[QGIS Commit] r9616 - trunk/qgis
svn_qgis at osgeo.org
Mon Nov 10 08:21:26 EST 2008
Author: jef
Date: 2008-11-10 08:21:26 -0500 (Mon, 10 Nov 2008)
New Revision: 9616
trunk/qgis/INSTALL
update INSTALL from doc/INSTALL.t2t
Modified: trunk/qgis/INSTALL
--- trunk/qgis/INSTALL 2008-11-10 12:07:34 UTC (rev 9615)
+++ trunk/qgis/INSTALL 2008-11-10 13:21:26 UTC (rev 9616)
@@ -49,7 +49,8 @@
5.7. Prepare your development environment
5.8. Check out the QGIS Source Code
5.9. Starting the compile
- 5.10. Running QGIS
+ 5.10. Building Debian packages
+ 5.11. Running QGIS
6. Creation of MSYS environment for compilation of Quantum GIS
6.1. Initial setup
6.1.1. MSYS
@@ -150,9 +151,9 @@
At version 0.8.1 QGIS no longer uses the autotools for building. QGIS, like a
-number of major projects (eg. KDE 4.0), now uses cmake for building from
-source. The configure script in this directory simply checks for the existence
-of cmake and provides some clues to build QGIS.
+number of major projects (eg. KDE 4.0), now uses cmake (http://www.cmake.org)
+for building from source. The configure script in this directory simply checks
+for the existence of cmake and provides some clues to build QGIS.
For complete information, see the wiki at:
http://wiki.qgis.org/qgiswiki/Building_with_CMake
@@ -170,16 +171,15 @@
* Proj >= ? (known to work with 4.4.x)
* GEOS >= 2.2 (3.0 is supported, maybe 2.1.x works too)
* Sqlite3 >= ? (probably 3.0.0)
- * GDAL/OGR >= ? (1.2.x should work)
+ * GDAL/OGR >= 1.4.x (1.2.x should work)
'''Optional dependencies:'''
* for GRASS plugin - GRASS >= 6.0.0
* for georeferencer - GSL >= ? (works with 1.8)
- * for postgis support and SPIT plugin - PostgreSQL >= ?
+ * for postgis support and SPIT plugin - PostgreSQL >= 8.0.x
* for gps plugin - expat >= ? (1.95 is OK)
- * for mapserver export and PyQGIS - Python >= ? (probably 2.3)
- * for PyQGIS - SIP >= 4.5, PyQt >= 4.1
+ * for mapserver export and PyQGIS - Python >= 2.3 (2.5+ preferred)
+ * for PyQGIS - SIP >= 4.5, PyQt >= must match Qt version
'''Recommended runtime deps:'''
* for gps plugin - gpsbabel
@@ -203,7 +203,7 @@
Get this:
-http://qgis.org/uploadfiles/msys/msys.zip
+http://download.osgeo.org/qgis/win32/msys.zip
and unpack to c:\msys
@@ -854,7 +854,7 @@
5.1. Building QGIS with Qt4.x
-Requires: Ubuntu Gutsy / Debian derived distro
+Requires: Ubuntu Hardy / Debian derived distro
These notes are current for Ubuntu 7.10 - other versions and Debian derived
distros may require slight variations in package names.
@@ -953,7 +953,13 @@
distributions (e.g. Debian or SuSE) only provide SIP < 4.5 and PyQt4 < 4.1. To include support for python
language bindings you may need to build and install those packages from source.
+If you do not have cmake installed already:
+ sudo apt-get install cmake
5.5. GRASS Specific Steps
@@ -1038,6 +1044,8 @@
+/!\ *Note:* The next section describes howto build debian packages
I compile my development version of QGIS into my ~/apps directory to avoid
conflicts with Ubuntu packages that may be under /usr. This way for example
you can use the binary packages of QGIS on your system along side with your
@@ -1077,7 +1085,46 @@
It may take a little while to build depending on your platform.
+Instead of creating a personal installation as in the previous step you can
+also create debian package. This is done from the qgis root directory, where
+you'll find a debian directory.
+First you need to install the debian packaging tools once:
+ apt-get install build-essential
+The QGIS packages will be created with:
+ dpkg-buildpackage -us -us -b
+/!\ *Note:* If dpkg-buildpackage complains about unmet build dependencies
+you can install them using apt-get and re-run the command.
+/!\ *Note:* If you have libqgis1-dev installed, you need to remove it first
+using dpkg -r libqgis1-dev. Otherwise dpkg-buildpackage will complain about at
+build conflict.
+The the packages are created in the parent directory (ie. one level up).
+Install them using dpkg. E.g.:
+ sudo dpkg -i \
+ ../qgis_1.0preview16_amd64.deb \
+ ../libqgis-gui1_1.0preview16_amd64.deb \
+ ../libqgis-core1_1.0preview16_amd64.deb \
+ ../qgis-plugin-grass_1.0preview16_amd64.deb \
+ ../python-qgis_1.0preview16_amd64.deb
Now you can try to run QGIS:
@@ -2228,11 +2275,12 @@
- Juergen Fischer 2007
- OSX Section
- - Tim Sutton, 2007
+ - Tim Sutton 2007
- With special thanks to Tom Elwertowski and William Kyngesburye
- GNU/Linux Section
- Tim Sutton 2006
+ - Debian package section: Juergen Fischer 2008
