[QGIS Commit] r8162 - in branches/gdalogr-capi-branch/qgis/src:
core/raster plugins/georeferencer
svn_qgis at osgeo.org
Fri Feb 15 22:11:09 EST 2008
Author: warmerdam
Date: 2008-02-15 22:11:09 -0500 (Fri, 15 Feb 2008)
New Revision: 8162
branches/gdalogr-capi-branch/qgis/src/core/raster/qgsrasterlayer.cpp
branches/gdalogr-capi-branch/qgis/src/core/raster/qgsrasterlayer.h
branches/gdalogr-capi-branch/qgis/src/plugins/georeferencer/qgsimagewarper.cpp
ported GDAL calls to C API
Modified: branches/gdalogr-capi-branch/qgis/src/core/raster/qgsrasterlayer.cpp
--- branches/gdalogr-capi-branch/qgis/src/core/raster/qgsrasterlayer.cpp 2008-02-15 23:37:51 UTC (rev 8161)
+++ branches/gdalogr-capi-branch/qgis/src/core/raster/qgsrasterlayer.cpp 2008-02-16 03:11:09 UTC (rev 8162)
@@ -28,7 +28,9 @@
#include "qgsrasterviewport.h"
#include "qgsrect.h"
#include "qgsspatialrefsys.h"
#include "gdalwarper.h"
+#include "cpl_conv.h"
#include "qgspseudocolorshader.h"
#include "qgsfreakoutshader.h"
@@ -121,18 +123,10 @@
// first get the GDAL driver manager
registerGdalDrivers();
- GDALDriverManager *myGdalDriverManager = GetGDALDriverManager();
- if (!myGdalDriverManager)
- QgsLogger::warning("unable to get GDALDriverManager");
- return; // XXX good place to throw exception if we
- } // XXX decide to do exceptions
// then iterate through all of the supported drivers, adding the
// corresponding file filter
- GDALDriver *myGdalDriver; // current driver
+ GDALDriverH myGdalDriver; // current driver
char **myGdalDriverMetadata; // driver metadata strings
@@ -145,7 +139,7 @@
QStringList catchallFilter; // for Any file(*.*), but also for those
// drivers with no specific file filter
- GDALDriver *jp2Driver = NULL; // first JPEG2000 driver found
+ GDALDriverH jp2Driver = NULL; // first JPEG2000 driver found
// Grind through all the drivers and their respective metadata.
// We'll add a file filter for those drivers that have a file
@@ -158,9 +152,9 @@
// driver, which will be found in DMD_LONGNAME, which will have the
// same form.
- for (int i = 0; i < myGdalDriverManager->GetDriverCount(); ++i)
+ for (int i = 0; i < GDALGetDriverCount(); ++i)
- myGdalDriver = myGdalDriverManager->GetDriver(i);
+ myGdalDriver = GDALGetDriver(i);
Q_CHECK_PTR(myGdalDriver);
@@ -172,7 +166,7 @@
// now we need to see if the driver is for something currently
// supported; if not, we give it a miss for the next driver
- myGdalDriverDescription = myGdalDriver->GetDescription();
+ myGdalDriverDescription = GDALGetDescription(myGdalDriver);
if (!isSupportedRasterDriver(myGdalDriverDescription))
@@ -182,7 +176,7 @@
// std::cerr << "got driver string " << myGdalDriver->GetDescription() << "\n";
- myGdalDriverMetadata = myGdalDriver->GetMetadata();
+ myGdalDriverMetadata = GDALGetMetadata(myGdalDriver,NULL);
// presumably we know we've run out of metadta if either the
// address is 0, or the first character is null
@@ -275,7 +269,7 @@
else
- catchallFilter << QString(myGdalDriver->GetDescription());
+ catchallFilter << QString(GDALGetDescription(myGdalDriver));
@@ -439,7 +433,7 @@
if ( mGdalBaseDataset )
- mGdalBaseDataset->Dereference();
+ GDALDereferenceDataset( mGdalBaseDataset );
GDALClose(mGdalDataset);
@@ -454,7 +448,7 @@
mGdalDataset = NULL;
//open the dataset making sure we handle char encoding of locale properly
- mGdalBaseDataset = (GDALDataset *) GDALOpen(QFile::encodeName(fileName).constData(), GA_ReadOnly);
+ mGdalBaseDataset = GDALOpen(QFile::encodeName(fileName).constData(), GA_ReadOnly);
if (mGdalBaseDataset == NULL)
@@ -466,23 +460,23 @@
mLastModified = lastModified ( fileName );
// Check if we need a warped VRT for this file.
