[QGIS Commit] r8600 - trunk/qgis/src/mac/Contents
svn_qgis at osgeo.org
Fri Jun 6 02:11:00 EDT 2008
Author: telwertowski
Date: 2008-06-06 02:10:56 -0400 (Fri, 06 Jun 2008)
New Revision: 8600
Added:
trunk/qgis/src/mac/Contents/Info.plist.cmake
trunk/qgis/src/mac/Contents/CMakeLists.txt
trunk/qgis/src/mac/Contents/Info.plist.in
Use cmake script with CONFIGURE_FILE rather than grep/sed to create Mac Info.plist. This circumvents command-line quoting problems when upgrading to CMake 2.6.
Modified: trunk/qgis/src/mac/Contents/CMakeLists.txt
--- trunk/qgis/src/mac/Contents/CMakeLists.txt 2008-06-06 05:48:39 UTC (rev 8599)
+++ trunk/qgis/src/mac/Contents/CMakeLists.txt 2008-06-06 06:10:56 UTC (rev 8600)
@@ -3,21 +3,12 @@
# create Info.plist
ADD_CUSTOM_TARGET(Info.plist ALL
- VERSION=`grep VERSION ${CMAKE_BINARY_DIR}/qgsconfig.h | head -1 |
- sed -e "s/#define VERSION //"
- -e "s/\\\"//g"` &&
- SVNVERSION=`grep QGSSVNVERSION ${CMAKE_BINARY_DIR}/qgssvnversion.h |
- sed -e "s/#define QGSSVNVERSION //"
- sed -e "s/@VERSION/$$VERSION/"
- -e "s/@SHORTVERSION/$$VERSION/"
- -e "s/@SVNVERSION/$$SVNVERSION/"
- < ${CMAKE_CURRENT_SOURCE_DIR}/Info.plist.in > Info.plist
- DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/Info.plist.in
- ${CMAKE_BINARY_DIR}/qgsconfig.h)
+ DEPENDS ${SVN_MARKER}
+ COMMAND ${CMAKE_COMMAND}
+ -D CURRENT_SOURCE_DIR=${CMAKE_CURRENT_SOURCE_DIR}
+ -D VERSION=${COMPLETE_VERSION}-${RELEASE_NAME}
+ -P ${CMAKE_CURRENT_SOURCE_DIR}/Info.plist.cmake)
-ADD_DEPENDENCIES(Info.plist svnversion)
# process subdirs
Added: trunk/qgis/src/mac/Contents/Info.plist.cmake
--- trunk/qgis/src/mac/Contents/Info.plist.cmake (rev 0)
+++ trunk/qgis/src/mac/Contents/Info.plist.cmake 2008-06-06 06:10:56 UTC (rev 8600)
@@ -0,0 +1,15 @@
+SET(CMAKE_BACKWARDS_COMPATIBILITY "2.4")
+# See if we have svn installed
+FIND_PROGRAM(SVNVERSION svnversion)
+# Read the revision if installed, else set to "unknown"
+IF (SVNVERSION)
+ EXEC_PROGRAM (${SVNVERSION} ARGS ${CURRENT_SOURCE_DIR} OUTPUT_VARIABLE REVISION)
+ELSE (SVNVERSION)
+ SET (REVISION unknown)
+ENDIF (SVNVERSION)
+# Create Info.plist
+CONFIGURE_FILE (${CURRENT_SOURCE_DIR}/Info.plist.in
+ ${CMAKE_CURRENT_BINARY_DIR}/Info.plist)
Property changes on: trunk/qgis/src/mac/Contents/Info.plist.cmake
___________________________________________________________________
+ Author Date Id Revision
+ native
Modified: trunk/qgis/src/mac/Contents/Info.plist.in
--- trunk/qgis/src/mac/Contents/Info.plist.in 2008-06-06 05:48:39 UTC (rev 8599)
+++ trunk/qgis/src/mac/Contents/Info.plist.in 2008-06-06 06:10:56 UTC (rev 8600)
@@ -11,11 +11,11 @@
<key>CFBundleSignature</key>
<string>QGIS</string>
<key>CFBundleGetInfoString</key>
- <string>QGIS @VERSION (@SVNVERSION), © 2002-2008 QGIS Development Team</string>
+ <string>QGIS @VERSION@ (@REVISION@), © 2002-2008 QGIS Development Team</string>
<key>CFBundleShortVersionString</key>
- <string>@SHORTVERSION (@SVNVERSION)</string>
+ <string>@VERSION@ (@REVISION@)</string>
<key>CFBundleVersion</key>
- <string>@VERSION</string>
<key>CFBundleIconFile</key>
<string>qgis.icns</string>
<key>CFBundleDocumentTypes</key>
@@ -176,15 +176,17 @@
</array>
<key>CFBundleLocalizations</key>
<array>
+ <string>en</string>
<string>ar</string>
- <string>en</string>
<string>cs_CZ</string>
<string>de</string>
<string>es</string>
<string>fr</string>
+ <string>hu</string>
<string>id</string>
<string>it</string>
<string>ja</string>
+ <string>lo</string>
<string>lt</string>
<string>lv</string>
<string>mn</string>
