[QGIS Commit] r9609 - in trunk/code_examples: . 3_basic_labelling
images
svn_qgis at osgeo.org
Sun Nov 9 04:44:11 EST 2008
Author: timlinux
Date: 2008-11-09 04:44:11 -0500 (Sun, 09 Nov 2008)
New Revision: 9609
Added:
trunk/code_examples/3_basic_labelling/tutorial3.t2t
trunk/code_examples/images/tutorial3.jpg
Removed:
trunk/code_examples/3_basic_labelling/tutorial3.html
trunk/code_examples/generate_docs.sh
trunk/code_examples/index.t2t
Conversion of tutorial to t2t format
Deleted: trunk/code_examples/3_basic_labelling/tutorial3.html
--- trunk/code_examples/3_basic_labelling/tutorial3.html 2008-11-09 09:30:50 UTC (rev 9608)
+++ trunk/code_examples/3_basic_labelling/tutorial3.html 2008-11-09 09:44:11 UTC (rev 9609)
@@ -1,145 +0,0 @@
-<img src="images/tim50x50.png" align="left">In my last tutorial I briefly ran through using map tools to facilitate user interaction with the map canvas. Today we will take a brief look at labelling features.
-<strong>Updated November 2008 to use cmake build system and the updated QGIS 1.0.0 API. Tim</strong>
-<!--break-->
-<img src="http://blog.qgis.org/files/tutorial3.jpg"/>
-Before I carry on too far, note that QGIS's automatic labelling algorithm is very primative. Martin Dobias is planning to implement a much more useful label placement routine - but its not going to be available in QGIS 0.8. For the best label placement results you should defined fields in your attribute table for position, rotation etc of the label. Since this is only intended to be a 'get you started' introduction, I won't be doing all that here...
-<p>The entire project can be checked out form the QGIS Subversion repository using the following command:</p>
-<pre>svn co https://svn.qgis.org/repos/qgis/trunk/code_examples/3_basic_labelling
-</pre>
-<p>In the working directory for the tutorial code you will find a number of files including c++ sources, icons and a simple data file under data. There is also the .ui file for the main window.</p>
-<p><strong>Note:</strong> You will need to edit the .pro file in the above svn directory to match your system.
-<h3>Labelling Specifics</h3>
-If you look in mainwindow.cpp you will notice a couple of new includes introduced since the last tutorial:
-<pre>
- #include <qgslabel.h>
- #include <qgslabelattributes.h>
- #include <qgsfield.h>
-</pre>
-Each vector layer can have a QgsLabel associated with it. A QgsLabel is a renderer for labels. It has a member of type QgsLabelAttributes which determines the placement (above / below / left / right etc), rotation, size, size units (points or map units), font, colour and various other elements of the label. The QgsField include is needed because we will be querying the vector layer for its available fields so that we can determine which field should be used for labelling.
-In the same cpp file you will see I define a label and a label attributes pointer. These will be used to setup the labelling characteristics we want and then assigned to the layer:
-<pre>
- QgsLabel * mypLabel;
- QgsLabelAttributes * mypLabelAttributes;
-</pre>
-Now we will see how we actually initialise and assign the QgsLabel and the QgsLabelAttributes to the vector layer.
-<pre>
- //set up labelling for the layer
- //get the label instance associated with the layer
- mypLabel = mypLayer->label();
- //and the label attributes associated with the label
- mypLabelAttributes = mypLabel->layerAttributes();
-</pre>
-Great now we have a handle on the QgsLabel and QgsLabelAttributes we can start to manipulate how the label will be displayed. Note that the mypLabel->layerAttributes() method is poorly named and will likely be changed (to labelAttributes()) before the final release of QGIS 1.0.
-Ok next lets ask the vector layer's data provider what attribute fields it has so that we can select one to be used for labelling:
-<pre>
- //get the field list associated with the layer
- //we'll print the names out to console for diagnostic purposes
- QgsFieldMap myFields = mypLayer->dataProvider()->fields();
- for (unsigned int i = 0; i < myFields.size(); i++ )
- qDebug("Field Name: " + QString(myFields[i].name()).toLocal8Bit() );
-</pre>
-By the way - you can browse the code for field, label, lable attributes etc from <a href="https://trac.osgeo.org/qgis/browser/trunk/qgis/src/">the QGIS source browser</a>. Look in the 'core' and 'gui' subdirectories. Also for more implementation examples of how to set up labelling, it is worth taking a look at <a href="https://trac.osgeo.org/qgis/browser/trunk/qgis/src/gui/qgslabeldialog.cpp">qgslabeldialog.cpp</a>.
