[QGIS Commit] r8496 - trunk/qgis/src/app
svn_qgis at osgeo.org
Fri May 23 11:12:53 EDT 2008
Author: wonder
Date: 2008-05-23 11:12:53 -0400 (Fri, 23 May 2008)
New Revision: 8496
trunk/qgis/src/app/qgspythonutils.cpp
trunk/qgis/src/app/qgspythonutils.h
Even better python errors handling: now displaying traceback, python version and python path.
Modified: trunk/qgis/src/app/qgspythonutils.cpp
--- trunk/qgis/src/app/qgspythonutils.cpp 2008-05-23 07:59:45 UTC (rev 8495)
+++ trunk/qgis/src/app/qgspythonutils.cpp 2008-05-23 15:12:53 UTC (rev 8496)
@@ -44,9 +44,11 @@
mMainModule = PyImport_AddModule("__main__"); // borrowed reference
mMainDict = PyModule_GetDict(mMainModule); // borrowed reference
- // import sys module
- runString("import sys");
+ runString("import sys"); // import sys module (for display / exception hooks)
+ runString("import traceback"); // for formatting stack traces
+ runString("import __main__"); // to access explicitly global variables
// expect that bindings are installed locally, so add the path to modules
// also add path to plugins
runString("sys.path = [\"" + homePluginsPath() + "\", \"" + pythonPath() + "\", \"" + pluginsPath() + "\"] + sys.path");
@@ -75,23 +77,22 @@
return;
- runString("import __main__");
- runString("import traceback"); // for formatting stack traces
// hook that will show information and traceback in message box
runString(
"def qgis_except_hook_msg(type, value, tb, msg):\n"
" lst = traceback.format_exception(type, value, tb)\n"
- " if msg == None: msg = 'An error has occured while executing Python code:'\n"
- " str = '<font color=\"red\">'+msg+'</font><br><br>'\n"
+ " if msg == None: msg = '" + QObject::tr("An error has occured while executing Python code:") + "'\n"
+ " txt = '<font color=\"red\">'+msg+'</font><br><br>'\n"
" for s in lst:\n"
- " str += s\n"
- " str = str.replace('\\n', '<br>')\n"
- " str = str.replace(' ', ' ')\n" // preserve whitespaces for nicer output
+ " txt += s\n"
+ " txt += '<br>" + QObject::tr("Python version:") + "<br>' + sys.version + '<br><br>'\n"
+ " txt += '"+QObject::tr("Python path:") + "' + str(sys.path)\n"
+ " txt = txt.replace('\\n', '<br>')\n"
+ " txt = txt.replace(' ', ' ')\n" // preserve whitespaces for nicer output
" \n"
" msg = QgsMessageOutput.createMessageOutput()\n"
- " msg.setTitle('Error')\n"
- " msg.setMessage(str, QgsMessageOutput.MessageHtml)\n"
+ " msg.setTitle('" + QObject::tr("Python error") + "')\n"
+ " msg.setMessage(txt, QgsMessageOutput.MessageHtml)\n"
" msg.showMessage()\n");
runString(
"def qgis_except_hook(type, value, tb):\n"
@@ -168,23 +169,22 @@
if (res)
return true;
- // an error occured
- // fetch error details and show it
- QString err_type, err_value;
- getError(err_type, err_value);
if (msgOnError.isEmpty())
// use some default message if custom hasn't been specified
msgOnError = QObject::tr("An error occured during execution of following code:") + "\n<tt>" + command + "</tt>";
- msgOnError.replace("\n", "<br>");
- QString str = msgOnError + "<br><br>" + QObject::tr("Error details:") + "<br>"
- + QObject::tr("Type:") + " <b>" + err_type + "</b><br>"
- + QObject::tr("Value:") + " <b>" + err_value + "</b>";
- // TODO: show sys.path, local variables, traceback
+ QString traceback = getTraceback();
+ QString path, version;
+ evalString("str(sys.path)", path);
+ evalString("sys.version", version);
+ QString str = "<font color=\"red\">"+ msgOnError + "</font><br><br>" + traceback + "<br>" +
+ QObject::tr("Python version:") + "<br>" + version + "<br><br>" +
+ QObject::tr("Python path:") + "<br>" + path;
+ str.replace("\n","<br>").replace(" ", " ");
QgsMessageOutput* msg = QgsMessageOutput::createMessageOutput();
msg->setTitle(QObject::tr("Python error"));
msg->setMessage(str, QgsMessageOutput::MessageHtml);
@@ -194,6 +194,78 @@
+QString QgsPythonUtils::getTraceback()
+#define TRACEBACK_FETCH_ERROR(what) {errMsg = what; goto done;}
+ QString errMsg;
+ QString result;
+ PyObject *modStringIO = NULL;
+ PyObject *modTB = NULL;
+ PyObject *obStringIO = NULL;
+ PyObject *obResult = NULL;
+ PyObject *type, *value, *traceback;
+ PyErr_Fetch(&type, &value, &traceback);
+ PyErr_NormalizeException(&type, &value, &traceback);
+ modStringIO = PyImport_ImportModule("cStringIO");
+ if (modStringIO==NULL)
+ TRACEBACK_FETCH_ERROR("can't import cStringIO");
+ obStringIO = PyObject_CallMethod(modStringIO, (char*) "StringIO", NULL);
+ /* Construct a cStringIO object */
+ if (obStringIO==NULL)
+ TRACEBACK_FETCH_ERROR("cStringIO.StringIO() failed");
+ modTB = PyImport_ImportModule("traceback");
+ if (modTB==NULL)
+ TRACEBACK_FETCH_ERROR("can't import traceback");
+ obResult = PyObject_CallMethod(modTB, (char*) "print_exception",
+ (char*) "OOOOO",
+ type, value ? value : Py_None,
+ traceback ? traceback : Py_None,
+ Py_None,
+ obStringIO);
+ if (obResult==NULL)
+ TRACEBACK_FETCH_ERROR("traceback.print_exception() failed");
+ Py_DECREF(obResult);
+ obResult = PyObject_CallMethod(obStringIO, (char*) "getvalue", NULL);
+ TRACEBACK_FETCH_ERROR("getvalue() failed.");
+ /* And it should be a string all ready to go - duplicate it. */
+ if (!PyString_Check(obResult))
+ TRACEBACK_FETCH_ERROR("getvalue() did not return a string");
+ result = PyString_AsString(obResult);
+done:
+ // All finished - first see if we encountered an error
+ if (result.isEmpty() && !errMsg.isEmpty())
+ result = errMsg;
+ Py_XDECREF(modStringIO);
+ Py_XDECREF(modTB);
+ Py_XDECREF(obStringIO);
+ Py_XDECREF(obResult);
+ Py_XDECREF(value);
+ Py_XDECREF(traceback);
+ Py_XDECREF(type);
+ return result;
QString QgsPythonUtils::getTypeAsString(PyObject* obj)
if (obj == NULL)
Modified: trunk/qgis/src/app/qgspythonutils.h
--- trunk/qgis/src/app/qgspythonutils.h 2008-05-23 07:59:45 UTC (rev 8495)
+++ trunk/qgis/src/app/qgspythonutils.h 2008-05-23 15:12:53 UTC (rev 8496)
@@ -114,7 +114,8 @@
static void installErrorHook();
+ static QString getTraceback();
//! path where
static QString mPluginsPath;