- if( (mGdalBaseDataset->GetGeoTransform(mGeoTransform) == CE_None
+ if( (GDALGetGeoTransform(mGdalBaseDataset,mGeoTransform) == CE_None
&& (mGeoTransform[1] < 0.0
|| mGeoTransform[2] != 0.0
|| mGeoTransform[4] != 0.0
|| mGeoTransform[5] > 0.0))
- || mGdalBaseDataset->GetGCPCount() > 0 )
+ || GDALGetGCPCount(mGdalBaseDataset) > 0 )
QgsLogger::warning("Creating Warped VRT.");
- mGdalDataset = (GDALDataset *)
+ mGdalDataset =
GDALAutoCreateWarpedVRT( mGdalBaseDataset, NULL, NULL,
GRA_NearestNeighbour, 0.2, NULL );
else
mGdalDataset = mGdalBaseDataset;
- mGdalDataset->Reference();
+ GDALReferenceDataset( mGdalDataset );
//check f this file has pyramids
@@ -532,11 +526,11 @@
// Use the affine transform to get geo coordinates for
// the corners of the raster
double myXMax = mGeoTransform[0] +
- mGdalDataset->GetRasterXSize() * mGeoTransform[1] +
- mGdalDataset->GetRasterYSize() * mGeoTransform[2];
+ GDALGetRasterXSize(mGdalDataset) * mGeoTransform[1] +
+ GDALGetRasterYSize(mGdalDataset) * mGeoTransform[2];
double myYMin = mGeoTransform[3] +
- mGdalDataset->GetRasterXSize() * mGeoTransform[4] +
- mGdalDataset->GetRasterYSize() * mGeoTransform[5];
+ GDALGetRasterXSize(mGdalDataset) * mGeoTransform[4] +
+ GDALGetRasterYSize(mGdalDataset) * mGeoTransform[5];
mLayerExtent.setXmax(myXMax);
// The affine transform reduces to these values at the
@@ -548,8 +542,8 @@
// Set up the x and y dimensions of this raster layer
- mRasterXDim = mGdalDataset->GetRasterXSize();
- mRasterYDim = mGdalDataset->GetRasterYSize();
+ mRasterXDim = GDALGetRasterXSize(mGdalDataset);
+ mRasterYDim = GDALGetRasterYSize(mGdalDataset);
// Determin the nodatavalue
@@ -557,7 +551,7 @@
mNoDataValue = -9999; //Standard default?
mValidNoDataValue = false;
int isValid = false;
- double myNoDataValue = mGdalDataset->GetRasterBand(1)->GetNoDataValue(&isValid);
+ double myNoDataValue = GDALGetRasterNoDataValue(GDALGetRasterBand(mGdalDataset,1),&isValid);
if(isValid)
mNoDataValue = myNoDataValue;
@@ -571,10 +565,10 @@
//initialise the raster band stats and contrast enhancement vector
- for (int i = 1; i <= mGdalDataset->GetRasterCount(); i++)
+ for (int i = 1; i <= GDALGetRasterCount(mGdalDataset); i++)
- GDALRasterBand *myGdalBand = mGdalDataset->GetRasterBand(i);
- QString myColorQString = GDALGetColorInterpretationName(myGdalBand->GetColorInterpretation());
+ GDALRasterBandH myGdalBand = GDALGetRasterBand(mGdalDataset,i);
+ QString myColorQString = GDALGetColorInterpretationName(GDALGetRasterColorInterpretation(myGdalBand));
QgsRasterBandStats myRasterBandStats;
//myRasterBandStats.bandName = myColorQString ;
myRasterBandStats.bandName=QString::number(i) + " : " + myColorQString;
@@ -587,7 +581,7 @@
mRasterStatsList.push_back(myRasterBandStats);
//Build a new contrast enhancement for the band and store in list
- QgsContrastEnhancement myContrastEnhancement((QgsContrastEnhancement::QgsRasterDataType)myGdalBand->GetRasterDataType());
+ QgsContrastEnhancement myContrastEnhancement((QgsContrastEnhancement::QgsRasterDataType)GDALGetRasterDataType(myGdalBand));
mContrastEnhancementList.append(myContrastEnhancement);
@@ -597,7 +591,7 @@
//decide what type of layer this is...
//note that multiband images can have one or more 'undefindd' bands,
//so we must do this check first!
