList(QString type);
private:
+ enum columns {
+ dbssType=0,
+ dbssDetail,
+ dbssSql,
+ dbssColumns,
typedef std::pair<QString, QString> geomPair;
typedef std::list<geomPair > geomCol;
@@ -102,32 +115,39 @@
geomCol& details,
bool searchPublicOnly);
+ /**Inserts information about the spatial tables into mTableModel*/
+ bool getTableInfo(PGconn *pg, bool searchGeometryColumnsOnly, bool searchPublicOnly);
+ // queue another query for the thread
+ void addSearchGeometryColumn(const QString &schema, const QString &table, const QString &column);
// Set the position of the database connection list to the last
// used one.
void setConnectionListPosition();
// Show the context help for the dialog
void showHelp();
+ // Combine the schema, table and column data into a single string
+ // useful for display to the user
+ QString fullDescription(QString schema, QString table, QString column, QString type);
// The column labels
QStringList mColumnLabels;
// Our thread for doing long running queries
QgsGeomColumnTypeThread* mColumnTypeThread;
QString m_connInfo;
- //QStringList m_selectedTables;
+ QStringList m_selectedTables;
// Storage for the range of layer type icons
QMap<QString, QPair<QString, QIcon> > mLayerIcons;
//! Pointer to the qgis application mainwindow
QgisApp *qgisApp;
PGconn *pd;
- QgsConnectionManager* mConnMan;
- QgsConnection mConn;
+ QgsConnectionRegistry* mConnectionRegistry;
static const int context_id = 939347163;
+ //! Model that acts as datasource for mTableTreeWidget
+ QgsDbTableModel mTableModel;
+ QgsDbFilterProxyModel mProxyModel;
+ QgsDatabaseConnection* mDatabaseConnection;
#endif // QGSDBSOURCESELECT_H
Modified: branches/ogr-plugin-branch/src/app/qgsnewconnection.cpp
--- branches/ogr-plugin-branch/src/app/qgsnewconnection.cpp 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/app/qgsnewconnection.cpp 2008-02-15 21:20:17 UTC (rev 8160)
@@ -26,12 +26,14 @@
-QgsNewConnection::QgsNewConnection(QWidget *parent, const QgsConnection* conn, Qt::WFlags fl)
+QgsNewConnection::QgsNewConnection(QWidget *parent, const QgsConnectionParameters* conn, Qt::WFlags fl)
: QDialog(parent, fl)
setupUi(this);
+ mConnReg=new QgsConnectionRegistry;
//set the type of connection
- QString type=connManager.getSelectedType();
+ QString type=mConnReg->selectedType();
if (conn!=NULL)
@@ -41,10 +43,7 @@
txtDatabase->setText(conn->database);
if (conn->save)
txtPassword->setText(conn->password);
- /*QString port = settings.readEntry(key + "/port");
- if(port.length() ==0){
- port = "5432";
txtPort->setText(conn->port);
txtUsername->setText(conn->user);
if (conn->publicOnly)
@@ -62,10 +61,7 @@
else
chkStorePassword->setCheckState(Qt::Unchecked);
txtName->setText(conn->name);
- qDebug("QgsNewConnection::QgsNewConnection : type "+conn->type);
cmbType->setCurrentText(conn->type);
@@ -99,45 +95,48 @@
QgsNewConnection::~QgsNewConnection()
- //delete connManager;
+ delete mConnReg;
void QgsNewConnection::testConnection()
- // following line uses Qt SQL plugin - currently not used
- // QSqlDatabase *testCon = QSqlDatabase::addDatabase("QPSQL7","testconnection");
- QgsConnectionManager* connMan=new QgsConnectionManager;
- QgsConnection conn;
+ QgsDatabaseConnection* connection=NULL;
+ QgsConnectionParameters connPar;
- conn.type=cmbType->currentText();
- conn.name=txtName->text();
- conn.host=txtHost->text();
- conn.database=txtDatabase->text();
- conn.port=txtPort->text();
- conn.user=txtUsername->text();
- conn.password=txtPassword->text();
- conn.geometryColumnsOnly=cb_geometryColumnsOnly->isChecked();
- conn.publicOnly=cb_publicSchemaOnly->isChecked();
- conn.selected=txtName->text();
