[QGIS Commit] r8529 - in branches/advanced_printing_branch/src:
app/composer ui
svn_qgis at osgeo.org
Wed May 28 03:46:59 EDT 2008
Author: mhugent
Date: 2008-05-28 03:46:59 -0400 (Wed, 28 May 2008)
New Revision: 8529
branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposer.h
branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposermap.h
branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.h
branches/advanced_printing_branch/src/app/composer/qgscomposition.cpp
branches/advanced_printing_branch/src/app/composer/qgscomposition.h
branches/advanced_printing_branch/src/ui/qgscomposerbase.ui
Improvements with new composer map widget, but not fully functional yet
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposer.cpp 2008-05-28 07:46:59 UTC (rev 8529)
@@ -75,8 +75,6 @@
mCompositionOptionsLayout = new QGridLayout( mCompositionOptionsFrame );
mCompositionOptionsLayout->setMargin(0);
- mItemOptionsLayout = new QGridLayout( mItemOptionsFrame );
- mItemOptionsLayout->setMargin(0);
mCompositionNameComboBox->insertItem( tr("Map 1") );
@@ -147,72 +145,52 @@
-void QgsComposer::removeWidgetChildren ( QWidget *w )
+void QgsComposer::showCompositionOptions ( QWidget *w )
-#ifdef QGISDEBUG
- std::cout << "QgsComposer::removeWidgetChildren" << std::endl;
-#endif
+ QWidget* currentWidget = mItemStackedWidget->currentWidget();
+ mItemStackedWidget->removeWidget(currentWidget);
+ mItemStackedWidget->addWidget(w);
- const QObjectList ol = mItemOptionsFrame->children();
- if ( !ol.isEmpty() )
- QListIterator<QObject*> olit( ol );
- QObject *ob;
- while( olit.hasNext() )
+void QgsComposer::showItemOptions(const QgsComposerItem* item)
+ if(!item)
- ob = olit.next();
- if( ob->isWidgetType() )
- QWidget *ow = (QWidget *) ob;
- // The following line is legacy Qt3, is not supported in Qt4
- // and can cause a SIGABRT
- //w->removeChild ( ob );
- // instead:
- ow->setParent(0);
- // TODO: Eventually mItemOptionsFrame should be made
- // a Qt4 QStackedWidget and all this removeWidgetChildren
- // shenanigans can alledgedly go away
+ QMap<QgsComposerItem*, QWidget*>::iterator it = mItemWidgetMap.find(const_cast<QgsComposerItem*>(item));
+ if(it == mItemWidgetMap.constEnd())
+ return;
- ow->hide();
+ QWidget* newWidget = it.value();
+ if(!newWidget || newWidget == currentWidget) //bail out if new widget does not exist or is already there
+ return;
-void QgsComposer::showCompositionOptions ( QWidget *w ) {
-#ifdef QGISDEBUG
- std::cout << "QgsComposer::showCompositionOptions" << std::endl;
-#endif
- removeWidgetChildren ( mCompositionOptionsFrame );
- if ( w ) {
- w->reparent ( mCompositionOptionsFrame, QPoint(0,0), TRUE );
- mCompositionOptionsLayout->addWidget( w, 0, 0 );
+ mItemStackedWidget->addWidget(newWidget);
-void QgsComposer::showItemOptions ( QWidget *w )
+void QgsComposer::addItem(QgsComposerItem* item, QWidget* widget)
-#ifdef QGISDEBUG
- std::cout << "QgsComposer::showItemOptions" << std::endl;
-#endif
- removeWidgetChildren ( mItemOptionsFrame );
+ mItemWidgetMap.insert(item, widget);
- // NOTE: It is better to leave there the tab with item options if w is NULL
- if ( w ) {
- w->reparent ( mItemOptionsFrame, QPoint(0,0), TRUE );
- mItemOptionsLayout->addWidget( w, 0, 0 );
- mOptionsTabWidget->setCurrentPage (1);
-void QgsComposer::showItemOptions(const QgsComposerItem* i)
+void QgsComposer::removeItem(QgsComposerItem* item)
- //todo...
+ QMap<QgsComposerItem*, QWidget*>::iterator it = mItemWidgetMap.find(item);
+ if(it != mItemWidgetMap.end())
+ delete it.value();
+ mView->scene()->removeItem(item);
+ mItemWidgetMap.remove(item);
+ delete item;
QgsMapCanvas *QgsComposer::mapCanvas(void)
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposer.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposer.h 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposer.h 2008-05-28 07:46:59 UTC (rev 8529)
@@ -77,7 +77,6 @@
void showCompositionOptions ( QWidget *w );
//! Show item options in widget
- //void showItemOptions ( QWidget *w );
void showItemOptions(const QgsComposerItem* i);
/** \brief stores statei in project */
@@ -95,6 +94,15 @@
//! Restore the window and toolbar state
void restoreWindowState();
+ /** Adds an item and its configuration widget to the composer. \
+ QgsComposer takes ownership of these objects and deletes them \
+ if not needed any more.
