[QGIS Commit] r8463 - trunk/qgis/src/gui
svn_qgis at osgeo.org
Mon May 19 09:23:07 EDT 2008
Author: timlinux
Date: 2008-05-19 09:23:07 -0400 (Mon, 19 May 2008)
New Revision: 8463
Added:
trunk/qgis/src/gui/qgsdetaileditemdata.cpp
trunk/qgis/src/gui/qgsdetaileditemdata.h
trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp
trunk/qgis/src/gui/qgsdetaileditemdelegate.h
trunk/qgis/src/gui/qgsdetaileditemwidget.cpp
trunk/qgis/src/gui/qgsdetaileditemwidget.h
Created a custom view delegate for displaying in lists like the plugin manager and the grass toolbox.
The delegate allows displaying a title (in bold) and a description underneath it (in normal font), without needing to resort to using tables & columns. The delegate currently works in two modes:
1) Direct rendering of item onto a painter
2) Renderng the item via a qgsdetaileditemwidget (disabled for not as its experimental)
THe qgsdetailed item data class is a new qvariant type that can be used to pass title, description etc between the model and the view.
Added: trunk/qgis/src/gui/qgsdetaileditemdata.cpp
--- trunk/qgis/src/gui/qgsdetaileditemdata.cpp (rev 0)
+++ trunk/qgis/src/gui/qgsdetaileditemdata.cpp 2008-05-19 13:23:07 UTC (rev 8463)
@@ -0,0 +1,46 @@
+ qgsdetailedlistdata.cpp - A data represenation for a rich QItemData subclass
+ begin : Sat May 17 2008
+ copyright : (C) 2008 Tim Sutton
+ email : tim at linfiniti.com
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+/* $Id:$ */
+#include "qgsdetaileditemdata.h"
+QgsDetailedItemData::QgsDetailedItemData()
+QgsDetailedItemData::~QgsDetailedItemData()
+void QgsDetailedItemData::setTitle(QString theTitle)
+ mTitle=theTitle;
+void QgsDetailedItemData::setDetail(QString theDetail)
+ mDetail=theDetail;
+QString QgsDetailedItemData::title()
+ return mTitle;
+QString QgsDetailedItemData::detail()
+ return mDetail;
Property changes on: trunk/qgis/src/gui/qgsdetaileditemdata.cpp
___________________________________________________________________
Added: trunk/qgis/src/gui/qgsdetaileditemdata.h
--- trunk/qgis/src/gui/qgsdetaileditemdata.h (rev 0)
+++ trunk/qgis/src/gui/qgsdetaileditemdata.h 2008-05-19 13:23:07 UTC (rev 8463)
@@ -0,0 +1,47 @@
+ qgsdetaileditemdata.h - A data represenation for a rich QItemData subclass
+/* $Id:$ */
+#ifndef QGSDETAILEDITEMDATA_H
+#define QGSDETAILEDITEMDATA_H
+#include <QMetaType>
+#include <QString>
+/** This class is the data only representation of a
+ * QgsDetailedItemWidget, designed to be used in custom views.
