[QGIS Commit] r9570 - in trunk/qgis/src: app/composer core/composer
svn_qgis at osgeo.org
Fri Nov 7 05:35:32 EST 2008
Author: timlinux
Date: 2008-11-07 05:35:32 -0500 (Fri, 07 Nov 2008)
New Revision: 9570
trunk/qgis/src/app/composer/qgscomposer.cpp
trunk/qgis/src/app/composer/qgscompositionwidget.cpp
trunk/qgis/src/core/composer/qgscomposerscalebar.cpp
trunk/qgis/src/core/composer/qgscomposition.cpp
trunk/qgis/src/core/composer/qgscomposition.h
trunk/qgis/src/core/composer/qgsticksscalebarstyle.cpp
trunk/qgis/src/core/composer/qgsticksscalebarstyle.h
API Tidy ups for composer
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp 2008-11-07 09:56:02 UTC (rev 9569)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp 2008-11-07 10:35:32 UTC (rev 9570)
@@ -456,7 +456,7 @@
//set user-defined resolution
if ( mComposition )
- printer.setResolution( mComposition->printoutResolution() );
+ printer.setResolution( mComposition->printResolution() );
QPainter p( &printer );
@@ -489,8 +489,8 @@
// Image size
- int width = ( int )( mComposition->printoutResolution() * mComposition->paperWidth() / 25.4 );
- int height = ( int )( mComposition-> printoutResolution() * mComposition->paperHeight() / 25.4 );
+ int width = ( int )( mComposition->printResolution() * mComposition->paperWidth() / 25.4 );
+ int height = ( int )( mComposition-> printResolution() * mComposition->paperHeight() / 25.4 );
int memuse = width * height * 3 / 1000000; // pixmap + image
QgsDebugMsg( QString( "Image %1 x %2" ).arg( width ).arg( height ) );
@@ -592,8 +592,8 @@
mView->setScene( 0 );
QImage image( QSize( width, height ), QImage::Format_ARGB32 );
- image.setDotsPerMeterX( mComposition->printoutResolution() / 25.4 * 1000 );
- image.setDotsPerMeterY( mComposition->printoutResolution() / 25.4 * 1000 );
+ image.setDotsPerMeterX( mComposition->printResolution() / 25.4 * 1000 );
+ image.setDotsPerMeterY( mComposition->printResolution() / 25.4 * 1000 );
image.fill( 0 );
QPainter p( &image );
QRectF sourceArea( 0, 0, mComposition->paperWidth(), mComposition->paperHeight() );
Modified: trunk/qgis/src/app/composer/qgscompositionwidget.cpp
--- trunk/qgis/src/app/composer/qgscompositionwidget.cpp 2008-11-07 09:56:02 UTC (rev 9569)
+++ trunk/qgis/src/app/composer/qgscompositionwidget.cpp 2008-11-07 10:35:32 UTC (rev 9570)
@@ -41,7 +41,7 @@
//read printout resolution from composition
if ( mComposition )
- mResolutionLineEdit->setText( QString::number( mComposition->printoutResolution() ) );
+ mResolutionLineEdit->setText( QString::number( mComposition->printResolution() ) );
@@ -281,12 +281,12 @@
int resolution = text.toInt( &conversionOk );
if ( conversionOk && mComposition )
- mComposition->setPrintoutResolution( resolution );
+ mComposition->setPrintResolution( resolution );
else if ( mComposition )
//set screen resolution per default
QPrinter resolutionInfo( QPrinter::ScreenResolution );
- mComposition->setPrintoutResolution( resolutionInfo.resolution() );
+ mComposition->setPrintResolution( resolutionInfo.resolution() );
Modified: trunk/qgis/src/core/composer/qgscomposerscalebar.cpp
--- trunk/qgis/src/core/composer/qgscomposerscalebar.cpp 2008-11-07 09:56:02 UTC (rev 9569)
+++ trunk/qgis/src/core/composer/qgscomposerscalebar.cpp 2008-11-07 10:35:32 UTC (rev 9570)
@@ -210,15 +210,15 @@
QgsTicksScaleBarStyle* tickStyle = new QgsTicksScaleBarStyle( this );
if ( styleName == tr( "Line Ticks Middle" ) )
- tickStyle->setTickPosition( QgsTicksScaleBarStyle::MIDDLE );
+ tickStyle->setTickPosition( QgsTicksScaleBarStyle::TicksMiddle );
else if ( styleName == tr( "Line Ticks Down" ) )
- tickStyle->setTickPosition( QgsTicksScaleBarStyle::DOWN );