+ void addItem(QgsComposerItem* item, QWidget* widget);
+ /**Removes (and deletes) the item and its configuration widget from the composer*/
+ void removeItem(QgsComposerItem* item);
//! Move event
void moveEvent ( QMoveEvent * );
@@ -159,8 +167,6 @@
private:
//! Set teh pixmap / icons on the toolbar buttons
void setupTheme();
- //! remove widget childrens
- void removeWidgetChildren ( QWidget *w );
/** \brief move up the content of the file
\param file file
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermap.cpp 2008-05-28 07:46:59 UTC (rev 8529)
@@ -667,14 +667,16 @@
void QgsComposerMap::resize(double dx, double dy)
- qWarning("QgsComposerMap::resize");
- qWarning(QString::number(dx).toLatin1());
- qWarning(QString::number(dy).toLatin1());
//setRect
QRectF currentRect = QGraphicsRectItem::rect();
- setRect(currentRect.x(), currentRect.y(), currentRect.width() + dx, currentRect.height() + dy);
+ QRectF newRect = QRectF(currentRect.x(), currentRect.y(), currentRect.width() + dx, currentRect.height() + dy);
+ setRect(newRect);
+void QgsComposerMap::setRect(const QRectF rectangle)
+ QGraphicsRectItem::setRect(rectangle);
recalculate();
+ emit extentChanged();
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermap.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposermap.h 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermap.h 2008-05-28 07:46:59 UTC (rev 8529)
@@ -108,9 +108,17 @@
/** resizes an item in x- and y direction (canvas coordinates)*/
void resize(double dx, double dy);
+ /**Sets new rect and does recalculate*/
+ void setRect(const QRectF rectangle);
/** \brief Scale */
double scale ( void );
+ Calculate calculationMode() {return mCalculate;}
+ PreviewMode previewMode() {return mPreviewMode;}
+ void setPreviewMode(PreviewMode m) {mPreviewMode = m;}
+ void setCalculationMode(Calculate c) {mCalculate = c;}
// Set cache outdated
void setCacheUpdated ( bool u = false );
@@ -142,6 +150,10 @@
// Called if map canvas has changed
void mapCanvasChanged ( );
+ signals:
+ /**Is emitted when width/height is changed as a result of user interaction*/
+ void extentChanged();
private:
// Called by GUI if with or height was changed
//void sizeChanged ( void );
@@ -189,7 +201,7 @@
bool mCacheUpdated;
// Resize schema
- int mCalculate;
+ Calculate mCalculate;
// Line width scale
double mWidthScale;
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.cpp 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.cpp 2008-05-28 07:46:59 UTC (rev 8529)
@@ -16,13 +16,181 @@
#include "qgscomposermapwidget.h"
+#include "qgscomposermap.h"
QgsComposerMapWidget::QgsComposerMapWidget(QgsComposerMap* composerMap): QWidget(), mComposerMap(composerMap)
setupUi(this);
+ mWidthLineEdit->setValidator(new QDoubleValidator(0));
+ mHeightLineEdit->setValidator(new QDoubleValidator(0));
+ mScaleLineEdit->setValidator(new QDoubleValidator(0));
+ mCalculateComboBox->insertItem( 0, tr("Extent (calculate scale)"));
+ mCalculateComboBox->insertItem( 1, tr("Scale (calculate extent)"));
+ mPreviewModeComboBox->insertItem(0, tr("Cache"));
+ mPreviewModeComboBox->insertItem(1, tr("Render"));
+ mPreviewModeComboBox->insertItem(2, tr("Rectangle"));
+ if(composerMap)
+ connect(composerMap, SIGNAL(extentChanged()), this, SLOT(updateSettingsNoSignals()));
+ updateGuiElements();
QgsComposerMapWidget::~QgsComposerMapWidget()
+void QgsComposerMapWidget::on_mWidthLineEdit_editingFinished()
+ if(mComposerMap)
+ bool conversionSuccess = true;
+ double newWidth = mWidthLineEdit->text().toDouble(&conversionSuccess);
+ if(!conversionSuccess)
+ return;
+ QRectF composerMapRect = mComposerMap->rect();
+ QRectF newRect(composerMapRect.x(), composerMapRect.y(), newWidth, composerMapRect.height());
+ mComposerMap->setRect(newRect);
