[QGIS Commit] r9593 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Sat Nov 8 06:56:28 EST 2008
Author: pcav
Date: 2008-11-08 06:56:28 -0500 (Sat, 08 Nov 2008)
New Revision: 9593
trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm
trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm
trunk/qgis/src/plugins/grass/modules/g.proj.geo.qgm
trunk/qgis/src/plugins/grass/modules/g.proj.proj.new.qgm
trunk/qgis/src/plugins/grass/modules/g.proj.proj.qgm
trunk/qgis/src/plugins/grass/modules/g.region.multiple.raster.qgm
trunk/qgis/src/plugins/grass/modules/g.region.multiple.vector.qgm
trunk/qgis/src/plugins/grass/modules/g.region.zoom.qgm
trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm
trunk/qgis/src/plugins/grass/modules/r.blend.qgm
trunk/qgis/src/plugins/grass/modules/r.clump.qgm
trunk/qgis/src/plugins/grass/modules/r.compress.qgm
trunk/qgis/src/plugins/grass/modules/r.fill.dir.qgm
trunk/qgis/src/plugins/grass/modules/r.fillnulls.qgm
trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm
trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm
trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm
trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm
trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm
trunk/qgis/src/plugins/grass/modules/r.in.poly.qgm
trunk/qgis/src/plugins/grass/modules/r.in.srtm.qgm
trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm
trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm
trunk/qgis/src/plugins/grass/modules/r.param.scale.qgm
trunk/qgis/src/plugins/grass/modules/r.patch.qgm
trunk/qgis/src/plugins/grass/modules/r.proj.qgm
trunk/qgis/src/plugins/grass/modules/r.recode.file.qgm
trunk/qgis/src/plugins/grass/modules/r.region.vector.qgm
trunk/qgis/src/plugins/grass/modules/r.regression.line.qgm
trunk/qgis/src/plugins/grass/modules/r.texture.bis.qgm
trunk/qgis/src/plugins/grass/modules/r.texture.qgm
trunk/qgis/src/plugins/grass/modules/r.topidx.qgm
trunk/qgis/src/plugins/grass/modules/v.build.all.qgm
trunk/qgis/src/plugins/grass/modules/v.in.db.qgm
trunk/qgis/src/plugins/grass/modules/v.in.dxf.multiple.qgm
trunk/qgis/src/plugins/grass/modules/v.in.dxf.qgm
trunk/qgis/src/plugins/grass/modules/v.in.e00.qgm
trunk/qgis/src/plugins/grass/modules/v.in.mapgen.qgm
trunk/qgis/src/plugins/grass/modules/v.in.ogr.all.loc.qgm
trunk/qgis/src/plugins/grass/modules/v.in.ogr.all.qgm
trunk/qgis/src/plugins/grass/modules/v.in.ogr.loc.qgm
trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgm
trunk/qgis/src/plugins/grass/modules/v.out.ogr.gml.qgm
trunk/qgis/src/plugins/grass/modules/v.out.ogr.mapinfo.qgm
trunk/qgis/src/plugins/grass/modules/v.out.ogr.postgis.qgm
trunk/qgis/src/plugins/grass/modules/v.out.ogr.qgm
trunk/qgis/src/plugins/grass/modules/v.out.ogr.shape.qgm
trunk/qgis/src/plugins/grass/modules/v.patch.qgm
trunk/qgis/src/plugins/grass/modules/v.rast.stats.qgm
Further cleanup of GRASS modules
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Print projection information from a georeferenced ASCII file containing a Wkt projection description and create a new location based on it" module="g.proj">
+<qgisgrassmodule label="Print projection information from georeferenced ASCII file containing WKT projection description and create a new location based on it" module="g.proj">
<file key="wkt" type="old" />
<option key="location" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from a georeferenced ASCII file containing a Wkt projection description" module="g.proj">
+<qgisgrassmodule label="Print projection information from georeferenced ASCII file containing WKT projection description" module="g.proj">
<flag key="p" />
<flag key="d" />
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.geo.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.geo.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.geo.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from a georeferenced file (raster, vector or image)" module="g.proj">
+<qgisgrassmodule label="Print projection information from georeferenced file (raster, vector or image)" module="g.proj">
<file key="georef" type="old" />
<flag key="p" />
<flag key="d" />
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.proj.new.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.proj.new.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.proj.new.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from a PROJ.4 projection description file and create a new location based on it" module="g.proj">
+<qgisgrassmodule label="Print projection information from PROJ.4 projection description file and create a new location based on it" module="g.proj">
<file key="proj4" type="new"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.proj.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.proj.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.proj.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from a PROJ.4 projection description file" module="g.proj">