-With access to the list of fields in your vector layer, you can then for example present the user with a combo box to select a label field. In this simple tutorial though I am simply going to use the last field in the attribute table. Its a bit of a no brainer because our attribute table only has one field! But at least this way its soft coded...
-<pre>
- //just use the last field's name in the fields list as the label field!
- qDebug("set label field to " + myFields[myFields.size()-1].name());
- mypLabel->setLabelField( QgsLabel::Text, myFields.size()-1);
-</pre>
-There are a bunch of other things we can do to manipulate the appearance of the label. Lets set the text colour to black and draw a yellow 1 point 'halo' buffer around it so the label won't get lost when there are black features behind it:
-<pre>
- //set the colour of the label text
- mypLabelAttributes->setColor(Qt::black);
- //create a 'halo' effect around each label so it
- //can still be read on dark backgrounds
- mypLabelAttributes->setBufferEnabled(true);
- mypLabelAttributes->setBufferColor(Qt::yellow);
- int myType = QgsLabelAttributes::PointUnits;
- mypLabelAttributes->setBufferSize(1,myType);
-</pre>
-Finally we need to tell the layer that rendering of labels should be enabled:
-<pre>
- mypLayer->enableLabels(true);
-</pre>
-For the absolute best labelling results, I advise you to store all the label properties you can inside your attribute table. Doing this will allow you to set rotation, placement etc on a per label basis. I left some comments in the tutorial source code that will get you started with this:
-<pre>
- * Here are a bunch of other things you can set based on values on a database field
- * the second parameter in each case would be the field name from which the
- * attribute can be retrieved.
- mypLabel->setLabelField( QgsLabel::Family, "fontFamily" );
- mypLabel->setLabelField( QgsLabel::Bold, "fontIsBold" );
- mypLabel->setLabelField( QgsLabel::Italic, "fontIsItalic" );
- mypLabel->setLabelField( QgsLabel::Underline, "fontIsUnderlined" );
- mypLabel->setLabelField( QgsLabel::Size, "fontSize" );
- mypLabel->setLabelField( QgsLabel::BufferSize,"fontBufferSize" );
- mypLabel->setLabelField( QgsLabel::XCoordinate, "labelX" );
- mypLabel->setLabelField( QgsLabel::YCoordinate, "labelY");
- mypLabel->setLabelField( QgsLabel::XOffset, "labelXOffset");
- mypLabel->setLabelField( QgsLabel::YOffset, "labelYOffset");
- mypLabel->setLabelField( QgsLabel::Alignment, "labelAlignment" );
- mypLabel->setLabelField( QgsLabel::Angle, "labelAngle");
-</pre>
-Well that wraps up this tutorial. One thing I noticed is that the canvas is not refreshing properly sometimes on the mac unless you cover the application briefly with another window. Ill post an update here if I figure out what is causing this.
-You can check out and build this tutorial using SVN and CMake using the following steps:
-<pre>
-svn co https://svn.osgeo.org/qgis/trunk/code_examples/3_basic_labelling
-cd 3_basic_labelling
-mkdir build
-#optionally specify where your QGIS is installed (should work on all platforms)
-#if your QGIS is installed to /usr or /usr/local you can leave this next step out
-export LIB_DIR=/home/timlinux/apps
-cmake ..
-make
-./timtut3
-</pre>
-<h3>Mac Specific Notes</h3>
-After building the application bundle (cmake; make) you can copy the spatial reference system database into the bundle to avoid 'cant find resource' type errors:
-<pre>
-mkdir -p qgis_example3.app/Contents/MacOS/share/qgis/resources/
-cp -r /Applications/qgis.app/Contents/MacOS/share/qgis/resources/* \
- qgis_example3.app/Contents/MacOS/share/qgis/resources/
-</pre>
Copied: trunk/code_examples/3_basic_labelling/tutorial3.t2t (from rev 9601, trunk/code_examples/3_basic_labelling/tutorial3.html)
--- trunk/code_examples/3_basic_labelling/tutorial3.t2t (rev 0)
+++ trunk/code_examples/3_basic_labelling/tutorial3.t2t 2008-11-09 09:44:11 UTC (rev 9609)
@@ -0,0 +1,224 @@
+Tutorial 3 - Basic Labelling
+Tim Sutton, 2008
+%! target : html
+%! style : style.css
+%! Options : --toc --toc-level 3 --enum-title --css-sugar --css-inside
+%! preproc : TUT_URL https://qgis.org
+%! PostProc(html): '(?i)(```)' '<div class="code">\1'
+%! PostProc(html): '(?i)(```)' '\1</div>'
+%! encoding: iso-8859-1
+% These are comments and will not be generated in any output
+%This document is in text2tags format. You can generate html, plain text and
+%moinmoin formatted documentation by running txt2tags on this document. See the
+%txt2tags home page for more details. Please insert manual line breaks in this
+%document as it makes diffing for changes much easier. To do this in vim
+%automatically, select a section then issue (gq) command. Please dont
+%apply vim formatting to the whol document as it screws up some formatting
+%rather apply it selectively to paragraphs where needed.
