[QGIS Commit] r9617 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org
Mon Nov 10 09:37:01 EST 2008
Author: borysiasty
Date: 2008-11-10 09:37:01 -0500 (Mon, 10 Nov 2008)
New Revision: 9617
Added:
trunk/qgis/python/plugins/plugin_installer/i18n.cpp
Plugin Installer update: inclusion to i18n
Added: trunk/qgis/python/plugins/plugin_installer/i18n.cpp
--- trunk/qgis/python/plugins/plugin_installer/i18n.cpp (rev 0)
+++ trunk/qgis/python/plugins/plugin_installer/i18n.cpp 2008-11-10 14:37:01 UTC (rev 9617)
@@ -0,0 +1,212 @@
+ This is NOT a proper c++ source code. This file is only designed to be catched
+ by qmake and included to lupdate. It contains all translateable strings copied
+ from the python files:
+ installer_data.py
+ installer_plugin.py
+ installer_gui.py
+ Please keep the python files and this file synchronized. I hope we'll find
+ a more automated way to put PyQt strings to the qgis_*.ts files some day.
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+file: installer_data.py
+ // Repositories::xmlDownloaded
+ translate("QgsPluginInstaller","Couldn't parse output from the repository")
+ // Plugins::getAllInstalled
+ translate("QgsPluginInstaller","Couldn't open the system plugin directory")
+ translate("QgsPluginInstaller","Couldn't open the local plugin directory")
+file: installer_plugin.py
+// InstallerPlugin::initGui
+ translate("QgsPluginInstaller","Fetch Python Plugins...")
+ translate("QgsPluginInstaller","Install more plugins from remote repositories")
+ translate("QgsPluginInstaller","Looking for new plugins...")
+// InstallerPlugin::checkingDone
+ translate("QgsPluginInstaller","There is a new plugin available")
+ translate("QgsPluginInstaller","There is a plugin update available")
+// InstallerPlugin::run
+ translate("QgsPluginInstaller","QGIS Python Plugin Installer")
+ translate("QgsPluginInstaller","Error reading repository:")
+file: installer_gui.py
+// common functions
+ translate("QgsPluginInstaller","Plugin directory doesn't exist:")
+ translate("QgsPluginInstaller","Failed to remove the directory:")
+ translate("QgsPluginInstaller","Check permissions or remove it manually")
+QgsPluginInstallerFetchingDialog::foo()
+ // def displayState
+ tr("Success")
+ tr("Resolving host name...")
+ tr("Connecting...")
+ tr("Host connected. Sending request...")
+ tr("Downloading data...")
+ tr("Idle")
+ tr("Closing connection...")
+ tr("Error")
+QgsPluginInstallerInstallingDialog::foo()
+ // def stateChanged
+ tr("Installing...")
+ tr("Idle")
+ tr("Error")
+ // def requestFinished
+ tr("Failed to unzip file to the following directory:")
+ tr("Check permissions")
+ // def abort
+ tr("Aborted by user")
+QgsPluginInstallerPluginErrorDialog::foo()
+ // def __init__
+ tr("No error message received. Try to restart Quantum GIS and ensure the plugin isn't installed under a different name. If it is, contact the plugin author and submit this issue, please.")
+QgsPluginInstallerDialog::foo()
+ // def __init__
+ // def getAllAvailablePlugins
+ tr("QGIS Python Plugin Installer")
+ tr("Error reading repository:")
+ // def populateMostWidgets
+ tr("all repositories")
+ tr("connected")
+ tr("This repository is connected")
+ tr("unavailable")
+ tr("This repository is enabled, but unavailable")
+ tr("disabled")
+ tr("This repository is disabled")
+ tr("This repository is blocked due to incompatibility with your Quantum GIS version")
+ tr("orphans")
+ tr("any status")
+ tr("not installed", "plural")
+ tr("installed", "plural")
+ tr("upgradeable and news")
+ // def filterChanged
+ // def filterCheck
+ tr("orphans")
+ tr("orphans")
+ // def populatePluginTree
+ tr("This plugin is not installed")
+ tr("This plugin is installed")
+ tr("This plugin is installed, but there is an updated version available")
+ tr("This plugin is installed, but I can't find it in any enabled repository")
+ tr("This plugin is not installed and is seen for the first time")
+ tr("This plugin is installed and is newer than its version available in a repository")
+ tr("This plugin seems to be invalid or have unfulfilled dependencies\nIt has been installed, but can't be loaded")
+ tr("not installed", "singular")
+ tr("installed", "singular")
+ tr("upgradeable", "singular")
+ tr("new!", "singular")
+ tr("invalid", "singular")
+ tr("Note that it's an uninsatallable core plugin")
+ tr("installed version")
+ tr("available version")
+ tr("That's the newest available version")
+ tr("There is no version available for download")
+ tr("This plugin seems to be invalid or have unfulfilled dependencies")
+ tr("only locally available")
+ // def treeClicked
+ tr("Install plugin")
+ tr("Reinstall plugin")
+ tr("Upgrade plugin")
+ tr("Install/upgrade plugin")
+ tr("Downgrade plugin")
+ // def installPlugin
+ tr("Plugin installation failed")
+ tr("Plugin installed successfully")
+ tr("Python plugin installed.\nYou have to enable it in the Plugin Manager.")
+ tr("Python plugin reinstalled.\nYou have to restart Quantum GIS to reload it.")
+ tr("Plugin uninstall failed")
+ // def uninstallPlugin
+ tr("Are you sure you want to uninstall the following plugin?")
+ tr("Warning: this plugin isn't available in any accessible repository!")
+ tr("Plugin uninstalled successfully")
+ // def ChangeCheckingPolicy
+ // def addKnownRepositories
+ tr("You are going to add some plugin repositories neither authorized nor supported by the Quantum GIS team, however provided by folks associated with us. Plugin authors generally make efforts to make their works useful and safe, but we can't assume any responsibility for them. FEEL WARNED!")
+ // def addRepository
+ tr("Unable to add another repository with the same URL!")
+ // def editRepository
+ // def deleteRepository
+ tr("Are you sure you want to remove the following repository?")
+ // def reject
