[QGIS Commit] r8530 - in trunk/qgis/src: . app python
svn_qgis at osgeo.org
Wed May 28 08:35:20 EDT 2008
Author: wonder
Date: 2008-05-28 08:35:20 -0400 (Wed, 28 May 2008)
New Revision: 8530
Added:
trunk/qgis/src/python/
trunk/qgis/src/python/CMakeLists.txt
trunk/qgis/src/python/qgispython.cpp
trunk/qgis/src/python/qgspythonutils.h
trunk/qgis/src/python/qgspythonutilsimpl.cpp
trunk/qgis/src/python/qgspythonutilsimpl.h
Removed:
trunk/qgis/src/app/qgspythonutils.cpp
trunk/qgis/src/app/qgspythonutils.h
trunk/qgis/src/app/qgspythonutilsimpl.h
trunk/qgis/src/CMakeLists.txt
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/app/qgisapp.cpp
Moved python support to a library, QGIS app now during the initialization tries to load that library.
Modified: trunk/qgis/src/CMakeLists.txt
--- trunk/qgis/src/CMakeLists.txt 2008-05-28 07:46:59 UTC (rev 8529)
+++ trunk/qgis/src/CMakeLists.txt 2008-05-28 12:35:20 UTC (rev 8530)
@@ -1,6 +1,10 @@
SUBDIRS(core ui gui app providers plugins helpviewer)
+IF (HAVE_PYTHON AND WITH_BINDINGS)
+ SUBDIRS(python)
+ENDIF (HAVE_PYTHON AND WITH_BINDINGS)
IF (APPLE)
SUBDIRS(mac)
ENDIF(APPLE)
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2008-05-28 07:46:59 UTC (rev 8529)
+++ trunk/qgis/src/app/CMakeLists.txt 2008-05-28 12:35:20 UTC (rev 8530)
@@ -153,10 +153,6 @@
ENDIF (POSTGRES_FOUND)
-# Python support
-IF (PYTHON_FOUND)
- SET (QGIS_APP_SRCS ${QGIS_APP_SRCS} qgspythonutils.cpp)
-ENDIF (PYTHON_FOUND)
QT4_WRAP_CPP(QGIS_APP_MOC_SRCS ${QGIS_APP_MOC_HDRS})
@@ -198,6 +194,7 @@
../core/raster ../core/renderer ../core/symbology
../gui
../plugins
+ ../python
${PROJ_INCLUDE_DIR}
${SQLITE3_INCLUDE_DIR}
${GEOS_INCLUDE_DIR}
@@ -208,10 +205,6 @@
INCLUDE_DIRECTORIES(${POSTGRES_INCLUDE_DIR})
-IF (PYTHON_FOUND)
- INCLUDE_DIRECTORIES(${PYTHON_INCLUDE_PATH})
IF (WIN32)
@@ -250,10 +243,6 @@
INSTALL_RPATH_USE_LINK_PATH true
-IF (PYTHON_FOUND)
- TARGET_LINK_LIBRARIES(qgis ${PYTHON_LIBRARIES})
IF (POSTGRES_FOUND)
TARGET_LINK_LIBRARIES (qgis ${POSTGRES_LIBRARY})
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2008-05-28 07:46:59 UTC (rev 8529)
+++ trunk/qgis/src/app/qgisapp.cpp 2008-05-28 12:35:20 UTC (rev 8530)
@@ -169,9 +169,6 @@
#include "qgspythondialog.h"
#include "qgspythonutils.h"
-#ifdef HAVE_PYTHON
-#include "qgspythonutilsimpl.h"
-#endif
#ifndef WIN32
#include <dlfcn.h>
@@ -360,17 +357,44 @@
qApp->processEvents();
QgsApplication::initQgis();
-#ifdef HAVE_PYTHON
mSplash->showMessage(tr("Starting Python"), Qt::AlignHCenter | Qt::AlignBottom);
+ // try to load python support
+ QLibrary pythonlib("qgispython");
+ // It's necessary to set these two load hints, otherwise Python library won't work correctly
+ // see http://lists.kde.org/?l=pykde&m=117190116820758&w=2
+ pythonlib.setLoadHints(QLibrary::ResolveAllSymbolsHint | QLibrary::ExportExternalSymbolsHint);
+ if (pythonlib.load())
+ QgsDebugMsg("Python support library loaded successfully.");
+ typedef QgsPythonUtils* (*inst)();
+ inst pythonlib_inst = (inst) pythonlib.resolve("instance");
+ if (pythonlib_inst)
+ QgsDebugMsg("Python support library's instance() symbol resolved.");
+ mPythonUtils = pythonlib_inst();
+ mPythonUtils->initPython(mQgisInterface);
+ else
+ QgsDebugMsg("Couldn't resolve python support library's instance() symbol.");
+ else
+ QgsDebugMsg("Couldn't load Python support library.");
- mPythonUtils = QgsPythonUtilsImpl::instance();
- mPythonUtils->initPython(mQgisInterface);
-#endif
- if (!mPythonUtils || !mPythonUtils->isEnabled())
+ if (mPythonUtils && mPythonUtils->isEnabled())
+ QgsDebugMsg("Python support ENABLED :-)");
+ else
mActionShowPythonDialog->setEnabled(false);
+ QgsDebugMsg("Python support DISABLED :-(");
// Create the plugin registry and load plugins
// load any plugins that were running in the last session
Deleted: trunk/qgis/src/app/qgspythonutils.cpp
--- trunk/qgis/src/app/qgspythonutils.cpp 2008-05-28 07:46:59 UTC (rev 8529)
+++ trunk/qgis/src/app/qgspythonutils.cpp 2008-05-28 12:35:20 UTC (rev 8530)
@@ -1,515 +0,0 @@
- qgspythonutils.cpp - routines for interfacing Python
- begin : October 2006
- copyright : (C) 2006 by Martin Dobias
- email : wonder.sk at gmail dot com
- * This program is free software; you can redistribute it and/or modify *
- * it under the terms of the GNU General Public License as published by *
- * the Free Software Foundation; either version 2 of the License, or *
- * (at your option) any later version. *
-/* $Id$ */
-// python should be first include
-// otherwise issues some warnings
-#include <Python.h>
-#include "qgsapplication.h"
-#include "qgslogger.h"
-#include "qgsmessageoutput.h"
-#include <QMessageBox>
-#include <QStringList>
-#include <QDir>
-QgsPythonUtilsImpl* QgsPythonUtilsImpl::mInstance = NULL;
-QgsPythonUtilsImpl::QgsPythonUtilsImpl()
- mMainModule = NULL;
- mMainDict = NULL;
- mPythonEnabled = false;
-QgsPythonUtilsImpl::~QgsPythonUtilsImpl()
-QgsPythonUtilsImpl* QgsPythonUtilsImpl::instance()
- if (mInstance == NULL)
- mInstance = new QgsPythonUtilsImpl();
