[QGIS Commit] r9613 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Nov 9 12:30:14 EST 2008
Author: pcav
Date: 2008-11-09 12:30:13 -0500 (Sun, 09 Nov 2008)
New Revision: 9613
Removed:
   trunk/qgis/src/plugins/grass/modules/r.bilinear.1.png
   trunk/qgis/src/plugins/grass/modules/r.bilinear.2.png
   trunk/qgis/src/plugins/grass/modules/r.bilinear.qgm
   trunk/qgis/src/plugins/grass/modules/db.connect.which.qgm
   trunk/qgis/src/plugins/grass/modules/db.select.qgm
   trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm
   trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm
   trunk/qgis/src/plugins/grass/modules/g.proj.geo.new.qgm
   trunk/qgis/src/plugins/grass/modules/g.proj.geo.qgm
   trunk/qgis/src/plugins/grass/modules/g.proj.print.qgm
   trunk/qgis/src/plugins/grass/modules/g.proj.proj.new.qgm
   trunk/qgis/src/plugins/grass/modules/g.proj.proj.qgm
   trunk/qgis/src/plugins/grass/modules/i.fft.qgm
   trunk/qgis/src/plugins/grass/modules/i.his.rgb.qgm
   trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm
   trunk/qgis/src/plugins/grass/modules/i.landsat.rgb.qgm
   trunk/qgis/src/plugins/grass/modules/i.oif.qgm
   trunk/qgis/src/plugins/grass/modules/i.tasscap4.qgm
   trunk/qgis/src/plugins/grass/modules/i.tasscap5.qgm
   trunk/qgis/src/plugins/grass/modules/i.tasscap7.qgm
   trunk/qgis/src/plugins/grass/modules/m.cogo.qgm
   trunk/qgis/src/plugins/grass/modules/nviz.qgm
   trunk/qgis/src/plugins/grass/modules/r.average.qgm
   trunk/qgis/src/plugins/grass/modules/r.basins.fill.qgm
   trunk/qgis/src/plugins/grass/modules/r.carve.qgm
   trunk/qgis/src/plugins/grass/modules/r.category.qgm
   trunk/qgis/src/plugins/grass/modules/r.coin.qgm
   trunk/qgis/src/plugins/grass/modules/r.contour.qgm
   trunk/qgis/src/plugins/grass/modules/r.contour2.qgm
   trunk/qgis/src/plugins/grass/modules/r.covar.qgm
   trunk/qgis/src/plugins/grass/modules/r.describe.qgm
   trunk/qgis/src/plugins/grass/modules/r.drain.qgm
   trunk/qgis/src/plugins/grass/modules/r.fill.dir.qgm
   trunk/qgis/src/plugins/grass/modules/r.grow.qgm
   trunk/qgis/src/plugins/grass/modules/r.his.qgm
   trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm
   trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm
   trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm
   trunk/qgis/src/plugins/grass/modules/r.in.mat.qgm
   trunk/qgis/src/plugins/grass/modules/r.in.srtm.qgm
   trunk/qgis/src/plugins/grass/modules/r.lake.seed.qgm
   trunk/qgis/src/plugins/grass/modules/r.median.qgm
   trunk/qgis/src/plugins/grass/modules/r.mode.qgm
   trunk/qgis/src/plugins/grass/modules/r.neighbors.qgm
   trunk/qgis/src/plugins/grass/modules/r.patch.qgm
   trunk/qgis/src/plugins/grass/modules/r.proj.qgm
   trunk/qgis/src/plugins/grass/modules/r.quant.qgm
   trunk/qgis/src/plugins/grass/modules/r.random.cells.qgm
   trunk/qgis/src/plugins/grass/modules/r.random.qgm
   trunk/qgis/src/plugins/grass/modules/r.reclass.area.greater.qgm
   trunk/qgis/src/plugins/grass/modules/r.reclass.area.lesser.qgm
   trunk/qgis/src/plugins/grass/modules/r.reclass.qgm
   trunk/qgis/src/plugins/grass/modules/r.recode.qgm
   trunk/qgis/src/plugins/grass/modules/r.region.alignTo.qgm
   trunk/qgis/src/plugins/grass/modules/r.region.edge.qgm
   trunk/qgis/src/plugins/grass/modules/r.region.qgm
   trunk/qgis/src/plugins/grass/modules/r.region.raster.qgm
   trunk/qgis/src/plugins/grass/modules/r.region.region.qgm
   trunk/qgis/src/plugins/grass/modules/r.region.vector.qgm
   trunk/qgis/src/plugins/grass/modules/r.report.qgm
   trunk/qgis/src/plugins/grass/modules/r.resamp.stats.qgm
   trunk/qgis/src/plugins/grass/modules/r.resample.qgm
   trunk/qgis/src/plugins/grass/modules/r.rescale.qgm
   trunk/qgis/src/plugins/grass/modules/r.slope.aspect.aspect.qgm
   trunk/qgis/src/plugins/grass/modules/r.slope.aspect.slope.qgm
   trunk/qgis/src/plugins/grass/modules/r.sum.qgm
   trunk/qgis/src/plugins/grass/modules/r.support.stats.qgm
   trunk/qgis/src/plugins/grass/modules/r.surf.area.qgm
   trunk/qgis/src/plugins/grass/modules/r.surf.contour.qgm
   trunk/qgis/src/plugins/grass/modules/r.surf.fractal.qgm
   trunk/qgis/src/plugins/grass/modules/r.surf.gauss.qgm
   trunk/qgis/src/plugins/grass/modules/r.surf.idw.qgm
   trunk/qgis/src/plugins/grass/modules/r.surf.idw2.qgm
   trunk/qgis/src/plugins/grass/modules/r.surf.random.qgm
   trunk/qgis/src/plugins/grass/modules/r.texture.bis.qgm
   trunk/qgis/src/plugins/grass/modules/r.texture.qgm
   trunk/qgis/src/plugins/grass/modules/r.topidx.qgm
   trunk/qgis/src/plugins/grass/modules/r.univar.qgm
   trunk/qgis/src/plugins/grass/modules/r.volume.qgm
   trunk/qgis/src/plugins/grass/modules/r.water.outlet.qgm
   trunk/qgis/src/plugins/grass/modules/v.clean.chdangles.qgm
   trunk/qgis/src/plugins/grass/modules/v.clean.rmdangles.qgm
   trunk/qgis/src/plugins/grass/modules/v.clean.snap.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.addcol.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.addtable.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.connect.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.dropcol.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.join.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.renamecol.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.sconnect.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.select.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.univar.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.update_const.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.update_op.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.update_op_query.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.update_query.qgm
   trunk/qgis/src/plugins/grass/modules/v.db.what.connect.qgm
   trunk/qgis/src/plugins/grass/modules/v.distance.qgm
   trunk/qgis/src/plugins/grass/modules/v.drape.qgm
   trunk/qgis/src/plugins/grass/modules/v.generalize.qgm
   trunk/qgis/src/plugins/grass/modules/v.in.region.qgm
   trunk/qgis/src/plugins/grass/modules/v.normal.qgm
   trunk/qgis/src/plugins/grass/modules/v.patch.qgm
   trunk/qgis/src/plugins/grass/modules/v.random.qgm
   trunk/qgis/src/plugins/grass/modules/v.report.qgm
   trunk/qgis/src/plugins/grass/modules/v.segment.qgm
   trunk/qgis/src/plugins/grass/modules/v.support.qgm
   trunk/qgis/src/plugins/grass/modules/v.surf.idw.qgm
   trunk/qgis/src/plugins/grass/modules/v.surf.rst.qgm
   trunk/qgis/src/plugins/grass/modules/v.univar.qgm
   trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm
Major cleanup of GRASS modules. Closing #1151
Modified: trunk/qgis/src/plugins/grass/modules/db.connect.which.qgm
--- trunk/qgis/src/plugins/grass/modules/db.connect.which.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/db.connect.which.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,6 +1,6 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Print general DB connection" module="db.connect">
+<qgisgrassmodule label="Display general DB connection" module="db.connect">
 	<flag key="p" answer="on" hidden="yes"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/db.select.qgm
--- trunk/qgis/src/plugins/grass/modules/db.select.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/db.select.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print result of SQL selection from database" module="db.select">
