[QGIS Commit] r8663 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Sat Jun 21 06:04:03 EDT 2008
Author: taraathan
Date: 2008-06-21 06:04:03 -0400 (Sat, 21 Jun 2008)
New Revision: 8663
docs/trunk/english_us/user_guide/working_with_ogc.tex
used \dialog macro
changed [h] float option to [ht] to eliminate latex warning messages
Modified: docs/trunk/english_us/user_guide/working_with_ogc.tex
--- docs/trunk/english_us/user_guide/working_with_ogc.tex 2008-06-21 10:02:46 UTC (rev 8662)
+++ docs/trunk/english_us/user_guide/working_with_ogc.tex 2008-06-21 10:04:03 UTC (rev 8663)
@@ -70,7 +70,7 @@
select \button{New}. Then enter in the parameters to connect to your desired
WMS server, as listed in table \ref{tab:wms_connection_parms}:
-\begin{table}[h]\index{WMS!client!connection parameters}
+\begin{table}[ht]\index{WMS!client!connection parameters}
\centering
\caption{WMS Connection Parameters}\label{tab:wms_connection_parms}\medskip
\begin{tabular}{|l|p{5in}|}
@@ -96,7 +96,7 @@
Once the new WMS Server has been created, it will be preserved across future
QGIS sessions.
-\begin{Tip}[h]\caption{\textsc{On WMS Server URLs}}
+\begin{Tip}[ht]\caption{\textsc{On WMS Server URLs}}
\qgistip{Be sure, when entering in the WMS server URL, that you have
the base URL. For example, you shouldn't have fragments such as
\usertext{request=GetCapabilities} or \usertext{version=1.0.0}
@@ -109,7 +109,7 @@
%FIXME: WMS URLs should be checked again and maybe extended in QGIS
-\begin{table}[h]\index{WMS!remote server!URL!examples}
+\begin{table}[ht]\index{WMS!remote server!URL!examples}
\centering
\caption{Example Public WMS URLs}\label{tab:wms_example_urls}\medskip
\begin{tabular}{|l|l|}
@@ -139,7 +139,7 @@
response provided by the NASA JPL OnEarth WMS server.
% \begin{figure}[ht]
-\begin{figure}[h]
+\begin{figure}[ht]
\begin{center}
\caption{Dialog for adding a WMS server, showing its available layers}\label{fig:connection_wms}
\includegraphics[clip=true,width=0.6\textwidth]{connection_wms}
@@ -151,7 +151,7 @@
The \tab{Image encoding} section now lists the formats that are supported by both
the client and server. Choose one depending on your image accuracy requirements.
-\begin{Tip}[h]\caption{\textsc{Image Encoding}}
+\begin{Tip}[ht]\caption{\textsc{Image Encoding}}
\qgistip{You will typically find that a WMS server offers you the choice
of JPEG or PNG image encoding. JPEG is a lossy compression format,
whereas PNG faithfully reproduces the raw raster data.
@@ -176,7 +176,7 @@
When several layers are selected, they will be combined at the WMS Server
and transmitted to QGIS in one go.
-\begin{Tip}[h]\caption{\textsc{WMS Layer Ordering}}
+\begin{Tip}[ht]\caption{\textsc{WMS Layer Ordering}}
\qgistip{In this version of QGIS, WMS layers rendered by a server are overlaid
in the order listed in the Layers section, from top to bottom of the list.
If you want to overlay layers in the opposite order, then you can
@@ -196,7 +196,7 @@
This, in theory, allows you to overlay WMS layers on other layers (raster,
vector or WMS) and still see through to those lower layers.
-\begin{Tip}[h]\caption{\textsc{WMS Layer Transparency}}
+\begin{Tip}[ht]\caption{\textsc{WMS Layer Transparency}}
\qgistip{The availability of WMS image transparency depends on
the image encoding used: PNG and GIF support transparency,
whilst JPEG leaves it unsupported.
@@ -224,7 +224,7 @@
those CRSs supported by the WMS Server will be shown.
-\begin{Tip}[h]\caption{\textsc{WMS Projections}}
+\begin{Tip}[ht]\caption{\textsc{WMS Projections}}
\qgistip{For best results, make the WMS layer the first layer
you add in the project. This allows the project
projection to inherit the CRS you used to render the WMS layer.
@@ -417,7 +417,7 @@
Remember this plugin is still experimental. You might also experience random behavior
and crashes. You can look forward to improvements in a future version of the plugin.
-\begin{Tip}[h]\caption{\textsc{Finding WMS and WFS Servers}}
+\begin{Tip}[ht]\caption{\textsc{Finding WMS and WFS Servers}}
\qgistip{You can find additional WMS and WFS servers by using Google or your
favorite search engine. There are a number of lists, some of them
maintained and some not, that list public servers you can use.
