[QGIS Commit] r8495 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri May 23 03:59:45 EDT 2008
Author: dassau
Date: 2008-05-23 03:59:45 -0400 (Fri, 23 May 2008)
New Revision: 8495
   trunk/qgis/i18n/qgis_pl_PL.ts
updated polish gui translation file
Modified: trunk/qgis/i18n/qgis_pl_PL.ts
--- trunk/qgis/i18n/qgis_pl_PL.ts	2008-05-23 07:58:03 UTC (rev 8494)
+++ trunk/qgis/i18n/qgis_pl_PL.ts	2008-05-23 07:59:45 UTC (rev 8495)
@@ -1,5 +1,4 @@
-<?xml version="1.0" encoding="utf-8"?>
-<!DOCTYPE TS><TS version="1.1" language="pl_PL">
+<!DOCTYPE TS><TS>
 <defaultcodec></defaultcodec>
 <context>
     <name>Dialog</name>
@@ -551,21 +550,6 @@
         <translation type="unfinished"></translation>
     </message>
     <message>
-        <source>Couldn&apos;t load SIP module.
-Python support will be disabled.</source>
-        <translation type="unfinished"></translation>
-    </message>
-    <message>
-        <source>Couldn&apos;t load PyQt bindings.
-    </message>
-    <message>
-        <source>Couldn&apos;t load QGIS bindings.
-    </message>
-    <message>
         <source>Couldn&apos;t load plugin </source>
         <translation>Nie można wczytać wtyczki</translation>
     </message>
@@ -1035,6 +1019,50 @@
         <source>File could not been opened.</source>
     </message>
+    <message>
+        <source>Couldn&apos;t load SIP module.</source>
+        <translation type="unfinished"></translation>
+    </message>
+    <message>
+        <source>Python support will be disabled.</source>
+    </message>
+    <message>
+        <source>Couldn&apos;t load PyQt4.</source>
+    </message>
+    <message>
+        <source>Couldn&apos;t load PyQGIS.</source>
+    </message>
+    <message>
+        <source>An error occured during execution of following code:</source>
+    </message>
+    <message>
+        <source>Error details:</source>
+    </message>
+    <message>
+        <source>Type:</source>
+        <translation type="unfinished">Typ:</translation>
+    </message>
+    <message>
+        <source>Value:</source>
+    </message>
+    <message>
+        <source> is not writeable.</source>
+    </message>
+    <message>
+        <source>Please adjust permissions (if possible) and try again.</source>
+    </message>
+    <message>
+        <source>Uncatched fatal GRASS error</source>
+    </message>
 </context>
 <context>
     <name>QgisApp</name>
@@ -1052,11 +1080,11 @@
     </message>
     <message>
         <source>Map canvas. This is where raster and vector layers are displayed when added to the map</source>
-        <translation>Okno mapy. Tutaj wyświetlane są warstwy rastrowe i wektorowe, które zostały dodane do mapy</translation>
+        <translation type="obsolete">Okno mapy. Tutaj wyświetlane są warstwy rastrowe i wektorowe, które zostały dodane do mapy</translation>
     </message>
     <message>
         <source>Progress bar that displays the status of rendering layers and other time-intensive operations</source>
-        <translation>Pasek postępu informuje o postępie rysowania warstw oraz innych czasochłonnych operacji</translation>
+        <translation type="obsolete">Pasek postępu informuje o postępie rysowania warstw oraz innych czasochłonnych operacji</translation>
     </message>
     <message>
         <source>Displays the current map scale</source>
@@ -1072,23 +1100,23 @@
     </message>
     <message>
         <source>Version </source>
-        <translation>Wersja </translation>
+        <translation type="obsolete">Wersja </translation>
     </message>
     <message>
         <source> with PostgreSQL support</source>
-        <translation> z obsługą PostgreSQL</translation>
+        <translation type="obsolete"> z obsługą PostgreSQL</translation>
     </message>
     <message>
         <source> (no PostgreSQL support)</source>
-        <translation> (bez obsługi PostgreSQL)</translation>
+        <translation type="obsolete"> (bez obsługi PostgreSQL)</translation>
     </message>
     <message>
         <source>Quantum GIS is licensed under the GNU General Public License</source>
-        <translation>Quantum GIS jest rozpowszechniany na zasadach określonych w Powszechnej Licencji Publicznej GNU</translation>
+        <translation type="obsolete">Quantum GIS jest rozpowszechniany na zasadach określonych w Powszechnej Licencji Publicznej GNU</translation>
     </message>
     <message>
         <source>http://www.gnu.org/licenses</source>
-        <translation>http://www.gnu.org/licenses</translation>
+        <translation type="obsolete">http://www.gnu.org/licenses</translation>
     </message>
     <message>
         <source>Version</source>
@@ -1096,7 +1124,7 @@
     </message>
     <message>
         <source>Available Data Provider Plugins</source>
-        <translation>Dostępne wtyczki źródeł danych</translation>
+        <translation type="obsolete">Dostępne wtyczki źródeł danych</translation>
     </message>
     <message>
         <source>is not a valid or recognized data source</source>
@@ -2004,15 +2032,6 @@
         <translation>Wklej zaznaczone obiekty</translation>
     </message>
     <message>
-        <source>
-Compiled against Qt </source>
-    </message>
-    <message>
-        <source>, running against Qt </source>
-    </message>
-    <message>
         <source>T</source>
         <comment>Show most toolbars</comment>
         <translation>T</translation>
@@ -2022,7 +2041,7 @@
         <comment>
 Hide most toolbars</comment>
-        <translation>Ctrl+T</translation>
+        <translation type="obsolete">Ctrl+T</translation>
     </message>
     <message>
         <source>Checking provider plugins</source>
@@ -2093,10 +2112,6 @@
     </message>
     <message>
-        <source>Shows the map coordinates at the current cursor position. The display is continuously updated as the mouse is moved.</source>
-    </message>
-    <message>
         <source>Saved project to:</source>
     </message>
@@ -2226,6 +2241,58 @@
         <source>Support for migration of old projects to work in newer QGIS versions.</source>
     </message>
+    <message>
+        <source>Ctrl+T</source>
+        <comment>Hide most toolbars</comment>
+        <translation type="unfinished">Ctrl+T</translation>
+    </message>
+    <message>
+        <source>Progress bar that displays the statusof rendering layers and other time-intensive operations</source>
+    </message>
+    <message>
+        <source>Shows the map coordinates at thecurrent cursor position. The display is continuously updated as the mouse is moved.</source>
+    </message>
+    <message>
+        <source>Resource Location Error</source>
+    </message>
+    <message>
+        <source>Error reading icon resources from:
+ %1
+ Quitting...</source>
+    </message>
+    <message>
+        <source>Map canvas. This is where raster and vectorlayers are displayed when added to the map</source>
+    </message>
+    <message>
+        <source>Overview</source>
+    </message>
+    <message>
+        <source>Legend</source>
+        <translation type="unfinished">Legenda</translation>
+    </message>
+    <message>
+        <source>You are using QGIS version %1 built against code revision %2.</source>
+    </message>
+    <message>
+        <source> This copy of QGIS has been built with PostgreSQL support.</source>
+    </message>
+    <message>
+        <source> This copy of QGIS has been built without PostgreSQL support.</source>
+    </message>
+    <message>
+        <source>
+This binary was compiled against Qt %1,and is currently running against Qt %2</source>
+    </message>
 </context>
 <context>
     <name>QgisAppBase</name>
@@ -2262,7 +2329,7 @@
     </message>
     <message>
         <source>Subscribe to the QGIS-User mailing list</source>
-        <translation>Subskrybuj listę QGIS-User</translation>