- conn.save=chkStorePassword->isChecked();
+ connPar.type=cmbType->currentText();
+ connPar.name=txtName->text();
+ connPar.host=txtHost->text();
+ connPar.database=txtDatabase->text();
+ connPar.port=txtPort->text();
+ connPar.user=txtUsername->text();
+ connPar.password=txtPassword->text();
+ connPar.geometryColumnsOnly=cb_geometryColumnsOnly->isChecked();
+ connPar.publicOnly=cb_publicSchemaOnly->isChecked();
+ connPar.selected=txtName->text();
+ connPar.save=chkStorePassword->isChecked();
- qDebug("QgsNewConnection::testConnection: before connect");
- if (connMan->connect(cmbType->currentText(),conn))
+ if (connPar.type.startsWith("Ogr"))
- QMessageBox::information(this, tr("Test connection"), tr("Connection to %1 was successful").arg(txtDatabase->text()));
+ connection=new QgsOgrDatabaseConnection(&connPar);
+ else
+ connection=new QgsPostgresDatabaseConnection(&connPar);
+ if (connection->connect())
+ QMessageBox::information(this, tr("Test connection"), tr("Connection to %1 was successful").arg(txtName->text()));
} else
- QMessageBox::information(this, tr("Test connection"), tr("Connection failed - Check settings and try again.\n\nExtended error information:\n") +connMan->getError());
+ QMessageBox::information(this, tr("Test connection"), tr("Connection failed - Check settings and try again.\n\nExtended error information:\n") +connection->error());
- qDebug("QgsNewConnection::testConnection: after connect");
- delete connMan;
+ delete connection;
void QgsNewConnection::saveConnection()
+ QgsConnectionParameters conn;
@@ -154,9 +153,9 @@
- connManager.saveConnection(conn);
- connManager.setSelectedType(conn.type);
- connManager.setSelected(conn.type,conn.name);
+ mConnReg->saveConnection(conn);
+ mConnReg->setSelectedType(conn.type);
+ mConnReg->setSelected(conn.type,conn.name);
accept();
Modified: branches/ogr-plugin-branch/src/app/qgsnewconnection.h
--- branches/ogr-plugin-branch/src/app/qgsnewconnection.h 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/app/qgsnewconnection.h 2008-02-15 21:20:17 UTC (rev 8160)
@@ -19,8 +19,13 @@
#define QGSNEWCONNECTION_H
#include "ui_qgsnewconnectionbase.h"
-//fred
+#include "qgsconnectionparameters.h"
+#include "qgsogrdatabaseconnection.h"
+#include "qgspostgresdatabaseconnection.h"
/*! \class QgsNewConnection
* \brief Dialog to allow the user to configure and save connection
* information for a PostgresQl database
@@ -30,7 +35,7 @@
Q_OBJECT
public:
//! Constructor
- QgsNewConnection(QWidget *parent = 0, const QgsConnection* conn=0, Qt::WFlags fl = QgisGui::ModalDialogFlags);
+ QgsNewConnection(QWidget *parent = 0, const QgsConnectionParameters* conn=0, Qt::WFlags fl = QgisGui::ModalDialogFlags);
//! Destructor
~QgsNewConnection();
//! Tests the connection using the parameters supplied
@@ -47,7 +52,7 @@
void on_cb_geometryColumnsOnly_clicked();
private:
//fred
- QgsConnectionManager connManager;
+ QgsConnectionRegistry* mConnReg;
static const int context_id = 929865718;
Modified: branches/ogr-plugin-branch/src/core/qgsdatasourceuri.cpp
--- branches/ogr-plugin-branch/src/core/qgsdatasourceuri.cpp 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/core/qgsdatasourceuri.cpp 2008-02-15 21:20:17 UTC (rev 8160)
@@ -250,11 +250,38 @@
QString QgsDataSourceURI::uri() const
- return connInfo()
+ QString connString="";
+ if (mType=="OgrMySQL")
+ connString="MySQL:"+mDatabase+","+
+ "host="+mHost+","+
+ "user="+mUsername+","+
+ "password="+mPassword;
+ else if (mType=="OgrPostgreSQL")
+ connString="PG:dbname="+mDatabase+" "+
+ "host="+mHost+" "+
+ "user="+mUsername+" "+
+ else if (mType=="OgrOracle")
