[QGIS Commit] r8434 - trunk/qgis
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed May 14 14:15:40 EDT 2008
Author: timlinux
Date: 2008-05-14 14:15:40 -0400 (Wed, 14 May 2008)
New Revision: 8434
   trunk/qgis/CMakeLists.txt
Enable qtsql module
Modified: trunk/qgis/CMakeLists.txt
--- trunk/qgis/CMakeLists.txt	2008-05-14 13:05:48 UTC (rev 8433)
+++ trunk/qgis/CMakeLists.txt	2008-05-14 18:15:40 UTC (rev 8434)
@@ -138,14 +138,11 @@
 SET( QT_USE_QTXML      TRUE )
 SET( QT_USE_QTNETWORK  TRUE )
 SET( QT_USE_QTSVG      TRUE )
+SET( QT_USE_QTSQL      TRUE )
 IF (ENABLE_TESTS)
   SET( QT_USE_QTTEST  TRUE )
   ENABLE_TESTING()
 ENDIF (ENABLE_TESTS)
-# TODO: should not be needed, report it to CMake devs
-IF (APPLE AND QT_USE_QT3SUPPORT)
-  SET( QT_USE_QTSQL    TRUE )
-ENDIF (APPLE AND QT_USE_QT3SUPPORT)
 FIND_PACKAGE(Qt4 REQUIRED)
More information about the QGIS-commit mailing list