- return mInstance;
-void QgsPythonUtilsImpl::initPython(QgisInterface* interface)
- // initialize python
- Py_Initialize();
- mPythonEnabled = true;
- mMainModule = PyImport_AddModule("__main__"); // borrowed reference
- mMainDict = PyModule_GetDict(mMainModule); // borrowed reference
- runString("import sys"); // import sys module (for display / exception hooks)
- runString("import traceback"); // for formatting stack traces
- runString("import __main__"); // to access explicitly global variables
- // expect that bindings are installed locally, so add the path to modules
- // also add path to plugins
- runString("sys.path = [\"" + pythonPath() + "\", \"" + homePluginsPath() + "\", \"" + pluginsPath() + "\"] + sys.path");
- // import SIP
- if (!runString("from sip import wrapinstance, unwrapinstance",
- QObject::tr("Couldn't load SIP module.") + "\n" + QObject::tr("Python support will be disabled.")))
- exitPython();
- return;
- // import Qt bindings
- if (!runString("from PyQt4 import QtCore, QtGui",
- QObject::tr("Couldn't load PyQt4.") + "\n" + QObject::tr("Python support will be disabled.")))
- exitPython();
- return;
- // import QGIS bindings
- QString error_msg = QObject::tr("Couldn't load PyQGIS.") + "\n" + QObject::tr("Python support will be disabled.");
- if (!runString("from qgis.core import *", error_msg) || !runString("from qgis.gui import *", error_msg))
- exitPython();
- return;
- // hook that will show information and traceback in message box
- runString(
- "def qgis_except_hook_msg(type, value, tb, msg):\n"
- " lst = traceback.format_exception(type, value, tb)\n"
- " if msg == None: msg = '" + QObject::tr("An error has occured while executing Python code:") + "'\n"
- " txt = '<font color=\"red\">'+msg+'</font><br><br>'\n"
- " for s in lst:\n"
- " txt += s\n"
- " txt += '<br>" + QObject::tr("Python version:") + "<br>' + sys.version + '<br><br>'\n"
- " txt += '"+QObject::tr("Python path:") + "' + str(sys.path)\n"
- " txt = txt.replace('\\n', '<br>')\n"
- " txt = txt.replace(' ', ' ')\n" // preserve whitespaces for nicer output
- " \n"
- " msg = QgsMessageOutput.createMessageOutput()\n"
- " msg.setTitle('" + QObject::tr("Python error") + "')\n"
- " msg.setMessage(txt, QgsMessageOutput.MessageHtml)\n"
- " msg.showMessage()\n");
- runString(
- "def qgis_except_hook(type, value, tb):\n"
- " qgis_except_hook_msg(type, value, tb, None)\n");
- runString(
- "class QgisOutputCatcher:\n"
- " def __init__(self):\n"
- " self.data = ''\n"
- " def write(self, stuff):\n"
- " self.data += stuff\n"
- " def get_and_clean_data(self):\n"
- " tmp = self.data\n"
- " return tmp\n");
- // hook for python console so all output will be redirected
- // and then shown in console
- runString(
- "def console_display_hook(obj):\n"
- " __main__.__result = obj\n");
- installErrorHook();
- // initialize 'iface' object
- runString("iface = wrapinstance(" + QString::number((unsigned long) interface) + ", QgisInterface)");
- runString("plugins = {}");
-void QgsPythonUtilsImpl::exitPython()
- Py_Finalize();
- mMainDict = NULL;
-bool QgsPythonUtilsImpl::isEnabled()
- return mPythonEnabled;
-void QgsPythonUtilsImpl::installErrorHook()
- runString("sys.excepthook = qgis_except_hook");
-void QgsPythonUtilsImpl::installConsoleHooks()
- runString("sys.displayhook = console_display_hook\n");
- runString("_old_stdout = sys.stdout\n");
- runString("sys.stdout = QgisOutputCatcher()\n");
-void QgsPythonUtilsImpl::uninstallConsoleHooks()
- runString("sys.displayhook = sys.__displayhook__");
- runString("sys.stdout = _old_stdout");
-bool QgsPythonUtilsImpl::runStringUnsafe(const QString& command)
- PyRun_String(command.toLocal8Bit().data(), Py_single_input, mMainDict, mMainDict);
- return (PyErr_Occurred() == 0);
-bool QgsPythonUtilsImpl::runString(const QString& command, QString msgOnError)
- bool res = runStringUnsafe(command);
- if (res)
- return true;
- if (msgOnError.isEmpty())
- // use some default message if custom hasn't been specified
- msgOnError = QObject::tr("An error occured during execution of following code:") + "\n<tt>" + command + "</tt>";
- QString traceback = getTraceback();
- QString path, version;
- evalString("str(sys.path)", path);
- evalString("sys.version", version);
- QString str = "<font color=\"red\">"+ msgOnError + "</font><br><br>" + traceback + "<br>" +
- QObject::tr("Python version:") + "<br>" + version + "<br><br>" +
- QObject::tr("Python path:") + "<br>" + path;
- str.replace("\n","<br>").replace(" ", " ");
- QgsMessageOutput* msg = QgsMessageOutput::createMessageOutput();
- msg->setTitle(QObject::tr("Python error"));
- msg->setMessage(str, QgsMessageOutput::MessageHtml);
- msg->showMessage();
- return res;
-QString QgsPythonUtilsImpl::getTraceback()
-#define TRACEBACK_FETCH_ERROR(what) {errMsg = what; goto done;}
- QString errMsg;
- QString result;
- PyObject *modStringIO = NULL;
- PyObject *modTB = NULL;
- PyObject *obStringIO = NULL;
- PyObject *obResult = NULL;