+<qgisgrassmodule label="Display results of SQL selection from database" module="db.select">
 	<option key="table" />
 	<option key="database" answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" />
 	<option key="driver" />
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.ascii.new.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from georeferenced ASCII file containing WKT projection description and create a new location based on it" module="g.proj">
+<qgisgrassmodule label="Display projection information from georeferenced ASCII file containing WKT projection description and create a new location based on it" module="g.proj">
 	<file key="wkt" type="old" />
 	<option key="location" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.ascii.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from georeferenced ASCII file containing WKT projection description" module="g.proj">
+<qgisgrassmodule label="Display projection information from georeferenced ASCII file containing WKT projection description" module="g.proj">
 	<flag key="p" />
 	<flag key="d" />
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.geo.new.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.geo.new.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.geo.new.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from a georeferenced file (raster, vector or image) and create a new location based on it" module="g.proj">
+<qgisgrassmodule label="Display projection information from a georeferenced file (raster, vector or image) and create a new location based on it" module="g.proj">
 	<file key="georef" type="old" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.geo.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.geo.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.geo.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from georeferenced file (raster, vector or image)" module="g.proj">
+<qgisgrassmodule label="Display projection information from georeferenced file (raster, vector or image)" module="g.proj">
 	<flag key="p" />
 	<flag key="d" />
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.print.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.print.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.print.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information of the current location" module="g.proj">
+<qgisgrassmodule label="Display projection information of the current location" module="g.proj">
 	<flag key="p" />
 	<flag key="d" />
 	<flag key="j" />
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.proj.new.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.proj.new.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.proj.new.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from PROJ.4 projection description file and create a new location based on it" module="g.proj">
+<qgisgrassmodule label="Display projection information from PROJ.4 projection description file and create a new location based on it" module="g.proj">
 	<file key="proj4" type="new"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.proj.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.proj.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.proj.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print projection information from PROJ.4 projection description file" module="g.proj">
+<qgisgrassmodule label="Display projection information from PROJ.4 projection description file" module="g.proj">
 	<flag key="p" />
 	<flag key="d" />
 	<flag key="j" />
Modified: trunk/qgis/src/plugins/grass/modules/i.fft.qgm
--- trunk/qgis/src/plugins/grass/modules/i.fft.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/i.fft.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Fast Fourier Transform (FFT) for image processing" module="i.fft">
+<qgisgrassmodule label="Fast fourier transform for image processing" module="i.fft">
 	<option key="input_image" />
 	<option key="real_image" />
 	<option key="imaginary_image" />
Modified: trunk/qgis/src/plugins/grass/modules/i.his.rgb.qgm
--- trunk/qgis/src/plugins/grass/modules/i.his.rgb.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/i.his.rgb.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Hue Intensity Saturation (HIS) to Red Green Blue (RGB) raster map color transform function" module="i.his.rgb">
+<qgisgrassmodule label="Hue Intensity Saturation (HIS) to Red Green Blue (RGB) raster color transform function" module="i.his.rgb">
 	<option key="hue_input" />
 	<option key="intensity_input" />
 	<option key="saturation_input" />
Modified: trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm
--- trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/i.in.spotvgt.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import SPOT VGT NDVI to GRASS raster" module="i.in.spotvgt">
+<qgisgrassmodule label="Import SPOT VGT NDVI" module="i.in.spotvgt">
 	<file key="file" type="new" />
 	<flag key="a" />
 	<option key="rast" />
Modified: trunk/qgis/src/plugins/grass/modules/i.landsat.rgb.qgm
--- trunk/qgis/src/plugins/grass/modules/i.landsat.rgb.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/i.landsat.rgb.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Auto-balancing of colors for LANDSAT images" module="i.landsat.rgb">
+<qgisgrassmodule label="Auto-balancing of colors for LANDSAT-TM raster" module="i.landsat.rgb">
 	<option key="red" />
 	<option key="green" />
 	<option key="blue" />
Modified: trunk/qgis/src/plugins/grass/modules/i.oif.qgm
--- trunk/qgis/src/plugins/grass/modules/i.oif.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/i.oif.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates optimal index factor table for landsat tm bands" module="i.oif">
+<qgisgrassmodule label="Calculate optimal index factor table for LANDSAT-TM raster" module="i.oif">
 	<option key="image1" />
 	<option key="image2" />
 	<option key="image3" />
Modified: trunk/qgis/src/plugins/grass/modules/i.tasscap4.qgm
--- trunk/qgis/src/plugins/grass/modules/i.tasscap4.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/i.tasscap4.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 4 data" module="i.tasscap">
+<qgisgrassmodule label="Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 4 raster" module="i.tasscap">
 	<flag key="4" />
 	<option key="band1" />
 	<option key="band2" />
Modified: trunk/qgis/src/plugins/grass/modules/i.tasscap5.qgm
--- trunk/qgis/src/plugins/grass/modules/i.tasscap5.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/i.tasscap5.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 5 data" module="i.tasscap">
+<qgisgrassmodule label="Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 5 raster" module="i.tasscap">
 	<flag key="5" />
Modified: trunk/qgis/src/plugins/grass/modules/i.tasscap7.qgm
--- trunk/qgis/src/plugins/grass/modules/i.tasscap7.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/i.tasscap7.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 7 data" module="i.tasscap">
+<qgisgrassmodule label="Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM 7 raster" module="i.tasscap">
 	<flag key="7" />
Modified: trunk/qgis/src/plugins/grass/modules/m.cogo.qgm
--- trunk/qgis/src/plugins/grass/modules/m.cogo.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/m.cogo.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Converting bearing and distance measurements to coordinates and vice versa" module="m.cogo">