+<qgisgrassmodule label="Print projection information from PROJ.4 projection description file" module="g.proj">
<flag key="p" />
<flag key="d" />
<flag key="j" />
Modified: trunk/qgis/src/plugins/grass/modules/g.region.multiple.raster.qgm
--- trunk/qgis/src/plugins/grass/modules/g.region.multiple.raster.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/g.region.multiple.raster.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Set the region to match multiple raster maps" module="g.region">
+<qgisgrassmodule label="Set the region to match multiple rasters" module="g.region">
<file key="rast" label="Type in map names separated by a comma" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.region.multiple.vector.qgm
--- trunk/qgis/src/plugins/grass/modules/g.region.multiple.vector.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/g.region.multiple.vector.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Set the region to match multiple vector maps" module="g.region">
+<qgisgrassmodule label="Set the region to match multiple vectors" module="g.region">
<file key="vect" label="Type in map names separated by a comma" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.region.zoom.qgm
--- trunk/qgis/src/plugins/grass/modules/g.region.zoom.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/g.region.zoom.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Shrink the current region until it meets non-NULL data from a given raster map" module="g.region">
+<qgisgrassmodule label="Shrink current region until it meets non-NULL data from raster" module="g.region">
<option key="zoom" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm
--- trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import SPOT VGT NDVI into raster" module="i.in.spotvgt">
+<qgisgrassmodule label="Import SPOT VGT NDVI to GRASS raster" module="i.in.spotvgt">
<file key="file" type="new" />
<flag key="a" />
<option key="rast" />
Modified: trunk/qgis/src/plugins/grass/modules/r.blend.qgm
--- trunk/qgis/src/plugins/grass/modules/r.blend.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.blend.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Blend color components for two raster maps by given ratio" module="r.blend">
+<qgisgrassmodule label="Blend color components for two rasters by given ratio" module="r.blend">
<option key="first"/>
<option key="second"/>
<option key="output"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.clump.qgm
--- trunk/qgis/src/plugins/grass/modules/r.clump.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.clump.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Recategorizes into unique categories contiguous cells" module="r.clump">
+<qgisgrassmodule label="Recategorize contiguous cells to unique categories" module="r.clump">
<option key="input"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.compress.qgm
--- trunk/qgis/src/plugins/grass/modules/r.compress.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.compress.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Compresses and decompresses raster maps" module="r.compress">
+<qgisgrassmodule label="Compress and decompress raster" module="r.compress">
<option key="map" />
<flag key="u" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.fill.dir.qgm
--- trunk/qgis/src/plugins/grass/modules/r.fill.dir.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.fill.dir.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer" module="r.fill.dir">
+<qgisgrassmodule label="Filter and generate depressionless elevation map and flow direction map from elevation raster" module="r.fill.dir">
<option key="input" />
<option key="type" answer="grass" hidden="yes"/>
<option key="elevation" />
Modified: trunk/qgis/src/plugins/grass/modules/r.fillnulls.qgm
--- trunk/qgis/src/plugins/grass/modules/r.fillnulls.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.fillnulls.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Fills no-data areas in raster maps using v.surf.rst splines interpolation" module="r.fillnulls">
+<qgisgrassmodule label="Fill no-data areas in raster using v.surf.rst splines interpolation" module="r.fillnulls">
<option key="tension" answer="40" hidden="no"/>
<option key="smooth" answer="0.1" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import ESRI ARC/INFO ASCII raster (GRID) into GRASS raster" module="r.in.arc">
+<qgisgrassmodule label="Import ESRI ARC/INFO ASCII raster (GRID) to GRASS raster" module="r.in.arc">
<file key="input" type="old" />
<option key="type" />
<option key="mult" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import ASCII raster into GRASS raster" module="r.in.ascii">
+<qgisgrassmodule label="Import ASCII raster to GRASS raster" module="r.in.ascii">
<option key="nv" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import GDAL supported raster into GRASS raster and create fitted location" module="r.in.gdal">