- PyObject *type, *value, *traceback;
- PyErr_Fetch(&type, &value, &traceback);
- PyErr_NormalizeException(&type, &value, &traceback);
- modStringIO = PyImport_ImportModule("cStringIO");
- if (modStringIO==NULL)
- TRACEBACK_FETCH_ERROR("can't import cStringIO");
- obStringIO = PyObject_CallMethod(modStringIO, (char*) "StringIO", NULL);
- /* Construct a cStringIO object */
- if (obStringIO==NULL)
- TRACEBACK_FETCH_ERROR("cStringIO.StringIO() failed");
- modTB = PyImport_ImportModule("traceback");
- if (modTB==NULL)
- TRACEBACK_FETCH_ERROR("can't import traceback");
- obResult = PyObject_CallMethod(modTB, (char*) "print_exception",
- (char*) "OOOOO",
- type, value ? value : Py_None,
- traceback ? traceback : Py_None,
- Py_None,
- obStringIO);
- if (obResult==NULL)
- TRACEBACK_FETCH_ERROR("traceback.print_exception() failed");
- Py_DECREF(obResult);
- obResult = PyObject_CallMethod(obStringIO, (char*) "getvalue", NULL);
- TRACEBACK_FETCH_ERROR("getvalue() failed.");
- /* And it should be a string all ready to go - duplicate it. */
- if (!PyString_Check(obResult))
- TRACEBACK_FETCH_ERROR("getvalue() did not return a string");
- result = PyString_AsString(obResult);
-done:
- // All finished - first see if we encountered an error
- if (result.isEmpty() && !errMsg.isEmpty())
- result = errMsg;
- Py_XDECREF(modStringIO);
- Py_XDECREF(modTB);
- Py_XDECREF(obStringIO);
- Py_XDECREF(obResult);
- Py_XDECREF(value);
- Py_XDECREF(traceback);
- Py_XDECREF(type);
- return result;
-QString QgsPythonUtilsImpl::getTypeAsString(PyObject* obj)
- if (obj == NULL)
- return NULL;
- if (PyClass_Check(obj))
- QgsDebugMsg("got class");
- return QString(PyString_AsString(((PyClassObject*)obj)->cl_name));
- else if (PyType_Check(obj))
- QgsDebugMsg("got type");
- return QString(((PyTypeObject*)obj)->tp_name);
- else
- QgsDebugMsg("got object");
- PyObject* s = PyObject_Str(obj);
- QString str;
- if (s && PyString_Check(s))
- str = QString(PyString_AsString(s));
- Py_XDECREF(s);
- return str;
-bool QgsPythonUtilsImpl::getError(QString& errorClassName, QString& errorText)
- if (!PyErr_Occurred())
- return false;
- PyObject* obj_str;
- PyObject* err_type;
- PyObject* err_value;
- PyObject* err_tb;
- // get the exception information and clear error
- PyErr_Fetch(&err_type, &err_value, &err_tb);
- // get exception's class name
- errorClassName = getTypeAsString(err_type);
- // get exception's text
- if (err_value != NULL && err_value != Py_None)
- obj_str = PyObject_Str(err_value); // new reference
- errorText = PyString_AS_STRING(obj_str);
- Py_XDECREF(obj_str);
- else
- errorText.clear();
- // cleanup
- Py_XDECREF(err_type);
- Py_XDECREF(err_value);
- Py_XDECREF(err_tb);
- return true;
-QString QgsPythonUtilsImpl::getResult()
- return getVariableFromMain("__result");
-QString QgsPythonUtilsImpl::getVariableFromMain(QString name)
- PyObject* obj;
- QString output;
- // get the result
- obj = PyDict_GetItemString(mMainDict, name.toUtf8()); // obj is borrowed reference
- if (obj != NULL && obj != Py_None)
- obj_str = PyObject_Str(obj); // obj_str is new reference
- if (obj_str != NULL && obj_str != Py_None)
- output = PyString_AsString(obj_str);
- // erase result
- PyDict_SetItemString(mMainDict, name.toUtf8(), Py_None);
- return output;
-bool QgsPythonUtilsImpl::evalString(const QString& command, QString& result)
- PyObject* res = PyRun_String(command.toLocal8Bit().data(), Py_eval_input, mMainDict, mMainDict);
- if (res != NULL && PyString_Check(res))
- result = PyString_AsString(res);
- Py_XDECREF(res);
- return true;
- Py_XDECREF(res);
- return false;
-QString QgsPythonUtilsImpl::pythonPath()
- return QgsApplication::pkgDataPath() + "/python";
-QString QgsPythonUtilsImpl::pluginsPath()
- return pythonPath() + "/plugins";
-QString QgsPythonUtilsImpl::homePluginsPath()
- return QgsApplication::qgisSettingsDirPath() + "/python/plugins";
-QStringList QgsPythonUtilsImpl::pluginList()
- QDir pluginDir(QgsPythonUtilsImpl::pluginsPath(), "*",
- QDir::Name | QDir::IgnoreCase, QDir::Dirs | QDir::NoDotAndDotDot);
- QDir homePluginDir(QgsPythonUtilsImpl::homePluginsPath(), "*",
- QStringList pluginList = pluginDir.entryList();
- for (uint i = 0; i < homePluginDir.count(); i++)
- QString packageName = homePluginDir[i];
- if(!pluginList.contains(packageName))
- pluginList.append(packageName);
- return pluginList;
-QString QgsPythonUtilsImpl::getPluginMetadata(QString pluginName, QString function)
- QString command = pluginName + "." + function + "()";
- QString retval = "???";
- PyObject* obj = PyRun_String(command.toLocal8Bit().data(), Py_eval_input, mMainDict, mMainDict);
- if (PyErr_Occurred())
- PyErr_Print(); // just print it to console
- PyErr_Clear();
- return "__error__";
- else if (PyString_Check(obj))
- retval = PyString_AS_STRING(obj);
- else
- // bad python return value
- retval = "__error__";
- Py_XDECREF(obj);
- return retval;
-bool QgsPythonUtilsImpl::loadPlugin(QString packageName)
- // load plugin's package and ensure that plugin is reloaded when changed