+<qgisgrassmodule label="Convert bearing and distance measurements to coordinates and vice versa" module="m.cogo">
 	<file key="input" type="old" />
 	<option key="coord" />
 	<flag key="r" />
Modified: trunk/qgis/src/plugins/grass/modules/nviz.qgm
--- trunk/qgis/src/plugins/grass/modules/nviz.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/nviz.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Open 3D-View in NVIZ" module="nviz">
+<qgisgrassmodule label="3D-Viewer (NVIZ)" module="nviz">
 	<option key="elevation" />
 	<option key="color" />
 	<option key="vector" />
Modified: trunk/qgis/src/plugins/grass/modules/r.average.qgm
--- trunk/qgis/src/plugins/grass/modules/r.average.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.average.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Find average values in a cover map within areas with the same category in a user-defined base map" module="r.average">
+<qgisgrassmodule label="Calculate average of raster within areas with the same category in a user-defined base map" module="r.average">
 	<option key="base" />
 	<option key="cover" />
 	<flag key="c" />
Modified: trunk/qgis/src/plugins/grass/modules/r.basins.fill.qgm
--- trunk/qgis/src/plugins/grass/modules/r.basins.fill.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.basins.fill.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate raster showing watershed subbasins" module="r.basins.fill">
+<qgisgrassmodule label="Crate watershed subbasins raster" module="r.basins.fill">
 	<option key="number" />
 	<option key="c_map" />
 	<option key="t_map" />
Deleted: trunk/qgis/src/plugins/grass/modules/r.bilinear.1.png
(Binary files differ)
Deleted: trunk/qgis/src/plugins/grass/modules/r.bilinear.2.png
Deleted: trunk/qgis/src/plugins/grass/modules/r.bilinear.qgm
--- trunk/qgis/src/plugins/grass/modules/r.bilinear.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.bilinear.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Bilinear interpolation utility for rasters" module="r.bilinear">
-	<option key="input" />
-	<option key="output" />
-</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.carve.qgm
--- trunk/qgis/src/plugins/grass/modules/r.carve.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.carve.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Takes vector stream data, transforms it to raster, and subtracts depth from the output DEM" module="r.carve">
+<qgisgrassmodule label="Take vector stream data, transform it to raster, and subtract depth from the output DEM" module="r.carve">
 	<option key="vect" />
 	<option key="width" />
Modified: trunk/qgis/src/plugins/grass/modules/r.category.qgm
--- trunk/qgis/src/plugins/grass/modules/r.category.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.category.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Print category values and labels associated with user-defined rasters" module="r.category">
+<qgisgrassmodule label="Display raster category values and labels" module="r.category">
 	<option key="map" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.coin.qgm
--- trunk/qgis/src/plugins/grass/modules/r.coin.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.coin.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Tabulates the mutual occurrence (coincidence) of categories for two rasters" module="r.coin">
+<qgisgrassmodule label="Tabulate mutual occurrence (coincidence) of categories for two rasters" module="r.coin">
 	<option key="map1" />
 	<option key="map2" />
 	<option key="units" />
Modified: trunk/qgis/src/plugins/grass/modules/r.contour.qgm
--- trunk/qgis/src/plugins/grass/modules/r.contour.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.contour.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Produce contour vector at specified step from raster" module="r.contour">
+<qgisgrassmodule label="Create vector contour from rater at specified steps" module="r.contour">
 	<option key="step"/>
 	<option key="minlevel" answer="0" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.contour2.qgm
--- trunk/qgis/src/plugins/grass/modules/r.contour2.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.contour2.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Produce contour vector at specified levels from raster" module="r.contour">
+<qgisgrassmodule label="Create vector contour from raster at specified levels" module="r.contour">
 	<option key="levels" />
Modified: trunk/qgis/src/plugins/grass/modules/r.covar.qgm
--- trunk/qgis/src/plugins/grass/modules/r.covar.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.covar.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Output covariance/correlation matrix for user-defined raster(s)" module="r.covar">
+<qgisgrassmodule label="Calculate covariance/correlation matrix for user-defined rasters" module="r.covar">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.describe.qgm
--- trunk/qgis/src/plugins/grass/modules/r.describe.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.describe.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Print list of category values found in raster" module="r.describe">
+<qgisgrassmodule label="Display list of category values found in raster" module="r.describe">
 	<flag key="1" />
 	<flag key="r" />
 	<flag key="d" />
Modified: trunk/qgis/src/plugins/grass/modules/r.drain.qgm
--- trunk/qgis/src/plugins/grass/modules/r.drain.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.drain.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Traces a flow through an elevation model" module="r.drain">
+<qgisgrassmodule label="Trace a flow through an elevation model" module="r.drain">
 	<option key="input"/>
 	<option key="output"/>
 	<option key="coordinate"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.fill.dir.qgm
--- trunk/qgis/src/plugins/grass/modules/r.fill.dir.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.fill.dir.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Filter and generate depressionless elevation map and flow direction map from elevation raster" module="r.fill.dir">
+<qgisgrassmodule label="Filter and create depressionless elevation map and flow direction map from elevation raster" module="r.fill.dir">
 	<option key="type" answer="grass" hidden="yes"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.grow.qgm
--- trunk/qgis/src/plugins/grass/modules/r.grow.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.grow.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate raster with contiguous areas grown by one cell" module="r.grow">
+<qgisgrassmodule label="Create raster with contiguous areas grown by one cell" module="r.grow">
 	<option key="new"/>
 	<option key="metric"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.his.qgm
--- trunk/qgis/src/plugins/grass/modules/r.his.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.his.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate red, green and blue rasters combining hue, intensity, and saturation (his) values from user-defined input rasters" module="r.his">
+<qgisgrassmodule label="Create red, green and blue rasters combining hue, intensity, and saturation (his) values from rasters" module="r.his">
