[QGIS Commit] r8273 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Mar 25 17:24:56 EDT 2008
Author: jef
Date: 2008-03-25 17:24:56 -0400 (Tue, 25 Mar 2008)
New Revision: 8273
   trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
   trunk/qgis/src/providers/postgres/qgspostgresprovider.h
reintroduce connection pooling, but use cursors independantly of transactions
by declaring them "WITH HOLD" and "CLOSE" them when done.
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-03-25 20:19:53 UTC (rev 8272)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2008-03-25 21:24:56 UTC (rev 8273)
@@ -58,6 +58,9 @@
 const QString POSTGRES_KEY = "postgres";
 const QString POSTGRES_DESCRIPTION = "PostgreSQL/PostGIS data provider";
+QMap<QString, QgsPostgresProvider::Conn *> QgsPostgresProvider::connections;
+int QgsPostgresProvider::providerIds=0;
 QgsPostgresProvider::QgsPostgresProvider(QString const & uri)
 : QgsVectorDataProvider(uri),
   geomType(QGis::WKBUnknown),
@@ -67,10 +70,7 @@
   // assume this is a valid layer until we determine otherwise
   valid = true;
-  // Make connection to the data source
-  // For postgres, the connection information is passed as a space delimited
-  // string:
-  //  host=192.168.1.5 dbname=test port=5342 user=gsherman password=xxx table=tablename
+  providerId=providerIds++;
   QgsDebugMsg("Postgresql Layer Creation");
   QgsDebugMsg("URI: " + uri);
@@ -234,8 +234,6 @@
   QgsDebugMsg("Main thread just dispatched mCountThread");
 #endif
-  ready = false; // not ready to read yet cuz the cursor hasn't been created
   //fill type names into sets
   mSupportedNativeTypes.insert("double precision");
   mSupportedNativeTypes.insert("int4");
@@ -283,6 +281,13 @@
 PGconn *QgsPostgresProvider::connectDb(const QString & conninfo)
+  if( connections.contains(conninfo) )
+    QgsDebugMsg( QString("Using cached connection for %1").arg(conninfo) );
+    connections[conninfo]->ref++;
+    return connections[conninfo]->conn;
   QgsDebugMsg(QString("New postgres connection for ") + conninfo);
   PGconn *pd = PQconnectdb(conninfo.toLocal8Bit());	// use what is set based on locale; after connecting, use Utf8
@@ -323,14 +328,36 @@
           "work properly.\nPlease install PostGIS with "
           "GEOS support (http://geos.refractions.net)"));
-  //--std::cout << "Connection to the database was successful\n";
+  QgsDebugMsg("Connection to the database was successful");
+  Conn *conn = new Conn(pd);
+  connections.insert( conninfo, conn );
   return pd;
 void QgsPostgresProvider::disconnectDb()
-  PQfinish( connection );
+  if(mFetching)
+    PQexecNR(connection, QString("CLOSE qgisf%1").arg(providerId).toUtf8() );
+    mFetching=false;
+  QMap<QString, Conn *>::iterator i;
+  for(i=connections.begin(); i!=connections.end() && i.value()->conn!=connection; i++)
+  assert( i.value()->conn==connection );
+  assert( i.value()->ref>0 );
+  if( --i.value()->ref==0 ) {
+    PQfinish( connection );
+    delete i.value();
+    connections.remove( i.key() );
   connection = 0;
@@ -341,14 +368,17 @@
 bool QgsPostgresProvider::getNextFeature(QgsFeature& feature)
+  assert(mFetching);
   if (valid)
     // Top up our queue if it is empty
     if (mFeatureQueue.empty())
-      QString fetch = QString("fetch forward %1 from qgisf")
-        .arg(mFeatureQueueSize);
+      QString fetch = QString("fetch forward %1 from qgisf%2")
+                        .arg(mFeatureQueueSize)
+                        .arg(providerId);
       if(mFirstFetch)
@@ -368,9 +398,7 @@
         QgsDebugMsg("End of features");
         PQclear(queryResult);
-        if (ready)
-          PQexecNR(connection, QString("end work").toUtf8());
-        ready = false;
         return false;
@@ -499,7 +527,7 @@
