[QGIS Commit] r8468 - in trunk/qgis/src: app gui ui
svn_qgis at osgeo.org
Mon May 19 09:43:37 EDT 2008
Author: timlinux
Date: 2008-05-19 09:43:37 -0400 (Mon, 19 May 2008)
New Revision: 8468
Added:
trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui
trunk/qgis/src/app/qgspluginmanager.cpp
trunk/qgis/src/app/qgspluginmanager.h
trunk/qgis/src/gui/CMakeLists.txt
trunk/qgis/src/ui/CMakeLists.txt
trunk/qgis/src/ui/qgspluginmanagerbase.ui
Reimplemented plugin manager to use a list view rather than a table view and to use the custom qgsdetaileditemdelegate for display of available plugins
Modified: trunk/qgis/src/app/qgspluginmanager.cpp
--- trunk/qgis/src/app/qgspluginmanager.cpp 2008-05-19 13:37:53 UTC (rev 8467)
+++ trunk/qgis/src/app/qgspluginmanager.cpp 2008-05-19 13:43:37 UTC (rev 8468)
@@ -25,15 +25,22 @@
#include <QMessageBox>
#include <QLibrary>
#include <QSettings>
-#include "qgisplugin.h"
-#include "qgslogger.h"
+#include <QStandardItem>
+#include <QPushButton>
+#include <QRegExp>
#include "qgspluginmanager.h"
-#include "qgspluginitem.h"
-#include "qgsproviderregistry.h"
-#include "qgspluginregistry.h"
+#include <qgisplugin.h>
+#include <qgslogger.h>
+#include <qgspluginitem.h>
+#include <qgsproviderregistry.h>
+#include <qgspluginregistry.h>
+#include <qgsdetaileditemdelegate.h>
+#include <qgsdetaileditemwidget.h>
+#include <qgsdetaileditemdata.h>
#ifdef HAVE_PYTHON
-#include "qgspythonutils.h"
+#include <qgspythonutils.h>
#endif
#define TESTLIB
@@ -58,37 +65,47 @@
QString baseDir = appDir.left(bin);
QString libDir = baseDir + "/lib"; */
- txtPluginDir->setText(pr->libraryDirectory().path());
+ lblPluginDir->setText(pr->libraryDirectory().path());
setTable();
getPluginDescriptions();
getPythonPluginDescriptions();
+ // Create the select all and clear all buttons and add them to the
+ // buttonBox
+ QPushButton * btnSelectAll = new QPushButton(tr("&Select All"));
+ QPushButton * btnClearAll = new QPushButton(tr("&Clear All"));
+ btnSelectAll->setDefault(true);
+ buttonBox->addButton(btnSelectAll, QDialogButtonBox::ActionRole);
+ buttonBox->addButton(btnClearAll, QDialogButtonBox::ActionRole);
+ // connect the slot up to catch when a bookmark is deleted
+ connect(btnSelectAll, SIGNAL(clicked()), this, SLOT(selectAll()));
+ // connect the slot up to catch when a bookmark is zoomed to
+ connect(btnClearAll, SIGNAL(clicked()), this, SLOT(clearAll()));
QgsPluginManager::~QgsPluginManager()
+ delete mModelProxy;
+ delete mModelPlugins;
void QgsPluginManager::setTable()
- lstPlugins->setAlternatingRowColors(true);
- mModelPlugins= new QStandardItemModel(0,4);
- mModelPlugins->setHorizontalHeaderItem(0,new QStandardItem(tr("Name")));
- mModelPlugins->setHorizontalHeaderItem(1,new QStandardItem(tr("Version")));
- mModelPlugins->setHorizontalHeaderItem(2,new QStandardItem(tr("Description")));
- mModelPlugins->setHorizontalHeaderItem(3,new QStandardItem(tr("Library name")));
- lstPlugins->setModel(mModelPlugins);
- // No vertical headers
- lstPlugins->verticalHeader()->hide();
- lstPlugins->setSelectionBehavior(QAbstractItemView::SelectRows);
- lstPlugins->setFocus();
+ mModelPlugins= new QStandardItemModel(0,1);
+ mModelProxy = new QSortFilterProxyModel(this);
+ mModelProxy->setSourceModel(mModelPlugins);
+ //mModelProxy->setFilterKeyColumn(0);
+ vwPlugins->setModel(mModelProxy);
+ vwPlugins->setFocus();
+ vwPlugins->setItemDelegateForColumn(0,new QgsDetailedItemDelegate());
void QgsPluginManager::resizeColumnsToContents()
// Resize columns to contents.