 	<option key="h_map"/>
 	<option key="i_map"/>
 	<option key="s_map"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.in.arc.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import ESRI ARC/INFO ASCII raster (GRID) to GRASS raster" module="r.in.arc">
+<qgisgrassmodule label="Import ESRI ARC/INFO ASCII GRID" module="r.in.arc">
 	<option key="type" />
 	<option key="mult" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.in.ascii.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import ASCII raster to GRASS raster" module="r.in.ascii">
+<qgisgrassmodule label="Import ASCII raster" module="r.in.ascii">
 	<option key="nv" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.loc.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import GDAL supported raster to GRASS raster and create fitted location" module="r.in.gdal">
+<qgisgrassmodule label="Import GDAL supported raster and create fitted location" module="r.in.gdal">
 	<flag key="o" answer="off" hidden="yes" />
 	<flag key="e" answer="on" hidden="yes" />
 	<file key="input" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import GDAL supported raster to GRASS raster" module="r.in.gdal">
+<qgisgrassmodule label="Import GDAL supported raster" module="r.in.gdal">
 	<flag key="o" answer="on" hidden="yes" />
 	<flag key="e" answer="off" hidden="yes" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gridatb.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import GRIDATB.FOR map file (TOPMODEL) to GRASS raster" module="r.in.gridatb">
+<qgisgrassmodule label="Import GRIDATB.FOR (TOPMODEL)" module="r.in.gridatb">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.mat.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.mat.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.in.mat.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import binary MAT-File(v4) to GRASS raster" module="r.in.mat">
+<qgisgrassmodule label="Import binary MAT-File(v4)" module="r.in.mat">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.in.srtm.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.srtm.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.in.srtm.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import SRTM HGT files to GRASS raster" module="r.in.srtm">
+<qgisgrassmodule label="Import SRTM HGT" module="r.in.srtm">
 	<flag key="1" />
Modified: trunk/qgis/src/plugins/grass/modules/r.lake.seed.qgm
--- trunk/qgis/src/plugins/grass/modules/r.lake.seed.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.lake.seed.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Fills lake from seed at given level" module="r.lake">
+<qgisgrassmodule label="Fill lake from seed at given level" module="r.lake">
 	<option key="dem" />
 	<option key="seed" />
 	<option key="wl" />
Modified: trunk/qgis/src/plugins/grass/modules/r.median.qgm
--- trunk/qgis/src/plugins/grass/modules/r.median.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.median.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Find median of values in a cover map within areas with the same category in a user-defined base map" module="r.median">
+<qgisgrassmodule label="Calculate median of raster within areas with the same category in a user-defined base map" module="r.median">
Modified: trunk/qgis/src/plugins/grass/modules/r.mode.qgm
--- trunk/qgis/src/plugins/grass/modules/r.mode.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.mode.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Find the mode of values in a cover map within areas with the same category in a user-defined base map" module="r.mode">
+<qgisgrassmodule label="Calculate mode of raster within areas with the same category in a user-defined base map" module="r.mode">
Modified: trunk/qgis/src/plugins/grass/modules/r.neighbors.qgm
--- trunk/qgis/src/plugins/grass/modules/r.neighbors.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.neighbors.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -2,7 +2,7 @@
 <!-- TODO: this is bad -->
-<qgisgrassmodule label="Raster neighbors analysis" module="r.neighbors">
+<qgisgrassmodule label="Raster neighbours analysis" module="r.neighbors">
 	<option key="method"/>
 	<option key="size"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.patch.qgm
--- trunk/qgis/src/plugins/grass/modules/r.patch.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.patch.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Create a new raster by combining other rasters" module="r.patch">
+<qgisgrassmodule label="Create new raster by combining other rasters" module="r.patch">
 	<flag key="z" answer="off" hidden="no" />
 	<file key="input" label="Type in map names separated by a comma" />
Modified: trunk/qgis/src/plugins/grass/modules/r.proj.qgm
--- trunk/qgis/src/plugins/grass/modules/r.proj.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.proj.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Re-project a raster from a location to the current location" module="r.proj">
+<qgisgrassmodule label="Re-project raster from a location to the current location" module="r.proj">
 	<option key="dbase"/>
 	<option key="location"/>
Modified: trunk/qgis/src/plugins/grass/modules/r.quant.qgm
--- trunk/qgis/src/plugins/grass/modules/r.quant.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.quant.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="This routine produces the quantization file for a floating-point map" module="r.quant">
+<qgisgrassmodule label="Craete quantization file for floating-point raster" module="r.quant">
 	<option key="basemap" />
 	<option key="fprange" />
Modified: trunk/qgis/src/plugins/grass/modules/r.random.cells.qgm
--- trunk/qgis/src/plugins/grass/modules/r.random.cells.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.random.cells.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generates random cell values with spatial dependence" module="r.random.cells">
+<qgisgrassmodule label="Create random cell values with spatial dependence" module="r.random.cells">
 	<option key="distance" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.random.qgm
--- trunk/qgis/src/plugins/grass/modules/r.random.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.random.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Creates a random vector point map contained in a raster" module="r.random">
+<qgisgrassmodule label="Create random vector point contained in raster" module="r.random">
 	<option key="n" answer="1" hidden="no"/>
 	<option key="vector_output" />
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.area.greater.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.area.greater.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.area.greater.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reclassify raster map with patches larger than user-defined area size (in hectares)" module="r.reclass.area">
+<qgisgrassmodule label="Reclassify raster with patches larger than user-defined area size (in hectares)" module="r.reclass.area">
 	<option key="greater" />
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.area.lesser.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.area.lesser.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.area.lesser.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reclassify raster map with patches smaller than user-defined area size (in hectares)" module="r.reclass.area">