- if ((mGdalDataset->GetRasterCount() > 1))
+ if ((GDALGetRasterCount(mGdalDataset) > 1))
rasterLayerType = MULTIBAND;
@@ -626,7 +620,7 @@
mRedBandName = getRasterBandName(1); // sensible default
mGreenBandName = getRasterBandName(2); // sensible default
//for the third layer we cant be sure so..
- if (mGdalDataset->GetRasterCount() > 2)
+ if (GDALGetRasterCount(mGdalDataset) > 2)
mBlueBandName = getRasterBandName(3); // sensible default
@@ -669,12 +663,12 @@
QString myWKTString;
QgsSpatialRefSys mySRS;
- myWKTString=QString (mGdalDataset->GetProjectionRef());
+ myWKTString=QString (GDALGetProjectionRef(mGdalDataset));
mySRS.createFromWkt(myWKTString);
if (!mySRS.isValid())
//try to get the gcp srs from the raster layer if available
- myWKTString=QString(mGdalDataset->GetGCPProjection());
+ myWKTString=QString(GDALGetGCPProjection(mGdalDataset));
// What is the purpose of this piece of code?
// Sideeffects from validate()?
@@ -695,7 +689,7 @@
if ( !mValid ) return;
mValid = FALSE;
+ GDALDereferenceDataset(mGdalBaseDataset);
mGdalBaseDataset = NULL;
@@ -884,10 +878,10 @@
QgsDebugMsg("Looking for band : " + theBandName);
#ifdef QGISDEBUG
QgsLogger::debug("band", i, __FILE__, __FUNCTION__, __LINE__, 2);
#endif
@@ -951,7 +945,7 @@
QgsDebugMsg("....found paletted image");
QgsColorTable *myColorTable = colorTable ( 1 );
- GDALRasterBandH myGdalBand = mGdalDataset->GetRasterBand(1);
+ GDALRasterBandH myGdalBand = GDALGetRasterBand(mGdalDataset,1);
if( GDALGetRasterColorInterpretation(myGdalBand) == GCI_PaletteIndex && myColorTable->defined() )
QgsDebugMsg("....found GCI_PaletteIndex");
@@ -1437,8 +1431,8 @@
return;
- GDALRasterBand *myGdalBand = mGdalDataset->GetRasterBand(theBandNo);
- GDALDataType myDataType = myGdalBand->GetRasterDataType();
+ GDALRasterBandH myGdalBand = GDALGetRasterBand(mGdalDataset,theBandNo);
+ GDALDataType myDataType = GDALGetRasterDataType(myGdalBand);
void *myGdalScanData = readData ( myGdalBand, theRasterViewPort );
/* Check for out of memory error */
@@ -1541,8 +1535,8 @@
QgsRasterBandStats myRasterBandStats = getRasterBandStats(theBandNo);
@@ -1644,8 +1638,8 @@
return;
@@ -1730,8 +1724,8 @@
@@ -1829,8 +1823,8 @@
@@ -1957,8 +1951,8 @@
return;
@@ -2094,13 +2088,13 @@
return;
- GDALRasterBand *myGdalRedBand = mGdalDataset->GetRasterBand(myRedBandNo);
- GDALRasterBand *myGdalGreenBand = mGdalDataset->GetRasterBand(myGreenBandNo);
- GDALRasterBand *myGdalBlueBand = mGdalDataset->GetRasterBand(myBlueBandNo);
+ GDALRasterBandH myGdalRedBand = GDALGetRasterBand(mGdalDataset,myRedBandNo);
+ GDALRasterBandH myGdalGreenBand = GDALGetRasterBand(mGdalDataset,myGreenBandNo);
+ GDALRasterBandH myGdalBlueBand = GDALGetRasterBand(mGdalDataset,myBlueBandNo);
- GDALDataType myRedType = myGdalRedBand->GetRasterDataType();
- GDALDataType myGreenType = myGdalGreenBand->GetRasterDataType();
- GDALDataType myBlueType = myGdalBlueBand->GetRasterDataType();
+ GDALDataType myRedType = GDALGetRasterDataType(myGdalRedBand);
+ GDALDataType myGreenType = GDALGetRasterDataType(myGdalGreenBand);
+ GDALDataType myBlueType = GDALGetRasterDataType(myGdalBlueBand);
void *myGdalRedData = readData ( myGdalRedBand, theRasterViewPort );
void *myGdalGreenData = readData ( myGdalGreenBand, theRasterViewPort );
@@ -2294,7 +2288,7 @@
//we cant use a vector iterator because the iterator is astruct not a class
//and the qvector model does not like this.