+        <translation type="obsolete">Subskrybuj listę QGIS-User</translation>
     </message>
     <message>
@@ -2278,7 +2345,7 @@
     </message>
     <message>
         <source>&lt;h2&gt;Quantum GIS (qgis)&lt;/h2&gt;</source>
-        <translation>&lt;h2&gt;Quantum GIS (qgis)&lt;/h2&gt;</translation>
+        <translation type="obsolete">&lt;h2&gt;Quantum GIS (qgis)&lt;/h2&gt;</translation>
     </message>
     <message>
         <source>Developers</source>
@@ -2286,12 +2353,31 @@
     </message>
     <message>
         <source>&lt;h2&gt;QGIS Developers&lt;/h2&gt;</source>
-        <translation>&lt;h2&gt;Programiści QGIS&lt;/h2&gt;</translation>
+        <translation type="obsolete">&lt;h2&gt;Programiści QGIS&lt;/h2&gt;</translation>
     </message>
     <message>
         <source>Sponsors</source>
         <translation>Sponsorzy</translation>
     </message>
+    <message>
+        <source>&lt;html&gt;&lt;head&gt;&lt;meta name=&quot;qrichtext&quot; content=&quot;1&quot; /&gt;&lt;style type=&quot;text/css&quot;&gt;
+p, li { white-space: pre-wrap; }
+&lt;/style&gt;&lt;/head&gt;&lt;body style=&quot; font-family:&apos;Lucida Grande&apos;; font-size:13pt; font-weight:400; font-style:normal;&quot;&gt;
+&lt;p style=&quot; margin-top:16px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-size:x-large; font-weight:600;&quot;&gt;&lt;span style=&quot; font-size:x-large;&quot;&gt;Quantum GIS (QGIS)&lt;/span&gt;&lt;/p&gt;&lt;/body&gt;&lt;/html&gt;</source>
+    </message>
+    <message>
+        <source>Quantum GIS is licensed under the GNU General Public License</source>
+        <translation type="unfinished">Quantum GIS jest rozpowszechniany na zasadach określonych w Powszechnej Licencji Publicznej GNU</translation>
+    </message>
+    <message>
+        <source>http://www.gnu.org/licenses</source>
+        <translation type="unfinished">http://www.gnu.org/licenses</translation>
+    </message>
+    <message>
+        <source>Join our user mailing list</source>
+    </message>
 </context>
 <context>
     <name>QgsAddAttrDialogBase</name>
@@ -2309,28 +2395,24 @@
     </message>
     <message>
         <source>OK</source>
-        <translation>OK</translation>
+        <translation type="obsolete">OK</translation>
     </message>
     <message>
         <source>Cancel</source>
-        <translation>Anuluj</translation>
+        <translation type="obsolete">Anuluj</translation>
     </message>
 </context>
 <context>
     <name>QgsAttributeActionDialog</name>
     <message>
         <source>Name</source>
-        <translation>Nazwa</translation>
+        <translation type="obsolete">Nazwa</translation>
     </message>
     <message>
         <source>Action</source>
-        <translation>Akcja</translation>
+        <translation type="obsolete">Akcja</translation>
     </message>
     <message>
-        <source>Capture</source>
-    </message>
-    <message>
         <source>Select an action</source>
         <comment>File dialog window title</comment>
@@ -2340,7 +2422,7 @@
     <name>QgsAttributeActionDialogBase</name>
     <message>
         <source>Form1</source>
-        <translation>Form1</translation>
+        <translation type="obsolete">Form1</translation>
     </message>
     <message>
         <source>This list contains all actions that have been defined for the current layer. Add actions by entering the details in the controls below and then pressing the Insert action button. Actions can be edited here by double clicking on the item.</source>
@@ -2372,7 +2454,7 @@
     </message>
     <message>
         <source>Name:</source>
-        <translation>Nazwa:</translation>
+        <translation type="obsolete">Nazwa:</translation>
     </message>
     <message>
         <source>Enter the action name here</source>
@@ -2380,7 +2462,7 @@
     </message>
     <message>
         <source>Action:</source>
-        <translation>Akcja:</translation>
+        <translation type="obsolete">Akcja:</translation>
     </message>
     <message>
         <source>Enter the action command here</source>
@@ -2388,7 +2470,7 @@
     </message>
     <message>
         <source>Browse</source>
-        <translation>Przeglądaj</translation>
+        <translation type="obsolete">Przeglądaj</translation>
     </message>
     <message>
         <source>Insert action</source>
@@ -2411,10 +2493,6 @@
     </message>
     <message>
-        <source>Browse for action commands</source>
-    </message>
-    <message>
         <source>Inserts the action into the list above</source>
     </message>
@@ -2442,6 +2520,42 @@
         <source>Enter the action here. This can be any program, script or command that is available on your system. When the action is invoked any set of characters that start with a % and then have the name of a field will be replaced by the value of that field. The special characters %% will be replaced by the value of the field that was selected. Double quote marks group text into single arguments to the program, script or command. Double quotes will be ignored if preceeded by a backslash</source>
     </message>
+    <message>
+        <source>Attribute Actions</source>
+    </message>
+    <message>
+        <source>Action properties</source>
+    </message>
+    <message>
+        <source>Name</source>
+        <translation type="unfinished">Nazwa</translation>
+    </message>
+    <message>
+        <source>Action</source>
+        <translation type="unfinished">Akcja</translation>
+    </message>
+    <message>
+        <source>Browse for action</source>
+    </message>
+    <message>
+        <source>Click to browse for an action</source>
+    </message>
+    <message>
+        <source>Clicking the buttone will let you select an application to use as the action</source>
+    </message>
+    <message>
+        <source>...</source>
+        <translation type="unfinished">...</translation>
+    </message>
+    <message>
+        <source>Capture</source>
+    </message>
 </context>
 <context>
     <name>QgsAttributeDialogBase</name>
@@ -2463,11 +2577,11 @@
     </message>
     <message>
         <source>&amp;OK</source>
-        <translation>&amp;OK</translation>
+        <translation type="obsolete">&amp;OK</translation>
     </message>
     <message>
         <source>&amp;Cancel</source>
-        <translation>&amp;Anuluj</translation>
+        <translation type="obsolete">&amp;Anuluj</translation>
     </message>
 </context>
 <context>
@@ -2674,6 +2788,14 @@
 </source>
         <translation> z bazy danych. Komunikat bazy danych:</translation>
     </message>
+    <message>
+        <source>&amp;Delete</source>
+    </message>
+    <message>
+        <source>&amp;Zoom to</source>
+    </message>
 </context>
 <context>
     <name>QgsBookmarksBase</name>
@@ -2699,31 +2821,31 @@
     </message>
     <message>
         <source>Zoom To</source>
-        <translation>Powiększ do</translation>
+        <translation type="obsolete">Powiększ do</translation>
     </message>
     <message>
         <source>Zoom to the currently selected bookmark</source>
-        <translation>Powiększ do wybranej zakładki</translation>
+        <translation type="obsolete">Powiększ do wybranej zakładki</translation>
     </message>
     <message>
         <source>Delete</source>
-        <translation>Usuń</translation>
+        <translation type="obsolete">Usuń</translation>
     </message>
     <message>
         <source>Delete the currently selected bookmark</source>
-        <translation>Usuń wybraną zakładkę</translation>
+        <translation type="obsolete">Usuń wybraną zakładkę</translation>
     </message>
     <message>
         <source>Close</source>
-        <translation>Zamknij</translation>
+        <translation type="obsolete">Zamknij</translation>
     </message>
     <message>
