[QGIS Commit] r9571 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Fri Nov 7 10:50:33 EST 2008
Author: pcav
Date: 2008-11-07 10:50:32 -0500 (Fri, 07 Nov 2008)
New Revision: 9571
trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm
trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm
Fix for https://trac.osgeo.org/qgis/ticket/1177 (thanks to Stefano Bande)
and https://trac.osgeo.org/qgis/ticket/1361
Modified: trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm 2008-11-07 10:35:32 UTC (rev 9570)
+++ trunk/qgis/src/plugins/grass/modules/r.out.gdal.gtiff.qgm 2008-11-07 15:50:32 UTC (rev 9571)
@@ -4,6 +4,6 @@
<qgisgrassmodule label="Export raster layer to Geo TIFF" module="r.out.gdal">
<option key="input" region="no"/>
<option key="format" answer="GTiff" hidden="yes" />
- <option key="type" answer="Float64" />
+ <option key="type" answer="UInt16" />
<file key="output" type="new" filters="Geo TIFF (*.tif *.tiff)" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm
--- trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm 2008-11-07 10:35:32 UTC (rev 9570)
+++ trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm 2008-11-07 15:50:32 UTC (rev 9571)
@@ -3,7 +3,7 @@
<qgisgrassmodule label="Uploads map for which to edit attribute table" module="v.what.vect">
<option key="vector" layeroption="layer" typemask="point"/>
- <field key="column" layer="vector" type="integer,double,varchar"/>
+ <field key="column" layer="vector" type="integer,double,string"/>
<option key="qvector" layeroption="layer" typemask="area"/>
- <option key="qcolumn" layer="qvector" type="integer,double,varchar"/>
+ <option key="qcolumn" layer="qvector"/>
</qgisgrassmodule>