QgsRasterBandStats myRasterBandStats = getRasterBandStats(i);
if (myRasterBandStats.bandName == theBandNameQString)
@@ -2395,7 +2389,7 @@
const QgsRasterBandStats QgsRasterLayer::getRasterBandStats(int theBandNo)
// check if we have received a valid band number
- if ((mGdalDataset->GetRasterCount() < theBandNo) && rasterLayerType != PALETTE)
+ if ((GDALGetRasterCount(mGdalDataset) < theBandNo) && rasterLayerType != PALETTE)
// invalid band id, return nothing
QgsRasterBandStats myNullReturnStats;
@@ -2421,10 +2415,10 @@
emit setStatus(QString("Retrieving stats for ")+name());
qApp->processEvents();
QgsDebugMsg("QgsRasterLayer::retrieve stats for band " + QString::number(theBandNo));
- QString myColorerpretation = GDALGetColorInterpretationName(myGdalBand->GetColorInterpretation());
+ QString myColorerpretation = GDALGetColorInterpretationName(GDALGetRasterColorInterpretation(myGdalBand));
//declare a colorTable to hold a palette - will only be used if the layer color interp is palette ???
//get the palette colour table
@@ -2477,13 +2471,13 @@
// let the user know we're going to possibly be taking a while
//QApplication::setOverrideCursor(QCursor(Qt::WaitCursor));
int myNXBlocks, myNYBlocks, myXBlockSize, myYBlockSize;
- myGdalBand->GetBlockSize( &myXBlockSize, &myYBlockSize );
+ GDALGetBlockSize( myGdalBand, &myXBlockSize, &myYBlockSize );
- myNXBlocks = (myGdalBand->GetXSize() + myXBlockSize - 1) / myXBlockSize;
- myNYBlocks = (myGdalBand->GetYSize() + myYBlockSize - 1) / myYBlockSize;
+ myNXBlocks = (GDALGetRasterXSize(myGdalBand) + myXBlockSize - 1) / myXBlockSize;
+ myNYBlocks = (GDALGetRasterYSize(myGdalBand) + myYBlockSize - 1) / myYBlockSize;
void *myData = CPLMalloc ( myXBlockSize * myYBlockSize * GDALGetDataTypeSize(myDataType)/8 );
@@ -2538,8 +2532,8 @@
QgsDebugMsg("starting manual stat computation");
#endif
- int myGdalBandXSize = myGdalBand->GetXSize();
- int myGdalBandYSize = myGdalBand->GetYSize();
+ int myGdalBandXSize = GDALGetRasterXSize(myGdalBand);
+ int myGdalBandYSize = GDALGetRasterYSize(myGdalBand);
for( int iYBlock = 0; iYBlock < myNYBlocks; iYBlock++ )
emit drawingProgress ( iYBlock, myNYBlocks * 2 );
@@ -2547,7 +2541,7 @@
for( int iXBlock = 0; iXBlock < myNXBlocks; iXBlock++ )
int nXValid, nYValid;
- myGdalBand->ReadBlock( iXBlock, iYBlock, myData );
+ GDALReadBlock( myGdalBand, iXBlock, iYBlock, myData );
// Compute the portion of the block that is valid
// for partial edge blocks.