         <source>Close the dialog</source>
-        <translation>Zamknij okno</translation>
+        <translation type="obsolete">Zamknij okno</translation>
     </message>
     <message>
         <source>Help</source>
-        <translation>Pomoc</translation>
+        <translation type="obsolete">Pomoc</translation>
     </message>
 </context>
 <context>
@@ -3098,11 +3220,11 @@
     <name>QgsComposerVectorLegend</name>
     <message>
         <source>Layers</source>
-        <translation>Warstwy</translation>
+        <translation type="obsolete">Warstwy</translation>
     </message>
     <message>
         <source>Group</source>
-        <translation>Grupa</translation>
+        <translation type="obsolete">Grupa</translation>
     </message>
     <message>
         <source>Combine selected layers</source>
@@ -3149,12 +3271,24 @@
     </message>
     <message>
         <source>Column 1</source>
-        <translation>Kolumna 1</translation>
+        <translation type="obsolete">Kolumna 1</translation>
     </message>
     <message>
         <source>Preview</source>
         <translation>Podgląd</translation>
     </message>
+    <message>
+        <source>Layers</source>
+        <translation type="unfinished">Warstwy</translation>
+    </message>
+    <message>
+        <source>Group</source>
+        <translation type="unfinished">Grupa</translation>
+    </message>
+    <message>
+        <source>ID</source>
+    </message>
 </context>
 <context>
     <name>QgsComposition</name>
@@ -3431,8 +3565,12 @@
     </message>
     <message>
         <source>&#xa9; QGIS 2008</source>
-        <translation>© QGIS 2008</translation>
+        <translation type="obsolete">© QGIS 2008</translation>
     </message>
+    <message encoding="UTF-8">
+        <source>© QGIS 2008</source>
+    </message>
 </context>
 <context>
     <name>QgsCustomProjectionDialog</name>
@@ -3501,7 +3639,7 @@
     </message>
     <message>
         <source>Parameters:</source>
-        <translation>Parametry:</translation>
+        <translation type="obsolete">Parametry:</translation>
     </message>
     <message>
         <source>|&lt;</source>
@@ -3525,23 +3663,23 @@
     </message>
     <message>
         <source>New</source>
-        <translation>Nowy</translation>
+        <translation type="obsolete">Nowy</translation>
     </message>
     <message>
         <source>Save</source>
-        <translation>Zapisz</translation>
+        <translation type="obsolete">Zapisz</translation>
     </message>
     <message>
     </message>
     <message>
     </message>
     <message>
     </message>
     <message>
         <source>Test</source>
@@ -3549,7 +3687,7 @@
     </message>
     <message>
         <source>Transform from WGS84 to the chosen projection</source>
-        <translation>Przekształć z WGS84 do wybranego układu współrzędnych</translation>
+        <translation type="obsolete">Przekształć z WGS84 do wybranego układu współrzędnych</translation>
     </message>
     <message>
         <source>Calculate</source>
@@ -3561,11 +3699,11 @@
     </message>
     <message>
         <source>North:</source>
-        <translation>Północ:</translation>
+        <translation type="obsolete">Północ:</translation>
     </message>
     <message>
         <source>East:</source>
-        <translation>Wschód:</translation>
+        <translation type="obsolete">Wschód:</translation>
     </message>
     <message>
         <source>You can define your own custom projection here. The definition must conform to the proj4 format for specifying a Spatial Reference System.</source>
@@ -3579,6 +3717,34 @@
         <source>Projected Coordinate System</source>
     </message>
+    <message>
+    </message>
+    <message>
+        <source>Parameters</source>
+        <translation type="unfinished">Parametry</translation>
+    </message>
+    <message>
+        <source>*</source>
+    </message>
+    <message>
+        <source>S</source>
+        <translation type="unfinished">S</translation>
+    </message>
+    <message>
+        <source>X</source>
+    </message>
+    <message>
+        <source>North</source>
+        <translation type="unfinished">Północ</translation>
+    </message>
+    <message>
+        <source>East</source>
+        <translation type="unfinished">Wschód</translation>
+    </message>
 </context>
 <context>
     <name>QgsDbSourceSelect</name>
@@ -3945,7 +4111,7 @@
     </message>
     <message>
         <source>Browse...</source>
+        <translation type="unfinished">Przeglądaj...</translation>
     </message>
     <message>
         <source>The delimiter is taken as is</source>
@@ -3977,6 +4143,17 @@
     </message>
 </context>
 <context>
+    <name>QgsDetailedItemWidgetBase</name>
+    <message>
+        <source>Form</source>
+    </message>
+    <message>
+        <source>Heading Label</source>
+    </message>
+</context>
+<context>
     <name>QgsDlgPgBufferBase</name>
     <message>
         <source>Buffer features</source>
@@ -4519,11 +4696,11 @@
     <name>QgsGeomTypeDialog</name>
     <message>
     </message>
     <message>
         <source>Type</source>
-        <translation>Typ</translation>
+        <translation type="obsolete">Typ</translation>
     </message>
 </context>
 <context>
@@ -4550,7 +4727,7 @@
     </message>
     <message>
         <source>Attributes:</source>
-        <translation>Atrybuty:</translation>
+        <translation type="obsolete">Atrybuty:</translation>
     </message>
     <message>
         <source>Add</source>
@@ -4558,7 +4735,7 @@
     </message>
     <message>
     </message>
     <message>
         <source>Remove</source>
@@ -4566,8 +4743,20 @@
     </message>
     <message>
         <source>File Format:</source>
-        <translation>Format pliku:</translation>
+        <translation type="obsolete">Format pliku:</translation>
     </message>
+    <message>
+        <source>File format</source>
+    </message>
+    <message>
+        <source>Attributes</source>
+        <translation type="unfinished">Atrybuty</translation>
+    </message>
+    <message>
+    </message>
 </context>
 <context>
     <name>QgsGeorefDescriptionDialogBase</name>
@@ -4630,7 +4819,7 @@
     <name>QgsGeorefPluginGuiBase</name>
     <message>
         <source>Georeferencer</source>
+        <translation type="unfinished">Georeferencer</translation>
     </message>
     <message>
@@ -4718,15 +4907,15 @@
     </message>
     <message>
         <source>Classification Field:</source>
-        <translation>Pole klasyfikacji:</translation>
+        <translation type="obsolete">Pole klasyfikacji:</translation>
     </message>
     <message>
         <source>Mode:</source>
-        <translation>Tryb:</translation>
+        <translation type="obsolete">Tryb:</translation>
     </message>
     <message>
         <source>Number of Classes:</source>
-        <translation>Liczba klas:</translation>
+        <translation type="obsolete">Liczba klas:</translation>
     </message>
     <message>
         <source>Delete class</source>
@@ -4736,6 +4925,18 @@
         <source>Classify</source>
         <translation>Klasyfikuj</translation>
     </message>
+    <message>
+        <source>Classification field</source>
+    </message>
+    <message>
+        <source>Mode</source>
+        <translation type="unfinished">Tryb</translation>
+    </message>
+    <message>
+        <source>Number of classes</source>
+    </message>
 </context>
 <context>
     <name>QgsGrassAttributes</name>
@@ -5035,7 +5236,7 @@
 Column title</comment>
-        <translation type="unfinished">Kolor</translation>
+        <translation type="obsolete">Kolor</translation>
     </message>
     <message>
@@ -5043,7 +5244,7 @@
-        <translation type="unfinished">Typ</translation>
     </message>
     <message>
         <source>Index</source>