+% To generate the text version of this document:
+% Make sure you are in the top level code examples dir
+% since image paths are referenced from there:
+% txt2tags -t txt -o tutorial3 3_basic_labelling/tutorial3.t2t
+% To generate the moinmoin version of this document
+% txt2tags -t moin -o tutorial3.moin 3_basic_labelling/tutorial3.t2t
+% To generate the html version of this document
+% txt2tags -t html -o tutorial3.html 3_basic_labelling/tutorial3.t2t
+% End of comments
+= Working with Labels =
+[images/tim50x50.png]In my last tutorial I briefly ran through using map tools
+to facilitate user interaction with the map canvas. Today we will take a brief
+look at labelling features.
+**Updated November 2008 to use cmake build system and the updated QGIS 1.0.0 API. Tim**
+[images/tutorial3.jpg]
+Before I carry on too far, note that QGIS's automatic labelling algorithm is
+very primative. Martin Dobias is planning to implement a much more useful label
+placement routine - but its not going to be available in QGIS 0.8. For the best
+label placement results you should defined fields in your attribute table for
+position, rotation etc of the label. Since this is only intended to be a 'get
+you started' introduction, I won't be doing all that here...
+The entire project can be checked out form the QGIS Subversion repository using
+the following command:
+svn co https://svn.osgeo.org/qgis/trunk/code_examples/3_basic_labelling
+In the working directory for the tutorial code you will find a number of files
+including c++ sources, icons and a simple data file under data. There is also
+the .ui file for the main window.
+**Note:** You will need to edit the .pro file in the above svn directory to
+match your system.
+** Labelling Specifics **
+If you look in mainwindow.cpp you will notice a couple of new includes
+introduced since the last tutorial:
+ #include <qgslabel.h>
+ #include <qgslabelattributes.h>
+ #include <qgsfield.h>
+Each vector layer can have a QgsLabel associated with it. A QgsLabel is a
+renderer for labels. It has a member of type QgsLabelAttributes which
+determines the placement (above / below / left / right etc), rotation, size,
+size units (points or map units), font, colour and various other elements of
+the label. The QgsField include is needed because we will be querying the
+vector layer for its available fields so that we can determine which field
+should be used for labelling.
+In the same cpp file you will see I define a label and a label attributes
+pointer. These will be used to setup the labelling characteristics we want and
+then assigned to the layer:
+ QgsLabel * mypLabel;
+ QgsLabelAttributes * mypLabelAttributes;
+Now we will see how we actually initialise and assign the QgsLabel and the
+QgsLabelAttributes to the vector layer.
+ //set up labelling for the layer
+ //get the label instance associated with the layer
+ mypLabel = mypLayer->label();
+ //and the label attributes associated with the label
+ mypLabelAttributes = mypLabel->layerAttributes();
+Great now we have a handle on the QgsLabel and QgsLabelAttributes we can start
+to manipulate how the label will be displayed. Note that the
+mypLabel->layerAttributes() method is poorly named and will likely be changed
+(to labelAttributes()) before the final release of QGIS 1.0.
+Ok next lets ask the vector layer's data provider what attribute fields it has
+so that we can select one to be used for labelling:
+ //get the field list associated with the layer
+ //we'll print the names out to console for diagnostic purposes
+ QgsFieldMap myFields = mypLayer->dataProvider()->fields();
+ for (unsigned int i = 0; i < myFields.size(); i++ )
+ qDebug("Field Name: " + QString(myFields[i].name()).toLocal8Bit() );
+By the way - you can browse the code for field, label, label attributes etc
+from ["QGIS Source browser"
+http://trac.osgeo.org/qgis/browser/trunk/qgis/src/]. Look in the 'core' and
+'gui' subdirectories. Also for more implementation examples of how to set up
+labelling, it is worth taking a look at [qgslabeldialog.cpp
+http://trac.osgeo.org/qgis/browser/trunk/qgis/src/gui/qgslabeldialog.cpp].
+With access to the list of fields in your vector layer, you can then for
+example present the user with a combo box to select a label field. In this
+simple tutorial though I am simply going to use the last field in the attribute
+table. Its a bit of a no brainer because our attribute table only has one
+field! But at least this way its soft coded...
+ //just use the last field's name in the fields list as the label field!