   QgsFieldMap attributeMap = fields();
   QgsFieldMap::const_iterator fieldIt;
   for(QgsAttributeList::const_iterator it = mAttributesToFetch.constBegin();
-      it != mAttributesToFetch.constEnd(); ++it)
+    it != mAttributesToFetch.constEnd(); ++it)
     fieldIt = attributeMap.find(*it);
     if(fieldIt != attributeMap.end())
@@ -508,14 +536,22 @@
-  QString declare = "declare qgisf binary cursor for select " + quotedIdentifier(primaryKey);
+  if(mFetching)
+    mFetching=false;
+  QString declare = QString("declare qgisf%1 binary cursor with hold for select %2")
+                      .arg(providerId).arg(quotedIdentifier(primaryKey));
   if(fetchGeometry)
     declare += QString(",asbinary(%1,'%2') as qgs_feature_geometry")
-                  .arg( quotedIdentifier(geometryColumn) )
-                  .arg( endianString() );
+      .arg( quotedIdentifier(geometryColumn) )
+      .arg( endianString() );
   for(std::list<QString>::const_iterator it = mFetchAttributeNames.begin(); it != mFetchAttributeNames.end(); ++it)
     if( (*it) != primaryKey) //no need to fetch primary key again
@@ -570,18 +606,14 @@
   QgsDebugMsg("Selecting features using: " + declare);
-  // set up the cursor
-  if(ready){
+  PQexecNR(connection, declare.toUtf8());
+  while(!mFeatureQueue.empty())
+    mFeatureQueue.pop();
-  PQexecNR(connection,QString("begin work").toUtf8());
-  ready = true;
-  PQexecNR(connection, declare.toUtf8());
-  while(!mFeatureQueue.empty())
-      mFeatureQueue.pop();
+  mFetching = true;
   mFirstFetch = true;
@@ -605,40 +637,41 @@
-  QString sql = "declare qgisfid binary cursor for select " + quotedIdentifier(primaryKey);
+  QString declare = QString("declare qgisfid%1 binary cursor with hold for select %2")
   if(fetchGeometry)
-    sql += QString(",asbinary(%1,'%2') as qgs_feature_geometry")
+    declare += QString(",asbinary(%1,'%2') as qgs_feature_geometry")
   for(namesIt = attributeNames.begin(); namesIt != attributeNames.end(); ++namesIt)
     if( (*namesIt) != primaryKey) //no need to fetch primary key again
-      sql += "," + quotedIdentifier(*namesIt) + "::text";
+      declare += "," + quotedIdentifier(*namesIt) + "::text";
-  sql += " " + QString("from %1").arg(mSchemaTableName);
+  declare += QString(" from %1 where %2=%3")
+               .arg(mSchemaTableName)
+               .arg(quotedIdentifier(primaryKey))
+               .arg(featureId);
-  sql += " where " + quotedIdentifier(primaryKey) + "=" + QString::number(featureId);
+  QgsDebugMsg("Selecting feature using: " + declare);
-  QgsDebugMsg("Selecting feature using: " + sql);
   // execute query
-  PQexecNR(connection, sql.toUtf8());
-  PGresult *res = PQexec(connection, QString("fetch forward 1 from qgisfid").toUtf8());
+  PGresult *res = PQexec(connection, QString("fetch forward 1 from qgisfid%1").arg(providerId).toUtf8());
   int rows = PQntuples(res);
   if (rows == 0)
     PQclear(res);
+    PQexecNR(connection, QString("CLOSE qgisfid%1").arg(providerId).toUtf8());
     QgsDebugMsg("feature " + QString::number(featureId) + " not found");
     return FALSE;
@@ -710,7 +743,7 @@
   PQclear(res);
   return TRUE;
@@ -770,8 +803,11 @@
 void QgsPostgresProvider::reset()
-  QString move = "move 0 in qgisf"; //move cursor to first record
-  PQexecNR(connection, move.toUtf8());
+  if(mFetching)
+     //move cursor to first record
+    PQexecNR(connection, QString("move 0 in qgisf%1").arg(providerId).toUtf8());
   mFeatureQueue.empty();
   loadFields();
@@ -852,9 +888,6 @@
       fieldComment = QString::fromUtf8(PQgetvalue(tresult, 0, 0));
     PQclear(tresult);
-    QgsDebugMsg("Field: " + attnum + " maps to " + QString::number(i) + " " + fieldName + ", "