+<qgisgrassmodule label="Reclassify raster with patches smaller than user-defined area size (in hectares)" module="r.reclass.area">
 	<option key="lesser" />
Modified: trunk/qgis/src/plugins/grass/modules/r.reclass.qgm
--- trunk/qgis/src/plugins/grass/modules/r.reclass.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.reclass.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reclass a raster using a reclassification rules file" module="r.reclass">
+<qgisgrassmodule label="Reclass raster using reclassification rules" module="r.reclass">
 	<file key="rules" type="old" />
Modified: trunk/qgis/src/plugins/grass/modules/r.recode.qgm
--- trunk/qgis/src/plugins/grass/modules/r.recode.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.recode.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Recode a categorical raster using a reclassification rules file" module="r.recode">
+<qgisgrassmodule label="Recode categorical raster using reclassification rules" module="r.recode">
 	<file key="rules" type="old" filters="Txt (*.txt), Csv (*.csv)" />
Modified: trunk/qgis/src/plugins/grass/modules/r.region.alignTo.qgm
--- trunk/qgis/src/plugins/grass/modules/r.region.alignTo.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.region.alignTo.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sets region to align to a raster" module="r.region">
+<qgisgrassmodule label="Set region to align to raster" module="r.region">
 	<option key="align" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.region.edge.qgm
--- trunk/qgis/src/plugins/grass/modules/r.region.edge.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.region.edge.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sets the boundary definitions by edge (n-s-e-w)" module="r.region">
+<qgisgrassmodule label="Set boundary definitions by edge (n-s-e-w)" module="r.region">
 	<option key="n" />
 	<option key="s" />
Modified: trunk/qgis/src/plugins/grass/modules/r.region.qgm
--- trunk/qgis/src/plugins/grass/modules/r.region.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.region.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,9 +1,9 @@
-<qgisgrassmodule label="Sets the boundary definitions for a raster map" module="r.region">
+<qgisgrassmodule label="Set boundary definitions for raster" module="r.region">
 	<flag key="c" />
-	<flag key="d" />
+	<flag key="d" />
 	<option key="region" />
 	<option key="raster" />
Modified: trunk/qgis/src/plugins/grass/modules/r.region.raster.qgm
--- trunk/qgis/src/plugins/grass/modules/r.region.raster.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.region.raster.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sets the boundary definitions from existent raster map" module="r.region">
+<qgisgrassmodule label="Set boundary definitions from raster" module="r.region">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.region.region.qgm
--- trunk/qgis/src/plugins/grass/modules/r.region.region.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.region.region.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sets the boundary definitions to current or default region" module="r.region">
+<qgisgrassmodule label="Set boundary definitions to current or default region" module="r.region">
 	<flag key="c" />
 	<flag key="d" />
Modified: trunk/qgis/src/plugins/grass/modules/r.region.vector.qgm
--- trunk/qgis/src/plugins/grass/modules/r.region.vector.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.region.vector.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Sets boundary definitions from vector" module="r.region">
+<qgisgrassmodule label="Set boundary definitions from vector" module="r.region">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.report.qgm
--- trunk/qgis/src/plugins/grass/modules/r.report.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.report.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reports statistics for raster" module="r.report">
+<qgisgrassmodule label="Calculate statistics for raster" module="r.report">
 	<option key="units"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.resamp.stats.qgm
--- trunk/qgis/src/plugins/grass/modules/r.resamp.stats.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.resamp.stats.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Resamples raster using aggregation" module="r.resamp.stats">
+<qgisgrassmodule label="Resample raster using aggregation" module="r.resamp.stats">
 	<option key="method" />
Modified: trunk/qgis/src/plugins/grass/modules/r.resample.qgm
--- trunk/qgis/src/plugins/grass/modules/r.resample.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.resample.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Raster data resampling. Set new resolution first" module="r.resample">
+<qgisgrassmodule label="Resample raster. Set new resolution first" module="r.resample">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.rescale.qgm
--- trunk/qgis/src/plugins/grass/modules/r.rescale.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.rescale.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Rescale the range of category values in a raster" module="r.rescale">
+<qgisgrassmodule label="Rescale the range of category values in raster" module="r.rescale">
 	<option key="from" />
 	<option key="to" />
Modified: trunk/qgis/src/plugins/grass/modules/r.slope.aspect.aspect.qgm
--- trunk/qgis/src/plugins/grass/modules/r.slope.aspect.aspect.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.slope.aspect.aspect.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate aspect map from DEM (digital elevation model)" module="r.slope.aspect">
+<qgisgrassmodule label="Create aspect raster from DEM (digital elevation model)" module="r.slope.aspect">
 	<option key="aspect" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.slope.aspect.slope.qgm
--- trunk/qgis/src/plugins/grass/modules/r.slope.aspect.slope.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.slope.aspect.slope.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate slope raster from DEM (digital elevation model)" module="r.slope.aspect">
+<qgisgrassmodule label="Create slope raster from DEM (digital elevation model)" module="r.slope.aspect">
 	<option key="slope" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.sum.qgm
--- trunk/qgis/src/plugins/grass/modules/r.sum.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.sum.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Sums up the raster cell values" module="r.sum">
+<qgisgrassmodule label="Sum raster cell values" module="r.sum">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.support.stats.qgm
--- trunk/qgis/src/plugins/grass/modules/r.support.stats.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.support.stats.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Update raster map statistics" module="r.support.stats">
+<qgisgrassmodule label="Update raster statistics" module="r.support.stats">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.area.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.area.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.area.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Surface area estimation for rasters" module="r.surf.area">