@@ -5051,7 +5252,7 @@
-        <translation type="unfinished">Indeks</translation>
+        <translation type="obsolete">Indeks</translation>
     </message>
     <message>
         <source>Column</source>
@@ -5081,6 +5282,21 @@
         <source>Right: </source>
     </message>
+    <message>
+        <source>Color</source>
+        <comment>Column title</comment>
+        <translation type="unfinished">Kolor</translation>
+    </message>
+    <message>
+        <source>Type</source>
+        <translation type="unfinished">Typ</translation>
+    </message>
+    <message>
+        <source>Index</source>
+        <translation type="unfinished">Indeks</translation>
+    </message>
 </context>
 <context>
     <name>QgsGrassEditBase</name>
@@ -5943,7 +6159,7 @@
     </message>
     <message>
         <source>Location: </source>
+        <translation type="unfinished">Lokalizacja: </translation>
     </message>
     <message>
         <source>Mapset: </source>
@@ -6185,7 +6401,7 @@
     </message>
     <message>
         <source>GRASS layer</source>
+        <translation type="unfinished">Warstwa GRASS</translation>
     </message>
     <message>
         <source>Create new Grass Vector</source>
@@ -6549,7 +6765,7 @@
     </message>
     <message>
         <source>Save As...</source>
+        <translation type="unfinished">Zapisz jako...</translation>
     </message>
     <message>
         <source>QGIS Graticule Creator</source>
@@ -6822,7 +7038,7 @@
     </message>
     <message>
         <source>&#xb0;</source>
-        <translation>°</translation>
+        <translation type="obsolete">°</translation>
     </message>
     <message>
         <source>Buffer Labels?</source>
@@ -6940,6 +7156,10 @@
         <source>Size Units:</source>
     </message>
+        <source>°</source>
+    </message>
 </context>
 <context>
     <name>QgsLayerProjectionSelector</name>
@@ -7077,7 +7297,7 @@
     </message>
     <message>
         <source>Do you want to save the changes?</source>
+        <translation type="unfinished">Czy chcesz zapisać zmiany?</translation>
     </message>
     <message>
         <source>Error</source>
@@ -7482,11 +7702,11 @@
     </message>
     <message>
     </message>
     <message>
     </message>
 </context>
 <context>
@@ -7538,6 +7758,10 @@
         <source>Total:</source>
         <translation>Ogółem:</translation>
     </message>
+    <message>
+        <source>Segments</source>
+    </message>
 </context>
 <context>
     <name>QgsMeasureDialog</name>
@@ -7731,7 +7955,7 @@
     </message>
     <message>
         <source>Connection Information</source>
+        <translation type="unfinished">Informacja o połączeniu</translation>
     </message>
     <message>
@@ -7896,11 +8120,11 @@
     </message>
     <message>
         <source>New Item</source>
     </message>
     <message>
     </message>
 </context>
 <context>
@@ -7938,7 +8162,7 @@
     </message>
     <message>
         <source>&amp;Appearance</source>
-        <translation>&amp;Wygląd</translation>
+        <translation type="obsolete">&amp;Wygląd</translation>
     </message>
     <message>
         <source>Hide splash screen at startup</source>
@@ -7946,11 +8170,11 @@
     </message>
     <message>
         <source>&amp;Icon Theme</source>
-        <translation>&amp;Temat ikon</translation>
+        <translation type="obsolete">&amp;Temat ikon</translation>
     </message>
     <message>
         <source>Theme</source>
-        <translation>Temat</translation>
+        <translation type="obsolete">Temat</translation>
     </message>
     <message>
         <source>&lt;b&gt;Note: &lt;/b&gt;Theme changes take effect the next time QGIS is started</source>
@@ -7962,7 +8186,7 @@
     </message>
     <message>
         <source>Update display after reading</source>
-        <translation>Odśwież mapę po odczytaniu</translation>
+        <translation type="obsolete">Odśwież mapę po odczytaniu</translation>
     </message>
     <message>
         <source>Map display will be updated (drawn) after this many features have been read from the data source</source>
@@ -7970,16 +8194,16 @@
     </message>
     <message>
         <source>features</source>
-        <translation>obiektów</translation>
+        <translation type="obsolete">obiektów</translation>
     </message>
     <message>
         <source>(Set to 0 to not update the display until all features have been read)</source>
-        <translation>(Podanie wartości 0 sprawi, że ekran nie będzie aktualizowany aż do zakończenia
+        <translation type="obsolete">(Podanie wartości 0 sprawi, że ekran nie będzie aktualizowany aż do zakończenia
 odczytu ze źródła danych)</translation>
     </message>
     <message>
         <source>Initial Visibility</source>
-        <translation>Widoczność początkowa</translation>
+        <translation type="obsolete">Widoczność początkowa</translation>
     </message>
     <message>
         <source>Select Global Default ...</source>
@@ -7987,35 +8211,35 @@
     </message>
     <message>
         <source>Prompt for projection.</source>
-        <translation>Pytaj o układ współrzędnych.</translation>
+        <translation type="obsolete">Pytaj o układ współrzędnych.</translation>
     </message>
     <message>
         <source>Project wide default projection will be used.</source>
-        <translation>Użyj domyślnego układu współrzędnych projektu.</translation>
+        <translation type="obsolete">Użyj domyślnego układu współrzędnych projektu.</translation>
     </message>
     <message>
         <source>&amp;Splash screen</source>
-        <translation>&amp;Ekran powitalny</translation>
+        <translation type="obsolete">&amp;Ekran powitalny</translation>
     </message>
     <message>
         <source>Default Map Appearance (Overridden by project properties)</source>
-        <translation>Domyślny wygląd mapy (podrzędny do właściwości projektu)</translation>
+        <translation type="obsolete">Domyślny wygląd mapy (podrzędny do właściwości projektu)</translation>
     </message>
     <message>
         <source>Background Color:</source>
-        <translation>Kolor tła:</translation>
+        <translation type="obsolete">Kolor tła:</translation>
     </message>
     <message>
         <source>Selection Color:</source>
-        <translation>Kolor zaznaczenia:</translation>
+        <translation type="obsolete">Kolor zaznaczenia:</translation>
     </message>
     <message>
         <source>Appearance</source>
-        <translation>Wygląd</translation>
+        <translation type="obsolete">Wygląd</translation>
     </message>
     <message>
         <source>Capitalise layer name</source>
-        <translation>Nazwa warstwy od dużej litery</translation>
+        <translation type="obsolete">Nazwa warstwy od dużej litery</translation>
     </message>
     <message>
         <source>Make lines appear less jagged at the expense of some drawing performance</source>
@@ -8027,7 +8251,7 @@
     </message>
     <message>
         <source>&amp;Update during drawing</source>
-        <translation>&amp;Odświeżanie podczas rysowania</translation>
+        <translation type="obsolete">&amp;Odświeżanie podczas rysowania</translation>
     </message>
     <message>
         <source>Measure tool</source>
@@ -8035,7 +8259,7 @@
     </message>
     <message>
         <source>Ellipsoid for distance calculations:</source>
-        <translation>Elipsoida do kalkulacji odległości:</translation>
+        <translation type="obsolete">Elipsoida do kalkulacji odległości:</translation>
     </message>
     <message>
         <source>Search radius</source>
@@ -8051,11 +8275,11 @@
     </message>
     <message>
         <source>Global default projection displa&amp;yed below will be used.</source>
-        <translation>Użyj globalnego dom&amp;yślnego układu współrzędnych, wyświetlonego poniżej.</translation>
