[QGIS Commit] r9653 - trunk/qgis/python/core
svn_qgis at osgeo.org
Mon Nov 17 11:04:30 EST 2008
Author: wonder
Date: 2008-11-17 11:04:30 -0500 (Mon, 17 Nov 2008)
New Revision: 9653
trunk/qgis/python/core/qgslabel.sip
trunk/qgis/python/core/qgslabelattributes.sip
trunk/qgis/python/core/qgsrendercontext.sip
Added python bindings for changes in r9649.
Modified: trunk/qgis/python/core/qgslabel.sip
--- trunk/qgis/python/core/qgslabel.sip 2008-11-17 15:35:45 UTC (rev 9652)
+++ trunk/qgis/python/core/qgslabel.sip 2008-11-17 16:04:30 UTC (rev 9653)
@@ -41,6 +41,11 @@
LabelFieldCount
+ struct labelpoint {
+ QgsPoint p;
+ double angle;
/** \brief render label
* \param sizeScale global scale factor for size in pixels, labels in map units are not scaled
@@ -55,7 +60,7 @@
void readXML(const QDomNode& node);
/** Writes the contents of the renderer to a configuration file */
- // TODO: wrap void writeXML(std::ostream& xml);
+ void writeXML( QDomNode & label_node, QDomDocument & document );
//! add vector of required fields to existing list of fields
void addRequiredFields ( QList<int> & fields );
@@ -82,5 +87,18 @@
QString fieldValue ( int attr, QgsFeature& feature );
+ /** Accessor and mutator for the minimum scale member */
+ void setMinScale( float theMinScale );
+ float minScale();
+ /** Accessor and mutator for the maximum scale member */
+ void setMaxScale( float theMaxScale );
+ float maxScale();
+ /** Accessor and mutator for the scale based visilibility flag */
+ void setScaleBasedVisibility( bool theVisibilityFlag );
+ bool scaleBasedVisibility();
Modified: trunk/qgis/python/core/qgslabelattributes.sip
--- trunk/qgis/python/core/qgslabelattributes.sip 2008-11-17 15:35:45 UTC (rev 9652)
+++ trunk/qgis/python/core/qgslabelattributes.sip 2008-11-17 16:04:30 UTC (rev 9653)
@@ -68,6 +68,9 @@
bool angleIsSet ( ) const;
double angle ( ) const;
+ bool angleIsAuto( ) const;
+ void setAutoAngle(bool state);
/* Alignment */
void setAlignment ( int alignment );
bool alignmentIsSet ( ) const;
Modified: trunk/qgis/python/core/qgsrendercontext.sip
--- trunk/qgis/python/core/qgsrendercontext.sip 2008-11-17 15:35:45 UTC (rev 9652)
+++ trunk/qgis/python/core/qgsrendercontext.sip 2008-11-17 16:04:30 UTC (rev 9653)
@@ -30,6 +30,8 @@
bool drawEditingInformation() const;
+ double rendererScale() const;
//setters
/**Sets coordinate transformation. QgsRenderContext takes ownership and deletes if necessary*/
@@ -40,5 +42,6 @@
void setRenderingStopped(bool stopped);
void setScaleFactor(double factor);
void setRasterScaleFactor(double factor);
+ void setRendererScale( double scale );
void setPainter(QPainter* p);