+<qgisgrassmodule label="Calculate raster surface area" module="r.surf.area">
 	<option key="vscale" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.contour.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.contour.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.contour.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Surface generation program from rasterized contours" module="r.surf.contour">
+<qgisgrassmodule label="Genearate surface from rasterized contours" module="r.surf.contour">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.fractal.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.fractal.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.fractal.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Creates a fractal surface of a given fractal dimension" module="r.surf.fractal">
+<qgisgrassmodule label="Create fractal surface of given fractal dimension" module="r.surf.fractal">
 	<option key="d" />
 	<option key="n" />
 	<option key="out" />
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.gauss.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.gauss.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.gauss.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Produce raster of gaussian deviates with user-defined mean and standard deviation" module="r.surf.gauss">
+<qgisgrassmodule label="Create raster of gaussian deviates with user-defined mean and standard deviation" module="r.surf.gauss">
 	<option key="mean" />
 	<option key="sigma" />
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.idw.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.idw.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.idw.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Surface interpolation utility for raster" module="r.surf.idw">
+<qgisgrassmodule label="Inverse distance squared weighting raster interpolation" module="r.surf.idw">
 	<option key="npoints" />
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.idw2.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.idw2.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.idw2.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Surface generation program" module="r.surf.idw2">
+<qgisgrassmodule label="Inverse distance squared weighting raster interpolation" module="r.surf.idw2">
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.random.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.random.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.random.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Produce raster of uniform random deviates with user-defined range" module="r.surf.random">
+<qgisgrassmodule label="Create raster of uniform random deviates with user-defined range" module="r.surf.random">
 	<option key="min" />
 	<option key="max" />
Modified: trunk/qgis/src/plugins/grass/modules/r.texture.bis.qgm
--- trunk/qgis/src/plugins/grass/modules/r.texture.bis.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.texture.bis.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate images with textural features from raster (second serie of indices)" module="r.texture">
+<qgisgrassmodule label="Create raster with textural features from raster (second serie of indices)" module="r.texture">
 	<option key="size" answer="3" />
 	<option key="distance" answer="1" />
Modified: trunk/qgis/src/plugins/grass/modules/r.texture.qgm
--- trunk/qgis/src/plugins/grass/modules/r.texture.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.texture.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Generate images with textural features from raster (first serie of indices)" module="r.texture">
+<qgisgrassmodule label="Create raster images with textural features from raster (first serie of indices)" module="r.texture">
 	<option key="size" />
Modified: trunk/qgis/src/plugins/grass/modules/r.topidx.qgm
--- trunk/qgis/src/plugins/grass/modules/r.topidx.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.topidx.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Creates a 3D volume map based on 2D elevation and value rasters" module="r.topidx">
+<qgisgrassmodule label="Create 3D volume map based on 2D elevation and value rasters" module="r.topidx">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.univar.qgm
--- trunk/qgis/src/plugins/grass/modules/r.univar.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.univar.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Calculates univariate statistics from the non-null cells of a raster map" module="r.univar">
+<qgisgrassmodule label="Calculate univariate statistics from the non-null cells of raster" module="r.univar">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/r.volume.qgm
--- trunk/qgis/src/plugins/grass/modules/r.volume.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.volume.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculate volume of data clumps, and produces a vector with centroids of clumps" module="r.volume">
+<qgisgrassmodule label="Calculate volume of data clumps, and create vector with centroids of clumps" module="r.volume">
 	<flag key="f" />
 	<option key="data" />
 	<option key="clump" />
Modified: trunk/qgis/src/plugins/grass/modules/r.water.outlet.qgm
--- trunk/qgis/src/plugins/grass/modules/r.water.outlet.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/r.water.outlet.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Watershed basin creation program" module="r.water.outlet">
+<qgisgrassmodule label="Create watershed basin" module="r.water.outlet">
 	<option key="drainage" />
 	<option key="easting" />
 	<option key="northing" />
Modified: trunk/qgis/src/plugins/grass/modules/v.clean.chdangles.qgm
--- trunk/qgis/src/plugins/grass/modules/v.clean.chdangles.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.clean.chdangles.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Cleaning topology: change the type of boundary dangle to line" module="v.clean">
+<qgisgrassmodule label="Change the type of boundary dangle to line" module="v.clean">
 	<option key="input" typemask="area"/>
 	<option key="tool" answer="chdangle" hidden="yes"/>
 	<option key="thresh"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.clean.rmdangles.qgm
--- trunk/qgis/src/plugins/grass/modules/v.clean.rmdangles.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.clean.rmdangles.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Cleaning topology: remove dangles" module="v.clean">
+<qgisgrassmodule label="Remove dangles" module="v.clean">
 	<option key="input" typeoption="type"/>
 	<option key="tool" answer="rmdangle" hidden="yes"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.clean.snap.qgm
--- trunk/qgis/src/plugins/grass/modules/v.clean.snap.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.clean.snap.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Cleaning topology: snap lines to vertex in threshold" module="v.clean">
+<qgisgrassmodule label="Snap lines to vertex in threshold" module="v.clean">
 	<option key="tool" answer="snap" hidden="yes"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.addcol.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.addcol.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.addcol.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Adds one or more columns to the attribute table connected to a given vector map" module="v.db.addcol">