+        <translation type="obsolete">Użyj globalnego dom&amp;yślnego układu współrzędnych, wyświetlonego poniżej.</translation>
     </message>
     <message>
         <source>Rendering</source>
-        <translation type="unfinished">Renderowanie</translation>
+        <translation type="obsolete">Renderowanie</translation>
     </message>
     <message>
         <source>Fix problems with incorrectly filled polygons</source>
@@ -8090,117 +8314,194 @@
     </message>
     <message>
-        <source>Zoom factor:</source>
+        <source>&amp;General</source>
     </message>
     <message>
-        <source>Mouse wheel action:</source>
+        <source>General</source>
+        <translation type="obsolete">Ogólne</translation>
+    </message>
+    <message>
+        <source>Locale</source>
     </message>
     <message>
-        <source>&amp;General</source>
+        <source>Locale to use instead</source>
     </message>
     <message>
-        <source>General</source>
-        <translation type="unfinished">Ogólne</translation>
+        <source>Additional Info</source>
     </message>
     <message>
-        <source>Ask to save project changes when required</source>
+        <source>Detected active locale on your system:</source>
     </message>
     <message>
-        <source>Rubberband color:</source>
+        <source>Selecting this will unselect the &apos;make lines less&apos; jagged toggle</source>
     </message>
     <message>
-        <source>Locale</source>
+        <source>Digitizing</source>
+        <translation type="unfinished">Digitalizacja</translation>
+    </message>
+    <message>
+        <source>Rubberband</source>
     </message>
     <message>
-        <source>Force Override System Locale</source>
+        <source>Line Width:</source>
+        <translation type="obsolete">Szerokość linii:</translation>
+    </message>
+    <message>
+        <source>Line width in pixels</source>
+        <translation type="unfinished">Szerokość linii w pikselach</translation>
+    </message>
+    <message>
+        <source>Line Colour:</source>
+        <translation type="obsolete">Kolor linii:</translation>
+    </message>
+    <message>
+        <source>Snapping</source>
     </message>
     <message>
-        <source>Locale to use instead</source>
+        <source>Zoom to mouse cursor</source>
     </message>
     <message>
-        <source>Note: Enabling / changing overide on local requires an application restart.</source>
+        <source>Vertex markers</source>
     </message>
     <message>
-        <source>Additional Info</source>
+        <source>Project files</source>
     </message>
     <message>
-        <source>Detected active locale on your system:</source>
+        <source>Prompt to save project changes when required</source>
     </message>
     <message>
-        <source>Warn me when opening a project file saved with an older version of QGIS</source>
+        <source>Warn when opening a project file saved with an older version of QGIS</source>
     </message>
     <message>
-        <source>Selecting this will unselect the &apos;make lines less&apos; jagged toggle</source>
+        <source>Default Map Appearance (overridden by project properties)</source>
     </message>
     <message>
-        <source>(Specify the search radius as a percentage of the map width)</source>
+        <source>Selection color</source>
     </message>
     <message>
-        <source>Search Radius for Identifying Features and displaying Map Tips</source>
+        <source>Background color</source>
     </message>
     <message>
-        <source>Digitizing</source>
-        <translation type="unfinished">Digitalizacja</translation>
+        <source>&amp;Application</source>
     </message>
     <message>
-        <source>Rubberband</source>
+        <source>Icon theme</source>
     </message>
     <message>
-        <source>Line Width:</source>
-        <translation type="unfinished">Szerokość linii:</translation>
+        <source>Capitalise layer names in legend</source>
     </message>
     <message>
-        <source>Line width in pixels</source>
-        <translation type="unfinished">Szerokość linii w pikselach</translation>
+        <source>Rendering behavior</source>
     </message>
     <message>
-        <source>Line Colour:</source>
-        <translation type="unfinished">Kolor linii:</translation>
+        <source>Number of features to draw before updating the display</source>
     </message>
     <message>
-        <source>Snapping</source>
+&lt;p style=&quot; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;&quot;&gt;&lt;span style=&quot; font-weight:600;&quot;&gt;Note:&lt;/span&gt; Use zero to prevent display updates until all features have been rendered&lt;/p&gt;&lt;/body&gt;&lt;/html&gt;</source>
     </message>
     <message>
-        <source>Default Snapping Tolerance (in layer units):</source>
+        <source>Rendering quality</source>
     </message>
     <message>
-        <source>Search radius for vertex edits (in layer units):</source>
+        <source>Zoom factor</source>
     </message>
     <message>
-        <source>Zoom to mouse cursor</source>
+        <source>Mouse wheel action</source>
     </message>
     <message>
-        <source>Default Snap Mode:</source>
+        <source>Rubberband color</source>
     </message>
     <message>
-        <source>Vertex markers</source>
+        <source>Ellipsoid for distance calculations</source>
     </message>
     <message>
-        <source>Marker style:</source>
+&lt;p style=&quot; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;&quot;&gt;&lt;span style=&quot; font-weight:600;&quot;&gt;Note:&lt;/span&gt; Specify the search radius as a percentage of the map width&lt;/p&gt;&lt;/body&gt;&lt;/html&gt;</source>
     </message>
+    <message>
+        <source>Search radius for identifying features and displaying map tips</source>
+    </message>
+    <message>
+        <source>Line width</source>
+        <translation type="unfinished">Szerokość linii</translation>
+    </message>
+    <message>
+        <source>Line colour</source>
+    </message>
+    <message>
+        <source>Default snap mode</source>
+    </message>
+    <message>
+        <source>Default snapping tolerance in layer units</source>
+    </message>
+    <message>
+        <source>Search radius for vertex edits in layer units</source>
+    </message>
+    <message>
+        <source>Marker style</source>
+    </message>
+    <message>
+        <source>Prompt for projection</source>
+    </message>
+    <message>
+        <source>Project wide default projection will be used</source>
+    </message>
+    <message>
+        <source>Global default projection displa&amp;yed below will be used</source>
+    </message>
+    <message>
+        <source>Override system locale</source>
+    </message>
+    <message>
+&lt;p style=&quot; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;&quot;&gt;&lt;span style=&quot; font-weight:600;&quot;&gt;Note:&lt;/span&gt; Enabling / changing overide on local requires an application restart&lt;/p&gt;&lt;/body&gt;&lt;/html&gt;</source>
+    </message>
 </context>
 <context>
     <name>QgsPasteTransformationsBase</name>
@@ -8327,6 +8628,10 @@
         <source>Geoprocessing functions are only available for PostgreSQL/PostGIS Layers</source>
     </message>
+    <message>
+        <source>Create a buffer for a PostgreSQL layer. </source>
+    </message>
 </context>
 <context>
     <name>QgsPgQueryBuilder</name>
@@ -8431,7 +8736,7 @@
     </message>
     <message>
         <source>Datasource:</source>
-        <translation>Źródło danych:</translation>
+        <translation type="obsolete">Źródło danych:</translation>
     </message>
     <message>