- lstPlugins->resizeColumnsToContents();
QgsDebugMsg("QgsPluginManager::resizeColumnsToContents\n");
@@ -124,18 +141,24 @@
if (pluginName == "???" || description == "???" || version == "???")
continue;
- //create the items
- QStandardItem *myName=new QStandardItem(pluginName);
- QStandardItem *myVersion=new QStandardItem(version);
- QStandardItem *myDesc=new QStandardItem(description);
- QStandardItem *myDir=new QStandardItem("python:" + packageName);
+ // We will create two items for each row:
+ // The first has the following roles :
+ // - DisplayRole : the name and version of the version of the plugin e.g. Plugin Foo (version 1.0)
+ // - UserRole : the description of the plugin.
+ // And the second has these roles :
+ // - DisplayRole : the library name (without path) for the plugin e.g. libfoo.so
+ // - UserRole : the name of the plugin without version e.g. plugin foor
+ // The plugin name without version is used elsewhere in this class to match
+ // aganst plugins loaded in the plugin registry
+ QStandardItem * mypDetailItem = new QStandardItem(
+ pluginName + " (" + version + ")");
+ mypDetailItem->setData(description,Qt::UserRole);
+ QString myLibraryName = "python:" + packageName;;
+ QStandardItem * mypLibraryNameItem = new QStandardItem(myLibraryName);
+ mypLibraryNameItem->setData(pluginName,Qt::UserRole);
// myName have a checkbox
- myName->setCheckable(true);
- //read only
- myName->setEditable(false);
- myVersion->setEditable(false);
- myDesc->setEditable(false);
- myDir->setEditable(false);
+ mypDetailItem->setCheckable(true);
+ mypDetailItem->setEditable(false);
// check to see if the plugin is loaded and set the checkbox accordingly
QgsPluginRegistry *pRegistry = QgsPluginRegistry::instance();
@@ -151,12 +174,12 @@
if (libName == packageName)
// set the checkbox
- myName->setCheckState(Qt::Checked);
+ mypDetailItem->setCheckState(Qt::Checked);
// Add items to model
QList<QStandardItem *> myItems;
- myItems << myName << myVersion << myDesc << myDir;
+ myItems << mypDetailItem << mypLibraryNameItem;
mModelPlugins->appendRow(myItems);
#endif
@@ -173,18 +196,18 @@
#endif
// check all libs in the current plugin directory and get name and descriptions
- QDir pluginDir(txtPluginDir->text(), sharedLibExtension, QDir::Name | QDir::IgnoreCase, QDir::Files | QDir::NoSymLinks);
+ QDir pluginDir(lblPluginDir->text(), sharedLibExtension, QDir::Name | QDir::IgnoreCase, QDir::Files | QDir::NoSymLinks);
if (pluginDir.count() == 0)
- QMessageBox::information(this, tr("No Plugins"), tr("No QGIS plugins found in ") + txtPluginDir->text());
+ QMessageBox::information(this, tr("No Plugins"), tr("No QGIS plugins found in ") + lblPluginDir->text());
return;
QgsDebugMsg("PLUGIN MANAGER:");
for (uint i = 0; i < pluginDir.count(); i++)
- QString lib = QString("%1/%2").arg(txtPluginDir->text()).arg(pluginDir[i]);
+ QString lib = QString("%1/%2").arg(lblPluginDir->text()).arg(pluginDir[i]);
#ifdef TESTLIB
// This doesn't work on WIN32 and causes problems with plugins
@@ -263,18 +286,40 @@
continue;
- QStandardItem *myName=new QStandardItem(pName());
- QStandardItem *myVersion=new QStandardItem(pVersion());
- QStandardItem *myDesc=new QStandardItem(pDesc());
- QStandardItem *myDir=new QStandardItem(pluginDir[i]);
+ pName() + " (" + pVersion() + ")");
+ // Uncommnet this block to render item using simple painter technique
+ mypDetailItem->setData(pDesc(),Qt::UserRole);
+ //Uncomment this block to used widget based detail items (experimental)
+ //QgsDetailedItemData myData;
+ //myData.setTitle(pName());
+ //myData.setDetail(pDesc());
+ //QVariant myVariant = qVariantFromValue(myData);
+ //round trip test - delete this...no need to uncomment
+ //QgsDetailedItemData myData2 = qVariantValue<QgsDetailedItemData>(myVariant);
+ //Q_ASSERT(myData.title() == myData2.title());
+ //round trip test ends
+ //mypDetailItem->setData(myVariant,Qt::UserRole);
+ QString myLibraryName = pluginDir[i];
+ mypLibraryNameItem->setData(pName(),Qt::UserRole);
- //read only
QgsDebugMsg("Getting an instance of the QgsPluginRegistry");
