[QGIS Commit] r8183 - trunk/qgis/src/plugins/grid_maker
svn_qgis at osgeo.org
Thu Feb 28 12:16:31 EST 2008
Author: timlinux
Date: 2008-02-28 12:16:31 -0500 (Thu, 28 Feb 2008)
New Revision: 8183
trunk/qgis/src/plugins/grid_maker/graticulecreator.cpp
Write column and row as graticule attributes
Modified: trunk/qgis/src/plugins/grid_maker/graticulecreator.cpp
--- trunk/qgis/src/plugins/grid_maker/graticulecreator.cpp 2008-02-26 16:29:09 UTC (rev 8182)
+++ trunk/qgis/src/plugins/grid_maker/graticulecreator.cpp 2008-02-28 17:16:31 UTC (rev 8183)
@@ -30,11 +30,17 @@
QgsField myField3("LblOffsetX",QVariant::Int,"Int",5,0,"X Offset for label");
QgsField myField4("LblOffsetY",QVariant::Int,"int",5,0,"Y Offset for label");
QgsField myField5("Label",QVariant::String,"String",10,0,"Label text");
+ QgsField myField6("Row",QVariant::String,"String",10,0,"Row");
+ QgsField myField7("Column",QVariant::String,"String",10,0,"Col");
+ QgsField myField8("RowCol",QVariant::String,"String",10,0,"Row and col");
mFields.insert(0, myField1);
mFields.insert(1, myField2);
mFields.insert(2, myField3);
mFields.insert(3, myField4);
mFields.insert(4, myField5);
+ mFields.insert(5, myField6);
+ mFields.insert(6, myField7);
+ mFields.insert(7, myField8);
mSRS = QgsSpatialRefSys(GEOWKT);
mFileName = theOutputFileName;
@@ -77,7 +83,8 @@
theYEndPoint = myBuffer;
+ int myColumn=0;
+ int myRow=0;
for (double i=theXOrigin;
i<=theXEndPoint;
i+=theXInterval)
@@ -163,8 +170,16 @@
myFeature.addAttribute(3,20);//"LabelOffsetY"
myFeature.addAttribute(4,QString::number(i));//"Label"
+ // Set column and row attributes
+ myFeature.addAttribute(6,QString::number(myRow));
+ myFeature.addAttribute(7,QString::number(myColumn));
+ myFeature.addAttribute(8,QString::number(myRow) + "," +
+ QString::number(myColumn));
+ ++myRow;
+ ++myColumn;
// Write the feature to the filewriter
// and check for errors