         <source>Operators</source>
@@ -8525,6 +8830,10 @@
 &lt;p style=&quot; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;&quot;&gt;List of fields in this vector file&lt;/p&gt;&lt;/body&gt;&lt;/html&gt;</source>
     </message>
+    <message>
+        <source>Datasource</source>
+    </message>
 </context>
 <context>
     <name>QgsPluginManager</name>
@@ -8538,18 +8847,22 @@
     </message>
     <message>
-        <translation type="unfinished">Nazwa</translation>
     </message>
     <message>
-        <translation type="unfinished">Wersja</translation>
+        <translation type="obsolete">Wersja</translation>
     </message>
     <message>
         <source>Description</source>
-        <translation type="unfinished">Opis</translation>
+        <translation type="obsolete">Opis</translation>
     </message>
     <message>
-        <source>Library name</source>
+        <source>&amp;Select All</source>
+        <translation type="unfinished">&amp;Zaznacz wszystko</translation>
+    </message>
+    <message>
+        <source>&amp;Clear All</source>
     </message>
 </context>
@@ -8557,48 +8870,64 @@
     <name>QgsPluginManagerBase</name>
     <message>
         <source>Plugin Directory</source>
-        <translation>Katalog wtyczek</translation>
+        <translation type="obsolete">Katalog wtyczek</translation>
     </message>
     <message>
         <source>To load a plugin, click the checkbox next to the plugin and click Ok</source>
-        <translation>Aby wczytać wtyczkę, zaznacz pole wyboru obok nazwy wtyczki i kliknij OK</translation>
+        <translation type="obsolete">Aby wczytać wtyczkę, zaznacz pole wyboru obok nazwy wtyczki i kliknij OK</translation>
     </message>
     <message>
-        <translation>&amp;Zaznacz wszystko</translation>
+        <translation type="obsolete">&amp;Zaznacz wszystko</translation>
     </message>
     <message>
         <source>Alt+S</source>
-        <translation>Alt+S</translation>
+        <translation type="obsolete">Alt+S</translation>
     </message>
     <message>
         <source>C&amp;lear All</source>
-        <translation>&amp;Odznacz wszystko</translation>
+        <translation type="obsolete">&amp;Odznacz wszystko</translation>
     </message>
     <message>
         <source>Alt+L</source>
-        <translation>Alt+L</translation>
+        <translation type="obsolete">Alt+L</translation>
     </message>
     <message>
         <source>&amp;Ok</source>
     </message>
     <message>
         <source>Alt+O</source>
-        <translation>Alt+O</translation>
+        <translation type="obsolete">Alt+O</translation>
     </message>
     <message>
         <source>&amp;Close</source>
-        <translation>&amp;Zamknij</translation>
+        <translation type="obsolete">&amp;Zamknij</translation>
     </message>
     <message>
         <source>Alt+C</source>
-        <translation>Alt+C</translation>
+        <translation type="obsolete">Alt+C</translation>
     </message>
     <message>
         <source>QGIS Plugin Manager</source>
     </message>
+    <message>
+        <source>To enable / disable a plugin, click its checkbox or description</source>
+    </message>
+    <message>
+        <source>&amp;Filter</source>
+    </message>
+    <message>
+        <source>Plugin Directory:</source>
+    </message>
+    <message>
+        <source>Directory</source>
+        <translation type="unfinished">Katalog</translation>
+    </message>
 </context>
 <context>
     <name>QgsPointDialog</name>
@@ -8656,7 +8985,7 @@
     </message>
     <message>
         <source>Linear</source>
+        <translation type="unfinished">Liniowa</translation>
     </message>
     <message>
         <source>Helmert</source>
@@ -8963,6 +9292,10 @@
         <source>unexpected PostgreSQL error</source>
     </message>
+    <message>
+        <source>Qgis was unable to determine the type and srid of column </source>
+    </message>
 </context>
 <context>
     <name>QgsProjectPropertiesBase</name>
@@ -8976,7 +9309,7 @@
     </message>
     <message>
         <source>Map Units</source>
-        <translation>Jednostki mapy</translation>
+        <translation type="obsolete">Jednostki mapy</translation>
     </message>
     <message>
         <source>Meters</source>
@@ -9024,15 +9357,15 @@
     </message>
     <message>
         <source>Map Appearance</source>
-        <translation>Wygląd mapy</translation>
+        <translation type="obsolete">Wygląd mapy</translation>
     </message>
     <message>
     </message>
     <message>
         <source>Project Title</source>
-        <translation>Tytuł projektu</translation>
+        <translation type="obsolete">Tytuł projektu</translation>
     </message>
     <message>
         <source>Projection</source>
@@ -9044,7 +9377,7 @@
     </message>
     <message>
     </message>
     <message>
         <source>Precision</source>
@@ -9070,6 +9403,26 @@
         <source>Avoid intersections of new polygons</source>
     </message>
+    <message>
+        <source>Title and colors</source>
+    </message>
+    <message>
+        <source>Project title</source>
+    </message>
+    <message>
+    </message>
+    <message>
+    </message>
+    <message>
+        <source>Map units</source>
+        <translation type="unfinished">jednostkach mapy</translation>
+    </message>
 </context>
 <context>
     <name>QgsProjectionSelector</name>
@@ -9160,15 +9513,15 @@
     </message>
     <message>
         <source> miles</source>
+        <translation type="unfinished">mile</translation>
     </message>
     <message>
         <source> mile</source>
+        <translation type="unfinished">mila</translation>
     </message>
     <message>
         <source> inches</source>
+        <translation type="unfinished">cale</translation>
     </message>
     <message>
         <source> foot</source>
@@ -9176,7 +9529,7 @@
     </message>
     <message>
         <source> feet</source>
+        <translation type="unfinished">stopy</translation>
     </message>
     <message>
         <source> degree</source>
@@ -9291,11 +9644,11 @@
     </message>
     <message>
         <source>Property</source>
-        <translation>Właściwość</translation>
+        <translation type="obsolete">Właściwość</translation>
     </message>
     <message>
         <source>Value</source>
-        <translation>Wartość</translation>
+        <translation type="obsolete">Wartość</translation>
     </message>
     <message>
         <source>Band</source>
@@ -9381,6 +9734,10 @@
         <source>NoDataValue not set</source>
     </message>
+    <message>
+        <source>Band %1</source>
+    </message>
 </context>
 <context>
     <name>QgsRasterLayerProperties</name>
@@ -9574,6 +9931,10 @@
         <source>Color Ramp</source>
     </message>
+    <message>
+        <source>Not Set</source>
+        <translation type="unfinished">Brak</translation>
+    </message>
 </context>
 <context>
     <name>QgsRasterLayerPropertiesBase</name>
@@ -9594,18 +9955,10 @@
         <translation>Brak</translation>
     </message>
     <message>
-        <source>Invert Color Map</source>
-    </message>
-    <message>
         <source>Gray</source>
         <translation>Szary</translation>
     </message>
     <message>
-        <source>Color Map</source>
-    </message>
-    <message>
         <translation>Ogólne</translation>
     </message>
@@ -9635,7 +9988,7 @@
     </message>
     <message>
         <source>Maximum 1:</source>
-        <translation>Maksymalna 1:</translation>
+        <translation type="obsolete">Maksymalna 1:</translation>
     </message>
     <message>
         <source>Maximum scale at which this layer will be displayed. </source>
@@ -9643,7 +9996,7 @@
     </message>
     <message>
         <source>Minimum 1:</source>
-        <translation>Minimalna 1:</translation>