- runString(
- "try:\n"
- " import " + packageName + "\n"
- " __main__.__plugin_result = 'OK'\n"
- "except:\n"
- " __main__.__plugin_result = 'ERROR'\n");
- if( getVariableFromMain("__plugin_result") == "OK" )
- return true;
- // snake in the grass, we know it's there
- runString("sys.path_importer_cache.clear()");
- // retry
- runString(
- "try:\n"
- " reload(" + packageName + ")\n"
- "except:\n"
- " qgis_except_hook_msg(sys.exc_type, sys.exc_value, sys.exc_traceback, "
- "'Couldn\\'t load plugin \"" + packageName + "\" from [\\'' + '\\', \\''.join(sys.path) + '\\']')\n"
- return getVariableFromMain("__plugin_result") == "OK";
-bool QgsPythonUtilsImpl::startPlugin(QString packageName)
- QString pluginPythonVar = "plugins['" + packageName + "']";
- QString errMsg = QObject::tr("Couldn't load plugin ") + packageName;
- // create an instance of the plugin
- if (!runString(pluginPythonVar + " = " + packageName + ".classFactory(iface)",
- errMsg + QObject::tr(" due an error when calling its classFactory() method")))
- return false;
- // initGui
- if (!runString(pluginPythonVar + ".initGui()", errMsg + QObject::tr(" due an error when calling its initGui() method")))
- return false;
- return true;
-bool QgsPythonUtilsImpl::unloadPlugin(QString packageName)
- // unload and delete plugin!
- QString varName = "plugins['" + packageName + "']";
- QString errMsg = QObject::tr("Error while unloading plugin ") + packageName;
- if (!runString(varName + ".unload()", errMsg))
- return false;
- if (!runString("del " + varName, errMsg))
- return false;
- return true;
Deleted: trunk/qgis/src/app/qgspythonutils.h
--- trunk/qgis/src/app/qgspythonutils.h 2008-05-28 07:46:59 UTC (rev 8529)
+++ trunk/qgis/src/app/qgspythonutils.h 2008-05-28 12:35:20 UTC (rev 8530)
@@ -1,93 +0,0 @@
- qgspythonutils.h - abstract interface for Python routines
-/* $Id$ */
-#ifndef QGSPYTHONUTILS_H
-#define QGSPYTHONUTILS_H
-#include <QString>
-class QgisInterface;
- All calls to Python functions in QGIS come here.
- This class is a singleton.
- Default path for python plugins is:
- - QgsApplication::qgisSettingsDirPath() + "/python/plugins"
- - QgsApplication::pkgDataPath() + "/python/plugins"
-class QgsPythonUtils
- public:
- virtual ~QgsPythonUtils() {}
- //! returns true if python support is ready to use (must be inited first)
- virtual bool isEnabled() = 0;
- //! initialize python and import bindings
- virtual void initPython(QgisInterface* interface) = 0;
- //! close python interpreter
- virtual void exitPython() = 0;
- /* console */
- //! run a statement, error reporting is not done
- //! @return true if no error occured
- virtual bool runStringUnsafe(const QString& command) = 0;
- virtual bool evalString(const QString& command, QString& result) = 0;
- //! change displayhook and excepthook
- //! our hooks will just save the result to special variables
- //! and those can be used in the program
- virtual void installConsoleHooks() = 0;
- //! get back to the original settings (i.e. write output to stdout)
- virtual void uninstallConsoleHooks() = 0;
- //! get result from the last statement as a string
- virtual QString getResult() = 0;
- //! get information about error to the supplied arguments
- //! @return false if there was no python error
- virtual bool getError(QString& errorClassName, QString& errorText) = 0;
- /* plugins */
- //! return list of all available python plugins
- virtual QStringList pluginList() = 0;
- //! load python plugin (import)
- virtual bool loadPlugin(QString packageName) = 0;
- //! start plugin: add to active plugins and call initGui()
- virtual bool startPlugin(QString packageName) = 0;
- //! helper function to get some information about plugin
- //! @param function one of these strings: name, tpye, version, description
- virtual QString getPluginMetadata(QString pluginName, QString function) = 0;
- //! unload plugin
- virtual bool unloadPlugin(QString packageName) = 0;
-#endif
Deleted: trunk/qgis/src/app/qgspythonutilsimpl.h
--- trunk/qgis/src/app/qgspythonutilsimpl.h 2008-05-28 07:46:59 UTC (rev 8529)
+++ trunk/qgis/src/app/qgspythonutilsimpl.h 2008-05-28 12:35:20 UTC (rev 8530)
@@ -1,132 +0,0 @@
- qgspythonutilsimpl.h - routines for interfacing Python
- begin : May 2008
- copyright : (C) 2008 by Martin Dobias
-/* $Id$ */
-#ifndef QGSPYTHONUTILSIMPL_H
-#define QGSPYTHONUTILSIMPL_H
-#include "qgspythonutils.h"
-// forward declaration for PyObject
-#ifndef PyObject_HEAD
-struct _object;
-typedef _object PyObject;
-#endif
-class QgsPythonUtilsImpl : public QgsPythonUtils
- public:
- QgsPythonUtilsImpl();
- virtual ~QgsPythonUtilsImpl();
- static QgsPythonUtilsImpl* instance();
- /* general purpose functions */
- void initPython(QgisInterface* interface);
- void exitPython();
- bool isEnabled();
- //! returns path where QGIS python stuff is located
- QString pythonPath();
- //! run a statement (wrapper for PyRun_String)
- //! this command is more advanced as enables error checking etc.
