[QGIS Commit] r9655 - trunk/qgis/src/providers/grass
svn_qgis at osgeo.org
Mon Nov 17 11:29:34 EST 2008
Author: jef
Date: 2008-11-17 11:29:34 -0500 (Mon, 17 Nov 2008)
New Revision: 9655
trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
apply patch #364 from GRASS TRAC by Markus Neteler
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp 2008-11-17 16:11:11 UTC (rev 9654)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp 2008-11-17 16:29:34 UTC (rev 9655)
@@ -1040,7 +1040,11 @@
if ( level == 1 )
QgsGrass::resetError();
- Vect_build( map.map, stderr );
+#if GRASS_VERSION_MAJOR >= 6 && GRASS_VERSION_MINOR >= 4
+ Vect_build( map.map );
+#else
+ Vect_build( map.map, stderr );
+#endif
if ( QgsGrass::getError() == QgsGrass::FATAL )
@@ -1520,7 +1524,11 @@
G__setenv(( char * ) "MAPSET", map->mapset.toAscii().data() );
Vect_build_partial( map->map, GV_BUILD_NONE, NULL );
+#else
Vect_build( map->map, stderr );
+#endif
// If a new map was created close the map and return
if ( newMap )
