[QGIS Commit] r8487 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Wed May 21 13:31:00 EDT 2008
Author: timlinux
Date: 2008-05-21 13:31:00 -0400 (Wed, 21 May 2008)
New Revision: 8487
trunk/qgis/src/app/qgsprojectproperties.cpp
trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
Gui tidy ups for the project props dialog as part of the general GUI revision
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp 2008-05-21 17:29:32 UTC (rev 8486)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp 2008-05-21 17:31:00 UTC (rev 8487)
@@ -73,9 +73,13 @@
// position display is set (manual or automatic)
bool automaticPrecision = QgsProject::instance()->readBoolEntry("PositionPrecision","/Automatic");
if (automaticPrecision)
radAutomatic->setChecked(true);
else
radManual->setChecked(true);
int dp = QgsProject::instance()->readNumEntry("PositionPrecision", "/DecimalPlaces");
spinBoxDP->setValue(dp);
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2008-05-21 17:29:32 UTC (rev 8486)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2008-05-21 17:31:00 UTC (rev 8487)
@@ -5,8 +5,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>750</width>
- <height>615</height>
+ <width>452</width>
+ <height>495</height>
</rect>
</property>
<property name="windowTitle" >
@@ -22,12 +22,6 @@
<bool>true</bool>
</property>
<layout class="QGridLayout" >
- <property name="margin" >
- <number>9</number>
- </property>
- <property name="spacing" >
- <number>6</number>
- </property>
<item row="0" column="0" >
<widget class="QTabWidget" name="tabWidget" >
<property name="currentIndex" >
@@ -38,108 +32,47 @@
<string>General</string>
</attribute>
- </property>
- </property>
<widget class="QGroupBox" name="titleBox" >
<property name="title" >
- <string>Project Title</string>
+ <string>Title and colors</string>
</property>
- <number>11</number>
- </property>
- </property>
- <widget class="QLineEdit" name="titleEdit" >
- <property name="toolTip" >
- <string>Descriptive project name</string>
- </property>
+ <widget class="QLabel" name="label_2" >
<property name="text" >
- <string>Default project title</string>
+ <string>Project title</string>
</property>
</widget>
</item>
- </layout>
- </widget>
- </item>
- <item row="2" column="0" >
- <widget class="QGroupBox" name="btnGrpPrecision" >
- <property name="title" >
- <string>Precision</string>
- </property>
- <layout class="QHBoxLayout" >
- </property>
- </property>
- <item>
- <widget class="QRadioButton" name="radAutomatic" >
+ <item row="0" column="1" colspan="3" >
+ <widget class="QLineEdit" name="titleEdit" >
- <string>Automatically sets the number of decimal places in the mouse position display</string>
+ <string>Descriptive project name</string>
</property>
- <property name="whatsThis" >
- <string>The number of decimal places that are used when displaying the mouse position is automatically set to be enough so that moving the mouse by one pixel gives a change in the position display</string>
- </property>
- <string>Automatic</string>
+ <string>Default project title</string>
</property>
- <property name="checked" >
- <bool>true</bool>
- </property>
</widget>
</item>
- <item>
- <widget class="QRadioButton" name="radManual" >
- <string>Sets the number of decimal places to use for the mouse position display</string>
- </property>
- </property>
+ <item row="1" column="0" >
+ <widget class="QLabel" name="textLabel1" >
- <string>Manual</string>
+ <string>Selection color</string>
</property>
- </widget>
- </item>
- <item>
- <widget class="QSpinBox" name="spinBoxDP" >
- <string>The number of decimal places for the manual option</string>
+ <property name="buddy" >
+ <cstring>pbnSelectionColour</cstring>
</property>
- </property>
</widget>
</item>
- <item>
- <widget class="QLabel" name="textLabel3" >
- <property name="sizePolicy" >
- <sizepolicy>
- <hsizetype>0</hsizetype>
- <vsizetype>0</vsizetype>
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="text" >
- <string>decimal places</string>
- </property>
- </widget>
- </item>
- <item>
+ <item row="1" column="2" >
<spacer>
<property name="orientation" >
<enum>Qt::Horizontal</enum>
</property>
+ <property name="sizeType" >
+ <enum>QSizePolicy::Expanding</enum>
+ </property>
<property name="sizeHint" >
<size>
<width>40</width>
@@ -148,32 +81,7 @@
</property>
</spacer>
</item>
- </layout>
- </widget>
- </item>
- <item row="4" column="0" >
- <widget class="QGroupBox" name="groupBox" >
- <string>Map Appearance</string>
- </property>
- </property>
- </property>
- <item>
- <widget class="QLabel" name="textLabel1" >
- <string>Selection Color:</string>
- </property>
- <property name="buddy" >
- <cstring>pbnSelectionColour</cstring>
- </property>
- </widget>
- </item>
- <item>
+ <item row="1" column="3" >
<widget class="QgsColorButton" name="pbnSelectionColour" >
<property name="minimumSize" >
<size>
@@ -186,14 +94,21 @@
</property>
</widget>
</item>
- <item>
+ <item row="2" column="0" colspan="2" >
+ <widget class="QLabel" name="label" >
+ <property name="text" >
+ <string>Background color</string>
+ </property>
+ <cstring>pbnCanvasColor</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="2" >
<spacer>
</property>
- <property name="sizeType" >
- <enum>QSizePolicy::Expanding</enum>
- </property>
<size>
<width>40</width>
@@ -202,17 +117,7 @@
</property>
</spacer>
</item>
- <item>
- <widget class="QLabel" name="label" >
- <string>Background Color:</string>
- </property>
- <cstring>pbnCanvasColor</cstring>
- </property>
- </widget>
- </item>
- <item>