+ connString="OCI:"+mUsername+"/"+
+ mPassword+"@"+
+ mHost+"/"+
+ mDatabase;
+ else
+ connString=connInfo()
+ QString(" table=%1 (%2) sql=%3")
.arg( quotedTablename() )
.arg( mGeometryColumn )
- .arg( mSql );
+ .arg( mSql );
+ return connString;
QString QgsDataSourceURI::quotedTablename() const
Modified: branches/ogr-plugin-branch/src/ui/qgsdbsourceselectbase.ui
--- branches/ogr-plugin-branch/src/ui/qgsdbsourceselectbase.ui 2008-02-14 19:16:45 UTC (rev 8159)
+++ branches/ogr-plugin-branch/src/ui/qgsdbsourceselectbase.ui 2008-02-15 21:20:17 UTC (rev 8160)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>510</width>
- <height>475</height>
+ <width>384</width>
+ <height>457</height>
</rect>
</property>
<property name="windowTitle" >
@@ -77,6 +77,11 @@
<string>OgrOracle</string>
</property>
</item>
+ <item>
+ <property name="text" >
+ <string>OgrGeneric</string>
+ </property>
+ </item>
</widget>
</item>
<item>
@@ -137,50 +142,95 @@
<property name="title" >
<string>Tables:</string>
</property>
- <layout class="QVBoxLayout" >
+ <layout class="QGridLayout" >
<property name="margin" >
<number>9</number>
</property>
<property name="spacing" >
<number>6</number>
</property>
- <item>
- <widget class="QTableWidget" name="lstTables" >
- <property name="mouseTracking" >
- <bool>true</bool>
- </property>
- <property name="editTriggers" >
- <set>QAbstractItemView::NoEditTriggers</set>
- </property>
+ <item row="0" column="0" >
+ <widget class="QTreeView" name="mTablesTreeView" >
<property name="selectionMode" >
<enum>QAbstractItemView::MultiSelection</enum>
</property>
- <property name="selectionBehavior" >
- <enum>QAbstractItemView::SelectRows</enum>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <item>
+ <layout class="QHBoxLayout" >
+ <property name="margin" >
+ <number>0</number>
+ </property>
+ <property name="spacing" >
+ <number>6</number>
+ </property>
+ <item>
+ <spacer>
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" >
+ <size>
+ <width>305</width>
+ <height>25</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QPushButton" name="mSearchOptionsButton" >
+ <string>Search options...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
+ <widget class="QGroupBox" name="mSearchGroupBox" >
+ <property name="title" >
+ <string/>
+ </property>
+ <number>9</number>
+ </property>
+ </property>
+ <widget class="QLabel" name="mSearchLabel" >
+ <string>Search:</string>
</property>
- <property name="showGrid" >
- <bool>false</bool>
+ </widget>
+ </item>
+ <item row="2" column="0" colspan="2" >
+ <widget class="QLabel" name="mSearchModeLabel" >
+ <string>Search mode:</string>
</property>
- <property name="gridStyle" >
- <enum>Qt::SolidLine</enum>
+ </widget>
+ </item>
+ <item row="2" column="2" >
+ <widget class="QComboBox" name="mSearchModeComboBox" />
+ </item>
+ <item row="1" column="0" colspan="2" >
+ <widget class="QLabel" name="mSearchColumnsLabel" >
+ <string>Search in columns:</string>
</property>
- <column>
- <property name="text" >
- <string>Type</string>
- </property>
- </column>
- <column>
- <string>Name</string>
- </property>
- </column>
- <column>
- <string>Sql</string>
- </property>
- </column>
</widget>
</item>
+ <item row="1" column="2" >
+ <widget class="QComboBox" name="mSearchColumnComboBox" />
+ </item>
+ <item row="0" column="1" colspan="2" >
+ <widget class="QLineEdit" name="mSearchTableEdit" />
+ </item>
</layout>
</widget>
</item>
@@ -284,7 +334,6 @@
<tabstop>btnNew</tabstop>
<tabstop>btnEdit</tabstop>
<tabstop>btnDelete</tabstop>
- <tabstop>lstTables</tabstop>
<tabstop>mEncodingComboBox</tabstop>
<tabstop>btnHelp</tabstop>
<tabstop>btnAdd</tabstop>