+<qgisgrassmodule label="Import GDAL supported raster to GRASS raster and create fitted location" module="r.in.gdal">
<flag key="o" answer="off" hidden="yes" />
<flag key="e" answer="on" hidden="yes" />
<file key="input" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import GDAL supported raster file into GRASS raster" module="r.in.gdal">
+<qgisgrassmodule label="Import GDAL supported raster to GRASS raster" module="r.in.gdal">
<flag key="o" answer="on" hidden="yes" />
<flag key="e" answer="off" hidden="yes" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import GRIDATB.FOR map file (TOPMODEL) into GRASS raster" module="r.in.gridatb">
+<qgisgrassmodule label="Import GRIDATB.FOR map file (TOPMODEL) to GRASS raster" module="r.in.gridatb">
<option key="output" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.poly.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.poly.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.in.poly.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Create raster maps from ascii polygon/line data files in the current directory" module="r.in.poly">
+<qgisgrassmodule label="Create rasters from ASCII polygon/line data in current directory" module="r.in.poly">
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.srtm.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.srtm.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.in.srtm.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import SRTM HGT files into GRASS" module="r.in.srtm">
+<qgisgrassmodule label="Import SRTM HGT files to GRASS raster" module="r.in.srtm">
<flag key="1" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.out.arc.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export raster into ESRI ARCGRID" module="r.out.arc">
+<qgisgrassmodule label="Export raster to ESRI ARCGRID" module="r.out.arc">
<option key="dp" answer="2"/>
<flag key="h" />
Modified: trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm
--- trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.out.pov.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export raster into POVRAY height-field file" module="r.out.pov">
+<qgisgrassmodule label="Export raster to POVRAY height-field file" module="r.out.pov">
<option key="hftype" />
<option key="bias" />
Modified: trunk/qgis/src/plugins/grass/modules/r.param.scale.qgm
--- trunk/qgis/src/plugins/grass/modules/r.param.scale.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.param.scale.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Extracts terrain parameters from a DEM" module="r.param.scale">
+<qgisgrassmodule label="Extracts terrain parameters from DEM" module="r.param.scale">
<option key="param"/>
<option key="size" answer="3" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.patch.qgm
--- trunk/qgis/src/plugins/grass/modules/r.patch.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.patch.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Create a new raster map by combining other raster maps" module="r.patch">
+<qgisgrassmodule label="Create a new raster by combining other rasters" module="r.patch">
<flag key="z" answer="off" hidden="no" />
<file key="input" label="Type in map names separated by a comma" />
Modified: trunk/qgis/src/plugins/grass/modules/r.proj.qgm
--- trunk/qgis/src/plugins/grass/modules/r.proj.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.proj.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Re-project a raster map from one location to the current location" module="r.proj">
+<qgisgrassmodule label="Re-project a raster from a location to the current location" module="r.proj">
<option key="dbase"/>
<option key="location"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.recode.file.qgm
--- trunk/qgis/src/plugins/grass/modules/r.recode.file.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.recode.file.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Recode raster maps" module="r.recode.file">
+<qgisgrassmodule label="Recode raster" module="r.recode.file">
<file key="rules_file" type="new" fileoption="olayer" label="Text file" filters="Txt (*.txt), Csv (*.csv)" />
Modified: trunk/qgis/src/plugins/grass/modules/r.region.vector.qgm
--- trunk/qgis/src/plugins/grass/modules/r.region.vector.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.region.vector.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sets the boundary definitions from a vector map" module="r.region">
+<qgisgrassmodule label="Sets boundary definitions from vector" module="r.region">
<option key="vector" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.regression.line.qgm
--- trunk/qgis/src/plugins/grass/modules/r.regression.line.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.regression.line.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates linear regression from two raster maps: y = a + b*x" module="r.regression.line">
