[QGIS Commit] r8467 - trunk/qgis/src/app
svn_qgis at osgeo.org
Mon May 19 09:37:53 EDT 2008
Author: timlinux
Date: 2008-05-19 09:37:53 -0400 (Mon, 19 May 2008)
New Revision: 8467
trunk/qgis/src/app/main.cpp
On windows and mac, add the plugins dir to the search path on application start up.
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp 2008-05-19 13:32:10 UTC (rev 8466)
+++ trunk/qgis/src/app/main.cpp 2008-05-19 13:37:53 UTC (rev 8467)
@@ -32,6 +32,7 @@
#include <QStyle>
#include <QPlastiqueStyle>
#include <QTranslator>
+#include <QImageReader>
#include <iostream>
#include <cstdio>
@@ -501,6 +502,50 @@
mypSplash->show();
+ // For non static builds on mac and win (static builds are not supported)
+ // we need to be sure we can find the qt image
+ // plugins. In mac be sure to look in the
+ // application bundle...
+#ifdef Q_WS_WIN
+ QCoreApplication::addLibraryPath( QApplication::applicationDirPath()
+ + QDir::separator() + "plugins" );
+#endif
+#ifdef Q_OS_MACX
+ //qDebug("Adding qt image plugins to plugin search path...");
+ CFURLRef myBundleRef = CFBundleCopyBundleURL(CFBundleGetMainBundle());
+ CFStringRef myMacPath = CFURLCopyFileSystemPath(myBundleRef, kCFURLPOSIXPathStyle);
+ const char *mypPathPtr = CFStringGetCStringPtr(myMacPath,CFStringGetSystemEncoding());
+ CFRelease(myBundleRef);
+ CFRelease(myMacPath);
+ QString myPath(mypPathPtr);
+ // if we are not in a bundle assume that the app is built
+ // as a non bundle app and that image plugins will be
+ // in system Qt frameworks. If the app is a bundle
+ // lets try to set the qt plugin search path...
+ QFileInfo myInfo(myPath);
+ if (myInfo.isBundle())
+ // First clear the plugin search paths so we can be sure
+ // only plugins from the bundle are being used
+ QStringList myPathList;
+ QCoreApplication::setLibraryPaths(myPathList);
+ // Now set the paths inside the bundle
+ myPath += "/Contents/plugins";
+ QCoreApplication::addLibraryPath( myPath );
+ //next two lines should not be needed, testing only
+ //QCoreApplication::addLibraryPath( myPath + "/imageformats" );
+ //QCoreApplication::addLibraryPath( myPath + "/sqldrivers" );
+ //foreach (myPath, a.libraryPaths())
+ //qDebug("Path:" + myPath.toLocal8Bit());
+ //qDebug( "Added %s to plugin search path", qPrintable( myPath ) );
+ //QList<QByteArray> myFormats = QImageReader::supportedImageFormats();
+ //for ( int x = 0; x < myFormats.count(); ++x ) {
+ // qDebug("Format: " + myFormats[x]);
+#endif