@@ -2617,9 +2611,9 @@
if( (iXBlock+1) * myXBlockSize > myGdalBandXSize )
@@ -2926,8 +2920,8 @@
// Get the adjusted matrix stats
- GDALRasterBand *myGdalBand = mGdalDataset->GetRasterBand(1);
@@ -3178,8 +3172,8 @@
QPixmap myLegendQPixmap; //will be initialised once we know what drawing style is active
QPainter myQPainter;
@@ -3502,9 +3496,9 @@
myMetadataQString += "<tr><td>";
if (mProviderKey.isEmpty())
- myMetadataQString += QString(mGdalDataset->GetDriver()->GetDescription());
+ myMetadataQString += QString(GDALGetDescription(GDALGetDatasetDriver(mGdalDataset)));
myMetadataQString += "<br>";
- myMetadataQString += QString(mGdalDataset->GetDriver()->GetMetadataItem(GDAL_DMD_LONGNAME));
+ myMetadataQString += QString(GDALGetMetadataItem(GDALGetDatasetDriver(mGdalDataset),GDAL_DMD_LONGNAME,NULL));
else
@@ -3526,11 +3520,11 @@
myMetadataQString += tr("Dataset Description");
myMetadataQString += "</td></tr>";
- myMetadataQString += QFile::decodeName(mGdalDataset->GetDescription());
+ myMetadataQString += QFile::decodeName(GDALGetDescription(mGdalDataset));
- char ** GDALmetadata = mGdalDataset->GetMetadata();
+ char ** GDALmetadata = GDALGetMetadata(mGdalDataset,NULL);
if ( GDALmetadata )
@@ -3542,9 +3536,10 @@
QgsDebugMsg("dataset has no metadata");
- for ( int i = 1; i <= mGdalDataset->GetRasterCount(); ++i )
+ for ( int i = 1; i <= GDALGetRasterCount(mGdalDataset); ++i )
- mGdalDataset->GetRasterBand(i)->GetMetadata();
+ GDALRasterBandH gdalBand = GDALGetRasterBand(mGdalDataset,i);
+ GDALmetadata = GDALGetMetadata(gdalBand,NULL);
if ( GDALmetadata )
@@ -3556,7 +3551,7 @@
QgsDebugMsg("band " + QString::number(i) + "has no metadata");
- char ** GDALcategories = mGdalDataset->GetRasterBand(i)->GetCategoryNames();
+ char ** GDALcategories = GDALGetRasterCategoryNames(gdalBand);
if ( GDALcategories )
@@ -3576,12 +3571,12 @@
myMetadataQString += tr("Dimensions:");
- myMetadataQString += tr("X: ") + QString::number(mGdalDataset->GetRasterXSize()) +
- tr(" Y: ") + QString::number(mGdalDataset->GetRasterYSize()) + tr(" Bands: ") + QString::number(mGdalDataset->GetRasterCount());
+ myMetadataQString += tr("X: ") + QString::number(GDALGetRasterXSize(mGdalDataset)) +
+ tr(" Y: ") + QString::number(GDALGetRasterYSize(mGdalDataset)) + tr(" Bands: ") + QString::number(GDALGetRasterCount(mGdalDataset));
//just use the first band
myMetadataQString += "<tr><td class=\"glossy\">";
myMetadataQString += tr("No Data Value");
@@ -3602,7 +3597,7 @@
myMetadataQString += tr("Data Type:");
- switch (myGdalBand->GetRasterDataType())
+ switch (GDALGetRasterDataType(myGdalBand))
case GDT_Byte:
myMetadataQString += tr("GDT_Byte - Eight bit unsigned integer");
@@ -3683,7 +3678,7 @@
- if (mGdalDataset->GetGeoTransform(mGeoTransform) != CE_None)
+ if (GDALGetGeoTransform(mGdalDataset,mGeoTransform) != CE_None)
// if the raster does not have a valid transform we need to use
// a pixel size of (1,-1), but GDAL returns (1,1)
@@ -3858,14 +3853,14 @@
//close the gdal dataset and reopen it in read / write mode
- delete mGdalDataset;
- mGdalDataset = (GDALDataset *) GDALOpen(QFile::encodeName(mDataSource).constData(), GA_Update);
+ GDALClose( mGdalDataset );
+ mGdalDataset = GDALOpen(QFile::encodeName(mDataSource).constData(), GA_Update);
// if the dataset couldn't be opened in read / write mode, tell the user
if (!mGdalDataset)
emit drawingProgress(0,0);
- mGdalDataset = (GDALDataset *) GDALOpen(QFile::encodeName(mDataSource).constData(), GA_ReadOnly);
+ mGdalDataset = GDALOpen(QFile::encodeName(mDataSource).constData(), GA_ReadOnly);
return "ERROR_WRITE_FORMAT";
@@ -3912,26 +3907,26 @@
//see ticket #284
if(theResamplingMethod==tr("Average Magphase"))
- myError = mGdalDataset->BuildOverviews( "MODE", 1, myOverviewLevelsArray, 0, NULL,
+ myError = GDALBuildOverviews( mGdalDataset, "MODE", 1, myOverviewLevelsArray, 0, NULL,
