[QGIS Commit] r9608 - in trunk/code_examples: . 2_basic_main_window
images
svn_qgis at osgeo.org
Sun Nov 9 04:30:50 EST 2008
Author: timlinux
Date: 2008-11-09 04:30:50 -0500 (Sun, 09 Nov 2008)
New Revision: 9608
Added:
trunk/code_examples/2_basic_main_window/tutorial2.t2t
trunk/code_examples/images/tutorial2.jpg
Removed:
trunk/code_examples/2_basic_main_window/tutorial2.html
trunk/code_examples/index.t2t
txt2tags conversion for tutorial 2
Deleted: trunk/code_examples/2_basic_main_window/tutorial2.html
--- trunk/code_examples/2_basic_main_window/tutorial2.html 2008-11-09 09:09:25 UTC (rev 9607)
+++ trunk/code_examples/2_basic_main_window/tutorial2.html 2008-11-09 09:30:50 UTC (rev 9608)
@@ -1,110 +0,0 @@
-<p><img src="images/tim50x50.png" align="left">Tutorial 1 showed you the useage of the QgsMapCanvas api to create a simple application that loads a shapefile and displays the points in it. But what good is map that you can't interact with? Enter our second tutorial where we show you how to use QgsMapTool - the base class for all tools that need to interact with the canvas.</p>
-<strong>Updated November 2008 to use cmake build system and the updated QGIS 1.0.0 API. Tim</strong>
-<!--break-->
-<p><img src="http://blog.qgis.org/files/mapcanvas_tut2.jpg"/></p>
-<p>Today I will extend the last tutorial by making it a QMainWindow application with a menu, toolbar and canvas area. The purpose of the tutorial is to provide a demonstrator project, so I wont promise to write the most elegant or robust C++ code. The project will provide 4 toolbar icons for</p>
-<ul>
-<li>loading a map layer (layer name is hard coded in the application</li>
-<li>zooming in</li>
-<li> zooming out</li>
-<li> panning</li>
-</ul>
-<p>The entire project can be checked out form the QGIS Subversion repository using the following command:</p>
-<pre>svn co https://svn.osgeo.org/qgis/trunk/code_examples/2_basic_main_window</pre>
-<p>In the working directory for the tutorial code you will find a number of files including c++ sources, icons and a simple data file under data. There is also the .ui file for the main window.</p>
-<p><strong>Note:</strong> You will need to edit the .pro file in the above svn directory to match your system.
-<p>Since much of the code is the same as the previous tutorial, I will focus on the MapTool specifics - the rest of the implementation details can be investigated by checking out the project form SVN. A QgsMapTool is a class that interacts with the MapCanvas using the mouse pointer. QGIS has a number of QgsMapTools implemented, and you can subclass QgsMapTool to create your own. In mainwindow.cpp you will see I include the headers for the QgsMapTools near the start of the file:</p>
-<pre>
- // QGIS Map tools
- #include "qgsmaptoolpan.h"
- #include "qgsmaptoolzoom.h"
- // These are the other headers for available map tools (not used in this example)
- //#include "qgsmaptoolcapture.h"
- //#include "qgsmaptoolidentify.h"
- //#include "qgsmaptoolselect.h"
- //#include "qgsmaptoolvertexedit.h"
- //#include "qgsmeasure.h"
-</pre>
-<p>As you can see, I am only using two types of MapTool subclasses for this tutorial, but there are more available in the QGIS library. Hooking up our MapTools to the canvas is very easy using the normal Qt4 signal/slot mechanism:</p>
-<pre>
- //create the action behaviours
- connect(mActionPan, SIGNAL(triggered()), this, SLOT(panMode()));
- connect(mActionZoomIn, SIGNAL(triggered()), this, SLOT(zoomInMode()));
- connect(mActionZoomOut, SIGNAL(triggered()), this, SLOT(zoomOutMode()));
- connect(mActionAddLayer, SIGNAL(triggered()), this, SLOT(addLayer()));
-</pre>
-<p>Next we make a small toolbar to hold our toolbuttons. Note that the mpAction* actions were created in designer.</p>
-<pre>
- //create a little toolbar
- mpMapToolBar = addToolBar(tr("File"));
- mpMapToolBar->addAction(mpActionAddLayer);
- mpMapToolBar->addAction(mpActionZoomIn);
- mpMapToolBar->addAction(mpActionZoomOut);
- mpMapToolBar->addAction(mpActionPan);
-</pre>
-<p>Thats really pretty straightforward Qt stuff too. Now we create our three map tools:</p>
-<pre>
- //create the maptools
- mpPanTool = new QgsMapToolPan(mpMapCanvas);
- mpPanTool->setAction(mpActionPan);
- mpZoomInTool = new QgsMapToolZoom(mpMapCanvas, FALSE); // false = in
- mpZoomInTool->setAction(mpActionZoomIn);
- mpZoomOutTool = new QgsMapToolZoom(mpMapCanvas, TRUE ); //true = out
- mpZoomOutTool->setAction(mpActionZoomOut);
-</pre>
-<p>Again nothing here is very complicated - we are creating tool instances, each of which is associated with the same mapcanvas, and a different QAction. When the user selects one of the toolbar icons, the active MapTool for the canvas is set. For example when the pan icon is clicked, we do this:</p>
-<pre>
- void MainWindow::panMode()
- mpMapCanvas->setMapTool(mpPanTool);
-</pre>
-<p><strong>Conclusion</strong></p>
-<p>As you can see extending our previous example into something more functional using MapTools is really easy and only requires a few lines of code for each MapTool you want to provide.</p>
-You can check out and build this tutorial using SVN and CMake using the following steps:
-<pre>
-svn co https://svn.osgeo.org/qgis/trunk/code_examples/2_basic_main_window
-cd 2_basic_main_window
-mkdir build
-#optionally specify where your QGIS is installed (should work on all platforms)
-#if your QGIS is installed to /usr or /usr/local you can leave this next step out
-export LIB_DIR=/home/timlinux/apps
-cmake ..