@@ -293,22 +338,22 @@
if (libName == myLib->library())
// set the checkbox
delete myLib;
-void QgsPluginManager::on_btnOk_clicked()
+void QgsPluginManager::accept()
unload();
- accept();
+ done(1);
void QgsPluginManager::unload()
@@ -323,12 +368,15 @@
QModelIndex myIndex=mModelPlugins->index(row,0);
if (mModelPlugins->data(myIndex,Qt::CheckStateRole).toInt() == 0)
+ // Get the second col index now since it stores the
+ // plugin name without version string in its data UserRole [ts]
+ myIndex=mModelPlugins->index(row,1);
// its off -- see if it is loaded and if so, unload it
#ifdef QGISDEBUG
- std::cout << "Checking to see if " << mModelPlugins->data(myIndex).toString().toLocal8Bit().data() << " is loaded" << std::endl;
+ std::cout << "Checking to see if " << mModelPlugins->data(myIndex, Qt::UserRole).toString().toLocal8Bit().data() << " is loaded" << std::endl;
#endif
- QString pluginName = mModelPlugins->data(myIndex).toString();
+ QString pluginName = mModelPlugins->data(myIndex,Qt::UserRole).toString();
if (pRegistry->isPythonPlugin(pluginName))
#ifdef HAVE_PYTHON
@@ -362,10 +410,10 @@
if (mModelPlugins->item(row,0)->checkState() == Qt::Checked)
- QString pluginName = mModelPlugins->item(row,0)->text();
+ QString pluginName = mModelPlugins->item(row,1)->data(Qt::UserRole).toString();
bool pythonic = false;
- QString library = mModelPlugins->item(row,3)->text();
+ QString library = mModelPlugins->item(row,1)->text();
if (library.left(7) == "python:")
library = library.mid(7);
@@ -373,16 +421,16 @@
else // C++ plugin
- library = txtPluginDir->text() + "/" + library;
+ library = lblPluginDir->text() + QDir::separator() + library;
- pis.push_back(QgsPluginItem(pluginName, mModelPlugins->item(row,2)->text(), library, 0, pythonic));
+ pis.push_back(QgsPluginItem(pluginName, mModelPlugins->item(row,0)->text(), library, 0, pythonic));
return pis;
-void QgsPluginManager::on_btnSelectAll_clicked()
+void QgsPluginManager::selectAll()
// select all plugins
for (int row=0;row < mModelPlugins->rowCount();row++)
@@ -392,7 +440,7 @@
-void QgsPluginManager::on_btnClearAll_clicked()
+void QgsPluginManager::clearAll()
// clear all selection checkboxes
@@ -402,8 +450,33 @@
-void QgsPluginManager::on_btnClose_clicked()
+void QgsPluginManager::on_vwPlugins_clicked(const QModelIndex &theIndex )
- reject();
+ if (theIndex.column() == 0)
+ // If the model has been filtered, the index row in the proxy wont match
+ // the index row in the underlying model so we need to jump through this
+ // little hoop to get the correct item
+ QStandardItem * mypItem =
+ mModelPlugins->findItems(theIndex.data(Qt::DisplayRole).toString()).first();
+ if ( mypItem->checkState() == Qt::Checked )
+ mypItem->setCheckState(Qt::Unchecked);
+ else
+ mypItem->setCheckState(Qt::Checked);
+void QgsPluginManager::on_leFilter_textChanged(QString theText)
+ QgsDebugMsg("PluginManager filter changed to :" + theText);
+ QRegExp::PatternSyntax mySyntax = QRegExp::PatternSyntax(QRegExp::RegExp);
+ Qt::CaseSensitivity myCaseSensitivity = Qt::CaseInsensitive;
+ QRegExp myRegExp(theText, myCaseSensitivity, mySyntax);
+ mModelProxy->setFilterRegExp(myRegExp);
Modified: trunk/qgis/src/app/qgspluginmanager.h
--- trunk/qgis/src/app/qgspluginmanager.h 2008-05-19 13:37:53 UTC (rev 8467)
+++ trunk/qgis/src/app/qgspluginmanager.h 2008-05-19 13:43:37 UTC (rev 8468)
@@ -21,6 +21,7 @@
#include <vector>
#include <QTableView>
#include <QStandardItemModel>
+#include <QSortFilterProxyModel>
#include <QHeaderView>
#include "ui_qgspluginmanagerbase.h"
@@ -56,16 +57,19 @@
//! Sort model by column ascending
void sortModel(int );
public slots:
+ //! Enable disable checkbox
+ void on_vwPlugins_clicked(const QModelIndex & );
//! Load selected plugins and close the dialog
- void on_btnOk_clicked();
+ void accept();
//! Select all plugins by setting their checkbox on
- void on_btnSelectAll_clicked();
+ void selectAll();
//! Clear all selections by clearing the plugins checkbox
- void on_btnClearAll_clicked();
- //! Close the dialog
