[QGIS Commit] r8461 - in trunk/qgis/src: app app/composer core
svn_qgis at osgeo.org
Mon May 19 09:14:56 EDT 2008
Author: timlinux
Date: 2008-05-19 09:14:56 -0400 (Mon, 19 May 2008)
New Revision: 8461
trunk/qgis/src/app/composer/qgscomposition.cpp
trunk/qgis/src/app/qgsmaptooladdfeature.cpp
trunk/qgis/src/app/qgsmaptoolcapture.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/core/qgsdistancearea.cpp
trunk/qgis/src/core/qgslabel.cpp
trunk/qgis/src/core/qgsmaprender.cpp
Use qt Q_UNUSED for unused params rather
Modified: trunk/qgis/src/app/composer/qgscomposition.cpp
--- trunk/qgis/src/app/composer/qgscomposition.cpp 2008-05-19 13:06:03 UTC (rev 8460)
+++ trunk/qgis/src/app/composer/qgscomposition.cpp 2008-05-19 13:14:56 UTC (rev 8461)
@@ -623,7 +623,7 @@
catch (std::bad_alloc& ba)
- UNUSED(ba);
+ Q_UNUSED(ba);
// A better solution here would be to set the canvas back to the
// original size and carry on, but for the moment this will
// prevent a crash due to an uncaught exception.
Modified: trunk/qgis/src/app/qgsmaptooladdfeature.cpp
--- trunk/qgis/src/app/qgsmaptooladdfeature.cpp 2008-05-19 13:06:03 UTC (rev 8460)
+++ trunk/qgis/src/app/qgsmaptooladdfeature.cpp 2008-05-19 13:14:56 UTC (rev 8461)
@@ -108,7 +108,7 @@
catch(QgsCsException &cse)
- UNUSED(cse);
+ Q_UNUSED(cse);
QMessageBox::information(0, QObject::tr("Coordinate transform error"), \
QObject::tr("Cannot transform the point to the layers coordinate system"));
return;
Modified: trunk/qgis/src/app/qgsmaptoolcapture.cpp
--- trunk/qgis/src/app/qgsmaptoolcapture.cpp 2008-05-19 13:06:03 UTC (rev 8460)
+++ trunk/qgis/src/app/qgsmaptoolcapture.cpp 2008-05-19 13:14:56 UTC (rev 8461)
@@ -106,7 +106,7 @@
- UNUSED(cse);
+ Q_UNUSED(cse);
return 2;
@@ -123,7 +123,7 @@
- UNUSED (cse);
+ Q_UNUSED (cse);
return 2;
mRubberBand->addPoint(mapPoint);
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2008-05-19 13:06:03 UTC (rev 8460)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2008-05-19 13:14:56 UTC (rev 8461)
@@ -526,7 +526,7 @@
- UNUSED(cse);
+ Q_UNUSED(cse);
QgsDebugMsg( cse.what() );
myMetedata += "<tr><td>";
Modified: trunk/qgis/src/core/qgsdistancearea.cpp
--- trunk/qgis/src/core/qgsdistancearea.cpp 2008-05-19 13:06:03 UTC (rev 8460)
+++ trunk/qgis/src/core/qgsdistancearea.cpp 2008-05-19 13:14:56 UTC (rev 8461)
@@ -282,7 +282,7 @@
catch (QgsCsException &cse)
- UNUSED(cse);
+ Q_UNUSED(cse);
QgsLogger::warning(QObject::tr("Caught a coordinate system exception while trying to transform a point. Unable to calculate line length."));
return 0.0;
@@ -307,7 +307,7 @@
- UNUSED(cse);
+ Q_UNUSED(cse);
return 0.0;
@@ -369,7 +369,7 @@
- UNUSED(cse);
+ Q_UNUSED(cse);
QgsLogger::warning(QObject::tr("Caught a coordinate system exception while trying to transform a point. Unable to calculate polygon area."));
@@ -398,7 +398,7 @@
- UNUSED(cse);
+ Q_UNUSED(cse);
return 0.0;
Modified: trunk/qgis/src/core/qgslabel.cpp
--- trunk/qgis/src/core/qgslabel.cpp 2008-05-19 13:06:03 UTC (rev 8460)
+++ trunk/qgis/src/core/qgslabel.cpp 2008-05-19 13:14:56 UTC (rev 8461)
@@ -351,7 +351,7 @@
- UNUSED(cse); // unused otherwise
+ Q_UNUSED(cse); // unused otherwise
QgsDebugMsg("Caught transform error in QgsLabel::renderLabel(). "
"Skipping rendering this label");
return;
Modified: trunk/qgis/src/core/qgsmaprender.cpp
--- trunk/qgis/src/core/qgsmaprender.cpp 2008-05-19 13:06:03 UTC (rev 8460)
+++ trunk/qgis/src/core/qgsmaprender.cpp 2008-05-19 13:14:56 UTC (rev 8461)
@@ -541,7 +541,7 @@
- UNUSED(cse);
+ Q_UNUSED(cse);
QgsLogger::warning("Transform error caught in " + QString(__FILE__) + ", line " + QString::number(__LINE__));
extent = QgsRect(-DBL_MAX, -DBL_MAX, DBL_MAX, DBL_MAX);
r2 = QgsRect(-DBL_MAX, -DBL_MAX, DBL_MAX, DBL_MAX);