GDALDummyProgress, NULL );
else if(theResamplingMethod==tr("Average"))
- myError = mGdalDataset->BuildOverviews( "AVERAGE", 1, myOverviewLevelsArray, 0, NULL,
+ myError = GDALBuildOverviews( mGdalDataset, "AVERAGE", 1, myOverviewLevelsArray, 0, NULL,
else // fall back to nearest neighbor
- myError = mGdalDataset->BuildOverviews( "NEAREST", 1, myOverviewLevelsArray, 0, NULL,
+ myError = GDALBuildOverviews( mGdalDataset, "NEAREST", 1, myOverviewLevelsArray, 0, NULL,
if (myError == CE_Failure || CPLGetLastErrorNo()==CPLE_NotSupported )
//something bad happenend
//QString myString = QString (CPLGetLastError());
return "FAILED_NOT_SUPPORTED";
@@ -3947,8 +3942,8 @@
QgsDebugMsg("Pyramid overviews built");
//close the gdal dataset and reopen it in read only mode
return NULL; // returning null on success
@@ -4043,12 +4038,12 @@
-void QgsRasterLayer::readColorTable ( GDALRasterBand *gdalBand, QgsColorTable *theColorTable )
+void QgsRasterLayer::readColorTable ( GDALRasterBandH gdalBand, QgsColorTable *theColorTable )
QgsDebugMsg("QgsRasterLayer::readColorTable()");
// First try to read color table from metadata
- char **metadata = gdalBand->GetMetadata();
+ char **metadata = GDALGetMetadata(gdalBand,NULL);
theColorTable->clear();
bool found = false;
while ( metadata && metadata[0] )
@@ -4079,15 +4074,15 @@
// If no color table was found, try to read it from GDALColorTable
if ( !found )
- GDALColorTable *gdalColorTable = gdalBand->GetColorTable();
+ GDALColorTableH gdalColorTable = GDALGetRasterColorTable(gdalBand);
if ( gdalColorTable )
- int count = gdalColorTable->GetColorEntryCount();
+ int count = GDALGetColorEntryCount(gdalColorTable);
for ( int i = 0; i < count; i++ )
- const GDALColorEntry *colorEntry = gdalColorTable->GetColorEntry ( i );
+ const GDALColorEntry *colorEntry = GDALGetColorEntry(gdalColorTable,i);
if ( !colorEntry ) continue;
@@ -4109,9 +4104,9 @@
-void *QgsRasterLayer::readData ( GDALRasterBand *gdalBand, QgsRasterViewPort *viewPort )
+void *QgsRasterLayer::readData ( GDALRasterBandH gdalBand, QgsRasterViewPort *viewPort )
- GDALDataType type = gdalBand->GetRasterDataType();
+ GDALDataType type = GDALGetRasterDataType(gdalBand);
int size = GDALGetDataTypeSize ( type ) / 8;
QgsDebugMsg("QgsRasterLayer::readData: calling RasterIO with " +\
@@ -4131,15 +4126,15 @@
else
- CPLErr myErr = gdalBand->RasterIO ( GF_Read,
- viewPort->rectXOffset,
- viewPort->rectYOffset,
- viewPort->clippedWidth,
- viewPort->clippedHeight,
- data,
- viewPort->drawableAreaXDim,
- viewPort->drawableAreaYDim,
- type, 0, 0 );
+ CPLErr myErr = GDALRasterIO( gdalBand, GF_Read,
+ viewPort->rectXOffset,
+ viewPort->rectYOffset,
+ viewPort->clippedWidth,
+ viewPort->clippedHeight,
+ data,
+ viewPort->drawableAreaXDim,
+ viewPort->drawableAreaYDim,
+ type, 0, 0 );
if (myErr != CPLE_None)
QgsLogger::warning("RaterIO error: " + QString(CPLGetLastErrorMsg()));
@@ -4793,7 +4788,7 @@
if ( x < mLayerExtent.xMin() || x > mLayerExtent.xMax() || y < mLayerExtent.yMin() || y > mLayerExtent.yMax() )
// Outside the raster
- for ( int i = 1; i <= mGdalDataset->GetRasterCount(); i++ )
+ for ( int i = 1; i <= GDALGetRasterCount(mGdalDataset); i++ )
results[tr("Band") + QString::number(i)] = tr("out of extent");
@@ -4810,14 +4805,15 @@
QgsDebugMsg( "row = " + QString::number(row) + " col = " + QString::number(col));
- GDALRasterBand *gdalBand = mGdalDataset->GetRasterBand(i);
void *data = CPLMalloc ( size );
- CPLErr err = gdalBand->RasterIO ( GF_Read, col, row, 1, 1, data, 1, 1, type, 0, 0 );
+ CPLErr err = GDALRasterIO( gdalBand, GF_Read, col, row, 1, 1,
+ data, 1, 1, type, 0, 0 );
if (err != CPLE_None)
@@ -4861,7 +4857,7 @@
void QgsRasterLayer::populateHistogram(int theBandNo, int theBinCount,bool theIgnoreOutOfRangeFlag,bool theHistogramEstimatedFlag)
