[QGIS Commit] r9615 - trunk/qgis/doc
svn_qgis at osgeo.org
Mon Nov 10 07:07:34 EST 2008
Author: jef
Date: 2008-11-10 07:07:34 -0500 (Mon, 10 Nov 2008)
New Revision: 9615
trunk/qgis/doc/INSTALL.t2t
added debian package section
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t 2008-11-10 08:04:49 UTC (rev 9614)
+++ trunk/qgis/doc/INSTALL.t2t 2008-11-10 12:07:34 UTC (rev 9615)
@@ -912,6 +912,8 @@
== Starting the compile ==
+/!\ ***Note:*** The next section describes howto build debian packages
I compile my development version of QGIS into my ~/apps directory to avoid
conflicts with Ubuntu packages that may be under /usr. This way for example
you can use the binary packages of QGIS on your system along side with your
@@ -950,6 +952,43 @@
It may take a little while to build depending on your platform.
+== Building Debian packages ==
+Instead of creating a personal installation as in the previous step you can
+also create debian package. This is done from the qgis root directory, where
+you'll find a debian directory.
+First you need to install the debian packaging tools once:
+apt-get install build-essential
+The QGIS packages will be created with:
+dpkg-buildpackage -us -us -b
+/!\ ***Note:*** If ``dpkg-buildpackage`` complains about unmet build dependencies
+you can install them using ``apt-get`` and re-run the command.
+/!\ ***Note:*** If you have ``libqgis1-dev`` installed, you need to remove it first
+using ``dpkg -r libqgis1-dev``. Otherwise ``dpkg-buildpackage`` will complain about at
+build conflict.
+The the packages are created in the parent directory (ie. one level up).
+Install them using dpkg. E.g.:
+sudo dpkg -i \
+ ../qgis_1.0preview16_amd64.deb \
+ ../libqgis-gui1_1.0preview16_amd64.deb \
+ ../libqgis-core1_1.0preview16_amd64.deb \
+ ../qgis-plugin-grass_1.0preview16_amd64.deb \
+ ../python-qgis_1.0preview16_amd64.deb
== Running QGIS ==
Now you can try to run QGIS:
@@ -1989,14 +2028,14 @@
- MSVC install additions Tim Sutton 2007
- PostgreSQL, Qt compile, SIP, Python, AutoExp additions Juergen Fischer 2007
- Windows MSVC Section (Simplified install)
- Tim Sutton 2007
- Juergen Fischer 2007
- OSX Section
- - Tim Sutton, 2007
+ - Tim Sutton 2007
- With special thanks to Tom Elwertowski and William Kyngesburye
- GNU/Linux Section
- Tim Sutton 2006
+ - Debian package section: Juergen Fischer 2008
