[QGIS Commit] r9651 - trunk/qgis/src/python
svn_qgis at osgeo.org
Mon Nov 17 10:30:49 EST 2008
Author: wonder
Date: 2008-11-17 10:30:48 -0500 (Mon, 17 Nov 2008)
New Revision: 9651
trunk/qgis/src/python/qgspythonutilsimpl.cpp
trunk/qgis/src/python/qgspythonutilsimpl.h
disable error hooks when querying for plugin metadata
Modified: trunk/qgis/src/python/qgspythonutilsimpl.cpp
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp 2008-11-17 15:28:36 UTC (rev 9650)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp 2008-11-17 15:30:48 UTC (rev 9651)
@@ -147,6 +147,11 @@
runString( "sys.excepthook = qgis_except_hook" );
+void QgsPythonUtilsImpl::uninstallErrorHook()
+ runString( "sys.excepthook = sys.__excepthook__" );
void QgsPythonUtilsImpl::installConsoleHooks()
runString( "sys.displayhook = console_display_hook\n" );
@@ -419,12 +424,15 @@
QString command = pluginName + "." + function + "()";
QString retval = "???";
+ // temporary disable error hook - UI will handle this gracefully
+ uninstallErrorHook();
PyObject* obj = PyRun_String( command.toLocal8Bit().data(), Py_eval_input, mMainDict, mMainDict );
if ( PyErr_Occurred() )
PyErr_Print(); // just print it to console
PyErr_Clear();
- return "__error__";
+ retval = "__error__";
else if ( PyString_Check( obj ) )
@@ -436,6 +444,8 @@
Py_XDECREF( obj );
+ installErrorHook();
return retval;
Modified: trunk/qgis/src/python/qgspythonutilsimpl.h
--- trunk/qgis/src/python/qgspythonutilsimpl.h 2008-11-17 15:28:36 UTC (rev 9650)
+++ trunk/qgis/src/python/qgspythonutilsimpl.h 2008-11-17 15:30:48 UTC (rev 9651)
@@ -112,6 +112,8 @@
void installErrorHook();
+ void uninstallErrorHook();
QString getTraceback();
//! reference to module __main__
