[QGIS Commit] r8433 - trunk/qgis
svn_qgis at osgeo.org
Wed May 14 09:05:48 EDT 2008
Author: timlinux
Date: 2008-05-14 09:05:48 -0400 (Wed, 14 May 2008)
New Revision: 8433
trunk/qgis/CODING.t2t
Added some HIG guidelines (more to come)
Modified: trunk/qgis/CODING.t2t
--- trunk/qgis/CODING.t2t 2008-05-14 13:05:09 UTC (rev 8432)
+++ trunk/qgis/CODING.t2t 2008-05-14 13:05:48 UTC (rev 8433)
@@ -1066,6 +1066,30 @@
CMakeLists.txt parts) are still being worked on so that the testing framework
works in a truly platform way. I will update this document as things progress.
+= HIG (Human Interface Guidelines) =
+In order for all graphical user interface elements to appear consistant and
+to all the user to instinctively use dialogs, it is important that the following
+guidelines are followed in layout and design of GUIs.
+ + Group related elements using group boxes:
+ Try to identify elements that can be grouped together and then use
+ group boxes with a label identify the topic of that group.
+ + Capitalise first letter only in group box labels:
+ Group box labels should be written as a phrase with leading capital letter,
+ and all remaing words written with lower case first letters
+ + Do not end labels for widgets or group boxes with a colon:
+ Adding a colon causes visual noise and does not impart additional meaning,
+ so dont use them.
+ + Keep harmful actions away from harmless ones:
+ If you have actions for 'delete', 'remove' etc, try to impose adequate
+ space between the harmful action and innocuous actions so that the users
+ is less likely to inadvertantly click on the harmful action.
+ + Always use a QButtonBox for 'Ok', 'Cancel' etc buttons:
+ Using a button box will ensure that the order of 'Ok' and 'Cancel' etc,
+ buttons is consistent with the operating system / locale / desktop
+ environment that the user is using.
= Authors =
* Tim Sutton (author and editor)
