[QGIS Commit] r9607 - in trunk/code_examples: . 1_hello_world_qgis_style images
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 9 04:09:26 EST 2008
Author: timlinux
Date: 2008-11-09 04:09:25 -0500 (Sun, 09 Nov 2008)
New Revision: 9607
Added:
   trunk/code_examples/generate_docs.sh
   trunk/code_examples/images/
   trunk/code_examples/images/tim50x50.png
   trunk/code_examples/images/tutorial1.jpg
   trunk/code_examples/index.t2t
   trunk/code_examples/style.css
Removed:
   trunk/code_examples/1_hello_world_qgis_style/tutorial1.html
Start migrating tutorials to text2tags format
Deleted: trunk/code_examples/1_hello_world_qgis_style/tutorial1.html
--- trunk/code_examples/1_hello_world_qgis_style/tutorial1.html	2008-11-09 08:41:32 UTC (rev 9606)
+++ trunk/code_examples/1_hello_world_qgis_style/tutorial1.html	2008-11-09 09:09:25 UTC (rev 9607)
@@ -1,139 +0,0 @@
-<img src="images/tim50x50.png" align="left">Ok so not everyone wants a full blown GIS desktop application. Sometimes you want to just have a widget inside your application that displays a map while the main goal of the application lies elsewhere. Perhaps a database frontend with a map display?
-<bold>Updated November 2008 to use cmake build system and the updated QGIS 1.0.0 API. Tim</bold>
-<!--break-->
-So lets take a little walk through creating a simple mapping widget. It wont do anything much - just load a shape file and display it in a random colour. But it should give you an idea of the potential for using QGIS as an embedded mapping component. Before I carry on, many thanks to Francis Bolduc who wrote the beginnings of this demo and then came onto IRC today to do some communal debugging of his prototype. Francis kindly agreed to make his work generally available - though I've tweaked it a bit to use shapefiles instead of his original postgis demo.
-We start with typical adding the neccessary includes for our app:
-<pre>
-// QGIS Includes
-#include &lt;qgsapplication.h>
-#include &lt;qgsproviderregistry.h>
-#include &lt;qgssinglesymbolrenderer.h>
-#include &lt;qgsmaplayerregistry.h>
-#include &lt;qgsvectorlayer.h>
-#include &lt;qgsmapcanvas.h>
-// Qt Includes
-#include &lt;QString>
-#include &lt;QApplication>
-#include &lt;QWidget>
-</pre>
-We use QgsApplication instead of Qt's QApplication, and get some added benifits of various static methods that can be used to locate library paths and so on.
-The provider registry is a singleton that keeps track of vector data provider plugins. It does all the work for you of loading the plugins and so on. The single symbol renderer is the most basic symbology class. It renders points, lines or polygons in a single colour which is chosen at random by default (though you can set it yourself). Every vector layer must have a symbology associated with it.
-The map layer registry keeps track of all the layers you are using. The vector layer class inherits from maplayer and extends it to include specialist functionality for vector data.
-Finally the mapcanvas is really the nub of the matter. Its the drawable widget that our map will be drawn onto.
-Now we can move on to initialising our application....
-<pre>
-int main(int argc, char ** argv)
-  // Start the Application
-  QgsApplication app(argc, argv, true);
-  QString myPluginsDir        = "/home/timlinux/apps/lib/qgis";
-  QString myLayerPath         = "/home/timlinux/gisdata/brazil/BR_Cidades/";
-  QString myLayerBaseName     = "Brasil_Cap";
-  QString myProviderName      = "ogr";
-</pre>
-So now we have a qgsapplication and we have defined some variables. Since I tested this on the Ubuntu 8.10, I just specified the location of the vector provider plugins as being inside the my development install directory. It would probaby make more sense in general to keep the QGIS libs in one of the standard library search paths on your system (e.g. /usr/lib) but this way will do for now.
-The next two variables defined here just point to the shapefile I am going to be using (and you should substitute your own data here).
-The provider name is important - it tells qgis which data provider to use to load the file. Typically you will use 'ogr' or 'postgres'.
-Now we can go on to actually create our layer object.
-<pre>
-  // Instantiate Provider Registry
-  QgsProviderRegistry::instance(myPluginsDir);
-</pre>
-First we get the provider registry initialised. Its a singleton class so we use the static instance call and pass it the provider lib search path. As it initialises it will scan this path for provider libs.
-Now we go on to create a layer...
-<pre>
-  QgsVectorLayer * mypLayer =
-      new QgsVectorLayer(myLayerPath, myLayerBaseName, myProviderName);
-  QgsSingleSymbolRenderer *mypRenderer = new QgsSingleSymbolRenderer(mypLayer->geometryType());
-  QList &lt;QgsMapCanvasLayer> myLayerSet;
-  mypLayer->setRenderer(mypRenderer);
-  if (mypLayer->isValid())
-    qDebug("Layer is valid");
-  else
-    qDebug("Layer is NOT valid");
-  // Add the Vector Layer to the Layer Registry
-  QgsMapLayerRegistry::instance()->addMapLayer(mypLayer, TRUE);
-  // Add the Layer to the Layer Set
-  myLayerSet.append(QgsMapCanvasLayer(mypLayer, TRUE));
-</pre>
-The code is fairly self explanatory here. We create a layer using the variables we defined earlier. Then we assign the layer a renderer. When we create a renderer, we need to specify the geometry type, which do do by asking the vector layer for its geometry type. Next we add the layer to a layerset (which is used by the QgsMapCanvas to keep track of which layers to render and in what order) and to the maplayer registry. Finally we make sure the layer will be visible.