-make
-./timtut2
-</pre>
-<p><strong>A final note</strong></p>
-<p>I don't oftend check the comments on these posts - if you are stuck please write to the <a href="http://qgis.org/content/view/115/96/">QGIS Developer mailing list</a>! Thanks.Tim</p>
-<!-- technorati tags begin --><p style="font-size:10px;text-align:right;">technorati tags:<a href="http://technorati.com/tag/QgsMapCanvas" rel="tag">QgsMapCanvas</a>, <a href="http://technorati.com/tag/MapTool" rel="tag">MapTool</a>, <a href="http://technorati.com/tag/c++" rel="tag">c++</a>, <a href="http://technorati.com/tag/subversion" rel="tag">subversion</a>, <a href="http://technorati.com/tag/tutorial" rel="tag">tutorial</a></p><!-- technorati tags end -->
Copied: trunk/code_examples/2_basic_main_window/tutorial2.t2t (from rev 9592, trunk/code_examples/2_basic_main_window/tutorial2.html)
--- trunk/code_examples/2_basic_main_window/tutorial2.t2t (rev 0)
+++ trunk/code_examples/2_basic_main_window/tutorial2.t2t 2008-11-09 09:30:50 UTC (rev 9608)
@@ -0,0 +1,170 @@
+Tutorial 2 - Working with QgsMapCanvas
+Tim Sutton, 2008
+%! target : html
+%! style : style.css
+%! Options : --toc --toc-level 3 --enum-title --css-sugar --css-inside
+%! preproc : TUT_URL https://qgis.org
+%! PostProc(html): '(?i)(```)' '<div class="code">\1'
+%! PostProc(html): '(?i)(```)' '\1</div>'
+%! encoding: iso-8859-1
+% These are comments and will not be generated in any output
+%This document is in text2tags format. You can generate html, plain text and
+%moinmoin formatted documentation by running txt2tags on this document. See the
+%txt2tags home page for more details. Please insert manual line breaks in this
+%document as it makes diffing for changes much easier. To do this in vim
+%automatically, select a section then issue (gq) command. Please dont
+%apply vim formatting to the whol document as it screws up some formatting
+%rather apply it selectively to paragraphs where needed.
+% To generate the text version of this document:
+% Make sure you are in the top level code examples dir
+% since image paths are referenced from there:
+% txt2tags -t txt -o tutorial2 2_basic_main_window/tutorial2.t2t
+% To generate the moinmoin version of this document
+% txt2tags -t moin -o tutorial2.moin 2_basic_main_window/tutorial2.t2t
+% To generate the html version of this document
+% txt2tags -t html -o tutorial2.html 2_basic_main_window/tutorial2.t2t
+% End of comments
+= Working with QgsMapCanvas =
+[images/tim50x50.png]Tutorial 1 showed you the useage of the QgsMapCanvas api
+to create a simple application that loads a shapefile and displays the points
+in it. But what good is map that you can't interact with? Enter our second
+tutorial where we show you how to use QgsMapTool - the base class for all tools
+that need to interact with the canvas.
+**Updated November 2008 to use cmake build system and the updated QGIS 1.0.0 API. Tim**
+[images/tutorial2.jpg]
+Today I will extend the last tutorial by making it a QMainWindow application
+with a menu, toolbar and canvas area. The purpose of the tutorial is to provide
+a demonstrator project, so I wont promise to write the most elegant or robust
+C++ code. The project will provide 4 toolbar icons for
+ - loading a map layer (layer name is hard coded in the application
+ - zooming in
+ - zooming out
+ - panning
+The entire project can be checked out form the QGIS Subversion repository using
+the following command:
+```svn co https://svn.osgeo.org/qgis/trunk/code_examples/2_basic_main_window```
+In the working directory for the tutorial code you will find a number of files
+including c++ sources, icons and a simple data file under data. There is also
+the .ui file for the main window.