+class QgsDetailedItemData
+ public:
+ QgsDetailedItemData();
+ ~QgsDetailedItemData();
+ void setTitle(QString theTitle);
+ void setDetail(QString theDetail);
+ QString title();
+ QString detail();
+ private:
+ QString mTitle;
+ QString mDetail;
+ QString mLibraryName;
+ bool mCheckBoxEnabled;
+// Make QVariant aware of this data type (see qtdocs star
+// rating delegate example for more details)
+Q_DECLARE_METATYPE(QgsDetailedItemData)
+#endif //QGSDETAILEDITEMDATA_H
Property changes on: trunk/qgis/src/gui/qgsdetaileditemdata.h
Added: trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp
--- trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp (rev 0)
+++ trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp 2008-05-19 13:23:07 UTC (rev 8463)
@@ -0,0 +1,167 @@
+ qgsdetailedlistwidget.cpp - A rich QItemDelegate subclass
+/* $Id:$ */
+#include "qgsdetaileditemdelegate.h"
+#include "qgsdetaileditemwidget.h"
+#include <QPainter>
+#include <QFont>
+#include <QFontMetrics>
+#include <QStyleOptionViewItem>
+#include <QModelIndex>
+#include <QCheckBox>
+#include <QLinearGradient>
+QgsDetailedItemDelegate::QgsDetailedItemDelegate(QObject * parent) :
+ QAbstractItemDelegate(parent),
+ mpWidget(new QgsDetailedItemWidget()),
+ mpCheckBox(new QCheckBox())
+ mpCheckBox->resize(16,16);
+QgsDetailedItemDelegate::~QgsDetailedItemDelegate()
+ delete mpCheckBox;
+ delete mpWidget;
+void QgsDetailedItemDelegate::paint(QPainter * thepPainter,
+ const QStyleOptionViewItem & theOption,
+ const QModelIndex & theIndex) const
+ if (qVariantCanConvert<QgsDetailedItemData>(theIndex.data(Qt::UserRole)))
+ QgsDetailedItemData myData =
+ qVariantValue<QgsDetailedItemData>(theIndex.data(Qt::UserRole));
+ bool myCheckState = theIndex.model()->data(theIndex, Qt::CheckStateRole).toBool();
+ mpWidget->setChecked(myCheckState);
+ mpWidget->setData(myData);
+ mpWidget->resize(theOption.rect.width(),mpWidget->height());
+ mpWidget->setAutoFillBackground(false);
+ mpWidget->show();
+ mpWidget->repaint();
+ if (theOption.state & QStyle::State_Selected)
+ QColor myColor1 = theOption.palette.highlight();
+ QColor myColor2 = myColor1;
+ myColor2 = myColor2.lighter();
+ QLinearGradient myGradient(QPointF(0,theOption.rect.y()),
+ QPointF(0,theOption.rect.y() + mpWidget->height()));
+ myGradient.setColorAt(0, myColor1);
+ myGradient.setColorAt(0.1, myColor2);
+ myGradient.setColorAt(0.5, myColor1);
+ myGradient.setColorAt(0.9, myColor2);
+ myGradient.setColorAt(1, myColor2);
+ thepPainter->fillRect(theOption.rect, QBrush(myGradient));
+ QPixmap myPixmap(mpWidget->size());
+ mpWidget->render(&myPixmap);
+ thepPainter->drawPixmap(theOption.rect.x(),
+ theOption.rect.y(),
+ myPixmap);
+ else
+ // After painting we need to restore the painter to its original state
+ thepPainter->save();
+ // Get the strings and check box properties
+ QString myString = theIndex.model()->data(theIndex, Qt::DisplayRole).toString();
+ QString myDetailString = theIndex.model()->data(theIndex, Qt::UserRole).toString();
+ mpCheckBox->setChecked(myCheckState);
+ QPixmap myPixmap(mpCheckBox->size());
+ mpCheckBox->render(&myPixmap); //we will draw this onto the widget further down
+ // Calculate the widget height and other metrics
+ QFont myFont = theOption.font;
+ QFont myBoldFont = myFont;
+ myBoldFont.setBold(true);
+ myBoldFont.setPointSize(myFont.pointSize() + 3);
+ QFontMetrics myMetrics(myBoldFont);
+ int myVerticalSpacer = 3; //spacing between title and description
+ int myHorizontalSpacer = 5; //spacing between checkbox / icon and description