+ qDebug("set label field to " + myFields[myFields.size()-1].name());
+ mypLabel->setLabelField( QgsLabel::Text, myFields.size()-1);
+There are a bunch of other things we can do to manipulate the appearance of the
+label. Lets set the text colour to black and draw a yellow 1 point 'halo'
+buffer around it so the label won't get lost when there are black features
+behind it:
+ //set the colour of the label text
+ mypLabelAttributes->setColor(Qt::black);
+ //create a 'halo' effect around each label so it
+ //can still be read on dark backgrounds
+ mypLabelAttributes->setBufferEnabled(true);
+ mypLabelAttributes->setBufferColor(Qt::yellow);
+ int myType = QgsLabelAttributes::PointUnits;
+ mypLabelAttributes->setBufferSize(1,myType);
+Finally we need to tell the layer that rendering of labels should be enabled:
+ mypLayer->enableLabels(true);
+For the absolute best labelling results, I advise you to store all the label
+properties you can inside your attribute table. Doing this will allow you to
+set rotation, placement etc on a per label basis. I left some comments in the
+tutorial source code that will get you started with this:
+ * Here are a bunch of other things you can set based on values on a database field
+ * the second parameter in each case would be the field name from which the
+ * attribute can be retrieved.
+ mypLabel->setLabelField( QgsLabel::Family, "fontFamily" );
+ mypLabel->setLabelField( QgsLabel::Bold, "fontIsBold" );
+ mypLabel->setLabelField( QgsLabel::Italic, "fontIsItalic" );
+ mypLabel->setLabelField( QgsLabel::Underline, "fontIsUnderlined" );
+ mypLabel->setLabelField( QgsLabel::Size, "fontSize" );
+ mypLabel->setLabelField( QgsLabel::BufferSize,"fontBufferSize" );
+ mypLabel->setLabelField( QgsLabel::XCoordinate, "labelX" );
+ mypLabel->setLabelField( QgsLabel::YCoordinate, "labelY");
+ mypLabel->setLabelField( QgsLabel::XOffset, "labelXOffset");
+ mypLabel->setLabelField( QgsLabel::YOffset, "labelYOffset");
+ mypLabel->setLabelField( QgsLabel::Alignment, "labelAlignment" );
+ mypLabel->setLabelField( QgsLabel::Angle, "labelAngle");
+Well that wraps up this tutorial. One thing I noticed is that the canvas is not
+refreshing properly sometimes on the mac unless you cover the application
+briefly with another window. Ill post an update here if I figure out what is
+causing this.
+You can check out and build this tutorial using SVN and CMake using the
+following steps:
+cd 3_basic_labelling
+mkdir build
+#optionally specify where your QGIS is installed (should work on all platforms)
+#if your QGIS is installed to /usr or /usr/local you can leave this next step out
+export LIB_DIR=/home/timlinux/apps
+cmake ..
+make
+./timtut3
+== Mac Specific Notes ==
+After building the application bundle (cmake; make) you can copy the spatial
+reference system database into the bundle to avoid 'cant find resource' type
+errors:
+mkdir -p qgis_example3.app/Contents/MacOS/share/qgis/resources/
+cp -r /Applications/qgis.app/Contents/MacOS/share/qgis/resources/* \
+ qgis_example3.app/Contents/MacOS/share/qgis/resources/
Property changes on: trunk/code_examples/3_basic_labelling/tutorial3.t2t
___________________________________________________________________
Modified: trunk/code_examples/generate_docs.sh
--- trunk/code_examples/generate_docs.sh 2008-11-09 09:30:50 UTC (rev 9608)
+++ trunk/code_examples/generate_docs.sh 2008-11-09 09:44:11 UTC (rev 9609)
@@ -6,4 +6,6 @@
txt2tags -t html -o index.html index.t2t
txt2tags -t html -o tutorial1.html 1_hello_world_qgis_style/tutorial1.t2t
+txt2tags -t html -o tutorial2.html 2_basic_main_window/tutorial2.t2t
+txt2tags -t html -o tutorial3.html 3_basic_labelling/tutorial3.t2
Added: trunk/code_examples/images/tutorial3.jpg
(Binary files differ)
Property changes on: trunk/code_examples/images/tutorial3.jpg
+ application/octet-stream
Modified: trunk/code_examples/index.t2t
--- trunk/code_examples/index.t2t 2008-11-09 09:30:50 UTC (rev 9608)
+++ trunk/code_examples/index.t2t 2008-11-09 09:44:11 UTC (rev 9609)
@@ -33,3 +33,4 @@
%!include: 1_hello_world_qgis_style/tutorial1.t2t
%!include: 2_basic_main_window/tutorial2.t2t
+%!include: 3_basic_labelling/tutorial3.t2t
