[QGIS Commit] r8272 - trunk/qgis/src/core/renderer
svn_qgis at osgeo.org
Tue Mar 25 16:19:53 EDT 2008
Author: jef
Date: 2008-03-25 16:19:53 -0400 (Tue, 25 Mar 2008)
New Revision: 8272
trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp
trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.h
speed up loading of projects using unique value renderers
Modified: trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp
--- trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp 2008-03-25 20:16:03 UTC (rev 8271)
+++ trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp 2008-03-25 20:19:53 UTC (rev 8272)
@@ -31,6 +31,7 @@
QgsUniqueValueRenderer::QgsUniqueValueRenderer(QGis::VectorType type): mClassificationField(0)
mVectorType = type;
+ mSymbolAttributesDirty = false;
QgsUniqueValueRenderer::QgsUniqueValueRenderer(const QgsUniqueValueRenderer& other)
@@ -84,7 +85,7 @@
void QgsUniqueValueRenderer::insertValue(QString name, QgsSymbol* symbol)
mSymbols.insert(name, symbol);
- updateSymbolAttributes();
+ mSymbolAttributesDirty=true;
void QgsUniqueValueRenderer::setClassificationField(int field)
@@ -105,6 +106,11 @@
void QgsUniqueValueRenderer::renderFeature(QPainter* p, QgsFeature& f,QImage* img,
double* scalefactor, bool selected, double widthScale)
+ if(mSymbolAttributesDirty) {
+ QgsDebugMsg("Missed updateSymbolAttributes() call - doing it now");
+ updateSymbolAttributes();
QgsSymbol* symbol = symbolForFeature(&f);
if(!symbol) //no matching symbol
@@ -131,13 +137,13 @@
//first find out the value for the scale classification attribute
const QgsAttributeMap& attrs = f.attributeMap();
fieldScale = sqrt(fabs(attrs[symbol->scaleClassificationField()].toDouble()));
- QgsDebugMsg(QString("Feature has field scale factor %1").arg(fieldScale));
+ QgsDebugMsgLevel(QString("Feature has field scale factor %1").arg(fieldScale), 3);
if ( symbol->rotationClassificationField() >= 0 )
rotation = attrs[symbol->rotationClassificationField()].toDouble();
- QgsDebugMsg(QString("Feature has rotation factor %1").arg(rotation));
+ QgsDebugMsgLevel(QString("Feature has rotation factor %1").arg(rotation), 3);
*img = symbol->getPointSymbolAsImage( widthScale, selected, mSelectionColor,
*scalefactor * fieldScale, rotation);
@@ -194,10 +200,11 @@
QgsSymbol* msy = new QgsSymbol(mVectorType);
msy->readXML ( symbolnode );
- this->insertValue(msy->lowerValue(),msy);
+ insertValue(msy->lowerValue(),msy);
symbolnode = symbolnode.nextSibling();
- vl.setRenderer(this);
+ vl.setRenderer(this);
void QgsUniqueValueRenderer::clearValues()
@@ -212,8 +219,7 @@
void QgsUniqueValueRenderer::updateSymbolAttributes()
- // This function is only called after changing field specifier in the GUI.
- // Timing is not so important.
mSymbolAttributes.clear();
Modified: trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.h
--- trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.h 2008-03-25 20:16:03 UTC (rev 8271)
+++ trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.h 2008-03-25 20:19:53 UTC (rev 8272)
@@ -46,7 +46,8 @@
void updateSymbolAttributes();
/**Returns the renderers name*/
QString name() const;
- /**Inserts an entry into mEntries. The render items have to be created with the new operator and are automatically destroyed if not needed anymore*/
+ /**Inserts an entry into mEntries. The render items have to be created with the new operator and
+ are automatically destroyed if not needed anymore */
void insertValue(QString name, QgsSymbol* symbol);
/**Removes all entries from mEntries*/
void clearValues();
@@ -66,6 +67,7 @@
QgsSymbol* symbolForFeature(const QgsFeature* f);
/**Cached copy of all underlying symbols required attribute fields*/
QgsAttributeList mSymbolAttributes;
+ bool mSymbolAttributesDirty; // insertValue was called
inline bool QgsUniqueValueRenderer::needsAttributes() const