+ tickStyle->setTickPosition( QgsTicksScaleBarStyle::TicksDown );
else if ( styleName == tr( "Line Ticks Up" ) )
- tickStyle->setTickPosition( QgsTicksScaleBarStyle::UP );
+ tickStyle->setTickPosition( QgsTicksScaleBarStyle::TicksUp );
mStyle = tickStyle;
Modified: trunk/qgis/src/core/composer/qgscomposition.cpp
--- trunk/qgis/src/core/composer/qgscomposition.cpp 2008-11-07 09:56:02 UTC (rev 9569)
+++ trunk/qgis/src/core/composer/qgscomposition.cpp 2008-11-07 10:35:32 UTC (rev 9570)
@@ -30,7 +30,7 @@
mPaperItem->setBrush( Qt::white );
addItem( mPaperItem );
mPaperItem->setZValue( 0 );
- mPrintoutResolution = 300; //hardcoded default
+ mPrintResolution = 300; //hardcoded default
QgsComposition::QgsComposition(): QGraphicsScene( 0 ), mMapRenderer( 0 ), mPlotStyle( QgsComposition::Preview ), mPaperItem( 0 )
Modified: trunk/qgis/src/core/composer/qgscomposition.h
--- trunk/qgis/src/core/composer/qgscomposition.h 2008-11-07 09:56:02 UTC (rev 9569)
+++ trunk/qgis/src/core/composer/qgscomposition.h 2008-11-07 10:35:32 UTC (rev 9570)
@@ -69,8 +69,8 @@
@return id or 0 pointer if the composer map item does not exist*/
const QgsComposerMap* getComposerMapById( int id ) const;
- int printoutResolution() const {return mPrintoutResolution;}
- void setPrintoutResolution( int dpi ) {mPrintoutResolution = dpi;}
+ int printResolution() const {return mPrintResolution;}
+ void setPrintResolution( int dpi ) {mPrintResolution = dpi;}
/**Returns pointer to map renderer of qgis map canvas*/
QgsMapRenderer* mapRenderer() {return mMapRenderer;}
@@ -121,7 +121,7 @@
QLinkedList<QgsComposerItem*> mItemZList;
/**Dpi for printout*/
- int mPrintoutResolution;
+ int mPrintResolution;
QgsComposition(); //default constructor is forbidden
Modified: trunk/qgis/src/core/composer/qgsticksscalebarstyle.cpp
--- trunk/qgis/src/core/composer/qgsticksscalebarstyle.cpp 2008-11-07 09:56:02 UTC (rev 9569)
+++ trunk/qgis/src/core/composer/qgsticksscalebarstyle.cpp 2008-11-07 10:35:32 UTC (rev 9570)
@@ -20,12 +20,12 @@
QgsTicksScaleBarStyle::QgsTicksScaleBarStyle( const QgsComposerScaleBar* bar ): QgsScaleBarStyle( bar )
- mTickPosition = MIDDLE;
+ mTickPosition = TicksMiddle;
QgsTicksScaleBarStyle::QgsTicksScaleBarStyle(): QgsScaleBarStyle( 0 )
QgsTicksScaleBarStyle::~QgsTicksScaleBarStyle()
@@ -37,11 +37,11 @@
switch ( mTickPosition )
- case UP:
+ case TicksUp:
return "Line Ticks Up";
- case DOWN:
+ case TicksDown:
return "Line Ticks Down";
- case MIDDLE:
+ case TicksMiddle:
return "Line Ticks Middle";
return ""; // to make gcc happy
@@ -69,13 +69,13 @@
p->drawLine( segmentIt->first + xOffset, barTopPosition, segmentIt->first + xOffset, barTopPosition + mScaleBar->height() );
- case DOWN:
+ case TicksDown:
p->drawLine( xOffset + segmentIt->first, barTopPosition, xOffset + segmentIt->first + mScaleBar->segmentMillimeters(), barTopPosition );
break;
- case MIDDLE:
+ case TicksMiddle:
p->drawLine( xOffset + segmentIt->first, middlePosition, xOffset + segmentIt->first + mScaleBar->segmentMillimeters(), middlePosition );
break;
- case UP:
+ case TicksUp:
p->drawLine( xOffset + segmentIt->first, bottomPosition, xOffset + segmentIt->first + mScaleBar->segmentMillimeters(), bottomPosition );
break;
Modified: trunk/qgis/src/core/composer/qgsticksscalebarstyle.h
--- trunk/qgis/src/core/composer/qgsticksscalebarstyle.h 2008-11-07 09:56:02 UTC (rev 9569)
+++ trunk/qgis/src/core/composer/qgsticksscalebarstyle.h 2008-11-07 10:35:32 UTC (rev 9570)
@@ -27,9 +27,9 @@
public:
enum TickPosition
- UP,
- DOWN,
- MIDDLE
+ TicksUp,
+ TicksDown,
+ TicksMiddle
QgsTicksScaleBarStyle( const QgsComposerScaleBar* bar );