//calculate the histogram for this band
//we assume that it only needs to be calculated if the lenght of the histogram
@@ -4891,7 +4887,7 @@
double myerval = (myRasterBandStats.maxVal-myRasterBandStats.minVal)/theBinCount;
- myGdalBand->GetHistogram( myRasterBandStats.minVal-0.1*myerval, myRasterBandStats.maxVal+0.1*myerval, theBinCount, myHistogramArray ,theIgnoreOutOfRangeFlag ,theHistogramEstimatedFlag , GDALDummyProgress, NULL );
+ GDALGetRasterHistogram( myGdalBand, myRasterBandStats.minVal-0.1*myerval, myRasterBandStats.maxVal+0.1*myerval, theBinCount, myHistogramArray ,theIgnoreOutOfRangeFlag ,theHistogramEstimatedFlag , GDALDummyProgress, NULL );
for (int myBin = 0; myBin <theBinCount; myBin++)
Modified: branches/gdalogr-capi-branch/qgis/src/core/raster/qgsrasterlayer.h
--- branches/gdalogr-capi-branch/qgis/src/core/raster/qgsrasterlayer.h 2008-02-15 23:37:51 UTC (rev 8161)
+++ branches/gdalogr-capi-branch/qgis/src/core/raster/qgsrasterlayer.h 2008-02-16 03:11:09 UTC (rev 8162)
@@ -150,8 +150,10 @@
* END
-#include <gdal_priv.h>
+#define CPL_SUPRESS_CPLUSPLUS
+#include <gdal.h>
// Forward declarations
@@ -163,9 +165,6 @@
struct QgsRasterViewPort;
class QImage;
class QPixmap;
-class GDALDataset;
-class GDALRasterBand;
class QSlider;
class QLibrary;
@@ -316,10 +315,12 @@
void resetNoDataValue()
- if(mGdalDataset != NULL && mGdalDataset->GetRasterCount() > 0)
+ if(mGdalDataset != NULL && GDALGetRasterCount(mGdalDataset) > 0)
int myRequestValid;
- double myValue = mGdalDataset->GetRasterBand(1)->GetNoDataValue(&myRequestValid);
+ double myValue = GDALGetRasterNoDataValue(
+ GDALGetRasterBand( mGdalDataset, 1 ), &myRequestValid);
if(0 != myRequestValid)
setNoDataValue(myValue);
@@ -947,13 +948,13 @@
QgsMapToPixel * theQgsMapToPixel, QImage* theImage);
/** \brief Read color table from GDAL raster band */
- void readColorTable ( GDALRasterBand *gdalBand, QgsColorTable *theColorTable );
+ void readColorTable ( GDALRasterBandH gdalBand, QgsColorTable *theColorTable );
/** \brief Allocate memory and load data to that allocated memory, data type is the same
* as raster band. The memory must be released later!
* \return pointer to the memory
- void *readData ( GDALRasterBand *gdalBand, QgsRasterViewPort *viewPort );
+ void *readData ( GDALRasterBandH gdalBand, QgsRasterViewPort *viewPort );
/** \brief Read a raster value on given position from memory block created by readData()
* \param index index in memory block
@@ -992,9 +993,9 @@
/** \brief Flag to indicate whether debug infor overlay should be rendered onto the raster. */
bool mDebugOverlayFlag;
/** \brief Pointer to the gdaldataset. */
- GDALDataset * mGdalBaseDataset;
+ GDALDatasetH mGdalBaseDataset;
/** \brief Pointer to the gdaldataset (possibly warped vrt). */
- GDALDataset * mGdalDataset;
+ GDALDatasetH mGdalDataset;
/** \brief Values for mapping pixel to world coordinates. Contents of
* this array are the same as the gdal adfGeoTransform */
double mGeoTransform[6];
Modified: branches/gdalogr-capi-branch/qgis/src/plugins/georeferencer/qgsimagewarper.cpp
--- branches/gdalogr-capi-branch/qgis/src/plugins/georeferencer/qgsimagewarper.cpp 2008-02-15 23:37:51 UTC (rev 8161)
+++ branches/gdalogr-capi-branch/qgis/src/plugins/georeferencer/qgsimagewarper.cpp 2008-02-16 03:11:09 UTC (rev 8162)
@@ -19,9 +19,7 @@
#include <cpl_conv.h>
#include <cpl_string.h>
#include <gdal.h>
#include <gdalwarper.h>
-#include <gdal_frmts.h>
#include <QFile>
@@ -32,12 +30,11 @@
ResamplingMethod resampling, bool useZeroAsTrans, const QString& compression) {
// Open input file
GDALAllRegister();
- GDALDataset* hSrcDS = static_cast<GDALDataset*>(GDALOpen(QFile::encodeName(input).constData(),
- GA_ReadOnly));
+ GDALDatasetH hSrcDS = GDALOpen(QFile::encodeName(input).constData(),GA_ReadOnly);
// Setup warp options.
