[QGIS Commit] r8662 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Jun 21 06:02:46 EDT 2008
Author: taraathan
Date: 2008-06-21 06:02:46 -0400 (Sat, 21 Jun 2008)
New Revision: 8662
   docs/trunk/english_us/user_guide/getting_started.tex
used \dialog macro
Modified: docs/trunk/english_us/user_guide/getting_started.tex
--- docs/trunk/english_us/user_guide/getting_started.tex	2008-06-21 10:02:14 UTC (rev 8661)
+++ docs/trunk/english_us/user_guide/getting_started.tex	2008-06-21 10:02:46 UTC (rev 8662)
@@ -417,7 +417,7 @@
 Scale dependent rendering allows you to specify the minimum and maximum
 scales at which a layer will be visible.  To set scale dependency rendering,
-open the properties dialog by double-clicking on the layer in the legend. On
+open the \dialog{Properties} dialog by double-clicking on the layer in the legend. On
 the \tab{General} tab, set the minimum and maximum scale values and then
 click on the \checkbox{Use scale dependent rendering} checkbox.
@@ -539,7 +539,7 @@
 \subsection{GUI Options}
 \label{subsec:gui_options}
 \includegraphics[width=0.7cm,clip=true]{mActionOptions} Some basic options for QGIS
-can be selected using the Options dialog. Select the
+can be selected using the \dialog{Options} dialog. Select the
 menu option \mainmenuopt{Settings} >
  \dropmenuopttwo{mActionOptions}{Options} or press \keystroke{Alt-O}. The tabs where you can
 optmize your options are:
@@ -645,16 +645,17 @@
 Note that you can have multiple bookmarks with the same name.
 \subsubsection{Working with Bookmarks}
-To use or manage bookmarks, select the menu option \mainmenuopt{View} > \dropmenuopt{Show Bookmarks}.
-The bookmarks dialog allows you to zoom to or delete a bookmark.
+To use or manage bookmarks, select the menu
+option \mainmenuopt{View} > \dropmenuopt{Show Bookmarks}.
+The \dialog{Geospatial Bookmarks} dialog allows you to zoom to or delete a bookmark.
 You can not edit the bookmark name or coordinates.
 \subsubsection{Zooming to a Bookmark}
-From the Bookmarks dialog, select the desired bookmark by clicking on it,
+From the \dialog{Geospatial Bookmarks} dialog, select the desired bookmark by clicking on it,
 then click \button{Zoom To}.
 You can also zoom to a bookmark by double-clicking on it.
 \subsubsection{Deleting a Bookmark}
-To delete a bookmark from the Bookmarks dialog, click on it then click
+To delete a bookmark from the \dialog{Geospatial Bookmarks} dialog, click on it then click
  \button{Delete}.
 Confirm your choice by clicking \button{Yes} or cancel the delete by clicking \button{No}.
More information about the QGIS-commit mailing list