+<qgisgrassmodule label="Add one or more columns to attribute table" module="v.db.addcol">
 	<option key="map" layeroption="layer" />
 	<option key="columns"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.addtable.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.addtable.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.addtable.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Create and add a new table to a vector" module="v.db.addtable">
+<qgisgrassmodule label="Create and add new table to vector" module="v.db.addtable">
 	<option key="map" layeroption="layer"/>
 	<option key="table"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.connect.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.connect.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.connect.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Connect a vector to database" module="v.db.connect">
+<qgisgrassmodule label="Connect vector to database" module="v.db.connect">
 	<option key="driver" answer="dbf" hidden="no"/>
 	<option key="database" answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.dropcol.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.dropcol.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.dropcol.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Drops a column from the attribute table connected to a given vector map" module="v.db.dropcol">
+<qgisgrassmodule label="Drop column from attribute table" module="v.db.dropcol">
 	<field key="column" layer="map" label="Attribute field"  type="integer,double,varchar,string"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.droptable.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Remove existing attribute table of a vector map" module="v.db.droptable">
+<qgisgrassmodule label="Remove existing attribute table of vector" module="v.db.droptable">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.join.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.join.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.join.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Join table to vector table" module="v.db.join">
+<qgisgrassmodule label="Join table to existing vector table" module="v.db.join">
 	<field key="column" layer="map" type="integer,string" label="Attribute field" />
 	<option key="otable"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.renamecol.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.renamecol.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.renamecol.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Renames a column in a attribute table connected to a given vector map" module="v.db.renamecol">
+<qgisgrassmodule label="Rename column in attribute table" module="v.db.renamecol">
 	<option key="column"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.sconnect.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.sconnect.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.sconnect.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Disconnect a vector from database" module="v.db.connect">
+<qgisgrassmodule label="Disconnect vector from database" module="v.db.connect">
 	<flag key="d" answer="on" hidden="yes"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.select.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.select.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.select.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Prints vector map attribute" module="v.db.select">
+<qgisgrassmodule label="Display vector attributes" module="v.db.select">
 	<field key="column" layer="map" type="integer,double,varchar"/>
 	<option key="fs" answer="|" hidden="yes" />
Modified: trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Prints vector map attributes with SQL" module="v.db.select">
+<qgisgrassmodule label="Display vector map attributes with SQL" module="v.db.select">
 	<option key="where" />
Modified: trunk/qgis/src/plugins/grass/modules/v.db.univar.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.univar.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.univar.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates univariate statistics on selected table column for a vector" module="v.db.univar">
+<qgisgrassmodule label="Calculate univariate statistics for numeric attributes in a data table" module="v.db.univar">
 	<field key="column" layer="table" type="integer,double" label="Attribute field" />
 	<flag key="e" answer="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.update_const.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.update_const.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.update_const.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Assign a constant value to a column" module="v.db.update">
+<qgisgrassmodule label="Assign constant value to column" module="v.db.update">
 	<field key="column" layer="map" type="integer,double,varchar,string" label="Attribute field" />
 	<option key="value"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.update_op.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.update_op.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.update_op.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Assign a new value, result of operation on column/s, to a column in the attribute table" module="v.db.update">
+<qgisgrassmodule label="Assign new value as result of operation on columns to column in attribute table" module="v.db.update">
 	<option key="qcolumn" />
Modified: trunk/qgis/src/plugins/grass/modules/v.db.update_op_query.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.update_op_query.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.update_op_query.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Assign a new value to a column, result of operation on column/s, only if the result of a query is TRUE" module="v.db.update">
+<qgisgrassmodule label="Assign new value to column as result of operation on columns only if the result of query is TRUE" module="v.db.update">
Modified: trunk/qgis/src/plugins/grass/modules/v.db.update_query.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.update_query.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.update_query.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Assign a new constant value to a column only if the result of a query is TRUE" module="v.db.update">
+<qgisgrassmodule label="Assign new constant value to column only if the result of query is TRUE" module="v.db.update">
Modified: trunk/qgis/src/plugins/grass/modules/v.db.what.connect.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.what.connect.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.db.what.connect.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Set/Show database connection for a vector" module="v.db.connect">
+<qgisgrassmodule label="Set/Show database connection for vector" module="v.db.connect">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.distance.qgm
--- trunk/qgis/src/plugins/grass/modules/v.distance.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.distance.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Find the nearest element in vector 'to' for elements in vector 'from'. Various information about this relation may be uploaded to the attribute table of input vector 'from'" module="v.distance">