GDALWarpOptions *psWarpOptions = GDALCreateWarpOptions();
psWarpOptions->hSrcDS = hSrcDS;
- psWarpOptions->nBandCount = hSrcDS->GetRasterCount();
+ psWarpOptions->nBandCount = GDALGetRasterCount(hSrcDS);
psWarpOptions->panSrcBands =
(int *) CPLMalloc(sizeof(int) * psWarpOptions->nBandCount);
psWarpOptions->panDstBands =
@@ -52,8 +49,8 @@
// check the bounds for the warped raster
// order: upper right, lower right, lower left (y points down)
- double x[] = { hSrcDS->GetRasterXSize(), hSrcDS->GetRasterXSize(), 0 };
- double y[] = { 0, hSrcDS->GetRasterYSize(), hSrcDS->GetRasterYSize() };
+ double x[] = { GDALGetRasterXSize(hSrcDS), GDALGetRasterXSize(hSrcDS), 0 };
+ double y[] = { 0, GDALGetRasterYSize(hSrcDS), GDALGetRasterYSize(hSrcDS) };
int s[] = { 0, 0, 0 };
TransformParameters tParam = { mAngle, 0, 0 };
transform(&tParam, FALSE, 3, x, y, NULL, s);
@@ -73,32 +70,37 @@
psWarpOptions->pTransformerArg = &tParam;
// create the output file
- GDALDriver* driver = static_cast<GDALDriver*>(GDALGetDriverByName("GTiff"));
+ GDALDriverH driver = GDALGetDriverByName("GTiff");
char **papszOptions = NULL;
papszOptions = CSLSetNameValue(papszOptions, "INIT_DEST", "NO_DATA");
papszOptions = CSLSetNameValue(papszOptions, "COMPRESS", compression);
- GDALDataset* hDstDS =
- driver->Create(QFile::encodeName(output).constData(), newXSize, newYSize,
- hSrcDS->GetRasterCount(),
- hSrcDS->GetRasterBand(1)->GetRasterDataType(),
- papszOptions);
- for (int i = 0; i < hSrcDS->GetRasterCount(); ++i)
+ GDALDatasetH hDstDS =
+ GDALCreate(driver,
+ QFile::encodeName(output).constData(), newXSize, newYSize,
+ GDALGetRasterCount(hSrcDS),
+ GDALGetRasterDataType(GDALGetRasterBand(hSrcDS,1)),
+ papszOptions );
+ for( int i = 0; i < GDALGetRasterCount(hSrcDS); ++i )
+ GDALRasterBandH hSrcBand = GDALGetRasterBand(hSrcDS,i+1);
+ GDALRasterBandH hDstBand = GDALGetRasterBand(hDstDS,i+1);
+ GDALColorTableH cTable = GDALGetRasterColorTable(hSrcDS);
+ if (cTable)
- GDALColorTable* cTable = hSrcDS->GetRasterBand(i+1)->GetColorTable();
- if (cTable)
- hDstDS->GetRasterBand(i+1)->SetColorTable(cTable);
- double noData = hSrcDS->GetRasterBand(i+1)->GetNoDataValue();
- if (noData == -1e10 && useZeroAsTrans)
- hDstDS->GetRasterBand(i+1)->SetNoDataValue(0);
- else
- hDstDS->GetRasterBand(i+1)->SetNoDataValue(noData);
+ GDALSetRasterColorTable(hDstDS,cTable);
+ double noData = GDALGetRasterNoDataValue(hSrcBand,NULL);
+ if (noData == -1e10 && useZeroAsTrans)
+ GDALSetRasterNoDataValue(hDstBand,0);
+ else
+ GDALSetRasterNoDataValue(hDstBand,noData);
psWarpOptions->hDstDS = hDstDS;
// Initialize and execute the warp operation.
@@ -107,8 +109,9 @@
oOperation.ChunkAndWarpImage(0, 0, GDALGetRasterXSize(hDstDS),
GDALGetRasterYSize(hDstDS));
GDALDestroyWarpOptions(psWarpOptions);
- delete hSrcDS;
- delete hDstDS;
+ GDALClose( hSrcDS );
+ GDALClose( hDstDS );