-Now we create a map canvas on to which we can draw the layer.
-<pre>
-  // Create the Map Canvas
-  QgsMapCanvas * mypMapCanvas = new QgsMapCanvas(0, 0);
-  mypMapCanvas->setExtent(mypLayer->extent());
-  mypMapCanvas->enableAntiAliasing(true);
-  mypMapCanvas->setCanvasColor(QColor(255, 255, 255));
-  mypMapCanvas->freeze(false);
-  // Set the Map Canvas Layer Set
-  mypMapCanvas->setLayerSet(myLayerSet);
-  mypMapCanvas->setVisible(true);
-  mypMapCanvas->refresh();
-</pre>
-Once again there is nothing particularly tricky here. We create the canvas and then we set its extents to those of our layer. Next we tweak the canvas a bit to draw antialiased vectors. Next we set the background colour, unfreeze the canvas, make it visible and then refresh it.
-<pre>
-  // Start the Application Event Loop
-  return app.exec();
-</pre>
-In the last step we simply start the Qt event loop and we are all done. Easy as 1-2-3 eh?
-This example can be checked out of subversion, compiled and run using cmake like this:
-<pre>
-svn co https://svn.osgeo.org/qgis/trunk/code_examples/1_hello_world_qgis_style
-cd 1_hello_world_qgis_style
-mkdir build
-#optionally specify where your QGIS is installed (should work on all platforms)
-#if your QGIS is installed to /usr or /usr/local you can leave this next step out
-export LIB_DIR=/home/timlinux/apps
-cmake ..
-make
-./timtut1
-</pre>
-When we compile and run it here is what the running app looks like:
-<img src="http://blog.qgis.org/files/libqgis_minimal_example.jpg">
-Once again many thanks to Francis for prompting this posting.
Added: trunk/code_examples/generate_docs.sh
--- trunk/code_examples/generate_docs.sh	                        (rev 0)
+++ trunk/code_examples/generate_docs.sh	2008-11-09 09:09:25 UTC (rev 9607)
@@ -0,0 +1,9 @@
+#!/bin/bash
+# Simple bash script to generate tutorial documentation
+txt2tags -t html -o index.html index.t2t
+txt2tags -t html -o tutorial1.html 1_hello_world_qgis_style/tutorial1.t2t
Property changes on: trunk/code_examples/generate_docs.sh
___________________________________________________________________
Added: trunk/code_examples/images/tim50x50.png
(Binary files differ)
Property changes on: trunk/code_examples/images/tim50x50.png
   + application/octet-stream
Added: trunk/code_examples/images/tutorial1.jpg
Property changes on: trunk/code_examples/images/tutorial1.jpg
Added: trunk/code_examples/index.t2t
--- trunk/code_examples/index.t2t	                        (rev 0)
+++ trunk/code_examples/index.t2t	2008-11-09 09:09:25 UTC (rev 9607)
@@ -0,0 +1,34 @@
+QGIS Developer Tutorials
+Tim Sutton, 2008
+%! target       : html
+%! style        : style.css
+%! Options      : --toc --toc-level 3 --enum-title --css-sugar --css-inside
+%! preproc      : TUT_URL   https://qgis.org
+%! PostProc(html): '(?i)(<pre>)' '<div class="code">\1'
+%! PostProc(html): '(?i)(</pre>)' '\1</div>'
+%! encoding: iso-8859-1
+% These are comments and will not be generated in any output
+%This document is in text2tags format. You can generate html, plain text and
+%moinmoin formatted documentation by running txt2tags on this document. See the
+%txt2tags home page for more details.  Please insert manual line breaks in this
+%document as it makes diffing for changes much easier. To do this in vim
+%automatically, select a section then issue (gq) command. Please dont
+%apply vim formatting to the whol document as it screws up some formatting
+%rather apply it selectively to paragraphs where needed.
+% To generate the text version of this document:
+% txt2tags -t txt -o index index.t2t
+% To generate the moinmoin version of this document
+% txt2tags -t moin -o index.moin  index.t2t
+% To generate the html version of this document
+% txt2tags -t html -o index.html index.t2t
+% End of comments
+%!include: 1_hello_world_qgis_style/tutorial1.t2t
Property changes on: trunk/code_examples/index.t2t
Added: trunk/code_examples/style.css
--- trunk/code_examples/style.css	                        (rev 0)
+++ trunk/code_examples/style.css	2008-11-09 09:09:25 UTC (rev 9607)
@@ -0,0 +1,30 @@
+body {
+  padding: 2em 1em 2em 70px;
+  margin: 0;
+  font-family: sans-serif;
+  color: black;
+  background: white;
+:link { color: #00C; background: transparent }
+:visited { color: #609; background: transparent }
+a:active { color: #C00; background: transparent }
+a:link img, a:visited img { border-style: none }
+h1, h2, h3, h4, h5, h6 { text-align: left }
+h1, h2, h3 { color: #005A9C; background: white }
+h1 { font: 170% sans-serif }
+h2 { font: 140% sans-serif }
+h3 { font: 120% sans-serif }
+h4 { font: bold 100% sans-serif }
+h5 { font: italic 100% sans-serif }
+h6 { font: small-caps 100% sans-serif }
+pre { margin-left: 2em;
+      border: 1;
+      padding: 4px;
+      background: #ececec; }
+pre, code { font-family: monospace }
Property changes on: trunk/code_examples/style.css
More information about the QGIS-commit mailing list