- void on_btnClose_clicked();
+ void clearAll();
+ //! Update the filter when user changes the filter expression
+ void on_leFilter_textChanged(QString theText);
private:
QStandardItemModel *mModelPlugins;
+ QSortFilterProxyModel * mModelProxy;
#endif
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt 2008-05-19 13:37:53 UTC (rev 8467)
+++ trunk/qgis/src/gui/CMakeLists.txt 2008-05-19 13:43:37 UTC (rev 8468)
@@ -4,6 +4,9 @@
qgisinterface.cpp
qgscolorbutton.cpp
qgscursors.cpp
+qgsdetaileditemdelegate.cpp
+qgsdetaileditemwidget.cpp
+qgsdetaileditemdata.cpp
qgsencodingfiledialog.cpp
qgsfiledropedit.cpp
qgslayerprojectionselector.cpp
@@ -12,6 +15,7 @@
qgsmapcanvasmap.cpp
qgsmapcanvassnapper.cpp
qgsmapoverviewcanvas.cpp
+qgsmaptip.cpp
qgsmaptool.cpp
qgsmaptoolemitpoint.cpp
qgsmaptoolpan.cpp
@@ -21,17 +25,19 @@
qgsquickprint.cpp
qgsrubberband.cpp
qgsvertexmarker.cpp
-qgsmaptip.cpp
SET(QGIS_GUI_MOC_HDRS
+qgsdetaileditemdelegate.h
+qgsdetaileditemwidget.h
+qgsdetaileditemdata.h
qgisinterface.h
qgsencodingfiledialog.h
qgslayerprojectionselector.h
qgsmapcanvas.h
qgsmapoverviewcanvas.h
+qgsmaptoolemitpoint.h
qgsmessageviewer.h
-qgsmaptoolemitpoint.h
qgsprojectionselector.h
qgsquickprint.h
Modified: trunk/qgis/src/ui/CMakeLists.txt
--- trunk/qgis/src/ui/CMakeLists.txt 2008-05-19 13:37:53 UTC (rev 8467)
+++ trunk/qgis/src/ui/CMakeLists.txt 2008-05-19 13:43:37 UTC (rev 8468)
@@ -26,6 +26,7 @@
qgscustomprojectiondialogbase.ui
qgsdbsourceselectbase.ui
qgsdelattrdialogbase.ui
+ qgsdetaileditemwidgetbase.ui
qgsfillstylewidgetbase.ui
qgsgeomtypedialogbase.ui
qgsgraduatedsymboldialogbase.ui
Added: trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui
--- trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui (rev 0)
+++ trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui 2008-05-19 13:43:37 UTC (rev 8468)
@@ -0,0 +1,115 @@
+<ui version="4.0" >
+ <class>QgsDetailedItemWidgetBase</class>
+ <widget class="QWidget" name="QgsDetailedItemWidgetBase" >
+ <property name="geometry" >
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>299</width>
+ <height>159</height>
+ </rect>
+ </property>
+ <property name="windowTitle" >
+ <string>Form</string>
+ </property>
+ <layout class="QGridLayout" >
+ <property name="leftMargin" >
+ <number>3</number>
+ </property>
+ <property name="topMargin" >
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
+ <property name="horizontalSpacing" >
+ </property>
+ <property name="verticalSpacing" >
+ </property>
+ <item row="0" column="0" >
+ <layout class="QHBoxLayout" >
+ <item>
+ <widget class="QCheckBox" name="cbx" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="text" >
+ <string/>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="lblIcon" >
+ </sizepolicy>
+ </property>
+ <property name="minimumSize" >
+ <size>
+ <width>0</width>
+ <height>0</height>
+ </size>
+ </property>
+ <property name="maximumSize" >
+ <size>
+ <width>80</width>
+ <height>80</height>
+ </size>
+ </property>
+ <string/>
+ </property>
+ <property name="pixmap" >
+ <pixmap>../../images/icons/qgis-icon-16x16.png</pixmap>
+ </property>
+ <property name="alignment" >
+ <set>Qt::AlignLeading|Qt::AlignLeft|Qt::AlignVCenter</set>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="lblTitle" >
+ <sizepolicy vsizetype="Minimum" hsizetype="Expanding" >
+ </sizepolicy>
+ </property>
+ <property name="font" >
+ <font>
+ <pointsize>15</pointsize>
+ <weight>75</weight>
+ <bold>true</bold>
+ </font>
+ </property>
+ <string>Heading Label</string>
+ </property>
+ </property>
+ <property name="wordWrap" >
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QTextBrowser" name="tbDetail" />
+ </item>
+ </layout>
+ </widget>
+ <resources/>
+ <connections/>
+</ui>
Property changes on: trunk/qgis/src/ui/qgsdetaileditemwidgetbase.ui
___________________________________________________________________
Modified: trunk/qgis/src/ui/qgspluginmanagerbase.ui
--- trunk/qgis/src/ui/qgspluginmanagerbase.ui 2008-05-19 13:37:53 UTC (rev 8467)
+++ trunk/qgis/src/ui/qgspluginmanagerbase.ui 2008-05-19 13:43:37 UTC (rev 8468)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>564</width>