+<qgisgrassmodule label="Find nearest element in vector 'to' for elements in vector 'from'. Various information about this relation may be uploaded to attribute table of input vector 'from'" module="v.distance">
 	<option key="from" typemask="point" layeroption="from_layer"/>
 	<option key="to" typeoption="to_type" layeroption="to_layer"/>
 	<option key="upload"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.drape.qgm
--- trunk/qgis/src/plugins/grass/modules/v.drape.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.drape.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert 2D vector to 3D vector by sampling of elevation raster. Default sampling by nearest neighbor" module="v.drape">
+<qgisgrassmodule label="Convert 2D vector to 3D vector by sampling of elevation raster. Default sampling by nearest neighbour" module="v.drape">
Modified: trunk/qgis/src/plugins/grass/modules/v.generalize.qgm
--- trunk/qgis/src/plugins/grass/modules/v.generalize.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.generalize.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Vector based generalization" module="v.generalize">
+<qgisgrassmodule label="Simplify vector" module="v.generalize">
 	<option key="input" typeoption="type" layeroption="layer" />
 	<option key="threshold" ansewr="1.0" />
Modified: trunk/qgis/src/plugins/grass/modules/v.in.region.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.region.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.in.region.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,6 +1,6 @@
-<qgisgrassmodule label="Create new vector area map with current region extent" module="v.in.region">
+<qgisgrassmodule label="Create new vector with current region extent" module="v.in.region">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.normal.qgm
--- trunk/qgis/src/plugins/grass/modules/v.normal.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.normal.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Tests for normality for points" module="v.normal">
+<qgisgrassmodule label="Tests of normality on vector points" module="v.normal">
 	<option key="map" typemask="point" />
 	<field key="column" layer="input" type="integer,double" label="Attribute field" />
 	<option key="tests" answer="1-1000000" hidden="yes" />
Modified: trunk/qgis/src/plugins/grass/modules/v.patch.qgm
--- trunk/qgis/src/plugins/grass/modules/v.patch.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.patch.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,9 +1,9 @@
-<qgisgrassmodule label="Create a new vector by combining other vectors" module="v.patch">
+<qgisgrassmodule label="Create new vector by combining other vectors" module="v.patch">
 	<flag key="a" answer="off" hidden="no" />
-	<flag key="e" answer="off" hidden="no" label="Copy also the attribute table (only the table of layer 1 is currently supported)" />
+	<flag key="e" answer="off" hidden="no" label="Copy also attribute table (only the table of layer 1 is currently supported)" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.random.qgm
--- trunk/qgis/src/plugins/grass/modules/v.random.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.random.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Randomly generate 2D/3D vector points" module="v.random">
+<qgisgrassmodule label="Create random 2D/3D vector points" module="v.random">
 	<option key="zmin" answer="0.0" hidden="no"/>
 	<option key="zmax" answer="0.0" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.report.qgm
--- trunk/qgis/src/plugins/grass/modules/v.report.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.report.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reports geometry statistics for vectors" module="v.report">
+<qgisgrassmodule label="Calculate geometry statistics for vectors" module="v.report">
 	<option key="map" masktype="area" layeroption="layer" />
 	<option key="option" />
 	<option key="units" answer="h" hidden="no"/>
Modified: trunk/qgis/src/plugins/grass/modules/v.segment.qgm
--- trunk/qgis/src/plugins/grass/modules/v.segment.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.segment.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Creates points/segments from input vector lines and positions" module="v.segment">
+<qgisgrassmodule label="Create points/segments from input vector lines and positions" module="v.segment">
 	<option key="input" layeroption="llayer" typemask="line,boundary"/>
 	<file key="file" type="old" filters="Txt (*.txt), Csv (*.csv)" />
Modified: trunk/qgis/src/plugins/grass/modules/v.support.qgm
--- trunk/qgis/src/plugins/grass/modules/v.support.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.support.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Updates vector map metadata" module="v.support">
+<qgisgrassmodule label="Update vector map metadata" module="v.support">
 	<option key="organization" />
 	<option key="date" />
Modified: trunk/qgis/src/plugins/grass/modules/v.surf.idw.qgm
--- trunk/qgis/src/plugins/grass/modules/v.surf.idw.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.surf.idw.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Interpolate attribute values (IDW)" module="v.surf.idw">
+<qgisgrassmodule label="Inverse distance squared weighting raster interpolation based on vector points" module="v.surf.idw">
 	<option key="input" layeroption="layer" typemask="point,line" id="input" />
 	<field key="column" layerid="input" type="integer,double" label="Attribute field (interpolated values)" />
Modified: trunk/qgis/src/plugins/grass/modules/v.surf.rst.qgm
--- trunk/qgis/src/plugins/grass/modules/v.surf.rst.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.surf.rst.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Interpolate attribute values (RST)" module="v.surf.rst">
+<qgisgrassmodule label="Regularized spline with tension raster interpolation based on vector points" module="v.surf.rst">
 	<field key="zcolumn" layerid="input" type="integer,double" label="Attribute field (interpolated values)" />
 	<option key="tension" />
Modified: trunk/qgis/src/plugins/grass/modules/v.univar.qgm
--- trunk/qgis/src/plugins/grass/modules/v.univar.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.univar.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Calculates univariate statistics on selected table column for a vector" module="v.univar">
+<qgisgrassmodule label="Calculate univariate statistics of vector map features" module="v.univar">
 	<option key="map" typeoption="type"/>
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm
--- trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm	2008-11-09 17:24:10 UTC (rev 9612)
+++ trunk/qgis/src/plugins/grass/modules/v.what.vect.qgm	2008-11-09 17:30:13 UTC (rev 9613)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Uploads vector values at positions of vector points to the table" module="v.what.vect">
+<qgisgrassmodule label="Upload vector values at positions of vector points" module="v.what.vect">
 	<option key="vector" layeroption="layer" typemask="point"/>
 	<field key="column" layer="vector" type="integer,double,string"/>
 	<option key="qvector" layeroption="layer" typemask="area"/>
More information about the QGIS-commit mailing list
