[QGIS Commit] r8602 - trunk/qgis/src/core
svn_qgis at osgeo.org
Fri Jun 6 07:33:19 EDT 2008
Author: mhugent
Date: 2008-06-06 07:33:19 -0400 (Fri, 06 Jun 2008)
New Revision: 8602
trunk/qgis/src/core/qgsdistancearea.cpp
trunk/qgis/src/core/qgsvectorlayer.cpp
changed some debug statements to use QgsDebugMsg
Modified: trunk/qgis/src/core/qgsdistancearea.cpp
--- trunk/qgis/src/core/qgsdistancearea.cpp 2008-06-06 06:41:11 UTC (rev 8601)
+++ trunk/qgis/src/core/qgsdistancearea.cpp 2008-06-06 11:33:19 UTC (rev 8602)
@@ -114,9 +114,7 @@
// row for this ellipsoid wasn't found?
if (radius.isEmpty() || parameter2.isEmpty())
-#ifdef QGISDEBUG
- std::cout << "setEllipsoid: no row in tbl_ellipsoid for acronym '" << ellipsoid.toLocal8Bit().data() << "'" << std::endl;
-#endif
+ QgsDebugMsg(QString("setEllipsoid: no row in tbl_ellipsoid for acronym '") + ellipsoid.toLocal8Bit().data() + "'")
return false;
@@ -125,9 +123,7 @@
mSemiMajor = radius.mid(2).toDouble();
else
-#ifdef QGISDEBUG
- std::cout << "setEllipsoid: wrong format of radius field: '" << radius.toLocal8Bit().data() << "'" << std::endl;
-#endif
+ QgsDebugMsg(QString("setEllipsoid: wrong format of radius field: '") + radius.toLocal8Bit().data() + "'")
return false;
@@ -146,15 +142,11 @@
else
-#ifdef QGISDEBUG
- std::cout << "setEllipsoid: wrong format of parameter2 field: '" << parameter2.toLocal8Bit().data() << "'" << std::endl;
-#endif
+ QgsDebugMsg(QString("setEllipsoid: wrong format of parameter2 field: '") + parameter2.toLocal8Bit().data() + "'")
return false;
-#ifdef QGISDEBUG
- std::cout << "setEllipsoid: a=" << mSemiMajor << ", b=" << mSemiMinor << ", 1/f=" << mInvFlattening << std::endl;
-#endif
+ QgsDebugMsg(QString("setEllipsoid: a=") + mSemiMajor + ", b=" + mSemiMinor + ", 1/f=" + mInvFlattening)
// get spatial ref system for ellipsoid
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2008-06-06 06:41:11 UTC (rev 8601)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2008-06-06 11:33:19 UTC (rev 8602)
@@ -2009,9 +2009,8 @@
bool QgsVectorLayer::readXML_( QDomNode & layer_node )
-#ifdef QGISDEBUG
- std::cerr << "Datasource in QgsVectorLayer::readXML_: " << mDataSource.toLocal8Bit().data() << std::endl;
-#endif
+ QgsDebugMsg(QString("Datasource in QgsVectorLayer::readXML_: ") + mDataSource.toLocal8Bit().data());
// process the attribute actions
mActions->readXML(layer_node);
@@ -2131,17 +2130,14 @@
setLabelOn(true);
-#ifdef QGISDEBUG
- std::cout << "Testing if qgsvectorlayer can call label readXML routine" << std::endl;
-#endif
+ QgsDebugMsg("Testing if qgsvectorlayer can call label readXML routine")
QDomNode labelattributesnode = layer_node.namedItem("labelattributes");
if(!labelattributesnode.isNull())
-#ifdef QGISDEBUG
- std::cout << "qgsvectorlayer calling label readXML routine" << std::endl;
-#endif
+ QgsDebugMsg("qgsvectorlayer calling label readXML routine")
mLabel->readXML(labelattributesnode);
