[QGIS Commit] r8486 - in trunk/qgis: . src/designer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed May 21 13:29:32 EDT 2008
Author: timlinux
Date: 2008-05-21 13:29:32 -0400 (Wed, 21 May 2008)
New Revision: 8486
   trunk/qgis/PROVENANCE
   trunk/qgis/src/designer/README.txt
Some minor updates to docs
Modified: trunk/qgis/PROVENANCE
--- trunk/qgis/PROVENANCE	2008-05-21 17:25:48 UTC (rev 8485)
+++ trunk/qgis/PROVENANCE	2008-05-21 17:29:32 UTC (rev 8486)
@@ -114,6 +114,7 @@
 * Tools.cc
 === src/plugins/grid_maker ===
+NOTE: These files have since been removed from SVN:
 * shapefile.h  Copyright (c) 1999, Frank Warmerdam, MIT or LGPL
 * utils.h
 **Taken from txt2dbf 1.0.2 by Frank Koormann, see http://www.usf.uni-osnabrueck.de/~fkoorman/software/dbftools.en.html.  Licensed as "The program is free of charge as well as the source" but no license is mentioned
Modified: trunk/qgis/src/designer/README.txt
--- trunk/qgis/src/designer/README.txt	2008-05-21 17:25:48 UTC (rev 8485)
+++ trunk/qgis/src/designer/README.txt	2008-05-21 17:29:32 UTC (rev 8486)
@@ -5,8 +5,8 @@
 Introduction:
-The purpose of the QGIS designer plugins is to all third
-party developers to create GIS enabled QT4 based applications
+The purpose of the QGIS designer plugins is to enable all third
+party developers to create GIS enabled Qt4 based applications
 with minimal programming. The idea being that you use the
 standard Qt4 Designer GUI design tool to create your user
 interface and then add map canvas, legend, projection selector
@@ -41,6 +41,6 @@
 Additional Notes:
 If you built Qt4 in debug mode then the designer plugins must also
-be build in debug mode or they will be ignored. The converse is also
+be built in debug mode or they will be ignored. The converse is also
 true.
More information about the QGIS-commit mailing list