+void QgsComposerMapWidget::on_mHeightLineEdit_editingFinished()
+ if(mComposerMap)
+ double newHeight = mHeightLineEdit->text().toDouble(&conversionSuccess);
+ return;
+ mComposerMap->resize(composerMapRect.width(), newHeight);
+void QgsComposerMapWidget::on_mPreviewModeComboBox_activated(int i)
+ if(!mComposerMap)
+ return;
+ QString comboText = mPreviewModeComboBox->currentText();
+ if(comboText == tr("Cache"))
+ mComposerMap->setPreviewMode(QgsComposerMap::Cache);
+ else if(comboText == tr("Render"))
+ mComposerMap->setPreviewMode(QgsComposerMap::Render);
+ else if(comboText == tr("Rectangle"))
+ mComposerMap->setPreviewMode(QgsComposerMap::Rectangle);
+void QgsComposerMapWidget::on_mCalculateComboBox_activated(int i)
+ if(!mComposerMap)
+ return;
+ QString comboText = mCalculateComboBox->currentText();
+ if(comboText == tr("Extent (calculate scale)"))
+ mComposerMap->setCalculationMode(QgsComposerMap::Scale);
+ mHeightLineEdit->setEnabled(true);
+ mWidthLineEdit->setEnabled(true);
+ mScaleLineEdit->setEnabled(false);
+ else if(comboText == tr("Scale (calculate extent)"))
+ mComposerMap->setCalculationMode(QgsComposerMap::Extent);
+ mHeightLineEdit->setEnabled(false);
+ mWidthLineEdit->setEnabled(false);
+ mScaleLineEdit->setEnabled(true);
+void QgsComposerMapWidget::updateSettingsNoSignals()
+ mHeightLineEdit->blockSignals(true);
+ mWidthLineEdit->blockSignals(true);
+ mScaleLineEdit->blockSignals(true);
+ mCalculateComboBox->blockSignals(true);
+ mPreviewModeComboBox->blockSignals(true);
+ mHeightLineEdit->blockSignals(false);
+ mWidthLineEdit->blockSignals(false);
+ mScaleLineEdit->blockSignals(false);
+ mCalculateComboBox->blockSignals(false);
+ mPreviewModeComboBox->blockSignals(false);
+void QgsComposerMapWidget::updateGuiElements()
+ if(mComposerMap)
+ //width, height, scale
+ mWidthLineEdit->setText(QString::number(composerMapRect.width()));
+ mHeightLineEdit->setText(QString::number(composerMapRect.height()));
+ mScaleLineEdit->setText(QString::number(mComposerMap->scale()));
+ //calculation mode
+ QgsComposerMap::Calculate calculationMode = mComposerMap->calculationMode();
+ int index = -1;
+ if(calculationMode == QgsComposerMap::Scale)
+ index = mCalculateComboBox->findText(tr("Extent (calculate scale)"));
+ else if(calculationMode == QgsComposerMap::Extent)
+ index = mCalculateComboBox->findText(tr("Scale (calculate extent)"));
+ if(index != -1)
+ mCalculateComboBox->setCurrentIndex(index);
+ //preview mode
+ QgsComposerMap::PreviewMode previewMode = mComposerMap->previewMode();
+ index = -1;
+ if(previewMode == QgsComposerMap::Cache)
+ index = mPreviewModeComboBox->findText(tr("Cache"));
+ else if(previewMode == QgsComposerMap::Render)
+ index = mPreviewModeComboBox->findText(tr("Render"));
+ else if(previewMode == QgsComposerMap::Rectangle)
+ index = mPreviewModeComboBox->findText(tr("Rectangle"));
+ if(index != -1)
+ mPreviewModeComboBox->setCurrentIndex(index);
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.h 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposermapwidget.h 2008-05-28 07:46:59 UTC (rev 8529)
@@ -32,8 +32,20 @@
QgsComposerMapWidget(QgsComposerMap* composerMap);
~QgsComposerMapWidget();
+ public slots:
+ void on_mWidthLineEdit_editingFinished();
+ void on_mHeightLineEdit_editingFinished();
+ void on_mPreviewModeComboBox_activated(int i);
+ void on_mCalculateComboBox_activated(int i);
+ /**Updates width and height without notify the composer map (to avoid infinite recursion)*/
+ void updateSettingsNoSignals();
private:
QgsComposerMap* mComposerMap;
+ /**Sets the current composer map values to the GUI elements*/
+ void updateGuiElements();
#endif
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposition.cpp