- <height>368</height>
+ <width>551</width>
+ <height>377</height>
</rect>
</property>
<property name="mouseTracking" >
@@ -19,147 +19,113 @@
<bool>true</bool>
</property>
- <property name="margin" >
- <number>11</number>
- </property>
- <property name="spacing" >
- <number>6</number>
- </property>
- <item row="0" column="0" >
- <layout class="QHBoxLayout" >
- </property>
- </property>
- <item>
- <widget class="QLabel" name="textLabel1" >
- <property name="text" >
- <string>Plugin Directory</string>
- </property>
- <property name="buddy" >
- <cstring>txtPluginDir</cstring>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLineEdit" name="txtPluginDir" >
- <property name="windowModality" >
- <enum>Qt::NonModal</enum>
- </property>
- <property name="readOnly" >
- <bool>true</bool>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item row="1" column="0" >
+ <item row="0" column="0" colspan="3" >
<widget class="QLabel" name="textLabel1_2" >
- <string>To load a plugin, click the checkbox next to the plugin and click Ok</string>
+ <string>To enable / disable a plugin, click its checkbox or description</string>
</property>
</widget>
</item>
- <item row="4" column="0" >
+ <item row="1" column="0" colspan="3" >
+ <widget class="QListView" name="vwPlugins" >
+ <property name="selectionMode" >
+ <enum>QAbstractItemView::SingleSelection</enum>
</property>
+ <property name="selectionBehavior" >
+ <enum>QAbstractItemView::SelectItems</enum>
</property>
- <item>
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeType" >
- <enum>QSizePolicy::Expanding</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>100</width>
- <height>21</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QPushButton" name="btnSelectAll" >
- <string>&Select All</string>
- </property>
- <property name="shortcut" >
- <string>Alt+S</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="btnClearAll" >
- <string>C&lear All</string>
- </property>
- <string>Alt+L</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="btnOk" >
- <string>&Ok</string>
- </property>
- <string>Alt+O</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="btnClose" >
- <string>&Close</string>
- </property>
- <string>Alt+C</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer>
- </property>
- </property>
- <size>
- </size>
- </property>
- </spacer>
- </item>
- </layout>
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
<item row="2" column="0" >
- <widget class="QTableView" name="lstPlugins" >
- <property name="alternatingRowColors" >
- <bool>true</bool>
+ <widget class="QLabel" name="lblFilter" >
+ <string>&Filter</string>
</property>
- <property name="selectionMode" >
- <enum>QAbstractItemView::NoSelection</enum>
+ <property name="buddy" >
+ <cstring>leFilter</cstring>
</property>
- <property name="sortingEnabled" >
+ </widget>
+ </item>
+ <item row="2" column="1" colspan="2" >
+ <widget class="QLineEdit" name="leFilter" />
+ </item>
+ <item row="3" column="0" colspan="2" >
+ <widget class="QLabel" name="textLabel1" >
+ <string>Plugin Directory:</string>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="2" >
+ <widget class="QLabel" name="lblPluginDir" >
+ <sizepolicy vsizetype="Preferred" hsizetype="Expanding" >
+ </sizepolicy>
+ </property>
+ <string>Directory</string>
+ </property>
+ </property>
<bool>true</bool>
</property>
</widget>
</item>
+ <item row="4" column="0" colspan="3" >
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11" />
+ <tabstops>
+ <tabstop>vwPlugins</tabstop>
+ <tabstop>leFilter</tabstop>
+ <tabstop>buttonBox</tabstop>
+ </tabstops>
<resources/>
- <connections/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsPluginManagerBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>511</x>
+ <y>305</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>561</x>
+ <y>271</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>447</x>
+ <y>304</y>
+ </hint>
+ <x>479</x>
+ <y>341</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