+        <translation type="obsolete">Minimalna 1:</translation>
     </message>
     <message>
         <source>Minimum scale at which this layer will be displayed. </source>
@@ -9651,11 +10004,11 @@
     </message>
     <message>
         <source>Layer Source:</source>
-        <translation>Źródło warstwy:</translation>
+        <translation type="obsolete">Źródło warstwy:</translation>
     </message>
     <message>
         <source>Display Name:</source>
-        <translation>Nazwa wyświetlana:</translation>
+        <translation type="obsolete">Nazwa wyświetlana:</translation>
     </message>
     <message>
         <source>Metadata</source>
@@ -9666,10 +10019,6 @@
     </message>
     <message>
-        <source>Resampling Method</source>
-    </message>
-    <message>
         <source>Average</source>
     </message>
@@ -9678,249 +10027,320 @@
         <translation>Najbliższe sąsiedztwo</translation>
     </message>
     <message>
-        <source>Build Pyramids</source>
+        <source>Change</source>
+        <translation>Zmień</translation>
+    </message>
+    <message>
+        <source>Histogram</source>
     </message>
     <message>
-        <source>Pyramid Resolutions</source>
+        <source>Options</source>
+        <translation>Opcje</translation>
+    </message>
+    <message>
+        <source>Out Of Range OK?</source>
+        <translation type="obsolete">Poza zakresem OK?</translation>
+    </message>
+    <message>
+        <source>Chart Type</source>
     </message>
     <message>
-        <source>Spatial Reference System</source>
+        <source>Refresh</source>
+        <translation type="unfinished">Odśwież</translation>
+    </message>
+    <message>
+        <source>Max</source>
+        <translation type="unfinished">Max</translation>
+    </message>
+    <message>
+        <source>Min</source>
+        <translation type="unfinished">Min</translation>
+    </message>
+    <message>
+        <source>&lt;b&gt;&lt;font color=&apos;blue&apos;&gt;Max&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Change</source>
-        <translation>Zmień</translation>
+        <source>&lt;b&gt;&lt;font color=&apos;green&apos;&gt;Min&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Histogram</source>
+        <source>&lt;b&gt;&lt;font color=&apos;green&apos;&gt;Max&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Options</source>
-        <translation>Opcje</translation>
+        <source>&lt;b&gt;&lt;font color=&apos;red&apos;&gt;Min&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Out Of Range OK?</source>
-        <translation>Poza zakresem OK?</translation>
+        <source>&lt;b&gt;&lt;font color=&apos;red&apos;&gt;Max&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Allow Approximation</source>
+        <source>&lt;b&gt;&lt;font color=&apos;blue&apos;&gt;Min&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Chart Type</source>
+        <source>&lt;b&gt;&lt;font color=&apos;blue&apos;&gt;Blue&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Bar Chart</source>
+        <source>&lt;b&gt;&lt;font color=&apos;green&apos;&gt;Green&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Line Graph</source>
+        <source>&lt;b&gt;&lt;font color=&apos;red&apos;&gt;Red&lt;/font&gt;&lt;/b&gt;</source>
     </message>
     <message>
-        <source>Refresh</source>
+        <source> 00%</source>
     </message>
     <message>
-        <source>DebugInfo</source>
+        <source>Render as</source>
     </message>
     <message>
-        <source>Scale Dependent Visibility</source>
+    </message>
+    <message>
+        <source>Colormap</source>
     </message>
     <message>
-        <source>Column Count:</source>
+        <source>Delete entry</source>
     </message>
     <message>
-        <source>Grayscale Band Scaling</source>
+        <source>Classify</source>
+        <translation type="unfinished">Klasyfikuj</translation>
+    </message>
+    <message>
+        <source>1</source>
+        <translation type="unfinished">1</translation>
+    </message>
+    <message>
+        <source>2</source>
+        <translation type="unfinished">2</translation>
+    </message>
+    <message>
+        <source>Three band color</source>
     </message>
     <message>
-        <source>Max</source>
-        <translation type="unfinished">Max</translation>
+        <source>Single band gray</source>
     </message>
     <message>
-        <source>Std Deviation</source>
+        <source>Color map</source>
     </message>
     <message>
-        <source>Custom Min Max Values:</source>
+        <source>Invert color map</source>
     </message>
     <message>
-        <source>Min</source>
-        <translation type="unfinished">Min</translation>
+        <source>RGB mode band selection</source>
     </message>
     <message>
-        <source>Contrast Enhancement</source>
+        <source>Grayscale band selection</source>
     </message>
     <message>
-        <source>Load Min Max Values From Band(s)</source>
+        <source>RGB scaling</source>
     </message>
     <message>
-        <source>RGB Scaling</source>
+        <source>Std. deviation</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;blue&apos;&gt;Max&lt;/font&gt;&lt;/b&gt;</source>
+        <source>Custom min / max values</source>
     </message>
     <message>
-        <source>Custom Min Max Values</source>
+        <source>Grayscale band scaling</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;green&apos;&gt;Min&lt;/font&gt;&lt;/b&gt;</source>
+        <source>Load min / max values from band</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;green&apos;&gt;Max&lt;/font&gt;&lt;/b&gt;</source>
+        <source>Estimate (faster)</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;red&apos;&gt;Min&lt;/font&gt;&lt;/b&gt;</source>
+        <source>Load</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;red&apos;&gt;Max&lt;/font&gt;&lt;/b&gt;</source>
+        <source>Actual (slower)</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;blue&apos;&gt;Min&lt;/font&gt;&lt;/b&gt;</source>
+        <source>Contrast enhancement</source>
     </message>
     <message>
-        <source>Grayscale Band Selection</source>
+        <source>Current</source>
     </message>
     <message>
-        <source>RGB Mode Band Selection</source>
+        <source>Save current contrast enhancement algorithm as default. This setting will be persistent between QGIS sessions.</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;blue&apos;&gt;Blue&lt;/font&gt;&lt;/b&gt;</source>
+        <source>Saves current contrast enhancement algorithm as a default. This setting will be persistent between QGIS sessions.</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;green&apos;&gt;Green&lt;/font&gt;&lt;/b&gt;</source>
+        <source>Default</source>
     </message>
     <message>
-        <source>&lt;b&gt;&lt;font color=&apos;red&apos;&gt;Red&lt;/font&gt;&lt;/b&gt;</source>
+        <source>TextLabel</source>
     </message>
     <message>
-        <source>Global Transparency</source>
+        <source>Transparency</source>
     </message>
     <message>
-        <source> 00%</source>
+        <source>Global transparency</source>
     </message>
     <message>
-        <source>Render as</source>
+        <source>No data value</source>
     </message>
     <message>
-        <source>Single Band Gray</source>
+        <source>Reset no data value</source>
     </message>
     <message>
-        <source>Three Band Color</source>
+        <source>Custom transparency options</source>
     </message>
     <message>
-        <source>Transparent Pixels</source>
+        <source>Transparency band</source>
     </message>
     <message>
-        <source>Transparent Band:</source>
+        <source>Transparency layer;</source>