+<qgisgrassmodule label="Calculate linear regression from two rasters: y = a + b*x" module="r.regression.line">
<option key="map1" />
<option key="map2"/>
<file key="output" type="new" label="Output ASCII file" filters="txt (*.txt)" />
Modified: trunk/qgis/src/plugins/grass/modules/r.texture.bis.qgm
--- trunk/qgis/src/plugins/grass/modules/r.texture.bis.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.texture.bis.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate images with textural features from a raster map (second serie of indices)" module="r.texture">
+<qgisgrassmodule label="Generate images with textural features from raster (second serie of indices)" module="r.texture">
<option key="size" answer="3" />
<option key="distance" answer="1" />
Modified: trunk/qgis/src/plugins/grass/modules/r.texture.qgm
--- trunk/qgis/src/plugins/grass/modules/r.texture.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.texture.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate images with textural features from a raster map (first serie of indices)" module="r.texture">
+<qgisgrassmodule label="Generate images with textural features from raster (first serie of indices)" module="r.texture">
<option key="size" />
<option key="distance" />
Modified: trunk/qgis/src/plugins/grass/modules/r.topidx.qgm
--- trunk/qgis/src/plugins/grass/modules/r.topidx.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/r.topidx.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Creates a 3D volume map based on 2D elevation and value raster maps" module="r.topidx">
+<qgisgrassmodule label="Creates a 3D volume map based on 2D elevation and value rasters" module="r.topidx">
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.build.all.qgm
--- trunk/qgis/src/plugins/grass/modules/v.build.all.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.build.all.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,5 +1,5 @@
-<qgisgrassmodule label="Rebuild topology of all vectors in tha mapset" module="v.build.all">
+<qgisgrassmodule label="Rebuild topology of all vectors in mapset" module="v.build.all">
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.in.db.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.db.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.db.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import vector points from a database table containing coordinates" module="v.in.db">
+<qgisgrassmodule label="Import vector points from database table containing coordinates" module="v.in.db">
<file key="database" type="old" label="Database file" />
<option key="table" />
<option key="driver" />
Modified: trunk/qgis/src/plugins/grass/modules/v.in.dxf.multiple.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.dxf.multiple.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.dxf.multiple.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import only same layers of a DXF vector" module="v.in.dxf">
+<qgisgrassmodule label="Import only some layers of a DXF vector" module="v.in.dxf">
<ogr key="input" label="DXF vector layer" />
<option key="layers" />
Modified: trunk/qgis/src/plugins/grass/modules/v.in.dxf.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.dxf.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.dxf.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import DXF vector layer" module="v.in.dxf">
+<qgisgrassmodule label="Import DXF vector" module="v.in.dxf">
<file key="input" type="old" label="DXF vector layer" filters="dxf (*.dxf)" />
<flag key="1" answer="off" hidden="yes" />
Modified: trunk/qgis/src/plugins/grass/modules/v.in.e00.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.e00.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.e00.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import ESRI E00 file into vector" module="v.in.e00">
+<qgisgrassmodule label="Import ESRI E00 vector" module="v.in.e00">
<file key="file" type="old" label="E00 vector layer" />
<option key="vect" />
Modified: trunk/qgis/src/plugins/grass/modules/v.in.mapgen.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.mapgen.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.mapgen.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,8 +1,8 @@
-<qgisgrassmodule label="Import MapGen or MatLab vectors in GRASS" module="v.in.mapgen">
- <file key="input" type="old" label="E00 vector layer" />
+<qgisgrassmodule label="Import MapGen or MatLab vector" module="v.in.mapgen">
+ <file key="input" type="old" label="MapGen or MatLab vector layer" />
<flag key="f" answer="off" hidden="no" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.in.ogr.all.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.all.loc.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.all.loc.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import all the OGR/PostGIS vector layers in a given data source and create a fitted location" module="v.in.ogr">