- //! when an exception is raised, it shows dialog with exception details
- bool runString(const QString& command, QString msgOnError = QString());
- bool runStringUnsafe(const QString& command);
- bool evalString(const QString& command, QString& result);
- //! @return object's type name as a string
- QString getTypeAsString(PyObject* obj);
- bool getError(QString& errorClassName, QString& errorText);
- //! get variable from main dictionary
- QString getVariableFromMain(QString name);
- /* python console related functions */
- void installConsoleHooks();
- void uninstallConsoleHooks();
- QString getResult();
- /* plugins related functions */
- //! return current path for python plugins
- QString pluginsPath();
- //! return current path for home directory python plugins
- QString homePluginsPath();
- QStringList pluginList();
- bool loadPlugin(QString packageName);
- bool startPlugin(QString packageName);
- QString getPluginMetadata(QString pluginName, QString function);
- //! unload plugin
- bool unloadPlugin(QString packageName);
- protected:
- void installErrorHook();
- QString getTraceback();
- //! reference to module __main__
- PyObject* mMainModule;
- //! dictionary of module __main__
- PyObject* mMainDict;
- //! flag determining that python support is enabled
- bool mPythonEnabled;
- static QgsPythonUtilsImpl* mInstance;
-#endif
Added: trunk/qgis/src/python/CMakeLists.txt
--- trunk/qgis/src/python/CMakeLists.txt (rev 0)
+++ trunk/qgis/src/python/CMakeLists.txt 2008-05-28 12:35:20 UTC (rev 8530)
@@ -0,0 +1,25 @@
+SET(QGISPYTHON_SRCS qgispython.cpp qgspythonutilsimpl.cpp)
+INCLUDE_DIRECTORIES(
+ ../core
+ ../core/raster ../core/renderer ../core/symbology
+ ../gui
+ ${PYTHON_INCLUDE_PATH})
+ADD_LIBRARY (qgispython SHARED ${QGISPYTHON_SRCS})
+SET_TARGET_PROPERTIES(qgispython PROPERTIES
+ VERSION ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}
+ SOVERSION ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR})
+TARGET_LINK_LIBRARIES(qgispython
+ ${QT_QTCORE_LIBRARY}
+ ${QT_QTGUI_LIBRARY}
+ ${PYTHON_LIBRARIES}
+INSTALL(TARGETS qgispython
+ RUNTIME DESTINATION ${QGIS_BIN_DIR}
+ LIBRARY DESTINATION ${QGIS_LIB_DIR})
Added: trunk/qgis/src/python/qgispython.cpp
--- trunk/qgis/src/python/qgispython.cpp (rev 0)
+++ trunk/qgis/src/python/qgispython.cpp 2008-05-28 12:35:20 UTC (rev 8530)
@@ -0,0 +1,23 @@
+ qgispython.cpp - python support in QGIS
+ begin : May 2008
+ copyright : (C) 2008 by Martin Dobias
+ email : wonder.sk at gmail dot com
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+/* $Id$ */
+#include "qgis.h"
+#include "qgspythonutilsimpl.h"
+QGISEXTERN QgsPythonUtils* instance()
+ return new QgsPythonUtilsImpl();
Copied: trunk/qgis/src/python/qgspythonutils.h (from rev 8517, trunk/qgis/src/app/qgspythonutils.h)
--- trunk/qgis/src/python/qgspythonutils.h (rev 0)
+++ trunk/qgis/src/python/qgspythonutils.h 2008-05-28 12:35:20 UTC (rev 8530)
@@ -0,0 +1,93 @@
+ qgspythonutils.h - abstract interface for Python routines
+ begin : October 2006
+ copyright : (C) 2006 by Martin Dobias
+/* $Id$ */
+#ifndef QGSPYTHONUTILS_H
+#define QGSPYTHONUTILS_H
+#include <QString>
+#include <QStringList>
+class QgisInterface;
+ All calls to Python functions in QGIS come here.
+ This class is a singleton.