+ <item row="2" column="3" >
<widget class="QgsColorButton" name="pbnCanvasColor" >
<size>
@@ -225,88 +130,27 @@
</property>
</widget>
</item>
- <item>
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" >
- <size>
- <width>40</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
</layout>
</widget>
</item>
- <item row="3" column="0" >
- <widget class="QGroupBox" name="grpDigitizing" >
- <sizepolicy>
- <hsizetype>5</hsizetype>
- <vsizetype>7</vsizetype>
- </sizepolicy>
- </property>
- <string>Digitizing</string>
- </property>
- <widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox" >
- <property name="geometry" >
- <rect>
- <x>11</x>
- <y>21</y>
- <width>371</width>
- <height>31</height>
- </rect>
- </property>
- <string>Enable topological editing</string>
- </property>
- </widget>
- <widget class="QPushButton" name="mSnappingOptionsPushButton" >
- <rect>
- <x>11</x>
- <y>95</y>
- <width>194</width>
- <height>36</height>
- </rect>
- </property>
- <string>Snapping options...</string>
- </property>
- </widget>
- <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox" >
- <rect>
- <x>11</x>
- <y>58</y>
- </rect>
- </property>
- <string>Avoid intersections of new polygons</string>
- </property>
- </widget>
- </widget>
- </item>
<widget class="QGroupBox" name="btnGrpMapUnits" >
- <string>Map Units</string>
+ <string>Map units</string>
</property>
+ <property name="leftMargin" >
<number>11</number>
</property>
+ <property name="topMargin" >
+ <number>11</number>
</property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
<item>
<widget class="QRadioButton" name="radMeters" >
@@ -331,22 +175,106 @@
</property>
</widget>
</item>
- <item>
- <spacer>
+ </layout>
+ </widget>
+ </item>
+ <item row="2" column="0" >
+ <widget class="QGroupBox" name="btnGrpPrecision" >
+ <property name="title" >
+ <string>Precision</string>
+ </property>
+ <layout class="QGridLayout" >
+ <item row="0" column="0" >
+ <widget class="QRadioButton" name="radAutomatic" >
+ <property name="toolTip" >
+ <string>Automatically sets the number of decimal places in the mouse position display</string>
</property>
- <size>
- <width>40</width>
- </size>
+ <property name="whatsThis" >
+ <string>The number of decimal places that are used when displaying the mouse position is automatically set to be enough so that moving the mouse by one pixel gives a change in the position display</string>
</property>
- </spacer>
+ <string>Automatic</string>
+ </property>
+ <property name="checked" >
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
+ <item row="0" column="1" >
+ <widget class="QRadioButton" name="radManual" >
+ <string>Sets the number of decimal places to use for the mouse position display</string>
+ </property>
+ </property>
+ <string>Manual</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="2" >
+ <widget class="QSpinBox" name="spinBoxDP" >
+ <string>The number of decimal places for the manual option</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="3" >
+ <widget class="QLabel" name="textLabel3" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <string>decimal places</string>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
+ <item row="3" column="0" >
+ <widget class="QGroupBox" name="grpDigitizing" >
+ <sizepolicy vsizetype="Expanding" hsizetype="Preferred" >
+ </sizepolicy>
+ </property>
+ <string>Digitizing</string>
+ </property>
+ <widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox" >
+ <string>Enable topological editing</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox" >
+ <string>Avoid intersections of new polygons</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QPushButton" name="mSnappingOptionsPushButton" >
+ <string>Snapping options...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="tab2" >
@@ -354,12 +282,18 @@
<string>Projection</string>
</attribute>
<number>11</number>
</property>
</property>
+ </property>
+ </property>
<widget class="QCheckBox" name="cbxProjectionEnabled" >
@@ -401,18 +335,87 @@
</customwidget>
</customwidgets>
<tabstops>
- <tabstop>tabWidget</tabstop>
<tabstop>titleEdit</tabstop>
+ <tabstop>pbnSelectionColour</tabstop>
+ <tabstop>pbnCanvasColor</tabstop>
<tabstop>radMeters</tabstop>
<tabstop>radFeet</tabstop>
<tabstop>radDecimalDegrees</tabstop>
<tabstop>radAutomatic</tabstop>
<tabstop>radManual</tabstop>
<tabstop>spinBoxDP</tabstop>
- <tabstop>pbnSelectionColour</tabstop>
- <tabstop>pbnCanvasColor</tabstop>
+ <tabstop>mEnableTopologicalEditingCheckBox</tabstop>
+ <tabstop>mAvoidIntersectionsCheckBox</tabstop>
+ <tabstop>mSnappingOptionsPushButton</tabstop>
<tabstop>cbxProjectionEnabled</tabstop>
+ <tabstop>tabWidget</tabstop>
+ <tabstop>buttonBox</tabstop>
</tabstops>
<resources/>
- <connections/>
+ <connections>
+ <connection>
+ <sender>radManual</sender>
+ <signal>clicked(bool)</signal>
+ <receiver>spinBoxDP</receiver>
+ <slot>setEnabled(bool)</slot>
+ <hints>
+ <hint type="sourcelabel" >
+ <x>229</x>
+ <y>280</y>
+ </hint>
+ <hint type="destinationlabel" >
+ <x>416</x>
+ <y>286</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>textLabel3</receiver>
+ <hints>
+ <x>240</x>
+ <y>281</y>
+ </hint>
+ <x>583</x>
+ <y>290</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <sender>radAutomatic</sender>
+ <slot>setDisabled(bool)</slot>
+ <hints>
+ <x>100</x>
+ <y>290</y>
+ </hint>
+ <x>395</x>
+ <y>285</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <hints>
+ <x>87</x>
+ <y>284</y>
+ </hint>
+ <x>589</x>
+ <y>285</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
</ui>