--- branches/advanced_printing_branch/src/app/composer/qgscomposition.cpp 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposition.cpp 2008-05-28 07:46:59 UTC (rev 8529)
@@ -22,6 +22,7 @@
#include "qgscomposerlabel.h"
+#include "qgscomposermapwidget.h"
#include "qgscomposerpicture.h"
#include "qgscomposerscalebar.h"
#include "qgscomposervectorlegend.h"
@@ -201,20 +202,10 @@
QgsComposition::~QgsComposition()
-#ifdef QGISDEBUG
- std::cerr << "QgsComposition::~QgsComposition" << std::endl;
-#endif
mView->setScene ( 0 );
- if ( mPaperItem ) delete mPaperItem;
- for (std::list < QgsComposerItem * >::iterator it = mItems.begin();
- it != mItems.end(); ++it)
- delete *it;
- if ( mCanvas ) delete mCanvas;
+ delete mPaperItem;
+ delete mCanvas;
QgsMapCanvas *QgsComposition::mapCanvas(void) { return mMapCanvas; }
@@ -259,8 +250,9 @@
if(selectedItem != mSelectedItem)
mSelectedItem->setSelected(false);
- //mComposer->showItemOptions(selectedItem->options()); //todo: separate items from input widgets
mSelectedItem = selectedItem;
+ mCanvas->update();
+ mComposer->showItemOptions(selectedItem);
break;
@@ -457,23 +449,28 @@
QgsComposerMap* m = 0;
- if ( w > 0 && h > 0 ) {
- mComposer->selectItem(); // usually just one map
+ if ( w > 0 && h > 0 )
+ mComposer->selectItem(); // usually just one map
- m = new QgsComposerMap ( this, mNextItemId++, x, y, w, h );
+ m = new QgsComposerMap ( this, mNextItemId++, x, y, w, h );
+ QgsComposerMapWidget* w = new QgsComposerMapWidget(m);
+ mComposer->addItem(m, w);
- m->setPos(x, y);
+ m->setPos(x, y);
- m->setUserExtent( mMapCanvas->extent());
- mItems.push_back(m);
- m->setSelected ( true );
- mComposer->showItemOptions ( m->options() );
- mSelectedItem = dynamic_cast <QGraphicsItem *> (m);
- } else {
- mToolStep = 0;
- mCanvas->update();
+ m->setUserExtent( mMapCanvas->extent());
+ mItems.push_back(m);
+ m->setSelected ( true );
+ mComposer->showItemOptions(m);
+ mSelectedItem = m;
+ else
+ mToolStep = 0;
+ //mCanvas->update();
mView->unsetCursor();
break;
@@ -544,17 +541,7 @@
if ( e->key() == Qt::Key_Delete) { // delete
QgsComposerItem *coi = dynamic_cast <QgsComposerItem *> (mSelectedItem);
- coi->setSelected ( false );
- coi->removeSettings();
- if ( (*it) == coi ) {
- mItems.erase ( it );
- break;
- delete (mSelectedItem);
+ mComposer->removeItem(coi);
mSelectedItem = 0;
mCanvas->update();
@@ -727,7 +714,7 @@
mCanvas->update();
mSelectedItem = 0;
- mComposer->showItemOptions ( (QWidget *) 0 );
+ mComposer->showItemOptions (0);
if ( mNewCanvasItem ) {
mNewCanvasItem->setPos(-1000, -1000);
@@ -749,7 +736,7 @@
// Create new object outside the visible area
QgsComposerVectorLegend *vl = new QgsComposerVectorLegend ( this, mNextItemId++, -1000, -1000, (int) (mPaperHeight/50));
mNewCanvasItem = dynamic_cast <QGraphicsItem *> (vl);
- mComposer->showItemOptions ( vl->options() );
+ mComposer->showItemOptions(vl);
mView->viewport()->setMouseTracking ( true ); // to recieve mouse move
@@ -761,7 +748,7 @@
QgsComposerLabel *lab = new QgsComposerLabel ( this, mNextItemId++, -1000, -1000, tr("Label"), (int) (mPaperHeight/20));
mNewCanvasItem = dynamic_cast <QGraphicsItem *> (lab);
- mComposer->showItemOptions ( lab->options() );
+ mComposer->showItemOptions(lab);
@@ -771,7 +758,7 @@
QgsComposerScalebar *sb = new QgsComposerScalebar ( this, mNextItemId++, -1000, -1000);
mNewCanvasItem = dynamic_cast <QGraphicsItem*> (sb);
- mComposer->showItemOptions ( sb->options() );
+ mComposer->showItemOptions(sb);
@@ -801,7 +788,7 @@
std::cout << "picture is valid" << std::endl;
#endif
mNewCanvasItem = dynamic_cast <QGraphicsItem *> (pi);
- mComposer->showItemOptions ( pi->options() );
+ mComposer->showItemOptions(pi);
mView->viewport()->setMouseTracking ( true ); // start tracking the mouse