+ Default path for python plugins is:
+ - QgsApplication::qgisSettingsDirPath() + "/python/plugins"
+ - QgsApplication::pkgDataPath() + "/python/plugins"
+class QgsPythonUtils
+ public:
+ virtual ~QgsPythonUtils() {}
+ //! returns true if python support is ready to use (must be inited first)
+ virtual bool isEnabled() = 0;
+ //! initialize python and import bindings
+ virtual void initPython(QgisInterface* interface) = 0;
+ //! close python interpreter
+ virtual void exitPython() = 0;
+ /* console */
+ //! run a statement, error reporting is not done
+ //! @return true if no error occured
+ virtual bool runStringUnsafe(const QString& command) = 0;
+ virtual bool evalString(const QString& command, QString& result) = 0;
+ //! change displayhook and excepthook
+ //! our hooks will just save the result to special variables
+ //! and those can be used in the program
+ virtual void installConsoleHooks() = 0;
+ //! get back to the original settings (i.e. write output to stdout)
+ virtual void uninstallConsoleHooks() = 0;
+ //! get result from the last statement as a string
+ virtual QString getResult() = 0;
+ //! get information about error to the supplied arguments
+ //! @return false if there was no python error
+ virtual bool getError(QString& errorClassName, QString& errorText) = 0;
+ /* plugins */
+ //! return list of all available python plugins
+ virtual QStringList pluginList() = 0;
+ //! load python plugin (import)
+ virtual bool loadPlugin(QString packageName) = 0;
+ //! start plugin: add to active plugins and call initGui()
+ virtual bool startPlugin(QString packageName) = 0;
+ //! helper function to get some information about plugin
+ //! @param function one of these strings: name, tpye, version, description
+ virtual QString getPluginMetadata(QString pluginName, QString function) = 0;
+ //! unload plugin
+ virtual bool unloadPlugin(QString packageName) = 0;
+#endif
Copied: trunk/qgis/src/python/qgspythonutilsimpl.cpp (from rev 8517, trunk/qgis/src/app/qgspythonutils.cpp)
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp (rev 0)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp 2008-05-28 12:35:20 UTC (rev 8530)
@@ -0,0 +1,505 @@
+ qgspythonutils.cpp - routines for interfacing Python
+/* $Id$ */
+// python should be first include
+// otherwise issues some warnings
+#include <Python.h>
+#include "qgsapplication.h"
+#include "qgslogger.h"
+#include "qgsmessageoutput.h"
+#include <QMessageBox>
+#include <QDir>
+QgsPythonUtilsImpl::QgsPythonUtilsImpl()
+ mMainModule = NULL;
+ mMainDict = NULL;
+ mPythonEnabled = false;
+QgsPythonUtilsImpl::~QgsPythonUtilsImpl()
+void QgsPythonUtilsImpl::initPython(QgisInterface* interface)
+ // initialize python
+ Py_Initialize();
+ mPythonEnabled = true;
+ mMainModule = PyImport_AddModule("__main__"); // borrowed reference
+ mMainDict = PyModule_GetDict(mMainModule); // borrowed reference
+ runString("import sys"); // import sys module (for display / exception hooks)
+ runString("import traceback"); // for formatting stack traces
+ runString("import __main__"); // to access explicitly global variables
+ // expect that bindings are installed locally, so add the path to modules
+ // also add path to plugins
+ runString("sys.path = [\"" + pythonPath() + "\", \"" + homePluginsPath() + "\", \"" + pluginsPath() + "\"] + sys.path");
+ // import SIP
+ if (!runString("from sip import wrapinstance, unwrapinstance",
+ QObject::tr("Couldn't load SIP module.") + "\n" + QObject::tr("Python support will be disabled.")))
+ exitPython();
+ return;
+ // import Qt bindings
+ if (!runString("from PyQt4 import QtCore, QtGui",
+ QObject::tr("Couldn't load PyQt4.") + "\n" + QObject::tr("Python support will be disabled.")))
+ exitPython();
+ return;
+ // import QGIS bindings
+ QString error_msg = QObject::tr("Couldn't load PyQGIS.") + "\n" + QObject::tr("Python support will be disabled.");
+ if (!runString("from qgis.core import *", error_msg) || !runString("from qgis.gui import *", error_msg))
+ exitPython();
+ return;
+ // hook that will show information and traceback in message box
+ runString(
+ "def qgis_except_hook_msg(type, value, tb, msg):\n"
+ " lst = traceback.format_exception(type, value, tb)\n"
+ " if msg == None: msg = '" + QObject::tr("An error has occured while executing Python code:") + "'\n"
+ " txt = '<font color=\"red\">'+msg+'</font><br><br>'\n"
+ " for s in lst:\n"
+ " txt += s\n"
+ " txt += '<br>" + QObject::tr("Python version:") + "<br>' + sys.version + '<br><br>'\n"
+ " txt += '"+QObject::tr("Python path:") + "' + str(sys.path)\n"
+ " txt = txt.replace('\\n', '<br>')\n"
+ " txt = txt.replace(' ', ' ')\n" // preserve whitespaces for nicer output
+ " \n"
+ " msg = QgsMessageOutput.createMessageOutput()\n"
+ " msg.setTitle('" + QObject::tr("Python error") + "')\n"
+ " msg.setMessage(txt, QgsMessageOutput.MessageHtml)\n"
+ " msg.showMessage()\n");
+ runString(
+ "def qgis_except_hook(type, value, tb):\n"
+ " qgis_except_hook_msg(type, value, tb, None)\n");
+ runString(
+ "class QgisOutputCatcher:\n"
+ " def __init__(self):\n"
+ " self.data = ''\n"
+ " def write(self, stuff):\n"
+ " self.data += stuff\n"
+ " def get_and_clean_data(self):\n"
+ " tmp = self.data\n"
+ " return tmp\n");
+ // hook for python console so all output will be redirected
+ // and then shown in console
+ runString(
+ "def console_display_hook(obj):\n"
+ " __main__.__result = obj\n");
+ installErrorHook();
+ // initialize 'iface' object
