[QGIS Commit] r8163 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Sat Feb 16 14:34:27 EST 2008
Author: gsherman
Date: 2008-02-16 14:34:27 -0500 (Sat, 16 Feb 2008)
New Revision: 8163
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/app/qgsoptions.h
trunk/qgis/src/ui/qgsoptionsbase.ui
Remove need for specifying the web browser. QDesktopServices are used instead.
Drag and drop implementation.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-02-16 03:11:09 UTC (rev 8162)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-02-16 19:34:27 UTC (rev 8163)
@@ -31,6 +31,7 @@
#include <QClipboard>
#include <QColor>
#include <QCursor>
+#include <QDesktopServices>
#include <QDesktopWidget>
#include <QDialog>
#include <QDir>
@@ -401,6 +402,10 @@
mSplash->showMessage(tr("QGIS Ready!"), Qt::AlignHCenter | Qt::AlignBottom);
mMapTipsVisible = false;
+ // setup drag drop
+ setAcceptDrops(true);
mFullScreenMode = false;
showNormal();
qApp->processEvents();
@@ -439,6 +444,43 @@
QgsApplication::exitQgis();
+void QgisApp::dragEnterEvent(QDragEnterEvent *event)
+ if (event->mimeData()->hasUrls())
+ event->acceptProposedAction();
+void QgisApp::dropEvent(QDropEvent *event)
+ // get the file list
+ QList<QUrl>::iterator i;
+ QList<QUrl>urls = event->mimeData()->urls();
+ for (i = urls.begin(); i != urls.end(); i++)
+ QUrl mUrl = *i;
+ // seems that some drag and drop operations include an empty url
+ // so we test for length to make sure we have something
+ if( mUrl.path().length() > 0)
+ // check to see if we are opening a project file
+ QFileInfo fi(mUrl.path());
+ if( fi.completeSuffix() == "qgs" )
+ QgsDebugMsg("Opening project " + mUrl.path());
+ else
+ QgsDebugMsg("Adding " + mUrl.path() + " to the map canvas");
+ openLayer(mUrl.path());
// restore any application settings stored in QSettings
void QgisApp::readSettings()
@@ -4259,47 +4301,7 @@
status = 0; //avoid compiler warning
CFRelease(urlRef);
#else
- // find a browser
- QSettings settings;
- QString browser = settings.readEntry("/qgis/browser");
- if (browser.length() == 0)
- // ask user for browser and use it
- bool ok;
- QString myHeading = tr("QGIS Browser Selection");
- QString myMessage = tr("Enter the name of a web browser to use (eg. konqueror).\n");
- myMessage += tr("Enter the full path if the browser is not in your PATH.\n");
- myMessage += tr("You can change this option later by selecting Options from the Settings menu (Help Browser tab).");
- QString text = QInputDialog::getText(myHeading,
- myMessage,
- QLineEdit::Normal,
- QString::null, &ok, this);
- if (ok && !text.isEmpty())
- // user entered something and pressed OK
- browser = text;
- // save the setting
- settings.writeEntry("/qgis/browser", browser);
- else
- browser = "";
- if (browser.length() > 0)
- // find the installed location of the help files
- // open index.html using browser
- //XXX for debug on win32 QMessageBox::information(this,"Help opening...", browser + " - " + url);
- QProcess *helpProcess = new QProcess(this);
- QStringList myArgs;
- myArgs << url;
- helpProcess->start(browser,myArgs);
- /* mHelpViewer = new QgsHelpViewer(this,"helpviewer",false);
- mHelpViewer->showContent(QgsApplication::prefixPath() +"/share/doc","index.html");
- mHelpViewer->show(); */
+ QDesktopServices::openUrl(url);
#endif
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2008-02-16 03:11:09 UTC (rev 8162)
+++ trunk/qgis/src/app/qgisapp.h 2008-02-16 19:34:27 UTC (rev 8163)
@@ -145,6 +145,10 @@
//! Returns a pointer to the internal clipboard
QgsClipboard * clipboard();
+ void dragEnterEvent(QDragEnterEvent *);
+ void dropEvent(QDropEvent *);
//private slots:
public slots:
//! About QGis
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2008-02-16 03:11:09 UTC (rev 8162)
+++ trunk/qgis/src/app/qgsoptions.cpp 2008-02-16 19:34:27 UTC (rev 8163)
@@ -53,8 +53,6 @@
qparent = parent;
// read the current browser and set it
QSettings settings;
