[QGIS Commit] r8462 - in trunk/qgis: python/core src/core/raster
svn_qgis at osgeo.org
Mon May 19 09:17:31 EDT 2008
Author: timlinux
Date: 2008-05-19 09:17:31 -0400 (Mon, 19 May 2008)
New Revision: 8462
trunk/qgis/python/core/qgsrasterlayer.sip
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.h
Dont artificially limit the raster types available. Note if you have a lot of gdal file types supported the file filter is very long. We need to find a sensible way to manage that.
Modified: trunk/qgis/python/core/qgsrasterlayer.sip
--- trunk/qgis/python/core/qgsrasterlayer.sip 2008-05-19 13:14:56 UTC (rev 8461)
+++ trunk/qgis/python/core/qgsrasterlayer.sip 2008-05-19 13:17:31 UTC (rev 8462)
@@ -19,7 +19,6 @@
// Static methods:
static void buildSupportedRasterFileFilter(QString & fileFilters);
- static bool isSupportedRasterDriver(const QString & driverName);
static void registerGdalDrivers();
/** This helper checks to see whether the filename appears to be a valid
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-05-19 13:14:56 UTC (rev 8461)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-05-19 13:17:31 UTC (rev 8462)
@@ -76,43 +76,12 @@
- Static member variable storing the subset of GDAL formats
- that we currently support.
- @note
- Some day this won't be necessary as there'll be a time when
- theoretically we'll support everything that GDAL can throw at us.
- These are GDAL driver description strings.
-static const char *const mSupportedRasterFormats[] =
- "AAIGrid",
- "AIG",
- "DTED",
- "ECW",
- "GRASS",
- "GTiff",
- "HFA",
- "JP2ECW",
- "JP2KAK",
- "JP2MrSID",
- "JPEG2000",
- "MrSID",
- "SDTS",
- "USGSDEM",
- "" // used to indicate end of list
Builds the list of file filter strings to later be used by
QgisApp::addRasterLayer()
We query GDAL for a list of supported raster formats; we then build
a list of file filter strings from that list. We return a string
- that contains this list that is suitable for use in a a
+ that contains this list that is suitable for use in a
QFileDialog::getOpenFileNames() call.
@@ -166,12 +135,6 @@
myGdalDriverDescription = GDALGetDescription(myGdalDriver);
- if (!isSupportedRasterDriver(myGdalDriverDescription))
- // not supported, therefore skip
- QgsDebugMsg("skipping unsupported driver " + QString(GDALGetDescription(myGdalDriver)));
- continue;
// std::cerr << "got driver string " << myGdalDriver->GetDescription() << "\n";
myGdalDriverMetadata = GDALGetMetadata(myGdalDriver,NULL);
@@ -290,40 +253,7 @@
GDALAllRegister();
- returns true if the given raster driver name is one currently
- supported, otherwise it returns false
- @param theDriverName GDAL driver description string
-bool QgsRasterLayer::isSupportedRasterDriver(QString const &theDriverName)
- size_t i = 0;
- while (mSupportedRasterFormats[i][0]) // while not end of string list
- // If we've got a case-insensitive match for a GDAL aware driver
- // description, then we've got a match. Why case-insensitive?
- // I'm just being paranoid in that I can envision a situation
- // whereby GDAL slightly changes driver description string case,
- // in which case we'd catch it here. Not that that would likely
- // happen, but if it does, we'll already compensate.
- // GS - At Qt 3.1.2, the case sensitive argument. So we change the
- // driverName to lower case before testing
- QString format = mSupportedRasterFormats[i];
- if (theDriverName.lower().startsWith(format.lower()))
- return true;
- i++;
- return false;
-} // isSupportedRasterDriver
/** This helper checks to see whether the filename appears to be a valid raster file name */
bool QgsRasterLayer::isValidRasterFileName(QString const & theFileNameQString)
@@ -377,7 +307,6 @@
QString const & baseName,
bool loadDefaultStyleFlag)
: QgsMapLayer(RASTER, baseName, path),
- // XXX where is this? popMenu(0), //popMenu is the contextmenu obtained by right clicking on the legend
mRasterXDim( std::numeric_limits<int>::max() ),
mRasterYDim( std::numeric_limits<int>::max() ),
mDebugOverlayFlag(false),
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-05-19 13:14:56 UTC (rev 8461)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-05-19 13:17:31 UTC (rev 8462)
@@ -186,7 +186,6 @@
// Static methods:
