[QGIS Commit] r9594 - in trunk/qgis/src: core/raster gui
plugins/interpolation
svn_qgis at osgeo.org
Sat Nov 8 09:57:25 EST 2008
Author: jef
Date: 2008-11-08 09:57:25 -0500 (Sat, 08 Nov 2008)
New Revision: 9594
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.h
trunk/qgis/src/gui/qgsquickprint.cpp
trunk/qgis/src/plugins/interpolation/DualEdgeTriangulation.cc
fix warnings
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-11-08 11:56:28 UTC (rev 9593)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2008-11-08 14:57:25 UTC (rev 9594)
@@ -1228,7 +1228,7 @@
QgsContrastEnhancement* QgsRasterLayer::contrastEnhancement( unsigned int theBand )
- if ( 0 < theBand && theBand <= ( int ) bandCount() )
+ if ( 0 < theBand && theBand <= bandCount() )
return &mContrastEnhancementList[theBand - 1];
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-11-08 11:56:28 UTC (rev 9593)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2008-11-08 14:57:25 UTC (rev 9594)
@@ -771,6 +771,9 @@
/** \brief List containing the contrast enhancements for each band */
ContrastEnhancementList mContrastEnhancementList;
+ /** \brief Number of stddev to plot (0) to ignore. Not applicable to all layer types */
+ double mStandardDeviations;
/** [ data provider interface ] Pointer to data provider derived from the abstract base class QgsDataProvider */
QgsRasterDataProvider* mDataProvider;
@@ -806,6 +809,9 @@
/** \brief Whether this raster has overviews / pyramids or not */
bool mHasPyramids;
+ /** \brief Raster width */
+ int mWidth;
/** \brief Raster height */
int mHeight;
@@ -847,9 +853,6 @@
/** \brief Flag to indicate of the min max values are actual or estimates/user defined */
bool mRGBMinimumMaximumEstimated;
- /** \brief Number of stddev to plot (0) to ignore. Not applicable to all layer types */
- double mStandardDeviations;
/** \brief The band to be associated with transparency */
QString mTransparencyBandName;
@@ -861,9 +864,6 @@
/** \brief Flag indicating if the nodatavalue is valid*/
bool mValidNoDataValue;
- /** \brief Raster width */
- int mWidth;
#endif
Modified: trunk/qgis/src/gui/qgsquickprint.cpp
--- trunk/qgis/src/gui/qgsquickprint.cpp 2008-11-08 11:56:28 UTC (rev 9593)
+++ trunk/qgis/src/gui/qgsquickprint.cpp 2008-11-08 14:57:25 UTC (rev 9594)
@@ -229,7 +229,6 @@
//sensible default to prevent divide by zero
if ( 0 == myOriginalDpi ) myOriginalDpi = 96;
QSize myOriginalSize = mpMapRenderer->outputSize();
- int mySymbolScalingAmount = myPrintResolutionDpi / myOriginalDpi;
//define the font sizes and family
int myMapTitleFontSize = 24;
Modified: trunk/qgis/src/plugins/interpolation/DualEdgeTriangulation.cc
--- trunk/qgis/src/plugins/interpolation/DualEdgeTriangulation.cc 2008-11-08 11:56:28 UTC (rev 9593)
+++ trunk/qgis/src/plugins/interpolation/DualEdgeTriangulation.cc 2008-11-08 14:57:25 UTC (rev 9594)
@@ -473,7 +473,7 @@
int nulls = 0;//number of left-of-tests, which returned 0. 1 means, that the point is on a line, 2 means that it is on an existing point
int numinstabs = 0;//number of suspect left-of-tests due to 'leftOfTresh'
int runs = 0;//counter for the number of iterations in the loop to prevent an endless loop
- int firstendp, secendp, thendp, fouendp;//four numbers of endpoints in cases when two left-of-test are 0
+ int firstendp = 0, secendp = 0, thendp = 0, fouendp = 0; //four numbers of endpoints in cases when two left-of-test are 0
while ( true )