- cmbBrowser->setCurrentText(browser);
#ifdef QGISDEBUG
std::cout << "Standard Identify radius setting: " << QGis::DEFAULT_IDENTIFY_RADIUS << std::endl;
#endif
@@ -223,7 +221,6 @@
void QgsOptions::saveOptions()
QSettings settings;
- settings.writeEntry("/qgis/browser", cmbBrowser->currentText());
settings.writeEntry("/Map/identifyRadius", spinBoxIdentifyValue->value());
settings.writeEntry("/qgis/hideSplash",cbxHideSplash->isChecked());
settings.writeEntry("/qgis/new_layers_visible",chkAddedVisibility->isChecked());
@@ -300,26 +297,6 @@
-void QgsOptions::on_btnFindBrowser_clicked()
- QString filter;
-#ifdef WIN32
- filter = "Applications (*.exe)";
-#else
- filter = "All Files (*)";
-#endif
- QString browser = QFileDialog::getOpenFileName(
- this,
- "Choose a browser",
- filter );
- if(browser.length() > 0)
void QgsOptions::on_pbnSelectProjection_clicked()
QSettings settings;
Modified: trunk/qgis/src/app/qgsoptions.h
--- trunk/qgis/src/app/qgsoptions.h 2008-02-16 03:11:09 UTC (rev 8162)
+++ trunk/qgis/src/app/qgsoptions.h 2008-02-16 19:34:27 UTC (rev 8163)
@@ -49,7 +49,6 @@
public slots:
//! Slot called when user chooses to change the project wide projection.
void on_pbnSelectProjection_clicked();
- void on_btnFindBrowser_clicked();
void on_chkAntiAliasing_stateChanged();
void on_chkUseQPixmap_stateChanged();
void saveOptions();
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2008-02-16 03:11:09 UTC (rev 8162)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2008-02-16 19:34:27 UTC (rev 8163)
@@ -1021,107 +1021,6 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabHelpBrowser" >
- <attribute name="title" >
- <string>Help &Browser</string>
- </attribute>
- <layout class="QGridLayout" >
- <property name="margin" >
- <number>11</number>
- </property>
- <property name="spacing" >
- <number>6</number>
- </property>
- <item row="2" column="0" colspan="2" >
- <spacer>
- <property name="orientation" >
- <enum>Qt::Vertical</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>20</width>
- <height>40</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="1" column="0" colspan="3" >
- <widget class="QLabel" name="textLabel1_2" >
- <property name="text" >
- <string><b>Note:</b> The browser must be in your PATH or you can specify the full path above</string>
- </property>
- <property name="wordWrap" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- <item row="0" column="2" >
- <widget class="QPushButton" name="btnFindBrowser" >
- <property name="maximumSize" >
- <size>
- <width>60</width>
- <height>32767</height>
- </size>
- </property>
- <string>...</string>
- </property>
- </widget>
- </item>
- <item row="0" column="1" >
- <widget class="QComboBox" name="cmbBrowser" >
- <property name="editable" >
- <bool>true</bool>
- </property>
- <item>
- <string>epiphany</string>
- </property>
- </item>
- <item>
- <string>firefox</string>
- </property>
- </item>
- <item>
- <string>mozilla-firefox</string>
- </property>
- </item>
- <item>
- <string>galeon</string>
- </property>
- </item>
- <item>
- <string>konqueror</string>
- </property>
- </item>
- <item>
- <string>mozilla</string>
- </property>
- </item>
- <item>
- <string>opera</string>
- </property>
- </item>
- </widget>
- </item>
- <item row="0" column="0" >
- <widget class="QLabel" name="textLabel1" >
- <string>Open help documents with</string>
- </property>
- <property name="buddy" >
- <cstring>cmbBrowser</cstring>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
</widget>
</item>
</layout>
@@ -1136,7 +1035,6 @@
</customwidgets>
<tabstops>
<tabstop>tabWidget</tabstop>
- <tabstop>btnFindBrowser</tabstop>
<tabstop>cbxHideSplash</tabstop>
<tabstop>cmbTheme</tabstop>
<tabstop>pbnSelectionColour</tabstop>
@@ -1150,7 +1048,6 @@
<tabstop>radUseGlobalProjection</tabstop>
<tabstop>txtGlobalWKT</tabstop>
<tabstop>pbnSelectProjection</tabstop>
- <tabstop>cmbBrowser</tabstop>
</tabstops>
<resources/>
<connections/>