+<qgisgrassmodule label="Import all OGR/PostGIS vectors in a given data source and create a fitted location" module="v.in.ogr">
<flag key="e" answer="off" hidden="no" />
Modified: trunk/qgis/src/plugins/grass/modules/v.in.ogr.all.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.all.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.all.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import all the OGR/PostGIS vector layers in a given data source" module="v.in.ogr">
+<qgisgrassmodule label="Import all OGR/PostGIS vectors in a given data source" module="v.in.ogr">
<flag key="r" answer="off" hidden="no" />
Modified: trunk/qgis/src/plugins/grass/modules/v.in.ogr.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.loc.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.loc.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import OGR/PostGIS vector layers and create a fitted location" module="v.in.ogr">
+<qgisgrassmodule label="Import OGR/PostGIS vector and create a fitted location" module="v.in.ogr">
Modified: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import OGR/PostGIS vector layers" module="v.in.ogr">
+<qgisgrassmodule label="Import OGR/PostGIS vector" module="v.in.ogr">
Modified: trunk/qgis/src/plugins/grass/modules/v.out.ogr.gml.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.ogr.gml.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.out.ogr.gml.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export vector layer to GML" module="v.out.ogr">
+<qgisgrassmodule label="Export vector to GML" module="v.out.ogr">
<option key="input" layeroption="layer" typeoption="type" />
<option key="format" answer="GML" hidden="yes" />
<file key="dsn" type="new" label="Output GML file" filters="GML (*.gml)" />
Modified: trunk/qgis/src/plugins/grass/modules/v.out.ogr.mapinfo.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.ogr.mapinfo.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.out.ogr.mapinfo.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Mapinfo export of vector layer" module="v.out.ogr">
+<qgisgrassmodule label="Export vector to Mapinfo" module="v.out.ogr">
<option key="format" answer="MapInfo_File" hidden="yes" />
<file key="dsn" type="new" fileoption="olayer" label="Output Shapefile" filters="MapInfo (*.tab)" />
Modified: trunk/qgis/src/plugins/grass/modules/v.out.ogr.postgis.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.ogr.postgis.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.out.ogr.postgis.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export vector layer to various formats (OGR library)" module="v.out.ogr">
+<qgisgrassmodule label="Export vector to PostGIS" module="v.out.ogr">
<option key="format" answer="PostgreSQL" hidden="yes"/>
<option key="dsn" label="Database parameters" />
Modified: trunk/qgis/src/plugins/grass/modules/v.out.ogr.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.ogr.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.out.ogr.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
+<qgisgrassmodule label="Export vector to various formats (OGR library)" module="v.out.ogr">
<option key="format"/>
<file key="dsn" type="new" fileoption="olayer" label="Output vector file" />
Modified: trunk/qgis/src/plugins/grass/modules/v.out.ogr.shape.qgm
--- trunk/qgis/src/plugins/grass/modules/v.out.ogr.shape.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.out.ogr.shape.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export vector layer to Shapefile" module="v.out.ogr">
+<qgisgrassmodule label="Export vector to Shapefile" module="v.out.ogr">
<option key="format" answer="ESRI_Shapefile" hidden="yes" />
<file key="dsn" type="new" fileoption="olayer" label="Output Shapefile" filters="Shapefile (*.shp)" />
Modified: trunk/qgis/src/plugins/grass/modules/v.patch.qgm
--- trunk/qgis/src/plugins/grass/modules/v.patch.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.patch.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Create a new vector map by combining other vector maps" module="v.patch">
+<qgisgrassmodule label="Create a new vector by combining other vectors" module="v.patch">
<flag key="a" answer="off" hidden="no" />
<flag key="e" answer="off" hidden="no" label="Copy also the attribute table (only the table of layer 1 is currently supported)" />
Modified: trunk/qgis/src/plugins/grass/modules/v.rast.stats.qgm
--- trunk/qgis/src/plugins/grass/modules/v.rast.stats.qgm 2008-11-08 11:47:52 UTC (rev 9592)
+++ trunk/qgis/src/plugins/grass/modules/v.rast.stats.qgm 2008-11-08 11:56:28 UTC (rev 9593)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates univariate statistics from a raster map based on vector objects" module="v.rast.stats">
+<qgisgrassmodule label="Calculate univariate statistics from raster based on vector objects" module="v.rast.stats">
<option key="raster"/>
<option key="vector" typemask="area"/>
<option key="colprefix"/>