break; //quit the loop
Modified: branches/advanced_printing_branch/src/app/composer/qgscomposition.h
--- branches/advanced_printing_branch/src/app/composer/qgscomposition.h 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/app/composer/qgscomposition.h 2008-05-28 07:46:59 UTC (rev 8529)
@@ -145,9 +145,6 @@
/** \brief pointer to composer */
QgsComposer *composer(void);
- // Return pointer to widget with composition options
- //QWidget *options ( void );
/** \brief Set this composition as active, show its canvas with items and show general options */
void setActive ( bool active );
Modified: branches/advanced_printing_branch/src/ui/qgscomposerbase.ui
--- branches/advanced_printing_branch/src/ui/qgscomposerbase.ui 2008-05-27 11:42:22 UTC (rev 8528)
+++ branches/advanced_printing_branch/src/ui/qgscomposerbase.ui 2008-05-28 07:46:59 UTC (rev 8529)
@@ -14,12 +14,21 @@
</property>
<widget class="QWidget" name="centralwidget" >
<layout class="QVBoxLayout" >
- <property name="margin" >
- <number>9</number>
- </property>
<property name="spacing" >
<number>6</number>
</property>
+ <property name="leftMargin" >
+ <number>9</number>
+ </property>
+ <property name="topMargin" >
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
<item>
<widget class="QSplitter" name="mSplitter" >
<property name="orientation" >
@@ -35,9 +44,7 @@
</widget>
<widget class="QTabWidget" name="mOptionsTabWidget" >
<property name="sizePolicy" >
- <sizepolicy>
- <hsizetype>7</hsizetype>
- <vsizetype>7</vsizetype>
+ <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
@@ -55,19 +62,31 @@
</size>
</property>
<property name="currentIndex" >
- <number>0</number>
+ <number>1</number>
</property>
<widget class="QWidget" name="tab" >
<attribute name="title" >
<string>General</string>
</attribute>
<layout class="QGridLayout" >
<number>9</number>
</property>
- <property name="spacing" >
+ </property>
+ </property>
+ </property>
+ <property name="horizontalSpacing" >
<number>6</number>
</property>
+ <property name="verticalSpacing" >
+ <number>6</number>
+ </property>
<item row="1" column="0" colspan="2" >
<widget class="QFrame" name="mCompositionOptionsFrame" >
<property name="frameShape" >
@@ -84,9 +103,7 @@
<bool>false</bool>
</property>
- <sizepolicy>
- <vsizetype>0</vsizetype>
+ <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
</sizepolicy>
@@ -96,9 +113,7 @@
<item row="0" column="0" >
<widget class="QLabel" name="textLabel1" >
- <sizepolicy>
- <vsizetype>5</vsizetype>
+ <sizepolicy vsizetype="Preferred" hsizetype="Expanding" >
</sizepolicy>
@@ -115,20 +130,28 @@
<string>Item</string>
</attribute>
<number>9</number>
</property>
+ </property>
+ </property>
+ </property>
<number>6</number>
</property>
+ </property>
- <widget class="QFrame" name="mItemOptionsFrame" >
- <property name="frameShape" >
- <enum>QFrame::StyledPanel</enum>
- </property>
- <property name="frameShadow" >
- <enum>QFrame::Raised</enum>
- </property>
+ <widget class="QStackedWidget" name="mItemStackedWidget" >
+ <widget class="QWidget" name="page" />
+ <widget class="QWidget" name="page_2" />
</widget>
</item>
</layout>
@@ -138,12 +161,21 @@
</item>
<item>
<layout class="QHBoxLayout" >
- </property>
<number>6</number>
</property>
+ <number>0</number>
+ </property>
+ </property>
+ </property>
+ </property>
<item>
<widget class="QPushButton" name="helpPButton" >
<property name="text" >
@@ -180,8 +212,11 @@
<enum>Qt::Horizontal</enum>
</property>
<attribute name="toolBarArea" >
- <number>4</number>
+ <enum>TopToolBarArea</enum>
</attribute>
+ <attribute name="toolBarBreak" >
+ <bool>false</bool>
+ </attribute>
<addaction name="mActionOpenTemplate" />
<addaction name="mActionSaveTemplateAs" />
<addaction name="mActionExportAsImage" />