+ int myTextStartX = theOption.rect.x() + myPixmap.width() + myHorizontalSpacer;
+ int myHeight = myMetrics.height() + myVerticalSpacer;
+ // Draw the item background with a gradient if its highlighted
+ QPointF(0,theOption.rect.y() + myHeight*2));
+ // Draw the checkbox
+ theOption.rect.y() + mpCheckBox->height(),
+ myPixmap);
+ // Draw the title and description
+ thepPainter->setFont(myBoldFont);
+ thepPainter->drawText( myTextStartX ,theOption.rect.y() + myHeight, myString);
+ thepPainter->setFont(myFont); //return to original font set by client
+ thepPainter->drawText( myTextStartX,
+ theOption.rect.y() + (myHeight *2) - myVerticalSpacer,
+ myDetailString);
+ thepPainter->restore();
+QSize QgsDetailedItemDelegate::sizeHint(
+ const QModelIndex & theIndex ) const
+ return QSize(378,mpWidget->height());
+ else // fall back to hand calculated & hand drawn item
+ return QSize(50,
+ myHeight *2 + myVerticalSpacer);
Property changes on: trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp
Added: trunk/qgis/src/gui/qgsdetaileditemdelegate.h
--- trunk/qgis/src/gui/qgsdetaileditemdelegate.h (rev 0)
+++ trunk/qgis/src/gui/qgsdetaileditemdelegate.h 2008-05-19 13:23:07 UTC (rev 8463)
@@ -0,0 +1,44 @@
+ qgsdetaileditemdelegate.h - A rich QItemDelegate subclass
+/* $Id:$ */
+#ifndef QGSDETAILEDITEMDELEGATE_H
+#define QGSDETAILEDITEMDELEGATE_H
+#include <QAbstractItemDelegate>
+#include <QString>
+class QCheckBox;
+class QgsDetailedItemWidget;
+class QgsDetailedItemDelegate :
+ public QAbstractItemDelegate
+ Q_OBJECT;
+ public:
+ QgsDetailedItemDelegate(QObject * parent = 0);
+ ~QgsDetailedItemDelegate();
+ void paint(QPainter * thePainter,
+ const QModelIndex & theIndex) const;
+ QSize sizeHint( const QStyleOptionViewItem & theOption,
+ const QModelIndex & theIndex ) const;
+ private:
+ QgsDetailedItemWidget * mpWidget;
+ QCheckBox * mpCheckBox;
+#endif //QGSDETAILEDITEMDELEGATE_H
Property changes on: trunk/qgis/src/gui/qgsdetaileditemdelegate.h
Added: trunk/qgis/src/gui/qgsdetaileditemwidget.cpp
--- trunk/qgis/src/gui/qgsdetaileditemwidget.cpp (rev 0)
+++ trunk/qgis/src/gui/qgsdetaileditemwidget.cpp 2008-05-19 13:23:07 UTC (rev 8463)
@@ -0,0 +1,40 @@
+ qgsdetailedlistwidget.cpp - A rich QItemWidget subclass
+/* $Id:$ */
+QgsDetailedItemWidget::QgsDetailedItemWidget(QWidget * parent) :
+ QWidget(parent)
+ setupUi(this);
+QgsDetailedItemWidget::~QgsDetailedItemWidget()
+void QgsDetailedItemWidget::setData(QgsDetailedItemData theData)
+ lblTitle->setText(theData.title());
+ tbDetail->setText(theData.detail());
+void QgsDetailedItemWidget::setChecked(bool theFlag)
+ cbx->setChecked(theFlag);
Property changes on: trunk/qgis/src/gui/qgsdetaileditemwidget.cpp
Added: trunk/qgis/src/gui/qgsdetaileditemwidget.h
--- trunk/qgis/src/gui/qgsdetaileditemwidget.h (rev 0)
+++ trunk/qgis/src/gui/qgsdetaileditemwidget.h 2008-05-19 13:23:07 UTC (rev 8463)
@@ -0,0 +1,37 @@
+ qgsdetaileditemwidget.h - A rich QItemWidget subclass
+/* $Id:$ */
+#ifndef QGSDETAILEDITEMWIDGET_H
+#define QGSDETAILEDITEMWIDGET_H
+#include <ui_qgsdetaileditemwidgetbase.h>
+#include <qgsdetaileditemdata.h>
+class QgsDetailedItemWidget :
+ public QWidget, private Ui::QgsDetailedItemWidgetBase
+ Q_OBJECT;
+ public:
+ QgsDetailedItemWidget(QWidget * parent = 0);
+ ~QgsDetailedItemWidget();
+ void setData(QgsDetailedItemData theData);
+ void setChecked(bool theFlag);
+ private:
+ QgsDetailedItemData mData;
+#endif //QGSDETAILEDITEMWIDGET_H
Property changes on: trunk/qgis/src/gui/qgsdetaileditemwidget.h