+ runString("iface = wrapinstance(" + QString::number((unsigned long) interface) + ", QgisInterface)");
+ runString("plugins = {}");
+void QgsPythonUtilsImpl::exitPython()
+ Py_Finalize();
+ mMainDict = NULL;
+bool QgsPythonUtilsImpl::isEnabled()
+ return mPythonEnabled;
+void QgsPythonUtilsImpl::installErrorHook()
+ runString("sys.excepthook = qgis_except_hook");
+void QgsPythonUtilsImpl::installConsoleHooks()
+ runString("sys.displayhook = console_display_hook\n");
+ runString("_old_stdout = sys.stdout\n");
+ runString("sys.stdout = QgisOutputCatcher()\n");
+void QgsPythonUtilsImpl::uninstallConsoleHooks()
+ runString("sys.displayhook = sys.__displayhook__");
+ runString("sys.stdout = _old_stdout");
+bool QgsPythonUtilsImpl::runStringUnsafe(const QString& command)
+ PyRun_String(command.toLocal8Bit().data(), Py_single_input, mMainDict, mMainDict);
+ return (PyErr_Occurred() == 0);
+bool QgsPythonUtilsImpl::runString(const QString& command, QString msgOnError)
+ bool res = runStringUnsafe(command);
+ if (res)
+ return true;
+ if (msgOnError.isEmpty())
+ // use some default message if custom hasn't been specified
+ msgOnError = QObject::tr("An error occured during execution of following code:") + "\n<tt>" + command + "</tt>";
+ QString traceback = getTraceback();
+ QString path, version;
+ evalString("str(sys.path)", path);
+ evalString("sys.version", version);
+ QString str = "<font color=\"red\">"+ msgOnError + "</font><br><br>" + traceback + "<br>" +
+ QObject::tr("Python version:") + "<br>" + version + "<br><br>" +
+ QObject::tr("Python path:") + "<br>" + path;
+ str.replace("\n","<br>").replace(" ", " ");
+ QgsMessageOutput* msg = QgsMessageOutput::createMessageOutput();
+ msg->setTitle(QObject::tr("Python error"));
+ msg->setMessage(str, QgsMessageOutput::MessageHtml);
+ msg->showMessage();
+ return res;
+QString QgsPythonUtilsImpl::getTraceback()
+#define TRACEBACK_FETCH_ERROR(what) {errMsg = what; goto done;}
+ QString errMsg;
+ QString result;
+ PyObject *modStringIO = NULL;
+ PyObject *modTB = NULL;
+ PyObject *obStringIO = NULL;
+ PyObject *obResult = NULL;
+ PyObject *type, *value, *traceback;
+ PyErr_Fetch(&type, &value, &traceback);
+ PyErr_NormalizeException(&type, &value, &traceback);
+ modStringIO = PyImport_ImportModule("cStringIO");
+ if (modStringIO==NULL)
+ TRACEBACK_FETCH_ERROR("can't import cStringIO");
+ obStringIO = PyObject_CallMethod(modStringIO, (char*) "StringIO", NULL);
+ /* Construct a cStringIO object */
+ if (obStringIO==NULL)
+ TRACEBACK_FETCH_ERROR("cStringIO.StringIO() failed");
+ modTB = PyImport_ImportModule("traceback");
+ if (modTB==NULL)
+ TRACEBACK_FETCH_ERROR("can't import traceback");
+ obResult = PyObject_CallMethod(modTB, (char*) "print_exception",
+ (char*) "OOOOO",
+ type, value ? value : Py_None,
+ traceback ? traceback : Py_None,
+ Py_None,
+ obStringIO);
+ if (obResult==NULL)
+ TRACEBACK_FETCH_ERROR("traceback.print_exception() failed");
+ Py_DECREF(obResult);
+ obResult = PyObject_CallMethod(obStringIO, (char*) "getvalue", NULL);
+ TRACEBACK_FETCH_ERROR("getvalue() failed.");
+ /* And it should be a string all ready to go - duplicate it. */
+ if (!PyString_Check(obResult))
+ TRACEBACK_FETCH_ERROR("getvalue() did not return a string");
+ result = PyString_AsString(obResult);
+done:
+ // All finished - first see if we encountered an error
+ if (result.isEmpty() && !errMsg.isEmpty())
+ result = errMsg;
+ Py_XDECREF(modStringIO);
+ Py_XDECREF(modTB);
+ Py_XDECREF(obStringIO);
+ Py_XDECREF(obResult);
+ Py_XDECREF(value);
+ Py_XDECREF(traceback);
+ Py_XDECREF(type);
+ return result;
+QString QgsPythonUtilsImpl::getTypeAsString(PyObject* obj)
+ if (obj == NULL)
+ return NULL;
+ if (PyClass_Check(obj))
+ QgsDebugMsg("got class");
+ return QString(PyString_AsString(((PyClassObject*)obj)->cl_name));
+ else if (PyType_Check(obj))
+ QgsDebugMsg("got type");
+ return QString(((PyTypeObject*)obj)->tp_name);
+ else
+ QgsDebugMsg("got object");
+ PyObject* s = PyObject_Str(obj);
+ QString str;
+ if (s && PyString_Check(s))
+ str = QString(PyString_AsString(s));
+ Py_XDECREF(s);
+ return str;
+bool QgsPythonUtilsImpl::getError(QString& errorClassName, QString& errorText)
+ if (!PyErr_Occurred())
+ return false;
+ PyObject* obj_str;
+ PyObject* err_type;
+ PyObject* err_value;
+ PyObject* err_tb;
+ // get the exception information and clear error
+ PyErr_Fetch(&err_type, &err_value, &err_tb);
+ // get exception's class name
+ errorClassName = getTypeAsString(err_type);
+ // get exception's text
+ if (err_value != NULL && err_value != Py_None)
+ obj_str = PyObject_Str(err_value); // new reference
+ errorText = PyString_AS_STRING(obj_str);
+ Py_XDECREF(obj_str);
+ else
+ errorText.clear();
+ // cleanup
+ Py_XDECREF(err_type);
+ Py_XDECREF(err_value);
+ Py_XDECREF(err_tb);
+ return true;
+QString QgsPythonUtilsImpl::getResult()
+ return getVariableFromMain("__result");
+QString QgsPythonUtilsImpl::getVariableFromMain(QString name)
+ PyObject* obj;
+ QString output;
+ // get the result
+ obj = PyDict_GetItemString(mMainDict, name.toUtf8()); // obj is borrowed reference
+ if (obj != NULL && obj != Py_None)
+ obj_str = PyObject_Str(obj); // obj_str is new reference
+ if (obj_str != NULL && obj_str != Py_None)
+ output = PyString_AsString(obj_str);
+ // erase result
+ PyDict_SetItemString(mMainDict, name.toUtf8(), Py_None);
+ return output;
+bool QgsPythonUtilsImpl::evalString(const QString& command, QString& result)
+ PyObject* res = PyRun_String(command.toLocal8Bit().data(), Py_eval_input, mMainDict, mMainDict);