     </message>
     <message>
-        <source>Custom Transparency List</source>
+        <source>Transparent pixel list</source>
     </message>
     <message>
-        <source>Transparency Layer;</source>
+        <source>Add values manually</source>
     </message>
     <message>
-        <source>Add Values Manually</source>
+        <source>Add Values from display</source>
     </message>
     <message>
-        <source>...</source>
-        <translation type="unfinished">...</translation>
+        <source>Remove selected row</source>
     </message>
     <message>
-        <source>Add Values From Display</source>
+        <source>Default values</source>
     </message>
     <message>
-        <source>Remove Selected Row</source>
+        <source>Import from file</source>
     </message>
     <message>
-        <source>Default Values</source>
+        <source>Export to file</source>
     </message>
     <message>
-        <source>Import From File</source>
+        <source>Number of entries</source>
     </message>
     <message>
-        <source>Export To File</source>
+        <source>Color interpolation</source>
     </message>
     <message>
-        <source>No Data Value:</source>
+        <source>Classification mode</source>
     </message>
     <message>
-        <source>Reset No Data Value</source>
+        <source>Spatial reference system</source>
     </message>
     <message>
-        <source>Colormap</source>
+        <source>Scale dependent visibility</source>
     </message>
     <message>
-        <source>Number of entries:</source>
+        <source>Maximum</source>
     </message>
     <message>
-        <source>Delete entry</source>
+        <source>Minimum</source>
     </message>
     <message>
-        <source>Classify</source>
+        <source>Show debug info</source>
     </message>
     <message>
-        <source>1</source>
-        <translation type="unfinished">1</translation>
+        <source>Layer source</source>
     </message>
     <message>
-        <source>2</source>
-        <translation type="unfinished">2</translation>
+        <source>Display name</source>
+        <translation type="unfinished">Nazwa wyświetlana</translation>
     </message>
     <message>
-        <source>Color interpolation:</source>
+&lt;p style=&quot;-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:&apos;Sans Serif&apos;; font-size:9pt;&quot;&gt;&lt;/p&gt;&lt;/body&gt;&lt;/html&gt;</source>
     </message>
     <message>
-        <source>Classification mode:</source>
+        <source>Pyramid resolutions</source>
     </message>
+    <message>
+        <source>Resampling method</source>
+    </message>
+    <message>
+        <source>Build pyramids</source>
+    </message>
+    <message>
+        <source>Line graph</source>
+    </message>
+    <message>
+        <source>Bar chart</source>
+    </message>
+    <message>
+        <source>Column count</source>
+    </message>
+    <message>
+        <source>Out of range OK?</source>
+    </message>
+    <message>
+        <source>Allow approximation</source>
+    </message>
 </context>
 <context>
     <name>QgsRunProcess</name>
@@ -9934,7 +10354,7 @@
     </message>
     <message>
         <source>Done</source>
+        <translation type="unfinished">Zamknij</translation>
     </message>
 </context>
 <context>
@@ -10335,67 +10755,67 @@
     </message>
     <message>
-        <source>Solid Pattern</source>
+        <source>No Brush</source>
     </message>
     <message>
-        <source>Hor Pattern</source>
+        <source>Solid</source>
     </message>
     <message>
-        <source>Ver Pattern</source>
+        <source>Horizontal</source>
+        <translation type="unfinished">Poziomo</translation>
     </message>
     <message>
-        <source>Cross Pattern</source>
+        <source>Vertical</source>
+        <translation type="unfinished">Pionowo</translation>
     </message>
     <message>
-        <source>BDiag Pattern</source>
+        <source>Cross</source>
     </message>
     <message>
-        <source>FDiag Pattern</source>
+        <source>BDiagonal</source>
     </message>
     <message>
-        <source>Diag Cross Pattern</source>
+        <source>FDiagonal</source>
     </message>
     <message>
-        <source>Dense1 Pattern</source>
+        <source>Diagonal X</source>
     </message>
     <message>
-        <source>Dense2 Pattern</source>
+        <source>Dense1</source>
     </message>
     <message>
-        <source>Dense3 Pattern</source>
+        <source>Dense2</source>
     </message>
     <message>
-        <source>Dense4 Pattern</source>
+        <source>Dense3</source>
     </message>
     <message>
-        <source>Dense5 Pattern</source>
+        <source>Dense4</source>
     </message>
     <message>
-        <source>Dense6 Pattern</source>
+        <source>Dense5</source>
     </message>
     <message>
-        <source>Dense7 Pattern</source>
+        <source>Dense6</source>
     </message>
     <message>
-        <source>No Brush</source>
+        <source>Dense7</source>
     </message>
     <message>
-        <source>Texture Pattern</source>
+        <source>Texture</source>
     </message>
 </context>
@@ -10848,16 +11268,36 @@
     </message>
     <message>
     </message>
     <message>
-        <translation>Usuń klasę</translation>
+        <translation type="obsolete">Usuń klasę</translation>
     </message>
     <message>
     </message>
+    <message>
+    </message>
+    <message>
+        <source>Add class</source>
+    </message>
+    <message>
+        <source>Delete classes</source>
+    </message>
+    <message>
+        <source>Randomize Colors</source>
+    </message>
+    <message>
+        <source>Reset Colors</source>
+    </message>
 </context>
 <context>
     <name>QgsVectorLayer</name>
@@ -11037,7 +11477,7 @@
     </message>
     <message>
         <source>Legend type:</source>
-        <translation>Rodzaj legendy:</translation>
+        <translation type="obsolete">Rodzaj legendy:</translation>
     </message>
     <message>
         <source>Symbology</source>
@@ -11045,7 +11485,7 @@
     </message>
     <message>
         <source>Transparency:</source>
-        <translation>Przeźroczystość:</translation>
+        <translation type="obsolete">Przeźroczystość:</translation>
     </message>
     <message>
@@ -11057,11 +11497,11 @@
     </message>
     <message>
     </message>
     <message>
     </message>
     <message>
@@ -11080,12 +11520,8 @@
         <translation>Użyj tego narzędzia aby ustawić pola wyświetlane na górze w oknie wyników identyfikacji.</translation>
     </message>
     <message>
-    </message>
-    <message>
+        <translation type="obsolete">Zmień</translation>
     </message>
     <message>
         <source>Display field for the Identify Results dialog box</source>
@@ -11108,18 +11544,10 @@
         <translation>Kreator zapytań</translation>
     </message>
     <message>
-        <source>Spatial Index</source>
-    </message>
-    <message>
         <source>Create Spatial Index</source>
     </message>
     <message>
-        <source>Create</source>
-    </message>
-    <message>
         <translation>Metadane</translation>
     </message>
@@ -11151,6 +11579,30 @@
         <source>Save Style ...</source>
         <translation>Zapisz styl ...</translation>
     </message>
+    <message>
+        <source>Legend type</source>
+    </message>
+    <message>
+    </message>
+    <message>
+        <translation type="unfinished">Opcje</translation>
+    </message>
+    <message>
+        <source>Change SRS</source>
+    </message>
+    <message>
+    </message>
+    <message>
+    </message>
 </context>
 <context>
     <name>QgsVectorSymbologyWidgetBase</name>
More information about the QGIS-commit mailing list
