[QGIS Commit] r9652 - trunk/qgis/src/app
svn_qgis at osgeo.org
Mon Nov 17 10:35:45 EST 2008
Author: wonder
Date: 2008-11-17 10:35:45 -0500 (Mon, 17 Nov 2008)
New Revision: 9652
trunk/qgis/src/app/qgspluginmanager.cpp
trunk/qgis/src/app/qgspluginregistry.cpp
trunk/qgis/src/app/qgspluginregistry.h
Allow loading only compatible plugins, i.e. plugins implementing qgisMinimumVersion() metadata.
Incompatible plugins are disabled and can't be selected in plugin manager.
Example of new metadata: (plugin's __init__.py)
def qgisMinimumVersion():
return "1.0"
Modified: trunk/qgis/src/app/qgspluginmanager.cpp
--- trunk/qgis/src/app/qgspluginmanager.cpp 2008-11-17 15:30:48 UTC (rev 9651)
+++ trunk/qgis/src/app/qgspluginmanager.cpp 2008-11-17 15:35:45 UTC (rev 9652)
@@ -147,6 +147,11 @@
QString version = mPythonUtils->getPluginMetadata( packageName, "version" );
if ( pluginName == "???" || description == "???" || version == "???" ) continue;
+ bool isCompatible = QgsPluginRegistry::instance()->isPythonPluginCompatible( packageName );
+ QString compatibleString; // empty by default
+ if (!isCompatible)
+ compatibleString = " " + tr("[ incompatible ]");
// filtering will be done on the display role so give it name and desription
// user wont see this text since we are using a custome delegate
@@ -156,9 +161,11 @@
mypDetailItem->setData( packageName, PLUGIN_BASE_NAME_ROLE ); //for matching in registry later
mypDetailItem->setCheckable( false );
mypDetailItem->setEditable( false );
+ mypDetailItem->setEnabled( isCompatible );
// setData in the delegate with a variantised QgsDetailedItemData
QgsDetailedItemData myData;
- myData.setTitle( pluginName + " (" + version + ")" );
+ myData.setTitle( pluginName + " (" + version + ")" + compatibleString );
+ myData.setEnabled( isCompatible );
myData.setDetail( description );
//myData.setIcon(pixmap); //todo use a python logo here
myData.setCheckable( true );
@@ -476,14 +483,10 @@
QStandardItem* mypItem = mModelPlugins->itemFromIndex( realIndex );
QgsDetailedItemData myData =
qVariantValue<QgsDetailedItemData>( mypItem->data( PLUGIN_DATA_ROLE ) );
- if ( myData.isChecked() )
+ if ( myData.isEnabled() )
- myData.setChecked( false );
+ myData.setChecked( ! myData.isChecked() );
- else
- myData.setChecked( true );
QVariant myVariant = qVariantFromValue( myData );
mypItem->setData( myVariant, PLUGIN_DATA_ROLE );
Modified: trunk/qgis/src/app/qgspluginregistry.cpp
--- trunk/qgis/src/app/qgspluginregistry.cpp 2008-11-17 15:30:48 UTC (rev 9651)
+++ trunk/qgis/src/app/qgspluginregistry.cpp 2008-11-17 15:35:45 UTC (rev 9652)
@@ -152,7 +152,49 @@
+bool QgsPluginRegistry::checkQgisVersion(QString minVersion)
+ QStringList minVersionParts = minVersion.split('.');
+ // qgis version must be in form x.y.z or just x.y
+ if (minVersionParts.count() != 2 && minVersionParts.count() != 3)
+ return false;
+ int minVerMajor, minVerMinor, minVerBugfix=0;
+ bool ok;
+ minVerMajor = minVersionParts.at(0).toInt(&ok);
+ if (!ok) return false;
+ minVerMinor = minVersionParts.at(1).toInt(&ok);
+ if (minVersionParts.count() == 3)
+ minVerBugfix = minVersionParts.at(2).toInt(&ok);
+ // our qgis version - cut release name after version number
+ QString qgisVersion = QString(QGis::QGIS_VERSION).section( '-', 0, 0 );
+ QStringList qgisVersionParts = qgisVersion.split( "." );
+ int qgisMajor = qgisVersionParts.at( 0 ).toInt();
+ int qgisMinor = qgisVersionParts.at( 1 ).toInt();
+ int qgisBugfix= qgisVersionParts.at( 2 ).toInt();
+ // first check major version
+ if (minVerMajor > qgisMajor) return false;
+ if (minVerMajor < qgisMajor) return true;
+ // if same, check minor version
+ if (minVerMinor > qgisMinor) return false;
+ if (minVerMinor < qgisMinor) return true;
+ // if still same, check bugfix version
+ if (minVerBugfix > qgisBugfix) return false;
+ // looks like min version is the same as our version - that's fine
+ return true;
void QgsPluginRegistry::loadPythonPlugin( QString packageName )
if ( !mPythonUtils || !mPythonUtils->isEnabled() )
@@ -160,22 +202,30 @@
QgsDebugMsg( "Python is not enabled in QGIS." );
return;
+ QSettings settings;
// is loaded already?
if ( ! isLoaded( packageName ) )
+ // if plugin is not compatible, disable it
+ if ( ! isPythonPluginCompatible( packageName ) )
+ settings.setValue( "/PythonPlugins/" + packageName, false );
+ return;
mPythonUtils->loadPlugin( packageName );
mPythonUtils->startPlugin( packageName );
// TODO: test success
QString pluginName = mPythonUtils->getPluginMetadata( packageName, "name" );
// add to plugin registry
addPlugin( packageName, QgsPluginMetadata( packageName, pluginName, NULL, true ) );
// add to settings
- QSettings settings;
settings.setValue( "/PythonPlugins/" + packageName, true );
std::cout << "Loaded : " << pluginName.toLocal8Bit().constData() << " (package: "
<< packageName.toLocal8Bit().constData() << ")" << std::endl; // OK
@@ -364,3 +414,17 @@
return true;
+bool QgsPluginRegistry::isPythonPluginCompatible( QString packageName )
+ QString minVersion = mPythonUtils->getPluginMetadata( packageName, "qgisMinimumVersion" );
+ if (minVersion == "__error__" || !checkQgisVersion(minVersion))
+ //QMessageBox::information(mQgisInterface->mainWindow(),
+ // QObject::tr("Incompatible plugin"),
+ // QObject::tr("Plugin \"%1\" is not compatible with this version of Quantum GIS.\nIt will be disabled.").arg(pluginName));
+ //settings.setValue( "/PythonPlugins/" + packageName, false );
+ return false;
+ return true;
Modified: trunk/qgis/src/app/qgspluginregistry.h
--- trunk/qgis/src/app/qgspluginregistry.h 2008-11-17 15:30:48 UTC (rev 9651)
+++ trunk/qgis/src/app/qgspluginregistry.h 2008-11-17 15:35:45 UTC (rev 9652)
@@ -81,6 +81,9 @@
//! Load any plugins used in the last qgis session
void restoreSessionPlugins( QString thePluginDirString );
+ //! Check whether plugin is compatible with current version of QGIS
+ bool isPythonPluginCompatible( QString packageName );
protected:
//! protected constructor
QgsPluginRegistry();
@@ -90,6 +93,9 @@
//! Try to load and get metadata from Python plugin, return true on success
bool checkPythonPlugin( QString packageName );
+ //! Check current QGIS version against plugin's minimal requested QGIS version
+ bool checkQgisVersion(QString minVersion);
private:
static QgsPluginRegistry* _instance;
QMap<QString, QgsPluginMetadata> mPlugins;