+ if (res != NULL && PyString_Check(res))
+ result = PyString_AsString(res);
+ Py_XDECREF(res);
+ return true;
+ Py_XDECREF(res);
+ return false;
+QString QgsPythonUtilsImpl::pythonPath()
+ return QgsApplication::pkgDataPath() + "/python";
+QString QgsPythonUtilsImpl::pluginsPath()
+ return pythonPath() + "/plugins";
+QString QgsPythonUtilsImpl::homePluginsPath()
+ return QgsApplication::qgisSettingsDirPath() + "/python/plugins";
+QStringList QgsPythonUtilsImpl::pluginList()
+ QDir pluginDir(QgsPythonUtilsImpl::pluginsPath(), "*",
+ QDir::Name | QDir::IgnoreCase, QDir::Dirs | QDir::NoDotAndDotDot);
+ QDir homePluginDir(QgsPythonUtilsImpl::homePluginsPath(), "*",
+ QStringList pluginList = pluginDir.entryList();
+ for (uint i = 0; i < homePluginDir.count(); i++)
+ QString packageName = homePluginDir[i];
+ if(!pluginList.contains(packageName))
+ pluginList.append(packageName);
+ return pluginList;
+QString QgsPythonUtilsImpl::getPluginMetadata(QString pluginName, QString function)
+ QString command = pluginName + "." + function + "()";
+ QString retval = "???";
+ PyObject* obj = PyRun_String(command.toLocal8Bit().data(), Py_eval_input, mMainDict, mMainDict);
+ if (PyErr_Occurred())
+ PyErr_Print(); // just print it to console
+ PyErr_Clear();
+ return "__error__";
+ else if (PyString_Check(obj))
+ retval = PyString_AS_STRING(obj);
+ else
+ // bad python return value
+ retval = "__error__";
+ Py_XDECREF(obj);
+ return retval;
+bool QgsPythonUtilsImpl::loadPlugin(QString packageName)
+ // load plugin's package and ensure that plugin is reloaded when changed
+ runString(
+ "try:\n"
+ " import " + packageName + "\n"
+ " __main__.__plugin_result = 'OK'\n"
+ "except:\n"
+ " __main__.__plugin_result = 'ERROR'\n");
+ if( getVariableFromMain("__plugin_result") == "OK" )
+ return true;
+ // snake in the grass, we know it's there
+ runString("sys.path_importer_cache.clear()");
+ // retry
+ runString(
+ "try:\n"
+ " reload(" + packageName + ")\n"
+ "except:\n"
+ " qgis_except_hook_msg(sys.exc_type, sys.exc_value, sys.exc_traceback, "
+ "'Couldn\\'t load plugin \"" + packageName + "\" from [\\'' + '\\', \\''.join(sys.path) + '\\']')\n"
+ return getVariableFromMain("__plugin_result") == "OK";
+bool QgsPythonUtilsImpl::startPlugin(QString packageName)
+ QString pluginPythonVar = "plugins['" + packageName + "']";
+ QString errMsg = QObject::tr("Couldn't load plugin ") + packageName;
+ // create an instance of the plugin
+ if (!runString(pluginPythonVar + " = " + packageName + ".classFactory(iface)",
+ errMsg + QObject::tr(" due an error when calling its classFactory() method")))
+ return false;
+ // initGui
+ if (!runString(pluginPythonVar + ".initGui()", errMsg + QObject::tr(" due an error when calling its initGui() method")))
+ return false;
+ return true;
+bool QgsPythonUtilsImpl::unloadPlugin(QString packageName)
+ // unload and delete plugin!
+ QString varName = "plugins['" + packageName + "']";
+ QString errMsg = QObject::tr("Error while unloading plugin ") + packageName;
+ if (!runString(varName + ".unload()", errMsg))
+ return false;
+ if (!runString("del " + varName, errMsg))
+ return false;
+ return true;
Copied: trunk/qgis/src/python/qgspythonutilsimpl.h (from rev 8517, trunk/qgis/src/app/qgspythonutilsimpl.h)
--- trunk/qgis/src/python/qgspythonutilsimpl.h (rev 0)
+++ trunk/qgis/src/python/qgspythonutilsimpl.h 2008-05-28 12:35:20 UTC (rev 8530)
@@ -0,0 +1,128 @@
+ qgspythonutilsimpl.h - routines for interfacing Python
+ begin : May 2008
+/* $Id$ */
+#ifndef QGSPYTHONUTILSIMPL_H
+#define QGSPYTHONUTILSIMPL_H
+#include "qgspythonutils.h"
+// forward declaration for PyObject
+#ifndef PyObject_HEAD
+struct _object;
+typedef _object PyObject;
+#endif
+class QgsPythonUtilsImpl : public QgsPythonUtils
+ public:
+ QgsPythonUtilsImpl();
+ virtual ~QgsPythonUtilsImpl();
+ /* general purpose functions */
+ void initPython(QgisInterface* interface);
+ void exitPython();
+ bool isEnabled();
+ //! returns path where QGIS python stuff is located
+ QString pythonPath();
+ //! run a statement (wrapper for PyRun_String)
+ //! this command is more advanced as enables error checking etc.
+ //! when an exception is raised, it shows dialog with exception details
+ bool runString(const QString& command, QString msgOnError = QString());
+ bool runStringUnsafe(const QString& command);
+ bool evalString(const QString& command, QString& result);
+ //! @return object's type name as a string
+ QString getTypeAsString(PyObject* obj);
+ bool getError(QString& errorClassName, QString& errorText);
+ //! get variable from main dictionary
+ QString getVariableFromMain(QString name);
+ /* python console related functions */
+ void installConsoleHooks();
+ void uninstallConsoleHooks();
+ QString getResult();
+ /* plugins related functions */
+ //! return current path for python plugins
+ QString pluginsPath();
+ //! return current path for home directory python plugins
+ QString homePluginsPath();
+ QStringList pluginList();
+ bool loadPlugin(QString packageName);
+ bool startPlugin(QString packageName);
+ QString getPluginMetadata(QString pluginName, QString function);
+ //! unload plugin
+ bool unloadPlugin(QString packageName);
+ protected:
+ void installErrorHook();
+ QString getTraceback();
+ //! reference to module __main__
+ PyObject* mMainModule;
+ //! dictionary of module __main__
+ PyObject* mMainDict;
+ //! flag determining that python support is enabled
+ bool mPythonEnabled;
+#endif