+**Note:** You will need to edit the .pro file in the above svn directory to
+match your system.
+Since much of the code is the same as the previous tutorial, I will focus on
+the MapTool specifics - the rest of the implementation details can be
+investigated by checking out the project form SVN. A QgsMapTool is a class that
+interacts with the MapCanvas using the mouse pointer. QGIS has a number of
+QgsMapTools implemented, and you can subclass QgsMapTool to create your own. In
+mainwindow.cpp you will see I include the headers for the QgsMapTools near the
+start of the file:
+ // QGIS Map tools
+ #include "qgsmaptoolpan.h"
+ #include "qgsmaptoolzoom.h"
+ // These are the other headers for available map tools
+ // (not used in this example)
+ //#include "qgsmaptoolcapture.h"
+ //#include "qgsmaptoolidentify.h"
+ //#include "qgsmaptoolselect.h"
+ //#include "qgsmaptoolvertexedit.h"
+ //#include "qgsmeasure.h"
+As you can see, I am only using two types of MapTool subclasses for this
+tutorial, but there are more available in the QGIS library. Hooking up our
+MapTools to the canvas is very easy using the normal Qt4 signal/slot mechanism:
+ //create the action behaviours
+ connect(mActionPan, SIGNAL(triggered()), this, SLOT(panMode()));
+ connect(mActionZoomIn, SIGNAL(triggered()), this, SLOT(zoomInMode()));
+ connect(mActionZoomOut, SIGNAL(triggered()), this, SLOT(zoomOutMode()));
+ connect(mActionAddLayer, SIGNAL(triggered()), this, SLOT(addLayer()));
+Next we make a small toolbar to hold our toolbuttons. Note that the mpAction*
+actions were created in designer.
+ //create a little toolbar
+ mpMapToolBar = addToolBar(tr("File"));
+ mpMapToolBar->addAction(mpActionAddLayer);
+ mpMapToolBar->addAction(mpActionZoomIn);
+ mpMapToolBar->addAction(mpActionZoomOut);
+ mpMapToolBar->addAction(mpActionPan);
+Thats really pretty straightforward Qt stuff too. Now we create our three map
+tools:
+ //create the maptools
+ mpPanTool = new QgsMapToolPan(mpMapCanvas);
+ mpPanTool->setAction(mpActionPan);
+ mpZoomInTool = new QgsMapToolZoom(mpMapCanvas, FALSE); // false = in
+ mpZoomInTool->setAction(mpActionZoomIn);
+ mpZoomOutTool = new QgsMapToolZoom(mpMapCanvas, TRUE ); //true = out
+ mpZoomOutTool->setAction(mpActionZoomOut);
+Again nothing here is very complicated - we are creating tool instances, each
+of which is associated with the same mapcanvas, and a different QAction. When
+the user selects one of the toolbar icons, the active MapTool for the canvas is
+set. For example when the pan icon is clicked, we do this:
+ void MainWindow::panMode()
+ mpMapCanvas->setMapTool(mpPanTool);
+**Conclusion**
+As you can see extending our previous example into something more functional
+using MapTools is really easy and only requires a few lines of code for each
+MapTool you want to provide.
+You can check out and build this tutorial using SVN and CMake using the following steps:
+svn co https://svn.osgeo.org/qgis/trunk/code_examples/2_basic_main_window
+cd 2_basic_main_window
+mkdir build
+#optionally specify where your QGIS is installed (should work on all platforms)
+#if your QGIS is installed to /usr or /usr/local you can leave this next step out
+export LIB_DIR=/home/timlinux/apps
+cmake ..
+make
+./timtut2
+**A final note**
+I don't often check the comments on these posts - if you are stuck please
+write to the [QGIS Developer mailing list
+http://qgis.org/content/view/115/96/"]! Thanks.Tim
Property changes on: trunk/code_examples/2_basic_main_window/tutorial2.t2t
___________________________________________________________________
Added: trunk/code_examples/images/tutorial2.jpg
(Binary files differ)
Property changes on: trunk/code_examples/images/tutorial2.jpg
+ application/octet-stream
Modified: trunk/code_examples/index.t2t
--- trunk/code_examples/index.t2t 2008-11-09 09:09:25 UTC (rev 9607)
+++ trunk/code_examples/index.t2t 2008-11-09 09:30:50 UTC (rev 9608)
@@ -6,8 +6,8 @@
-%! PostProc(html): '(?i)(<pre>)' '<div class="code">\1'
-%! PostProc(html): '(?i)(</pre>)' '\1</div>'
@@ -32,3 +32,4 @@
%!include: 1_hello_world_qgis_style/tutorial1.t2t
+%!include: 2_basic_main_window/tutorial2.t2t