-        + fieldTypeName + " (" + QString::number(fldtyp) + "),  " + fieldSize + ", " + QString::number(fieldModifier));
     if(fieldName!=geometryColumn)
       QVariant::Type fieldType;
@@ -1906,10 +1939,8 @@
       appendGeomString( features->geometry(), geomParam);
       QList<QByteArray> qparam;
       qparam.append( geomParam.toUtf8() );
       qparam.append( QString("%1").arg( ++primaryKeyHighWater ).toUtf8() );
       param[0] = qparam[0];
       param[1] = qparam[1];
@@ -2446,8 +2477,7 @@
   // get the same value using a binary cursor
-  QString oidDeclare = "declare oidcursor binary cursor for select regclass('" + mSchemaTableName + "')::oid";
+  QString oidDeclare = "declare oidcursor binary cursor with hold for select regclass('" + mSchemaTableName + "')::oid";
   PQexecNR(connection, oidDeclare.toUtf8());
   QString fetch = "fetch forward 1 from oidcursor";
@@ -2455,7 +2485,6 @@
   QgsDebugMsg("Fetching a record and attempting to get check endian-ness");
   PGresult *fResult = PQexec(connection, fetch.toUtf8());
   swapEndian = true;
   if(PQntuples(fResult) > 0){
     // get the oid value from the binary cursor
@@ -2469,6 +2498,7 @@
     PQclear(fResult);
+  PQexecNR(connection, QString("close oidcursor").toUtf8());
   return swapEndian;
@@ -2643,16 +2673,15 @@
   PGresult *res = PQexec(conn, query);
   if(res)
-    QgsDebugMsg( QString("Query: %1 returned %2 [%3]")
-                   .arg(query)
-                   .arg(PQresStatus(PQresultStatus(res)))
-                   .arg(PQresultErrorMessage(res))
+    QgsDebugMsgLevel( QString("Query: %1 returned %2 [%3]")
+                        .arg(query)
+                        .arg(PQresStatus(PQresultStatus(res)))
+                        .arg(PQresultErrorMessage(res)), 3 );
     PQclear(res);
   else
-    QgsDebugMsg( QString("Query: %1 returned no result buffer").arg(query) );
+    QgsDebugMsgLevel( QString("Query: %1 returned no result buffer").arg(query), 3 );
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h	2008-03-25 20:19:53 UTC (rev 8272)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h	2008-03-25 21:24:56 UTC (rev 8273)
@@ -290,7 +290,6 @@
     QString name() const;
     /** return description
     Return a terse string describing what the provider is.
@@ -304,12 +303,7 @@
     QString description() const;
-    signals:
+  signals:
      *   This is emitted whenever the worker thread has fully calculated the
      *   PostGIS extents for this layer, and its event has been received by this
@@ -330,6 +324,7 @@
     void repaintRequested();
   private:
+    int providerId; // id to append to provider specific identified (like cursors)
     /** Double quote a PostgreSQL identifier for placement in a SQL string.
@@ -343,7 +338,8 @@
     void loadFields();
-    bool mFirstFetch; //true if fetch forward is called the first time after select
+    bool mFetching;   // true if a cursor was declared
+    bool mFirstFetch; // true if fetch forward is called the first time after select
     std::vector < QgsFeature > features;
     QgsFieldMap attributeFields;
     QString mDataComment;
@@ -547,9 +543,6 @@
     int SRCFromViewColumn(const QString& ns, const QString& relname, const QString& attname_table,
 			  const QString& attname_view, const QString& viewDefinition, SRC& result) const;
-    bool ready;
-    std::ofstream pLog;
     //! PostGIS version string
     QString postgisVersionInfo;
@@ -601,6 +594,16 @@
     // run a query and free result buffer
     static void PQexecNR(PGconn *conn, const char *query);
+    struct Conn
+      Conn(PGconn *connection) : ref(1), conn(connection) {}
+      int ref;
+      PGconn *conn;
+    static QMap<QString, Conn *> connections;
+    static int providerIds;
 #endif
More information about the QGIS-commit mailing list
